  What Did You Do To Your Fiero...TODAY ? (Page 127)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219389 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
Marine1981
Report this Post02-11-2013 12:05 AM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well I got some work done on my 86 SE Today. When I got the car it didn't have any keys at all. The steering column was unbolted from the dash so the wheels could be turned, and there was no cluster. Today I got a chance to work on it. I installed a new ignition switch, cluster, and a D- Shaped steering wheel. I got the trunk open by hooking up jumper cables to the battery cables and using the trunk release switch that I found on the floor. Thankfully the vents were not installed but they were in the trunk and one was touching the positive and negative terminals of the battery which drained it completely. I got it to turn over but not fire up. Which is probably good. The car has sat since 08 at least so I should probably drop the tank, change the oil, flush the coolant system, and clean out the vents in case anything made a home in there....
Ben
tbone42
Total ratings: 128
Report this Post02-11-2013 01:05 AM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
I started it fo rthe first time in a month and put my new insurance card in it. About a month before Fiero Driving Weather begins again in earnest.. waiting for the snow and salt to go away and then she needs new shocks, struts, sunroof gasket and tracks, and new headliner installed. Then I am ready for the 30th anniversary show.
tntcary
Report this Post02-11-2013 07:34 AM Click Here to See the Profile for tntcarySend a Private Message to tntcaryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed all the cloth covers on speakers, cleaned and painted bare covers gloss black. Look like freakin new awesomeness. I like I can see my new speakers threw the mesh. This will now become another standard practice for all my acquired Fieros.
FieroTony
Report this Post02-11-2013 01:05 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Late Friday night until about 1:30 Saturday morning. Changed the inner/outer tierods and the tranny mounts. Steering wheel is now centered and she don't wander all over the place.
36 more days til' SPRING!!!!!!!!!
katatak
Total ratings: 82
Report this Post02-11-2013 02:12 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Way to go Tony!
I continued the garage rehab so I can get my next project Fiero inside! Come on Spring!
Old Lar
Total ratings: 214
Report this Post02-20-2013 03:58 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I uncovered my 87 GT which has been in storage on wheel dollies since July (on a batterey tender) and moved it to the open door and took it off the wheel dollies. Checking for paper work, install 2013 tag, can't find the insurance card, call the insurance company and they emailed me the card. The car fired right up and I drove it around for about 25 miles. It is such a fun the car is to drive with the five speed. Maybe I'll take it to the Palm Bay cruise in tomorrow.
Old Lar
Total ratings: 214
Report this Post02-22-2013 05:01 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was having issues with the passenger side headlight motor.. It wouldn't go up by the switch, but would manually lift and close when lights turned off. I figured I'd switch motors as I had a rebuilt one in storage. I put the "new" motor in. It goes up with the switch, but doesn't go down.
So I figured I'd take the old motor apart and check the innards. I knew that one side is a PITA, the passenger side. I had to disassemble the top end to get the plastic gear out and to find that the innards were all good. There are two "floating" magnets that are held against the rotor with two small springs. What a real PITA to hold the magnets in place with the springs pushing them out, then insert the worm gear.. I can't remember how I did that in the past. No matter, I dropped one of the springs, even though I was working on a towel. I can't find the spring.
I put all the parts in a plastic ziptop bag and come back when I find another spring.
I'll try to fiddle with the "new" motor in the assembly, later.
kendallville
Report this Post02-22-2013 09:31 PM Click Here to See the Profile for kendallvilleSend a Private Message to kendallvilleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a fuel gage sending unit ( tired of running out of gas ) will install when garage warms up. now looking for a gray seat cover .
and need to get new shocks and struts and tires to get ready for spring and the 30th in Indy.
[This message has been edited by kendallville (edited 02-22-2013).]
Shonyman32
Report this Post02-23-2013 04:28 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
I started my car for the first time after its rebuild!
Curtis_Edgar
Report this Post03-05-2013 11:14 PM Click Here to See the Profile for Curtis_EdgarClick Here to visit Curtis_Edgar's HomePageSend a Private Message to Curtis_EdgarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not just today but within the last week.
New Amp Wired in behind the driver seat which also aided me in wiring up my powered driver seat.
New Original GT Sail Panels
New Wheels that I'm absolutely in love with.
And I finally redid my headliner in vinyl and couldn't be happier
Let me know what you all think
1985 Pontiac Fiero GT | 1994 Acura Integra LS/Vtec
hercimer01
Report this Post03-05-2013 11:25 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I swapped steering wheels. I like the looks of the standard wheel better. Plus the three spoke one was oozing goo in the heat, I had to keep a rag under the seat because my hands would get all mucked up when I was driving it.
88 Coupe under construction
kendallville
Report this Post03-05-2013 11:27 PM Click Here to See the Profile for kendallvilleSend a Private Message to kendallvilleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought a decklid support strut, ( no more getting hit in the head ) from Rodney Dickman.
ended a week that also got me a new gas gage sening unit, courtesy lights , horn paddles and seat cover.
time to warm up the weather.
Marine1981
Report this Post03-06-2013 01:05 AM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I got it legal and the title in my name. Today I took the blower motor out and cleaned out all the leaves from under the windshield area.
Ben
JCircs
Report this Post03-09-2013 06:19 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally found and installed a braided TV detent cable that don't melt from the heat of the turbo.
https://www.fiero.nl/forum/Forum1/HTML/087461.html
flimbob
Report this Post03-11-2013 05:09 AM Click Here to See the Profile for flimbobSend a Private Message to flimbobEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed 97 Chevy C1500 wipers/wiper arms from the local pick-a-part. Had a chronic issue with drivers side wiper coming off during even the lightest precip. New style are the hook and loop type. Already had to use them. They work great!
[This message has been edited by flimbob (edited 03-11-2013).]
FieroTony
Report this Post03-11-2013 08:46 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a darn thing!!!!!!
Had to run to Culpeper, VA (325 miles round trip) Saturday and sick in bed Sunday. It was a beautiful, warm & sunny weekend. The first of the season.
larini74
Report this Post03-13-2013 04:42 PM Click Here to See the Profile for larini74Click Here to visit larini74's HomePageSend a Private Message to larini74Edit/Delete MessageReply w/QuoteDirect Link to This Post
I installed the Hurst shifter that I made for my car.
I bought a short shifter online, cut the stock handle out of the shifter plate and had a friend weld the new handle in place.
The rubber boot is just an off the shelf item from Auto Zone, and it is held in by friction, no glue or screws holding it in.
It feels real nice and falls right to hand when shifting.
Jim_Martin29
Report this Post03-13-2013 06:55 PM Click Here to See the Profile for Jim_Martin29Send a Private Message to Jim_Martin29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took it in to get a smog check.
It passed California smog with flying colors. In fact, the owner pointed it out on the paperwork and said it was outstanding. CO was .00 at idle (average is .10) and at high idle it was .04 (average is .20).
Jim Martin
White '86 GT
Monterey, California
FieroTony
Report this Post03-13-2013 07:36 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 2M4 5 speed
Changed the back up light switch. First time the lights work since I bought it.
hercimer01
Report this Post03-13-2013 10:42 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove my 88 coupe till it ran out of gas. Fortunately I was 1/2 a block away from the gas station headed down hill so I coasted it in. When I filled it up, it took 9.9 gallons and I had driven 238 miles.
Is the capacity and mileage OK?
mrfiero
Total ratings: 150
Report this Post03-14-2013 12:19 AM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the capacity and mileage OK? (I
Something is amiss with your coupe. You should be getting 30-35 MPG and you should be able put in almost 12 gallons if you run it dry.......400 miles per tank is not unheard of (I came close to 400 miles in a Formula once). Anyway, 238 miles from 9.9 gallons is only about 24 MPG.....even with an automatic Duke you should be getting better mileage than that.
As for the topic at hand.....I put in a new fuel pump & injectors in my '86 SE. It runs great, but still needs a new clutch to be driveable (that's coming up this weekend).
oliver9000
Report this Post03-15-2013 04:41 PM Click Here to See the Profile for oliver9000Send a Private Message to oliver9000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced all the useless light bulbs! (Ashtrays and lighter)
fierogtlt1
Report this Post03-15-2013 11:59 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got most of my Fiero wet sanded and ready for paint.
FieroTony
Report this Post03-19-2013 02:07 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
This past Friday night. Replaced the struts. (Those things were worse than shot). Front ball joints, shocks and in/out tie rods recently replaced. Alignment tomorrow. $50. (Brother-in-law operations manager at Chevy dealership).
exoticse
Total ratings: 108
Report this Post03-19-2013 11:07 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow you are on top of it my friend !
Can't wait to see it painted.
FieroTony
Report this Post03-20-2013 08:53 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the shop for alignment today. Hope this thread doesn't go to "What went wrong with your Fiero.....Today"
FieroTony
Report this Post03-20-2013 12:19 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroTony
Member since Feb 2012
Not today, but this coming weekend. Just received new sail panels from FieroSails. Very nice!!!!!!!
fierogtlt1
Report this Post03-20-2013 07:15 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will have it with me at the April meeting......Hopefully..?
FieroTony
Report this Post03-20-2013 07:52 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alignment perfect.
Charlie64
Report this Post03-20-2013 08:29 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Completed my "pre flight" for my road trip to Daytona. Now to pack!
HTXtremes
Report this Post03-21-2013 12:43 AM Click Here to See the Profile for HTXtremesSend a Private Message to HTXtremesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled roof panel, half the interior, deck lid, and rear clip. Prepping for choptop!
Marine1981
Report this Post03-21-2013 11:16 PM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Worked on my 86 GT today. Swapped out the buttons on the window switched from ones out of a Firebird. My dash lights had stopped working so I took of my gauge cluster to find out the housing was shattered and barely held to the dash. When I looked at the circuit board on the back I saw this.
So I took the printed circuit board from an 84 cluster and swapped it over
I believe this is a first for any vehicle except the truck I had it in before. I installed a rear view mirror from an aircraft (I think it was ordered for an AV8-B Harrier but might have been a Prowler)
This is the view from the drivers seat, I may need to make some adjustments but will try it like this for a bit.
HTXtremes
Report this Post03-22-2013 06:36 PM Click Here to See the Profile for HTXtremesSend a Private Message to HTXtremesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow is all I can say! Started removing the other pieces of my roof panel/ a pillar panel, came off in four pieces. And found out the reason my car leaked in the rain, the only area of the windshield still glued was the bottom! Both sides from top to bottom and all the way across the top was just sitting there! Never drove the car in rain, just noticed wet floor boards after it rained, just figured it was the sunroof leaking!
falcon_ca
Report this Post03-23-2013 10:33 AM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Poured some fuel in the newly installed fuel tank with new pump. Turn the key to On to check for leak. And guess what, there was
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 |Work done 11-12 |Work done 12-13 |4.9 Swap |Parts for sale
Jfrost
Report this Post03-23-2013 07:20 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
I started it for the 2nd time with the L67 installed and let it warm up. The smoke cleared and no leaks were found, successful day!
hiwil88formula
Report this Post03-23-2013 08:09 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
installed an extra ground and fixed my passenger doorlock. also trying to get my digital cruise working but no luck. I think i need a new servo.
88FieroGT TTops
Report this Post03-23-2013 08:20 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
got both of my exhaust manifolds off!!! will soon be back on the road again!
Ponti88GT
Report this Post03-23-2013 08:47 PM Click Here to See the Profile for Ponti88GTSend a Private Message to Ponti88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Test drove the 3800 SC Series III fresh engine swap! Was so nerve racking, because it was the first time I had ever driven the car since purchasing it last summer.! It was a short shake down run, but all seemed to be working properly. Next is finishing the exhaust and putting the interior back together. Whew! Any 3800 Fieros in Minnesota shoot me a PM!
Sherman
solotwo
Total ratings: 62
Report this Post03-23-2013 09:19 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Last night I installed the summer tires and changed the oil. Adjusted the exhaust for a little bit more clearance. Tonight I adjusted the drivers side sunvisor
Charlie64
Report this Post03-23-2013 11:14 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Went to the show at Daytona International Speedway...
Then cruised Daytona Beach with a chop top...getting much attention
[This message has been edited by Charlie64 (edited 03-23-2013).]
