  What Did You Do To Your Fiero...TODAY ? (Page 128)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219388 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
Total ratings: 461
Report this Post03-24-2013 12:32 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally finished rebuilding the front suspension.
Installed poly in the control arms.
Installed modified 86 WS6 springs (FJF code. Shortened by 1 3/4 coils.)
Installed new Monroe Sensa-tracs.
When everything went back together, it was "duck footed" by nearly a half inch.
Since I reassembled everything pretty much where it was (using the alignment tools that are sold on eBay) I was surprised to find that there was that much disparity between the rubber bushings (which didn't seem worn) and the poly.
I whipped a quick "tape measure alignment" on it, and performed yet another gravity bleed on the right front caliper. (For the longest time, it's had an initial pull to the left whenever the brakes were nailed, after which it seemed to even out.)
I kept on getting bubbles in the hose, even though I had dabbed generous amounts of bearing grease around the bleeder threads. I was sure I still had a leak, and kept on messing with it. Finally the fluid started running out "clear". Not sure if I did something, or if there was really that much air in the system.
Took it for a quick ride. The front end seems to be more "precise", but I couldn't really put it through any paces, or check the braking, because it's raining. Again.
The rear is next. It's also getting new Sensa-Tracs. NAPA camber bolts,
Also getting the (stiffer) 88 front springs and fieroguru's camber correction kit.
A friend of mine is going to cobble together the upper spring hats.
(Some of you may have heard of John Fiero Champagne from Montreal. He lives here, now.)
Actually, he's going to let me do it, and try my hand at welding. Promises to be lots of fun.
Praise the Lowered!
[This message has been edited by Raydar (edited 03-24-2013).]
zap
Report this Post03-24-2013 07:14 AM Click Here to See the Profile for zapSend a Private Message to zapEdit/Delete MessageReply w/QuoteDirect Link to This Post
After 2 years of driving my 88GT in south Florida WITHOUT air conditioning I put on a new compressor, charged the system and now have A/C...... will wonders never cease.
Tony Kania
Total ratings: 305
Report this Post03-24-2013 10:09 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am taking mine for a ride today!
Brandons87
Report this Post03-24-2013 10:56 AM Click Here to See the Profile for Brandons87Send a Private Message to Brandons87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bled my brakes and drove it to work
Mr.Goodwrench
Report this Post03-24-2013 12:27 PM Click Here to See the Profile for Mr.GoodwrenchClick Here to visit Mr.Goodwrench's HomePageSend a Private Message to Mr.GoodwrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Putting her back together.
FieroTony
Report this Post03-25-2013 03:13 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
New sail panels from Paul at FieroSails.com. They look even better on the car. Very nice.
Report this Post03-26-2013 08:11 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put a rear swaybar on the 2m4.
David Hambleton
Report this Post03-27-2013 08:08 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ode to the ‘84 SE
When I started my car there arose such a clatter,
I crawled underneath to see what was the matter.
And what to my wondering eyes should appear?
Two nut-less studs; a bolt missing, quite clear.
So how did the starter stay on you might ask,
With only one loose bolt, left to the task?
Off from the parts car, a bolt to make tight,
Nuts from the wiper joint seemed to be right.
So now it is fixed, & quite cheaply ‘tis said,
Next is the leak from a screw in a tread...
My87gt
Report this Post03-28-2013 01:37 AM Click Here to See the Profile for My87gtClick Here to visit My87gt's HomePageSend a Private Message to My87gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Prepped for spring! Seafomed, found an ehaust leak (need to fix that). Reconditioned my window switches and replaced the plastic gray buttons with 84 black ones. Installed them in a new plate that I got from the fiero store along with a lightly used power mirror switch in preparation for my power mirror install. Also I migrated the wiring from a beachwood color consol to a dark gray cut t-top console for the performance sound package. One last thing was installed a battery disconnect on the battery with a 15amp pass through so when disconnected the radio remembers the time and the alarm still works.
Tomorrow I try and fix the Exaust leak and order some sound dampening.
White 88 Formula with factory T-TOPS. Number 1016 out of 1252
http://i1167.photobucket.co...35/My87gt/Sig1-1.jpg
kendallville
Report this Post03-28-2013 11:16 PM Click Here to See the Profile for kendallvilleSend a Private Message to kendallvilleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I looked at all the parts I bought to put on my 87. I allso took the 86 gt my son drive to a restoration shop to have some
work done to the door striker bolts , the thin sheetmetal around the bolts had cracked. a previous welding shop tried
to fix it but only made it worse. I have seen his work and he says he will restore it to original look .
The passenger side was so badly welded that it broke and fell out in an aproximate 3 inch section around it.
found under seat two of my missing flashlites , my daughters spare car key, two insulated cups, tire gage,
one womans ring, and assorted junk.
quins&dads88
Report this Post03-29-2013 10:30 AM Click Here to See the Profile for quins&dads88Send a Private Message to quins&dads88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Im taking back a front bumper kit I bought for my 88 GT .
from Vision AutoDynamics out of Chino, Ca.
Very unhappy.
JCircs
Report this Post03-30-2013 02:51 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my new license plate frame.
https://www.fiero.nl/forum/Forum1/HTML/087461.html
Richjk21
Report this Post03-30-2013 05:10 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Swapped the winter toys for the summer toy... Moved the Fiero out of the corner of the garage, and put the snowmobiles away in that spot.
Glad I didn't put the sleds away any sooner, was still out riding last weekend!!
Rich
88FieroGT TTops
Report this Post03-30-2013 07:19 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
ported my manifolds
fierogtlt1
Report this Post04-01-2013 08:22 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got my front bumper eggcrate and bumper mounted.
fierogtlt1
Report this Post04-02-2013 09:18 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished sanding car down and will be ready for paint tommorrow.
So car will be ready for the monthly meeting on Thursday.
Mr.Goodwrench
Report this Post04-03-2013 12:59 AM Click Here to See the Profile for Mr.GoodwrenchClick Here to visit Mr.Goodwrench's HomePageSend a Private Message to Mr.GoodwrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hooked up fuel lines, pulled oil pan off
SSN669chris
Report this Post04-03-2013 05:45 PM Click Here to See the Profile for SSN669chrisSend a Private Message to SSN669chrisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuilt my daughters steering column, those darn four bolts. Sorry to see Fieroman took down all of his posts. Thanks!!! to all the great information and gear heads on this sight. I would have never finished today without breaking something of launching the steering column into the neighbors yard with out you.
Chris
steve308
Total ratings: 59
Report this Post04-03-2013 05:53 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Had it towed from home to the repair shop -- fuel pump started buzzing on the way home Saturday --- would not start today. Pump less than a year old!
FieroTony
Report this Post04-04-2013 10:54 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing!!! Which is good and bad in the same sentence. Good, nothing needs fixing. Bad, don't have the time to tinker with it. Unfortunately, my daughters 66 Mustang needs some $$$$ and work. Looks like dad's car will take the back burner once again.
fierogtlt1
Report this Post04-04-2013 03:40 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got almost the whole car painted today,have to sand and prep the front bumper tommorrow and then paint all my trim, sail window inserts and engine vents.
[This message has been edited by fierogtlt1 (edited 04-14-2013).]
JCircs
Report this Post04-06-2013 05:57 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up a set of these
And installed them on this
JCircs
Report this Post04-06-2013 06:12 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
JCircs
Member since Jan 2011
[This message has been edited by JCircs (edited 04-06-2013).]
NightMare Cruiser
Report this Post04-06-2013 10:25 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced 6 rod bearing on my 3800 today. With help from my buddy of course! Started it up and let it run for 30mins. Sounded great!!
cpx
Report this Post04-07-2013 12:58 AM Click Here to See the Profile for cpxSend a Private Message to cpxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I installed a RD low temp fan switch / thermostat in my '87 GT. I also painted a replacement dash with SEM Presido (gray) / Satin Black and the HVAC surround, Fiero Store tray, speedo surround, aux surround and shifter surround in SEM Satin Black. I have some RD "OEM better quality speakers" that will get installed tomorrow (both front & rear) along with the dash and I'm going to re-wrap the speaker grills in RD Gray UV resistant speaker grill cloth.
Here's a pic of the painted dash / aux surround...
[This message has been edited by cpx (edited 04-07-2013).]
1986 Fiero GT
Total ratings: 54
Report this Post04-07-2013 04:25 AM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made this.
1988 Formula
Report this Post04-07-2013 08:43 AM Click Here to See the Profile for 1988 FormulaSend a Private Message to 1988 FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed a clutch disc and installed the engine back in the car. The small piece that broke out of the spring pocket wedged in the pressure plate and it wouldn't release. Kind of a hassel, but the guys a Spec did send me a replacement no charge.
sco77
Report this Post04-07-2013 02:20 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
This weekend got new tires on stock wheels, finally car drives smoooth... The other weekend put my deatschwerks fuel pump in to prep for 3800.
86 Fiero GT 4spd - (pending L67 swap)
98 GTP - Some mods
no2pencil
Report this Post04-07-2013 09:54 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got mine to start, timed good, & backed it out of the garage! Due to expired tags I just took it around the parking lot & brought it back into the garage.
No more glowing headers
Alex553
Report this Post04-08-2013 09:37 PM Click Here to See the Profile for Alex553Send a Private Message to Alex553Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally installed my keyless entry thingy. But my door handle broke it seems the past owner used plastic weld on it -___-
dbober
Report this Post04-08-2013 11:29 PM Click Here to See the Profile for dboberSend a Private Message to dboberEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steam cleaned the carpets after replacing the heater heater core. (Wasn't that bad)
tntcary
Report this Post04-09-2013 06:03 AM Click Here to See the Profile for tntcarySend a Private Message to tntcaryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey ik John, he used to work with my brother. Great dude!
falcon_ca
Report this Post04-09-2013 07:01 AM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed my Ausfiero's door pods with Boston Accoustic's S50 speakers.
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 |Work done 11-12 |Work done 12-13 |4.9 Swap |Parts for sale
doublec4
Total ratings: 150
Report this Post04-10-2013 10:41 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished installing my new brake swap today. The old ones came off but not without a fight. Just need to bleed the system now..
Old Lar
Total ratings: 214
Report this Post04-12-2013 12:55 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I spent the morning washing, waxing and detailing my 87 GT. It hadn't been out of the garage since the Daytona spring show and when I drove home it was all in the rain. Now I'm trying to locate my battery tender for it. It is somewhere in the garage, but I couldn't locate it. A sign of getting old I guess.
I found the battery tender...on the kitchen table..
[This message has been edited by Old Lar (edited 04-12-2013).]
fierogtlt1
Report this Post04-13-2013 09:18 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got time to paint all my molding,sail panel inserts and my
Engine vents all gloss black.
ThePriest
Report this Post04-13-2013 09:33 PM Click Here to See the Profile for ThePriestSend a Private Message to ThePriestEdit/Delete MessageReply w/QuoteDirect Link to This Post
haha bit of a first post anywhere but my one in the mall, but today I put new door locks and trunk lid lock in.......I swear to god, If I ever have to replace them again, someone else is getting paid, far to much of a job.
exoticse
Total ratings: 108
Report this Post04-13-2013 10:58 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
If i told you,.....i would have to shoot you !
fierogtlt1
Report this Post04-13-2013 11:07 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
f
What the hell..
exoticse
Total ratings: 108
Report this Post04-14-2013 12:08 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fierogtlt1:
f
What the hell..
lol just messin, made some nice progress today. shhhhhhhh,.....
