  What Did You Do To Your Fiero...TODAY ? (Page 11)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223244 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
avengador1
Total ratings: 571
Report this Post03-03-2008 06:30 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I walked past mine and thought to myself "maybe I should start it, it's been a while", but I decided to wait for the weekend and hope for better weather, so maybe I can take it out for a drive.
Blacktree
Total ratings: 350
Report this Post03-03-2008 06:47 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed the headliner, so I could get at the roof and rear clip mounting bolts. In a couple days, I'll be installing a custom rear clip and decklid.
fierohobby
Report this Post03-03-2008 07:36 PM Click Here to See the Profile for fierohobbySend a Private Message to fierohobbyEdit/Delete MessageReply w/QuoteDirect Link to This Post
(Saturday) New rotors and pads on the rear.
-fh
Spoilt_87fiero
Report this Post03-03-2008 09:23 PM Click Here to See the Profile for Spoilt_87fieroSend a Private Message to Spoilt_87fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
worked on my 3800SC wiring and wax one door panel
ltlfrari
Total ratings: 127
Report this Post03-03-2008 09:33 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed the battery box on the 88
Before...
After....
Dave
www.ltlfrari.com
fiero_silva
Total ratings: 51
Report this Post03-03-2008 11:25 PM Click Here to See the Profile for fiero_silvaSend a Private Message to fiero_silvaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I moved a spare set of wheels/tires around the shop and stacked them on the decklid... That was it for today... Tommorow I'm ordering about $1500 in parts
FieroBobo
Report this Post03-03-2008 11:31 PM Click Here to See the Profile for FieroBoboSend a Private Message to FieroBoboEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took my '88 GT with 33,000 miles into the shop to have the clutch bleed. (Again)
And just like last time they found a little air in the master cylinder, and a lot of air in the slave cylinder, but there seems to be NO fluid leaking. They can't explain whats going on here, and neither can I.
$Rich$
Total ratings: 398
Report this Post03-03-2008 11:42 PM Click Here to See the Profile for $Rich$Send a Private Message to $Rich$Edit/Delete MessageReply w/QuoteDirect Link to This Post
crawl under the dash and look up, maybe take a paper towel and rub it on the carpet in the clutch pedal area, i'd bet thats where its leaking
Saxman
Total ratings: 114
Report this Post03-04-2008 12:34 AM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped off the rear control arms to have the old rubber pressed out and the new poly pressed in.
Moved the flexplate and torque converter from the blown 88 engine over to the 87 block adn trans.
Moved cradle parts over to the new cradle and noticed they need some Por-15 pretty bad.
Drained the old oil out of the 87 block.
Stripped the old blown engine down of all useable parts.
Rerouted SP wires so they don't touch any more.
Looked at her longingly - waiting to get her on the road!
steve308
Total ratings: 58
Report this Post03-04-2008 08:28 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Up in the air via jack stands -- oil change - under car inspection - need to change all hoses soon. cleaned and inspected all grounds. some rust on starter cleaned with wire brush treated with terminal sealer. wash wax vaccum etc.., back in garage.
Philero
Report this Post03-04-2008 08:40 PM Click Here to See the Profile for PhileroSend a Private Message to PhileroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my TURBO for my LPG (Propane) setup for the 2.8L!!! w000000t!
https://www.fiero.nl/forum/Forum1/HTML/069714.html
Sooo excited!
Phil
Always trying to create something new!
Philero ~ Phil and his Fiero, melding into one (soon to be my license plate too!)
ss85fiero
Report this Post03-04-2008 09:58 PM Click Here to See the Profile for ss85fieroSend a Private Message to ss85fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
installed battery relocation box in my 87
87 fiero gt 4.9
99 trans am ls1
86 fiero se 2.8 (eventually to be a 3.8sc)
Saxman
Total ratings: 114
Report this Post03-04-2008 11:14 PM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the newly Por-15'd cradle on a dolly, then cussed and yelled about getting those damn retainer springs on to get the ehxaust to hang on the cradle.
I stripped some parts of the trunk with a wire wheel and Por-15'd the rough spots to get ready to be filled back in.
I stripped the blown engine down a bit more, but could not find a balancer puller, so the timing cover will have to stay in place for now.
Finally, I went to the auto parts store and returned some LED tail lights I can't use because the damn things glow red - and used the refund $ to buy fa iberglass kit for the trunk repair, header wrap for the exhaust and silicone sealer for the wrap. I also got the new trans mounts and water pump while I was there - and ordered the gasket for the cam end-cover. Jeez - it was $20! Wow!
Madscanner
Report this Post03-10-2008 08:27 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Modded some wiring to fit new 4x10 speakers to the original connectors, removed the "screens" from the old speakers and glued them onto the new speakers, and had a trial fit. Just need to bolt them down now, and find some read acoustic cloth to re-cover the grills...
The Madscanner
'85 SE 2M6 Auto
whodeanie
Total ratings: 120
Report this Post03-10-2008 08:33 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I started on my new frontend.
waiting for fiberglass to dry Blows!
jstricker
Total ratings: 370
Report this Post03-10-2008 08:56 AM Click Here to See the Profile for jstrickerSend a Private Message to jstrickerEdit/Delete MessageReply w/QuoteDirect Link to This Post
This weekend...........
Got the dash built and instruments installed, switch panel built and installed, and everything wired up and tested in the race car.
John Stricker
Blacktree
Total ratings: 350
Report this Post03-10-2008 10:01 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still gloating over my custom decklid/spoiler/tail lamp mod.
Oh, and I also ordered a rebuilt FWD Getrag transmission from Man-Trans, to replace my messed-up one.
whodeanie
Total ratings: 120
Report this Post03-10-2008 10:12 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
looking great
leppy_89
Report this Post03-12-2008 12:50 PM Click Here to See the Profile for leppy_89Send a Private Message to leppy_89Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put in a new fuel pressure regulator in hopes
of solving my MPG woes.
85SEnochie
Total ratings: 58
Report this Post03-12-2008 01:14 PM Click Here to See the Profile for 85SEnochieSend a Private Message to 85SEnochieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm working on my intake manifold head gasket replacement. My first real job by myself. I'm thinking about moving the computer out to the garage so my dad can hold my hand with video chat hehe...talk about pain staking tedious work. I finally got the intake manifold off it was as good as sex not better than and had to have a smoke after wards. :-( scraping gaskets sucks.
chaosfinity
Report this Post03-12-2008 01:46 PM Click Here to See the Profile for chaosfinitySend a Private Message to chaosfinityEdit/Delete MessageReply w/QuoteDirect Link to This Post
Prayed that the interior would not catch fire while i was using an angle grinder with cutoff wheel to remove the computer mounting bracket for my new 3800 PCM
leppy_89
Report this Post03-12-2008 07:05 PM Click Here to See the Profile for leppy_89Send a Private Message to leppy_89Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took my intake manifold off for the first time myself, by myself its awesome taking **** apart.
85SEnochie
Total ratings: 58
Report this Post03-13-2008 10:29 AM Click Here to See the Profile for 85SEnochieSend a Private Message to 85SEnochieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took my intake manifold off for the first time myself, by myself its awesome taking **** apart.[/QUOTE]
Yah putting back together will be the not so fun part.
Today the heads are clean and now working on the intake ....gently!
whodeanie
Total ratings: 120
Report this Post03-13-2008 11:06 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
still working on the nose wating for fiberglass to dry s**ks
Old Lar
Total ratings: 214
Report this Post03-13-2008 11:37 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went out to my 87 to clean it up for Daytona and the battery was too weak to turn the engine over, so put it on the charger and start over tomorrow.
litespd
Total ratings: 175
Report this Post03-13-2008 08:27 PM Click Here to See the Profile for litespdSend a Private Message to litespdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took my charged battery back over to the storage unit and put it in the GT, put the new license tags on it, pulled the coil wire and cranked it a few times until the oil pressure came up, then put the coil wire back on and she started right up. Took it for a short drive, then brought it home so that I could get started cleaning it up for the WOW show in Omaha.
CenTexIndy
Total ratings: 59
Report this Post03-14-2008 01:38 PM Click Here to See the Profile for CenTexIndySend a Private Message to CenTexIndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
ahhhh......
88 degrees here.
Drove mine to work today and will drive it to Baylor Baseball tonight.
Spoon
Total ratings: 61
Report this Post03-15-2008 09:41 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed some parts I bought 4 months ago. Red distributer cap and rotor and I replaced the amber parking light lens with the clear ones.
I then took advantage of "Al's global warming" 60F, and washed it then went to dinner and found a safe spot to park. I'll also take it bowling tomorrow. This will be the 3rd time I drove it this year.
kawana
Report this Post03-16-2008 12:50 AM Click Here to See the Profile for kawanaClick Here to visit kawana's HomePageSend a Private Message to kawanaEdit/Delete MessageReply w/QuoteDirect Link to This Post
well.. i made my fiero go round and round in circles really fast Did some donuts for the first time tonight, pavement was just slighly moist so she slid very nicely Boy was it fun lol, my friend just about pee'd himself cuz i didn't give him any warning lol. That ol' 2.8 sure does sound nice when she's screamin
hurricanefloyd41
Report this Post03-16-2008 01:14 AM Click Here to See the Profile for hurricanefloyd41Send a Private Message to hurricanefloyd41Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just finished and installed my version of the JimmyS GT windows and boy are they awesome...great idea...I would post pics but Im too much of a noob to know how..sorry..
fiero_silva
Total ratings: 51
Report this Post03-16-2008 03:51 PM Click Here to See the Profile for fiero_silvaSend a Private Message to fiero_silvaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Filled up a low tire with air.
Ordered side scoop 1/4 panels and Aero chin spoiler from Doug @ Fiero Warehouse.
slinger
Report this Post03-16-2008 04:07 PM Click Here to See the Profile for slingerSend a Private Message to slingerEdit/Delete MessageReply w/QuoteDirect Link to This Post
pulled notchie clip to make way for the fastback, and pulled the cradle
LT188GT
Total ratings: 99
Report this Post03-16-2008 04:23 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took it to another car show just like I did last night with Alex4mula.
[This message has been edited by LT188GT (edited 03-16-2008).]
86soon3.4
Report this Post03-16-2008 07:17 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the rear struts and spring cushions. Then I did the at home alignment. Drives much better now!
Replaced the front liscense plate bracket.
Took it for a ride.
Steve
lurker
Total ratings: 236
Report this Post03-16-2008 08:55 PM Click Here to See the Profile for lurkerSend a Private Message to lurkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
drove it about a mile to check out yesterday's clutch slave rebuild. so far, so good!
never2old
Total ratings: 68
Report this Post03-16-2008 10:39 PM Click Here to See the Profile for never2oldSend a Private Message to never2oldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Washed it , waxed it , armour-alled the inside dash and painted the engine cover thingys {silver}
Snow tires will remain on for another month yet.
whodeanie
Total ratings: 120
Report this Post03-17-2008 07:31 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I avoided the tornado and worked in the garadge on my custom frontend.
this is just a teaser I will have better pics soon.
looks a little wide ?
not for long !!!
Snapperhead
Report this Post03-17-2008 07:44 AM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled it out from winter storage and the wife and I went for a cruise.
Vince
Back On Holiday
Report this Post03-17-2008 09:14 AM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by possumlips:
degreased and painted the motor and engine bay of my lil red '88 dailey driver after MstangsBware replaced its 157K 2.5 engine for a 16K one.would of been easier with the motor out but it turned out okay.also put in a new heater core which was easier than i thought it would be.
jesse
That looks nice! good Job!
Back On Holiday
Report this Post03-17-2008 09:18 AM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Back On Holiday
Member since Jul 2001
Originally posted by Fieromaniac:
painted the engine-vents / decklid-grills
Wow, that really looks good + from me!
