  What Did You Do To Your Fiero...TODAY ? (Page 125)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223289 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
Curtis_Edgar
Report this Post10-17-2012 07:23 PM Click Here to See the Profile for Curtis_EdgarClick Here to visit Curtis_Edgar's HomePageSend a Private Message to Curtis_EdgarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car Wash for Both Cars Today
1985 Pontiac Fiero GT | 1994 Acura Integra LS/Vtec
johnyrottin
Total ratings: 85
Report this Post10-18-2012 12:30 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Indy just clicked over 50,000 miles!!!
bry2an
Report this Post10-18-2012 01:07 PM Click Here to See the Profile for bry2anSend a Private Message to bry2anEdit/Delete MessageReply w/QuoteDirect Link to This Post
Outside still ripping apart the gt for paint
jim94
Report this Post10-18-2012 04:11 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the o2 censor. It fell out, I guess it was bad.
Old Lar
Total ratings: 214
Report this Post10-18-2012 09:35 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 88GT got an oil change, cruise control servo motor, transmission output seal (old one was leaking), transmission service filter, AC recharged. $$$
Everytime I take off on trips and return, it seems the Fieros always need some repairs. I guess it is to be expected on 24 and 25 year old cars.
BlownFiero86
Report this Post10-19-2012 05:09 AM Click Here to See the Profile for BlownFiero86Send a Private Message to BlownFiero86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sand blasted my 88 cradle and applied first coat of paint. Getting it read to put into my 3800s/c f23 86 gt.
86GT, 3800SC, GETRAG, true duals, 3.4 pulley, comp VS cam, zzp match flow injectors, zzp power log, WCF air intake, ARP bolts, comp lifters and push rods, 90# springs, SI stainless valves, aero-force scantech meter.
Here is my build thread https://www.fiero.nl/forum/Forum2/HTML/122548.html
Charlie64
Report this Post10-21-2012 12:40 AM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's how today went. Got up early this morning...decided to wipe the car down and saw how much the suspension resettled with the new wheels and tires. The rear tires were both at about 1.5" of clearance from the fender. The front right was at about .75" while the left front was a bit lower...between .25 and .5 of clearance from the fender. I learned while driving the car today this was causing the tire to rub on the fender anytime I hit a bump, made a turn, or came to a sudden halt.
Fortunately there was no damage to the fender or tire. I spoke to Dave from Haus of Guru earlier this morning after seeing the car in daylight and he explained how to make the adjustment. I thought I would have the shop do it since I didn't really want to roll the vehicle onto lawn concrete squares to get my floor jack under the car, but that didn't work out. Too many errands and besides I was enjoying driving the car on this beautiful day here...just doing it with extra caution. First I didn't have the spanner wrench for my HAL QA1 coilover shocks
so with Dave's guidance I was able to come up with an effective alternate tool from Sears
After bringing my youngest daughter (who was more excited about the car being home again than I was) to all of her Saturday activities we were finally home so I decided to get the jack, jack stands, and concrete square out. Dave told me how easy the task was and he was right. Glad he doesn't charge for phone support I was able to adjust both sides to about 1.4" of fender clearance.
Once I figured out how to do it the adjustments were pretty easy and quick. After driving the car this evening the right side is holding steady at about 1.4" of clearance. The left side has come down slightly, but the tire is no longer rubbing the fender on bumps, turns, or sudden stops. I'll adjust it again tomorrow and monitor it. I was also able to find the issue with my bright lights with Dave's suggestion. I unplugged the adapter harness for my projector headlights from the factory plug...used one of my old hi/low bulbs and found the circuits were functioning normally. In the end one of the prongs from the aftermarket harness plug in had become indented into the plug and wasn't making contact on the associated hi-beam lead. Problem fixed. I'm all set with the paint shop for touch-up and chip removal this coming week. Once completed I'll be posting new photos from an actual photo shoot with a scenic background other than my driveway.
One of the most gratifying moments today was when two guys pulled up next to me at a traffic light after being behind me honking their horn to tell me how totally BAD ASS my car is I'm certainly enjoying all this attention.
RCR
Total ratings: 102
Report this Post10-21-2012 11:14 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought some brake calipers...Trying something a little different.
Bob
GBglide
Report this Post10-21-2012 08:39 PM Click Here to See the Profile for GBglideClick Here to visit GBglide's HomePageSend a Private Message to GBglideEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tested out my new stereo, It works! Now I have to tuck all those wires out of the way.
Charlie64
Report this Post10-21-2012 11:07 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Today when I was finally able to give my car some attention...I checked to see if I needed to make further adjustment to the front coilovers. Fortunately everything remained unchanged. Next I changed the Sears Platinum battery which Dave had to replace a few months ago with an Optima Yellow Top. The Sears battery wasn't even a year old and was a replacement for one I put in the car last August. That's three batteries in a little over a year. Anyway, I also installed new leather e-brake and shifter boot with yellow quad stitching. I am very pleased with how they came out.
Then it was time for a drive. Too bad there was so much traffic coming back home.
Eclipse
Report this Post10-25-2012 10:39 PM Click Here to See the Profile for EclipseSend a Private Message to EclipseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I missed it. I sold it a few weeks ago
Learning is not compulsory. Neither is survival. - W. Edwards Deming
Jay Brintnell
Eau_Rouge
Report this Post11-04-2012 04:58 PM Click Here to See the Profile for Eau_RougeSend a Private Message to Eau_RougeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pushed it into a gas station. If you're going to run out of gas, you can't get much luckier than running out of gas 20 metres from a gas station!
Charlie64
Report this Post11-04-2012 10:12 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it Enjoyed it and admired it
mattwa
Total ratings: 88
Report this Post11-04-2012 10:17 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lately I have been working on my dad's project, rebuilt 2.8 and 5-speed Isuzu for his 86 GT in my spare time.
hercimer01
Report this Post11-05-2012 12:47 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cussed at it alot while I was working on it!
IFLYR22
Report this Post11-05-2012 10:23 AM Click Here to See the Profile for IFLYR22Send a Private Message to IFLYR22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it for the past two weeks...
-Dave
ShockWave
Report this Post11-05-2012 06:59 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it around and gave it a full tank of gas for winter. Ordered a bunch of parts to try and get it road trip worthy if I decide to go see Plant 17 before the snow (and the factory itself) falls.
IanT720
Report this Post11-05-2012 11:24 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished my 3800sc swap, drove it for the first time... Wow!!! Blew a Trans line... Fixed... And got an alignment
86 Fiero GTX project now tearing up the street, My build thread! 3800sc, interior, wheels, suspension and more! https://www.fiero.nl/forum/Forum1/HTML/089483.html
DaveC
Report this Post11-06-2012 12:32 AM Click Here to See the Profile for DaveCSend a Private Message to DaveCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just ordered the rest of the J-bends to finish the 180 degree headers on my 331 powered '86 SE.
[This message has been edited by DaveC (edited 11-15-2012).]
Jonesy
Total ratings: 104
Report this Post11-06-2012 05:57 PM Click Here to See the Profile for JonesySend a Private Message to JonesyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I broke the inside driver side door handle off!
wolf63
Report this Post11-06-2012 10:52 PM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
used a fair amount of unflattering language on it. got a block away from home on my way to work when the clutch stopped engaging. nursed it home and will dig into it this weekend.
jim94
Report this Post11-07-2012 08:40 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I installed new distributor seal, oil cap repair seal and new exhaust hangers. Thanks Rodney dickman.
Marine1981
Report this Post11-08-2012 12:21 AM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to work with the clutch not engaging in rush hour traffic. Tried to fix it at work but the slave is gone so I drove it home in rush hour with no clutch. New slave will arrive tomorrow.
ShockWave
Report this Post11-08-2012 03:54 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to Advance to pick up the rear struts I ordered.
Puffpufpass
Report this Post11-09-2012 11:26 AM Click Here to See the Profile for PuffpufpassSend a Private Message to PuffpufpassEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by engine man:
i got the engine all bolted in
drooooll.....
87 SE. Cat delete, eibachs, aftermarket front swaybar, cone filter. short throw. 3.4 inc
sirtimeless
Report this Post11-12-2012 09:20 AM Click Here to See the Profile for sirtimelessClick Here to visit sirtimeless's HomePageSend a Private Message to sirtimelessEdit/Delete MessageReply w/QuoteDirect Link to This Post
More of the past few days.
Replaced: 02 sensor, Air temp sensor, steering stabilizer, wheel bearing, some under coating and a tune up. Think it's finally ready for winter
[This message has been edited by sirtimeless (edited 11-12-2012).]
FieroTony
Report this Post11-12-2012 03:02 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced clutch assembly. T/O bearing spring clip popped off of fork. What a fun weekend.
RACE
Total ratings: 157
Report this Post11-14-2012 06:53 AM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
This actually happened yesterday but it's close enough. I took my car, with new ASA wheels and Potenza S-04 Pole position summer only tires to Karl Chevrolet for a 4 wheel alignment. My car received a clean bill of health and I feel comfortable that it will not unnecessarily eat my new tires due to poor alignment.
DaveC
Report this Post11-15-2012 04:40 PM Click Here to See the Profile for DaveCSend a Private Message to DaveCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys,
It's been a long road, but it's coming together nicely. The car is an '86 SE with an Archie kit (thanks Archie!) and 331 small block. I purchased the Archie kit about 8 years ago, and ran tight tuck headers up until now. I always thought that the v8 sound was a little "heavy", and have always liked the smooth sound of the GT40, due to the use of 180 degree headers. They sound more "exotic", if you will, and add a bit of lightness to the aura.
It's a work in progress (what V8 Fiero isn't?), but I like the way she sounds now. In the video below, the stumble early on was me forgetting to turn the fuel pump on. After that, she runs smooth.
Gentlemen, meet Medusa : [/url]]http://www.youtube.c...atc...&feature=plcp][/URL]
Cheers,
Dave
DaveC
Report this Post11-15-2012 05:28 PM Click Here to See the Profile for DaveCSend a Private Message to DaveCEdit/Delete MessageReply w/QuoteDirect Link to This Post
DaveC
Member since Nov 2011
That's a sharp notchie! Like those wheels.
bomluuk
Report this Post11-15-2012 06:00 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
Walked by it in my garage, longingly whishing the 3800 was in it already...
Jarhead 2m4
Report this Post11-16-2012 01:06 AM Click Here to See the Profile for Jarhead 2m4Click Here to visit Jarhead 2m4's HomePageSend a Private Message to Jarhead 2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Day-dreamed about the return of my GT...
Old Lar
Total ratings: 214
Report this Post11-16-2012 04:09 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I stopped over to see Mr. Mike and he installed my new cloth seat covers for my 87 GT.
Same cloth pattern as the originals albeit a bit darker. I just have to re assemble the seats and mouting brackets then install them in the car.
[This message has been edited by Old Lar (edited 11-16-2012).]
FieroMaster88
Total ratings: 168
Report this Post11-16-2012 11:42 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Walked by it. It's tucked away for the winter.
kendallville
Report this Post11-18-2012 12:05 AM Click Here to See the Profile for kendallvilleSend a Private Message to kendallvilleEdit/Delete MessageReply w/QuoteDirect Link to This Post
bought a new oil pan cap( $ 23 rock auto ) and a lisle 53000 tool ( $ 34 Kendallville auto parts ) and did a oil change .
never spent that much to change oil before
what we wont do for a loved one
TejasFiero
Report this Post11-18-2012 12:52 AM Click Here to See the Profile for TejasFieroSend a Private Message to TejasFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed the ignition modual shield that the previous owner forgot to reinstall when he changed the ign modual . Good thing I checked on his poor mechanic skills. Got to drive my little 88 coupe to the insurance office to pick up my new card. Weather was nice and being a non ac car it was a pleasure to get out and drive it on the freeway with the windows down. Can't wait to drive it again.
FieroTony
Report this Post11-19-2012 12:04 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 2M4
Rebuilt rear calipers, new brakes, new e-brake cables. (RR piston/slider froze up). Good to go now.
Old Lar
Total ratings: 214
Report this Post11-26-2012 10:05 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put all the seat pieces together for my 87 GT and mounted them on their rails so all that is left is to install them into the car.
Which means I have to move two other Fieros out of the way to access the doors,
gtxbullet
Report this Post11-26-2012 08:05 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
installed the Remanufacture ECM into my 1988 Base Coupe to see if it solved my code 42 timing issues and crappy running...nope.
next will be factory coil packs in place of the current MSD ones.
I've replaced everything on the engine and transmission so far in the last 2 years (not because of this issue, but just and FYI). completely stripped the engine and put all new gaskets and seals on it; as well as honing the cylinder walls for better oiling, and serviced the trans, cylinder head, engine, fuel tank. everything is clean and pretty much perfect...
but this dumb running issue still wants to rain on my happiness...lol
oh well, going to continue to have patience and go through all the possibilities.
on my 87 GT I started removing the gas tank which had completely rusted/seized T-Bolts...long story short, grinder+simple removal = tank now has a cut in it. GHHHRRR (very small though.
ShockWave
Report this Post12-01-2012 01:11 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced possibly-bad IAC valve and drove it around for about 45 minutes; think this takes care of it stalling when coming to a stop after driving awhile. Will see how it runs over the weekend.
Also; over the week I've replaced plugs, wires, coil, and cap/rotor. Cap/rotor was defective and giving me a bad miss so I took it back today and have a replacement incoming from MSD.
