  What Did You Do To Your Fiero...TODAY ? (Page 123)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223275 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
Total ratings: 463
Report this Post08-13-2012 06:13 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found and fixed a nasty oil leak.
It was the oil filter of all things.
I tightened it a couple of days ago with no change. When I removed it, the seal looked fine. A new filter doesn't leak, however.
The leaking filter was a Mobil1 filter. The replacement was my preferred Pure One brand.
Praise the Lowered!
sabooo
Report this Post08-13-2012 07:24 PM Click Here to See the Profile for saboooSend a Private Message to saboooEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chased down a leaking o-ring in the AC. Hooray for cold air!
Mugwort
Report this Post08-13-2012 08:43 PM Click Here to See the Profile for MugwortSend a Private Message to MugwortEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ripped out the non-working stock stereo, re-did all the in-dash stereo wiring (someone had butchered it pretty good) installed the single DIN adapter so when the wiring harness for my stereo gets here i can just pop it right in.
Marine1981
Report this Post08-14-2012 10:34 AM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 1MohrFiero:
Where did you get that face plate for the radio?? I need to get me one of those.
FieroJam
Report this Post08-14-2012 02:06 PM Click Here to See the Profile for FieroJamSend a Private Message to FieroJamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed the EGR solenoid valve with a rebuilt one yesterday and so far the SES light has stayed off. Knocks on wood!
GBglide
Report this Post08-15-2012 04:22 AM Click Here to See the Profile for GBglideClick Here to visit GBglide's HomePageSend a Private Message to GBglideEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are custom made by Humount. I highly recommend them. You will have to take apart the console and make changes to the skeleton, though.
http://www.humount.com/
docholliday
Report this Post08-15-2012 04:26 AM Click Here to See the Profile for dochollidaySend a Private Message to dochollidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Humount faceplate in my 88 GT and I never took apart the skeleton. There is a rear radio mount for the original radio that has to be removed, but that was done fairly easy.
GBglide
Report this Post08-15-2012 04:49 AM Click Here to See the Profile for GBglideClick Here to visit GBglide's HomePageSend a Private Message to GBglideEdit/Delete MessageReply w/QuoteDirect Link to This Post
You must like working in tight spaces. My console skeleton needed work anyway.
Blacktop
Report this Post08-15-2012 02:36 PM Click Here to See the Profile for BlacktopSend a Private Message to BlacktopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got firmly fed up with my driver side exterior door handle tried several times to put the self-cutting nuts back on the studs only to have them pop right back off when the door handle was operated. Stuck some trim mounting tape on there and just have to remember to pull the door with my free hand and not by the handle.
Formula
Total ratings: 96
Report this Post08-15-2012 04:18 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a new fiero today! It's an 87gt with a 3800sc, needs a lot of little things, but overall I think its going to be a blast.
My wife said she wants the engine to sound lumpy
FieroTony
Report this Post08-15-2012 04:39 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
My wife wishes that I'd get rid of mine. She thinks it's the other woman.
mferrell
Report this Post08-15-2012 09:54 PM Click Here to See the Profile for mferrellSend a Private Message to mferrellEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah my wife calls mine the redheaded bi@#$. installed a new slave cylinder on the clutch. now I dont have to shut it off to get it into gear... wooooohoooooo..
pontiackid86
Total ratings: 344
Report this Post08-15-2012 10:00 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to Wawa... need to get it inspected though.
jim94
Report this Post08-15-2012 10:45 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
oil & filter change, trans fluid change and fuel filter. 45,644 miles.
exoticse
Total ratings: 106
Report this Post08-16-2012 12:26 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ordered a few small parts and just stared at it longingly as i babysat my daughter.
no2pencil
Report this Post08-16-2012 02:05 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled it back into the garage, drove about 10mph down the road. Still having major issues...
Mugwort
Report this Post08-16-2012 06:29 PM Click Here to See the Profile for MugwortSend a Private Message to MugwortEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got my stereo install after no tunes for the whole week. Burned of disc full of the music i listened to back in 86 to listen to music from the cars era
Mugwort
Report this Post08-19-2012 09:46 AM Click Here to See the Profile for MugwortSend a Private Message to MugwortEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced part of my dash from where the PO had glued something and tore up the dash when he ripped out whatever it was
Before:
After:
Still need to replace top of dash and the dash speakers as well as deal with the vinyl warping on console
[This message has been edited by Mugwort (edited 08-19-2012).]
JimmyS
Total ratings: 124
Report this Post08-19-2012 09:55 PM Click Here to See the Profile for JimmySClick Here to visit JimmyS's HomePageSend a Private Message to JimmySEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not today but yesterday...
I chopped the roof!
sco77
Report this Post08-19-2012 09:57 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed new oil pressure gauge from 88, upgraded to 88 sender, installed a keyless entry from a 95 Firebird, installed some interior LEDs.
today:
86 Fiero GT 4spd - Stock (new to me)
98 GTP - CAI, ZZP 304 3" DP, 304 PLOG, 3.5", Overkill PCM, PRJ wires, Autolite 605s, 180*, STB, Alt rewire, Projectors, 6000k HID, 12" Brakes, GMPP
JCircs
Report this Post08-22-2012 06:59 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut down my auto shift stick and installed a Corvette shift knob.
https://www.fiero.nl/forum/Forum1/HTML/087461.html
docholliday
Report this Post08-25-2012 12:54 PM Click Here to See the Profile for dochollidaySend a Private Message to dochollidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sold my '88 GT, got the asking price, so I guess I'm happy with that. I already miss it, I was going to a car show tonight.
88FieroGT TTops
Report this Post08-26-2012 12:55 AM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
fixed my L/H turn signal----loose bulb
Pat Jones
johnyrottin
Total ratings: 85
Report this Post08-27-2012 11:13 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil pan gasket replacment in a 2.5 Indy....man was it a PITA! Chasing down a problem with it stuttering under load but needed to start with the oil leak problem. We did the TBI gasket as well as a starting point for the chase. The EGR ports under the TBI unit had very little carbon buildup so that rules that one out. Gasket looked great but we replaced it anyway since we had a new one.
[This message has been edited by johnyrottin (edited 08-27-2012).]
Quad Raider
Report this Post08-27-2012 12:55 PM Click Here to See the Profile for Quad RaiderSend a Private Message to Quad RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started sanding the front fascia of my '87 Coupe. I bought the car on January 1, 2011 and thought my Quad 4 swap would be done by now. Instead, I'm just getting ready to start, and am taking care of miscellaneous other tasks while gathering parts.
engine man
Report this Post08-27-2012 04:14 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worked on V8 Audi swap
Curtis_Edgar
Report this Post08-30-2012 03:42 PM Click Here to See the Profile for Curtis_EdgarClick Here to visit Curtis_Edgar's HomePageSend a Private Message to Curtis_EdgarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut 1.5 coils out of the front today and loving it......
and a couple days ago put in some 95 Camaro Seats
1985 Pontiac Fiero GT
FieroMaster88
Total ratings: 168
Report this Post08-30-2012 08:41 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced the wiper motor and fixed the passenger xenon headlight that wasn't working on the 88. I can drive in the rain again!
Taijiguy
Total ratings: 244
Report this Post08-31-2012 09:18 AM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
*sigh* I walked past it and moved the motor on the engine stand so I could get to the lawn mower.
I *really* gotta get some time to get it back together...after 7 years.
falcon_ca
Report this Post08-31-2012 09:50 AM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drove her to work with the V6 reinstalled.
The V8 is in convalescence due to a blown head gasket
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 |Work done 11-12 |Work done 12-13 |4.9 Swap |Parts for sale
madcurl
Total ratings: 314
Report this Post08-31-2012 11:39 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looked at the car on a street corner.
engine man
Report this Post08-31-2012 11:55 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
i got the engine all bolted in
OneSlowFiero
Report this Post09-01-2012 03:49 AM Click Here to See the Profile for OneSlowFieroSend a Private Message to OneSlowFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I had my Fiero towed -__-
Curtis_Edgar
Report this Post09-01-2012 05:05 PM Click Here to See the Profile for Curtis_EdgarClick Here to visit Curtis_Edgar's HomePageSend a Private Message to Curtis_EdgarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went through and replaced most of the bulbs i could find that were out
1985 Pontiac Fiero GT | 1994 Acura Integra LS/Vtec
Report this Post09-01-2012 05:26 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced this connector (88 2.5):
88FieroGT TTops
Report this Post09-01-2012 11:30 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
replace messed up turn signal light--had difficulty with the socket but eventually got it in (didnt want to go in) tighten IAC but still getting 35 error code--ordered new one from Rock Auto
Pat Jones
XgovernmentAgent
Report this Post09-02-2012 05:17 PM Click Here to See the Profile for XgovernmentAgentSend a Private Message to XgovernmentAgentEdit/Delete MessageReply w/QuoteDirect Link to This Post
BledBleeding the clutch...
This Is taking forever.
[This message has been edited by XgovernmentAgent (edited 09-02-2012).]
johnyrottin
Total ratings: 85
Report this Post09-02-2012 09:00 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally found what the freaking problem was with my indy...bad wire and or plug arcing across the heatshield on #2 cyl. New Delco plugs and wires. Of course, this is after 5 days of swapping all sorts of parts like distributors and throtttle bodies trying to track down the power loss problem. Sheesh. We also did an oil pan gasket change out as I had some oil leaking from the passenger side of the pan.
XgovernmentAgent
Report this Post09-02-2012 10:30 PM Click Here to See the Profile for XgovernmentAgentSend a Private Message to XgovernmentAgentEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also test drove an auto 88 formula CJB w/ 60k miles. Defiantly not used to a bone stock Fiero...
Does that count?
johnyrottin
Total ratings: 85
Report this Post09-03-2012 09:53 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does that count?
Only if you enjoyed it!!!!!!!
