  What Did You Do To Your Fiero...TODAY ? (Page 131)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219389 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
solotwo
Total ratings: 62
Report this Post05-27-2013 09:16 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found the rear defroster wiring and installed on to switch on new bezel. In the process found the back upper - lower two screws for the IP/Gage cluster missing.
Moved and reinstalled the transmission "power" switch.
Cleaned and polished the "C6" exhaust tips. Wow they are either chrome or stainless, not brown and black.
solotwo
Total ratings: 62
Report this Post05-27-2013 09:18 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
solotwo
Member since Jun 2002
Double post. Darned old dell slow compter. A true POS.
[This message has been edited by solotwo (edited 05-27-2013).]
PatrickTRoof
Report this Post05-27-2013 09:26 PM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
I fired it up for the first time in almost ten years!
http://www.youtube.com/watch?v=bVY7fYhr4QM
May contain language...
litespd
Total ratings: 176
Report this Post05-28-2013 12:12 AM Click Here to See the Profile for litespdSend a Private Message to litespdEdit/Delete MessageReply w/QuoteDirect Link to This Post
I started it up, backed it out of the storage unit, and let it run for a while as I moved a couch out of the storage unit...then, I pulled it back in.
FieroTony
Report this Post05-28-2013 08:31 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Repainted rear bumper cover. (Kicked up a quart of brake fluid while rebuilding the rear calipers several months ago.) Re - wet sanded, compound, polished & waxed the entire car. Now it's raining AGAIN. Guess I'll be washing her when I get back home!!!!
Always
Loved
Fieros
johnyrottin
Total ratings: 85
Report this Post05-28-2013 10:33 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Washed, waxed, vacuum, Armor All, extreme rim cleaning, dew wipes, lube all mechanicals inside the window and lock mechanisms...result of a day!!!
Charlie1963
Report this Post05-28-2013 08:16 PM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed my horn. Found the terminal in the fuse block for the horn fuse was corroded and not making good contact. Now the horn and cigarette lighter works.
solotwo
Total ratings: 62
Report this Post05-28-2013 10:35 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Opened the trunk this morning to find water drops coming from the forward most nuts to the rear spoiler. Got home this evening and put some sealer in to stop the water leak. Old cars, sometimes are great and sometimes are a true burden. Bought my car in January and I am finding new things daily that need to be addressed. Getting to old for this crap.
fierogtlt1
Report this Post05-28-2013 11:26 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I repainted my front bumper and wing and then the rest of my molding in gloss black.
[This message has been edited by fierogtlt1 (edited 05-29-2013).]
jim94
Report this Post05-29-2013 11:18 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am getting ready for a heater core replacement. The how too helped out a lot,thanks. Lots of fluid inside air box.
fierogtlt1
Report this Post05-30-2013 12:08 AM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got my rear wing installed today that I got from "OldLar".
Synthesis
Total ratings: 294
Report this Post05-30-2013 06:52 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I pulled the Grand Am brakes off of Frankencar in the first act of carnibalism so that he can live on in FrankencarToo.
I installed the brakes and wheels over onto the 85,000 mile GT.
I also moved my Rodney Dickman hood strut over, and will be doing the upper intake manifold and several sensors from the old Frank to the new Frank.
Oh, and I got the car registered, and moved the MN Collector Custom plates over.
The original Frankencar has a frame that is so badly rusted that the front cradle mounting points and lower B-pillar mounting pads that are welded to the passenger compartment are separating...
The teardown and scrapping begins.
ShockWave
Report this Post06-01-2013 05:47 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
-Removed spare tire, jack, and jack mount to scrub front compartment; re-installed everything.
-Loosened exhaust U-clamp nuts so that when new tips are installed later this month the shop doesn't destroy the exhaust hangers with their impact wrench.
-Polished hood strut with wire cup brush.
-Found a small coolant leak in front of driver side rear wheel - just had to tighten a hose clamp.
doublec4
Total ratings: 150
Report this Post06-01-2013 06:18 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Picked up my car with my new F23 getrag swap Shifts and drives MUCH better now! Spec Stage 3+ clutch.
Also finished up version 2 of the LED tail lights I'm working on:
Check out my build and my website!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
Embrace Racing
northeastfiero
Report this Post06-01-2013 06:34 PM Click Here to See the Profile for northeastfieroSend a Private Message to northeastfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got a bit more work done on the engine swap
guitarfreak235
Report this Post06-01-2013 11:22 PM Click Here to See the Profile for guitarfreak235Send a Private Message to guitarfreak235Edit/Delete MessageReply w/QuoteDirect Link to This Post
Buy it.
TXOPIE
Report this Post06-01-2013 11:31 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
A LOT:
[This message has been edited by TXOPIE (edited 06-01-2013).]
Daredevil05
Report this Post06-02-2013 12:04 PM Click Here to See the Profile for Daredevil05Send a Private Message to Daredevil05Edit/Delete MessageReply w/QuoteDirect Link to This Post
While on vacation at Secret Silversands I was able to catch up with the forum. I feel so motivated that when I do get home I might even do something to my car. Thanks guys.
TheRiv
Fierosmith
Report this Post06-02-2013 12:43 PM Click Here to See the Profile for FierosmithSend a Private Message to FierosmithEdit/Delete MessageReply w/QuoteDirect Link to This Post
Test install of my new custom wing stands on my project car.
Still have to repaint wing, but that's down the road a ways anyhow.
Need to work on the custom tail light mod to complete this look.... tbc
Jim
The only thing more Fun than Driving a Fiero, is Learning how to Work on one...
PerKr
Report this Post06-02-2013 04:35 PM Click Here to See the Profile for PerKrClick Here to visit PerKr's HomePageSend a Private Message to PerKrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't do anything today. Or yesterday really. Well, I did stuff three young ladies in the passenger seat (almost, one of them, and she did smell rather nice and had rather nice legs, took a seat on the center console), giving them a lift in to town. I think the old 2M4 enjoyed that
Fierosmith: looks good, will have to keep that in mind if my fiero goes where I planned six years ago
Fierosmith
Report this Post06-02-2013 06:29 PM Click Here to See the Profile for FierosmithSend a Private Message to FierosmithEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
I've got better than 20 hours in building those... been dreaming of doing that for over two years now.
What takes some swaps so long, I've found is all the mini projects that spin off of the main projects. (ie, "well.... while I'm here......" ) LOL
Jim
Old86
Report this Post06-02-2013 08:42 PM Click Here to See the Profile for Old86Send a Private Message to Old86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took cover off, been on since October. Charged dead battery. Cleaned out the trash and leaves from the heater control resister and then changed out my heater core.
Synthesis
Total ratings: 294
Report this Post06-02-2013 09:08 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cleaned up all of the leftover ribbon, balloons and "Just Married" stuff from the GT, and then installed the new LeBra on the front end.
I then opened the trunk to get something and discovered a lot more helium filled balloons as they all rocketed upwards from the trunk.
Sourmug
Total ratings: 144
Report this Post06-02-2013 09:26 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, no no! Your supposed to be taking off "Le Bra"! Congrats on your wedding by the way.
Nolan
exoticse
Total ratings: 108
Report this Post06-03-2013 01:40 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Harry test fitting his new nose !
johnyrottin
Total ratings: 85
Report this Post06-03-2013 09:19 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday, the RottinIndy got freshly rebuilt headlight motors on both sides. Rebuilds were performed by the master, Charles Sewell. Thanks Charles!!!!! next project for her....New PONTIAC windscreen stickers from Fioero Sails (style 3) to replace the cracking ones that on on her.
johnyrottin
Total ratings: 85
Report this Post06-03-2013 12:59 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
johnyrottin
Member since Oct 2007
Today: New washer motor and wiper blades. Not sure what happened to it but washer motor went kaput. New blades this time of year every year so it made snse to do both at the same time.
Banshee
Report this Post06-05-2013 07:44 PM Click Here to See the Profile for BansheeClick Here to visit Banshee's HomePageSend a Private Message to BansheeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today a simple swap but for an Old Muscle Car Thumper guy I put in the HURST SHIFTER WITH WHITE 5 SPEED KNOW. DAMN IT LOOKS GOOD.
Yah I know it is just the arm but it looks like it is a true Hurst short throw super shifter!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CowsPatoot
Total ratings: 84
Report this Post06-07-2013 06:17 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Such a simple thing...but makes such a huge difference.
sricka01
Report this Post06-09-2013 03:21 AM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Added MP3 to my Monsoon Pontiac CD player. Worked great.
http://ls1tech.com/forums/s...without-adapter.html
Charlie1963
Report this Post06-09-2013 08:47 PM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
Made a replacement for the front support strut to replace the original that was just about rusted completely through.
FieroTony
Report this Post06-10-2013 09:05 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rebuilt the TBI. New gaskets and cleaned it up.
Always
Loved
Fieros
GTMN
Report this Post06-10-2013 01:36 PM Click Here to See the Profile for GTMNSend a Private Message to GTMNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent six hours yesterday finding out why the only place I can find to reseal two 3 piece centerline wheels wants to charge me $500 bucks for the job (oh and I would have to send them to Texas). The seal was bad, after a company (which shall for now remain nameless) in the Chicago area, was supposed to have done the job. I didn't want to take them back there because they screwed them up 3 times before I finally gave up on them. So as I spent 6 hours with scalpels, knives, scrapers, and wire wheels to remove the bad seal I found out why it failed. I found some pieces of the original seal material from the 80s, a different seal material where a reseal had been attempted later, and the seal material that the company in Chicago had squirted in on top of the pieces of the first two ( even though they assured me that they would remove tho old seal and re-seal them). And to make matters worse, they spray painted the inside of the rim, silver before they squirted in the sealant (which doesn't stick to spray paint very well. Now I'm ready to do a final clean out of the seal grooves with some residue free brake cleaner and an air gun. I've curved a large gauge hypodermic needle to reach into the front groove and have another straight one for the inside groove and will hopefully get the sealant squirted in this week.
After one wheel was done, I thought "man, I should find a moron to pay to do this!", but then I remembered, "Oh Yeah, I already did that and look how it turned out."
I"VE GOT BLISTERS ON ME FINGERS!
Find out how I did at the 30th. Will I have centerlines or OE rims on my Indy at the show?
See you all there,
Mark
[This message has been edited by GTMN (edited 06-10-2013).]
fierogtlt1
Report this Post06-10-2013 06:32 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had to buy a new battery today since my car died about a half mile down the road.
TXOPIE
Report this Post06-10-2013 06:40 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
New FRONT & REAR GLASS:
Al from Safelite came by and put in my new Front and Rear Glass:
steve308
Total ratings: 59
Report this Post06-12-2013 07:24 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Running warm on Sunday and had a green leak drip front side drivers rear tire. Up on jack stands as high as I could - replaced the four major hoses rad to pipes - pipe to engine (had a pin hole in the return line hose). What a pain in the A$$ !. Flush and fill - change stat. Nothing is more fun than the pipe to engine hose clamp behind the AC. What a design.
Charlie64
Report this Post06-12-2013 08:05 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
It was done just to annoy you Steve!
DPC
Report this Post06-12-2013 08:17 PM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello friends,
I have never had the nerve to post what I have been doing, since I am not nearly the mechanic or fabricator that many of you are. I have really learn a great deal from your posts over the years, and gotten a lot of great ideas. Anyway, I thought I would show what's been going on here. Today, I have been working on finishing up the wiring for my gauges for my 4.9 before I work on the bracket for the throttle cable. Anyway, I know it still looks pretty messy, but here's how things are now.
David
[This message has been edited by DPC (edited 06-12-2013).]
steve308
Total ratings: 59
Report this Post06-12-2013 08:40 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Charlie - you have a pm...
fierogtlt1
Report this Post06-12-2013 09:00 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing today since I got my bad news yesterday from the Doctor that I need to go on Oxygen and possibly a Lung Transplant in the near future.
