  What Did You Do To Your Fiero...TODAY ? (Page 137)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219389 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
dbober
Report this Post10-12-2013 11:49 PM Click Here to See the Profile for dboberSend a Private Message to dboberEdit/Delete MessageReply w/QuoteDirect Link to This Post
Autocrossed it again. Well, these were a few weeks ago.
http://youtu.be/MyaJTL-9ARM
http://youtu.be/NgY6_cdJ3_Q
SSN669chris
Report this Post10-13-2013 03:09 PM Click Here to See the Profile for SSN669chrisSend a Private Message to SSN669chrisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the interior with a pisa wrap around.
Total ratings: 259
Report this Post10-13-2013 07:16 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to the gas station to get fuel for the lawnmower!
Old Lar
Total ratings: 214
Report this Post10-14-2013 11:21 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spending time changing the oil, then remove the wheels to grease the fittings and clean the inside of the wheels, clean the wheel wells, the black lug nut covers. Wipe down the tires with "wheel shine". This was a lot easier when I was 20 years younger. I still have the front tires to remove, clean and reinstall.
Finished up with the front wheels, greased and cleaned. Man it still got hot and sweaty out there today.
Maybe in the next couple of days do a real clean up...wash and wax.
[This message has been edited by Old Lar (edited 10-14-2013).]
Spiders1
Report this Post10-14-2013 08:57 PM Click Here to See the Profile for Spiders1Send a Private Message to Spiders1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Changed the 4 speed shifter to a 5 speed. Painted the getrag black and various pieces hammered gray.
hercimer01
Report this Post10-15-2013 12:33 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started pulling my 88 duke apart again to fix the oil leaks from when I replaced the timing gear.
88 Coupe under construction
neph
Report this Post10-15-2013 09:39 AM Click Here to See the Profile for nephSend a Private Message to nephEdit/Delete MessageReply w/QuoteDirect Link to This Post
This past weekend: Replaced sway bar bushings, replaced the spark plugs, replaced the fuel filter, fixed a vacuum leak and attempted to sort out my clutch / shifting problem
N3M3S1S
Total ratings: 51
Report this Post10-15-2013 01:02 PM Click Here to See the Profile for N3M3S1SSend a Private Message to N3M3S1SEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed a code 21. TPS was sticky, resulting in sputtering at highway speeds, bad mileage, and a generally crappy ride. Past two days have been butter smooth. I could kick myself for overlooking such a simple thing.
1MohrFiero
Total ratings: 157
Report this Post10-16-2013 06:52 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the original sub-woofer with a Rodney Dickman kit last night. The old one was blown. The new one won't impress any audiophiles but it does round out the sound in the cabin now.
jaybug56
Report this Post10-18-2013 09:26 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
busted a 3800SC dog bone mount, accelerator cable retainer, supercharger back fire blowing the hoses off, shift cable retaining clip came off and it looks like something in the exhaust broke because the tips are now crooked. All this at the same time. Fun times.
Oh yeh.
Also put the car on a trailer to tow it home.
[This message has been edited by jaybug56 (edited 10-18-2013).]
SSN669chris
Report this Post10-19-2013 05:40 PM Click Here to See the Profile for SSN669chrisSend a Private Message to SSN669chrisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made a glove box to finish my dash install
Old Lar
Total ratings: 214
Report this Post10-20-2013 11:21 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got my car back from the shop with a rebuilt four speed auto plus other issues that needed fixing then took it to a cruise-in.
yellowstone
Total ratings: 250
Report this Post10-20-2013 11:25 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced oil pressure sending unit (secong time in a few months, yes, an AC Delco unit) and that fixed my non-working gauge. Also wanted to replace the coolant temp sensor but discovered that Rockauto sent me the wrong part :-(
FieroTony
Report this Post10-21-2013 11:22 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Left rear caliper was dragging so much that the rotor warped. (E-brake cable works fine, not seized - replaced 8 months ago). Rebuilt the calipers, works fine now. The PO installed SS brake lines that are too long. It was late and I hurried and didn't check it thoroughly. The rim wore through the brake line. That was EXCITING!!!! Put new brake lines on and works great. Only thing is some brake fluid swirled up on the rear bumper corner. Sanded and refinished it with primer. Got to repaint it now. AARRRGGG!!!!!
That hurry thing usually never works out well!!
johnyrottin
Total ratings: 85
Report this Post10-22-2013 10:08 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Headlights failed again after replacing the gears with Fiero Store gears. These lasted about 10 cycles of up and down. Needless to say I was a bit miffed. Enter Rodney Dickman full rebuild kits. Last night they arrived in the mail so I pulled the headlight motors out of my Indy. They are off to Charles Sewell for a full rubuild and recondition. Sad thing is that it is dark when I go to work now and dark when I leave work...so no Indy driving until thay get back! Hurrah for the MERA! Gonna get more use for the next two weeks. I usually only drive it on Fridays.
jimbolaya
Total ratings: 114
Report this Post10-22-2013 01:54 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put an axle on the rear yesterday. Ball joints and tie rods on the rear today. Front suspension parts tomorrow. Actually it's my sons car though.
Jim
jb1
Report this Post10-23-2013 06:34 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
got tires mounted and balanced...
265/35 looks small..
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 10-26-2013).]
stefanosg
Report this Post10-24-2013 05:21 PM Click Here to See the Profile for stefanosgClick Here to visit stefanosg's HomePageSend a Private Message to stefanosgEdit/Delete MessageReply w/QuoteDirect Link to This Post
New front shocks. Struts are next.
92wastheyear
Report this Post10-24-2013 05:49 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to work! We have a had a string of about 2 week of great Indian summer out here in Portland. Everyday about 65-70 degrees after some morning fog
Old Lar
Total ratings: 214
Report this Post10-24-2013 06:59 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
87 GT wheels before
After..
Drove down to Wheels America in Hialeah Florida on Wednesday to get some GT wheels refurbished. They said that the wheels will be done tomorrow Unbelievable at the turn around time..ONE DAY!
Drove back down today and picked them up. The wheels look new! But it was over 800 miles of driving down and back twice in two days plus Florida turnpike tolls.
notwohorns
Report this Post10-24-2013 08:24 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wheels look good. Would you care to till us how much it cost to have a wheel refinished? I'm think about have my wheels done
solotwo
Total ratings: 62
Report this Post10-24-2013 10:21 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed roof drip moldings that were missing when I purchased the car. Looks better that the chipped paint.Thanks Tim for the parts. Regapped the NGK TR55's to .045, then took it for a short drive and it seems to have taken care of the problem. Used Jetman's suggestion on power door locks and now they work for the first time since I bought the car!! Installing a different shifter plate/cover that came with spare parts in the car as the tabs for the auto shifter boot are broken on the one that came with car. Swapped ashtray doors off of the spares that came with car. Now gotta find ash tray light bulbs and figure out how to wire a light for the auto trans indicator. Car was a manual.
[This message has been edited by solotwo (edited 10-24-2013).]
Old Lar
Total ratings: 214
Report this Post10-25-2013 07:42 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
$129+ / wheel www.wheelsamerica.com
N3M3S1S
Total ratings: 51
Report this Post10-26-2013 07:46 PM Click Here to See the Profile for N3M3S1SSend a Private Message to N3M3S1SEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had my sub and amp for over a year, never bothered installing it. NOT TODAY! Finally did it, and am so glad I did. The extra boost to the stereo is night and day.
I did that while the engine was cooling because today's real mission was oil leak hunting. I determined the other day that one leak was from the ol' distributor o-ring. Got the good red one and took out the distributor annnnddd.. the magnets were toast when we took it apart to do the pickup coil. Ended up getting a Cardone reman'd dizzy and off to the races. Found a second leak at the oil filter where the last shop to touch it hadn't tightened it all the way. I was due for an oil change anyway so we did that too. So far so good, haven't seen any leaks again. *crosses fingers* I hope it stays that way!
87GT2M6
Report this Post11-12-2013 09:37 PM Click Here to See the Profile for 87GT2M6Send a Private Message to 87GT2M6Edit/Delete MessageReply w/QuoteDirect Link to This Post
going in this week
pontiackid86
Total ratings: 344
Report this Post11-12-2013 09:52 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
found out today the intake manifold has flamethrower capability's
On a good note though the basterdized mera is back on the road after 10 years I think
[This message has been edited by pontiackid86 (edited 11-12-2013).]
hnthomps
Total ratings: 51
Report this Post11-13-2013 10:06 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Connected the battery in my project car to test roll down the power windows and discovered that the new power door locks also operated into the locked position. Unfortunately it looks as if the keys I was provided with after installation of new door locks do not fit the lock cylinder. This is basically a lock out situation. Is there a good way to break into a Fiero without damaging components?
Nelson
johnyrottin
Total ratings: 85
Report this Post11-13-2013 10:24 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Freshly rebuilt headlights, done by Charles Sewell, installed into the Indy. We used Rodney Dickman's kits as two Fiero Store kits failed with less than ten uses. The Dickman parts work fantastic! The motors are now quieter and have already done 20 cycles.
N3M3S1S
Total ratings: 51
Report this Post11-13-2013 05:11 PM Click Here to See the Profile for N3M3S1SSend a Private Message to N3M3S1SEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 87GT2M6:
going in this week
I was thinking about getting those but I settled on something slightly cheaper of the 5.25" variety. Let me know how those work out, the ones I picked are a little too tall so I need to reconfigure it all.
jim94
Report this Post11-13-2013 11:21 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I removed 1sail panel and cleaned the double stick tape off. This is going to be fun putting the new sail panel on straight. Tomorrow the other side
FieroTony
Report this Post11-18-2013 12:01 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
- New tires on a four corners. No more vibrations at 90mph. Just had to see.
- Rebuilt right headlight motor. No more random winkie.
- Washed, wax (Turtle spay) and vacuum.
rbell2915
Report this Post11-18-2013 12:28 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished installing some new speakers after a weekend of work. Totally worth it. Now I just gotta get the hubs back from the metals teacher so I can upgrade the brakes and finally drive her again.
bomluuk
Report this Post11-18-2013 12:33 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swore at it.
Vernon8360
Report this Post11-18-2013 10:48 PM Click Here to See the Profile for Vernon8360Send a Private Message to Vernon8360Edit/Delete MessageReply w/QuoteDirect Link to This Post
Topped off the gas tank, parked it inside and covered it up for the winter. All I need is an up-dated window poster. Other than that, I'm ready for the 5th Annual Tyler Shipman Car Show. Thursday caravan to Frazee?
1988 GT
Medium Red Metallic
Manual, Gray Leather
K Beck LEDs & StuWipes
[This message has been edited by Vernon8360 (edited 11-18-2013).]
fierogtlt1
Report this Post11-18-2013 11:30 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Walked by it .....wanted to throw some gasoline on it and torch it and call it a day.
[This message has been edited by fierogtlt1 (edited 11-19-2013).]
pontiackid86
Total ratings: 344
Report this Post11-19-2013 01:28 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed the headlights on my Mera.... kinda.
yellowstone
Total ratings: 250
Report this Post11-19-2013 02:48 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Fiero got some TLC:
Danyel
Total ratings: 171
Report this Post11-19-2013 06:18 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gonna be nice to see you there again my friend.
My Build Thread
Tylers Toy
MeadmakerDave
Report this Post11-19-2013 09:54 PM Click Here to See the Profile for MeadmakerDaveSend a Private Message to MeadmakerDaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the passenger side rear caliper. Got everything laid out to do the driver side on Friday.
jb1
Report this Post11-20-2013 02:30 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
replaced pass side front caliper ( had brand new powder coated ) with an old used painted caliper. I got a bad caliper when I bought new ones , so I will order a rebuild kit and rebuild the new caliper.... and started removing the rear bumper to add Snapperheads led backup lights..
86GT 3800 n/a
My Build
