  What Did You Do To Your Fiero...TODAY ? (Page 139)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219388 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
hnthomps
Total ratings: 51
Report this Post12-20-2013 08:38 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by turbo86se:
Discovered the door locks are worthless. That key does work on decklid. Adding new door locks to the list.
Welcome to the club. I had new locks installed on the doors and the vehicle was delivered to my house prior to the owner going out of business. That was the good news but I did not discover that the key did not fit the door locks until they accidentally locked closed when I was installing a new battery. New dew strips and a very tight window complicated the problem. If the inner door panels had not been off at the time I would never have gotten the doors unlocked.
Nelson
solotwo
Total ratings: 62
Report this Post12-22-2013 01:41 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
2 Seat Garage installed intake gaskets and other gaskets that were shot. Replaced PCV and other gaskets.
paulcal
Total ratings: 96
Report this Post12-24-2013 03:32 PM Click Here to See the Profile for paulcalSend a Private Message to paulcalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Corrected the belt alignment on the 4.9. I've been battling this problem since I bought the car, come to find out, a spacer missing on the alternator was the problem all along. Unfortunely the mis-alignment caused an undue strain on the alternator bearings causing them to make way too much noise now. I dropped my spare alternator off at the shop for rebuilding on the way home. Hopefully the bearings don't fail on the current one between now and next week.
kooljess
Report this Post12-25-2013 04:13 PM Click Here to See the Profile for kooljessSend a Private Message to kooljessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Warmed her up...I've neglected her lately. It's time to pay attention to her once again!!!
LT188GT
Total ratings: 100
Report this Post12-25-2013 10:12 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plugged her in----------------battery tender.
Grantman
Report this Post12-25-2013 10:29 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to the storage locker and looked at my baby. Sigh....
1986 Fiero GT Fastback 3.4Lpr with 4T60
1998 Jeep Grand Cherokee with "big boy" 5.9 motor
1983 Honda Goldwing 1100 Interstate
LornesGT
Report this Post12-27-2013 07:40 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the fiero store exhaust tips on, one side anyway. Had to buy a 2 to 1 7/8 adaptor because the fiero store doesn't make the pipe size correct. first adaptor slipped on easy, second one is going to be a pain in the arse.
Also tried to change the radiator fan but I had another obstacle. The new fan has a raise area to slide into the fan blade where the original doesn't. Bought from Rockauto.com on close out maybe I will clean out the fan blade to slide it in.
[This message has been edited by LornesGT (edited 12-27-2013).]
FieroTony
Report this Post12-30-2013 10:25 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Myself and the misses had a date Friday night and took the Fiero. Life is good!!
solotwo
Total ratings: 62
Report this Post12-30-2013 09:23 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced a leaking thermostat housing cap.
Neils88
Total ratings: 56
Report this Post12-30-2013 09:32 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cursed it repeatedly. But did get the flywheel bolt threads chased (one was cross threaded) and cleaned AND drilled the last two bolt holes for the new 4.9L engine mounts.
jim94
Report this Post01-01-2014 06:52 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I took one of the 4 water tube clamps off and cleaned and painted with silver heat paint. 3 to go
FXYFIERO
Report this Post01-02-2014 07:16 AM Click Here to See the Profile for FXYFIEROSend a Private Message to FXYFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thought about my Fiero... Sigh.
-The Search for Jenny 2 continues...
hnthomps
Total ratings: 51
Report this Post01-03-2014 09:40 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Center console skeleton repair work using JB Weld epoxy. Oh what fun!!
Nelson
hercimer01
Report this Post01-04-2014 01:38 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took my 88 sledding!
I wonder if we can get skis for the front?
88 Coupe under construction
woodyhere
Report this Post01-04-2014 09:09 AM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made a serpentine belt set up for my sbc.
woodys 427
Lunatic
Report this Post01-05-2014 08:44 AM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
I built a simple cradle using 2"x2"x1/8" steel tubing.
It's only tacked and it needs a few gussets, braces and engine mounting points.
The day after I built it, I found some 88 knuckles. So now I'm going to build mounts so I can utilize the 88 specific suspension components.
[This message has been edited by Lunatic (edited 01-05-2014).]
turbo86se
Report this Post01-06-2014 10:42 AM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Last night I pulled the drivers side fender without ripping the bottom part. Got those two rivets out easily! Yay me! On to the passenger side later...
fierobug
Report this Post01-06-2014 02:00 PM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the Christmas decorations away to make room in the garage for the fiero to work on. Jacked up the front end and took off the wheels to get ready for the bushings, ball joints replacement. Put cover on it to protect it from my tendency to hit things. Tried to get area clear, organized and setup for the job.
FIEROBUG!!!!!!!!!!
johnyrottin
Total ratings: 85
Report this Post01-06-2014 07:18 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
We got 11 inches of snow and it was -30F...we didn't do anything with any of the Fieros today!!!
jim94
Report this Post01-08-2014 10:56 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Went to the Dr. apt and finished painting my water line clamps. Looks good now.
fierogtlt1
Report this Post01-08-2014 11:56 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cast some resin for my Center Console Skeleton project I have going on.
https://www.fiero.nl/forum/Forum1/HTML/092166.html
Ducati Jones
Report this Post01-09-2014 01:31 PM Click Here to See the Profile for Ducati JonesSend a Private Message to Ducati JonesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed the foot of snow that was on it so I could drive it to work today.
fierobug
Report this Post01-09-2014 02:03 PM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now that is a great post!
FIEROBUG!!!!!!!!!!
turbo86se
Report this Post01-09-2014 04:52 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I picked up a used AC Delco battery at a junkyard for the Fiero. First time I've had a battery in the car for the 2.5 months I've owned it. Drivers side headlight mechanism worked perfectly. Passenger side needed help. Must need new bushings. No biggie. I also picked up a x-over pipe for free, because the O2 sensor is literally rusted onto the fitting. I'm hoping it can be useable somehow. Mine is rusted badly.
Turned the key to on, and heard the fuel pump relay behind me do its thing, but didn't hear the whine of the fuel pump. As I was thinking, fuel pump is bad. Is this a good time to put on a in-line fuel pressure gauge?
Neils88
Total ratings: 56
Report this Post01-09-2014 05:46 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just received the new cradle bolts and flywheel bolts from the Fiero Store. Too cold in the garage to do any actual work...but at least I can stare at the bolts.
McTamney
Report this Post01-10-2014 12:08 AM Click Here to See the Profile for McTamneySend a Private Message to McTamneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing. I have no motivation to get it running again. It would only take a weekend to put the motor back in...
yellowstone
Total ratings: 250
Report this Post01-11-2014 12:25 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Adjusted the ride height on my coilovers and repainted the calipers while the wheels were off.
RCR
Total ratings: 102
Report this Post01-11-2014 04:27 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed the modified coolant lines (88 in the front and 84 in the back) and roughed in the 3-core radiator. It's ready for coolant again....
Bob
Lunatic
Report this Post01-12-2014 06:01 PM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made the instrument panel surround and gauge pod in CAD.
I laser cut it out of 1/8" aluminum but I think I'll make another set in brushed stainless steel.
I then installed some existing gauges that I had left over.
Danyel
Total ratings: 171
Report this Post01-12-2014 07:14 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
HUUMMMM looks familiar GOOD JOB !!!!
My Build Thread
Tylers Toy
zefferk
Report this Post01-13-2014 11:23 AM Click Here to See the Profile for zefferkSend a Private Message to zefferkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Saturday and Sunday I went to town on the overhaul of my Formula. I removed both rocker panels to remove both lower quarter panels in preparation for replacement with scoop ones, removed the trunk and the spoiler for repairs and paint, finally got the complete front and rear suspension removed and replaced with new bushings, ball joints, trailing arms, shocks, struts, and lowering springs, replaced the inner and outer tie rods as well as my steering bushing with Rodney's solid brass one, removed the gas tank to replace the fuel pump as preventive measure (never done to my knowledge) to find a pristine gas tank as well as pump. I still replaced it with the new AC/Delco one I had purchased and will be putting the old one up for sale as it looks perfect (no crud in the filter and ran perfect!). I removed the top end of the motor in anticipation of replacing the heads with rebuilt ones along with new sprint headers (figured I'd probably break some header bolts in the old ones and the valve seals would need to be replaced as well as the head gaskets while I'm in there). I also removed the entire exhaust for replacement with a new Ocelot System from the Fiero store. I fitted the new Archie battery relocation tray up front (by the way, the spare holder was signed and dated 11-22-87 from the factory on the underside of it!).
My poor baby is in pieces right now, but she is sure going to be rock solid once she's back together. I still have to replace the Oil Pan, Motor mounts with Rodney's solid poly, trans mounts as well, along with the dog bone. New EGR solenoid, EGR, EGR tube, ETC.... Lots of work to come and many nights out in the cold garage still to come. Can't wait for Spring!
My Fiero...
88 Yellow CJB #182 of 1252 formula
turbo86se
Report this Post01-13-2014 05:20 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went out to the junkyard today and scored a great set of floor mats, 120 mph speedo gauge cluster (for some reason my GT has the 80) left-side GT engine vent, mint condition extra gauge surround and radio surround. Also scored a decent red '86 GT front bumper. Last but not least a R-side GT tail light to replace my busted one. I went ahead and grabbed the L-side tail light, it was busted, but I figured what the heck!
I went out there for the drivers side seat, got the front bolts out, but the seat rails will not budge. I really want to get that seat. Couldn't get to the back bolts. Any ideas how to get the rails to move so I can unbolt the seat? You can pull the lever it just won't budge!
Lunatic
Report this Post01-13-2014 06:52 PM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was in a similar situation to yours. I wanted a seat that didn't budge. What worked for me was, I undid the front "seat bolts". (Not the ones that bolt the seat track to the floor but the ones that hold the seat track to the seat.) After those two were removed using a 1/4" drive ratchet and appropriate socket, I gained "a little" access to the crossover spring. They always break and therefore the seat adjuster doesn't do it's job. I swapped in a new spring and after a few minutes of persuading the stubborn seat, it moved. Access granted to the rear bolts.
Option 2. Bring a hacksaw and if you can get your arm in there, cut the track. Not pretty but it should get the job done.
Option 3. Adjust the seat back to the most forward position as possible. Try and rock the seat back and forth. That should fatigue the metal enough so that it breaks. You might have to locate another set of seat tracks but hey, you'll have your seat!
Note: Late model Cavalier seats fit as well. Just an option since they're more plentiful.
I hope this helps.
[This message has been edited by Lunatic (edited 01-13-2014).]
Lunatic
Report this Post01-13-2014 07:06 PM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lunatic
Member since Sep 2013
Actually, I designed and laser cut a nice F23 front mount. Since I built my own cradle, it's designed to work with that. Pics to follow as I left it at work today.
On another note:
Thanks Danyel. I read your "Black Widow" post. Damn, I have some catching up to do! I moved my speedo and tach up so as I can view them better.
Lunatic
Report this Post01-13-2014 07:11 PM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lunatic
Oops, I almost forgot. I picked up these 18" mystery wheels.
If anyone can tell me the manufacturer, that would be great.
I bought them missing the centre caps and there are no markings on them other the size and a DOT marking.
turbo86se
Report this Post01-14-2014 12:56 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope this helps.
Thanks for the tips! I might go with option 1. I'll get practice on my seats, they're 10x worse than the seat at the junkyard. I'll have to find that spring first.
Another option is a mint set of Camaro seats at the yard as well. I know I'll need the tracks from the Fiero seat for them to work. I really want to get that seat and carpet because they're in really good shape, the rest of the car...not so much. :/
carbon
Total ratings: 132
Report this Post01-14-2014 01:05 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I walked by it this morning, looked at the pile of parts next to it, got sad, and went to work.
FieroMaster88
Total ratings: 168
Report this Post01-14-2014 04:29 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Missed driving the 88 and wished I had room to work on the Indy.
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo.
84 Indy #64: Restoration Project, Super Duty 4 swap
turbo86se
Report this Post01-14-2014 05:08 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just got those pesky GT quarter windows trim pieces out. Eventually the GT clip is coming off.
fierogtlt1
Report this Post01-14-2014 10:11 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's funny,I just gave somebody on Facebook directions on how to remove those today.
Todd.
