  What Did You Do To Your Fiero...TODAY ? (Page 141)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6920 (219132 views)
Last post by: Doggo on 03-30-2025 09:15 PM
BrittB
Report this Post02-14-2014 08:15 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by PribanicS:
Locked my keys in the car and finally fixed the horn contact/relay
You replaced the relay or fixed it?
sco77
Report this Post02-14-2014 08:25 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed some new rear speakers, going to replace fronts again with something else because I am not happy with the sound.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
spcearle
Report this Post02-16-2014 03:48 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did an oil change.... Dropped the pan and discovered I do infact have a stroker kit in it like I was told when I bought the car/ unfortunately also have the wrong flex plate installed to go with it.... Tightened down some bolts that were either loose or vibrated loose..... Now I just need to get the funds together to start picing together what I need for a 4t60 swap I guess so I can replace the flex plate and slipping tranny all in one shot
BZAnathema
Report this Post02-16-2014 11:04 PM Click Here to See the Profile for BZAnathemaSend a Private Message to BZAnathemaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't get to do any work on the car itself, but may have found a donor for my 3800SC Series II.
notwohorns
Report this Post02-17-2014 10:38 AM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I put the ac/heater control out of my parts car in my car. The radiator fan wouldn't come on with the air conditioner and I found a burnt circuit on the original one . Another thing I can check off the list. Today I'm going to start installing the new carpet. I got tired of waiting for warmer weather cause I don't have a heated garage, so I'm using a torpedo heater.
RCR
Total ratings: 102
Report this Post02-17-2014 04:33 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Requested a quote for parts...
Bob
PribanicS
From: East Quogue, New York, United States of America
Report this Post02-19-2014 01:22 AM Click Here to See the Profile for PribanicSSend a Private Message to PribanicSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well the horn was missing the spring so I used an ink pens' spring and the relay was loose with a hole in it (still usable). Hit my head on the heater core when I put it in cause the nail contact point wasn't low enough and it blared like nobodies business.
mrfiero
Total ratings: 150
Report this Post02-21-2014 01:36 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the trunk side exhaust manifold gasket and installed a new EGR tube and a low-temp fan switch from Rodney. She's getting there.....slowly, but surely!
LornesGT
Report this Post02-21-2014 08:20 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removing the engine seems like its taking forever because it is. Nuts came off the front easily, back bolt drives side came out easy so I thought piece of cake. never should have said that, passenger side locked up tight. I drill the head off. Lowered it to drop the cradle, drivers side front bolt bound up in the rubber. Maybe tomorrow.
turbo86se
Report this Post02-21-2014 08:58 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the lower radiator support brackets that rusted thru, replacement front bumper, and the radiator fan. Noticed a little bit of rust on the cradle, so I decided to have a look at the frame rails. Pulled the cracked rear drivers side splash guard and the frame rails are nice and purty! Next to no rust. Same with the trunk corners. No rust. Wish I could say the same about the floor pan. CRUSTY!!! HELP!!!
mrfred8
Report this Post02-22-2014 05:00 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I actually drove it!!!! for the first time since October.
JCircs
Report this Post02-22-2014 05:54 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my Amida subwoofer console and armrest. Those factory seats need to go, Mr Mike it's time.
[This message has been edited by JCircs (edited 02-22-2014).]
NightMare Cruiser
Report this Post02-22-2014 06:19 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you're ready to sell the skins Let Me Know.
NightMare Cruiser
Report this Post02-22-2014 06:21 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
NightMare Cruiser
Member since Aug 2009
Installed a trans cooler.
JCircs
Report this Post02-22-2014 06:34 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
You got it.
BZAnathema
Report this Post02-23-2014 04:53 PM Click Here to See the Profile for BZAnathemaSend a Private Message to BZAnathemaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed out the license plate lights after being tailgated by a police officer for a quarter mile and FINALLY pulled over. Claimed he pulled me over for the lights, but I have a suspicion he pulled me over for being a teenager driving a sports car. Whatever. All fixed now.
notwohorns
Report this Post02-23-2014 05:18 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I put my seats back in my fiero after installing new carpet. I followed the advice of putting the new over the old. I had a heck of a time trying to get the nuts over the studs. The new carpet had a padding under it and it made the studs too short. I wasn't about to pull the new carpet to remove some of the backing. I fought and fought with the nuts trying to get them on. Finally I got my three foot screw driver and was able to put enough pressure on the rails to be able to start the nuts. What a job, but it is done
hercimer01
Report this Post02-23-2014 07:44 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bought a sunroof panel and sunroof for my 88 coupe.
88 Coupe under construction
BZAnathema
Report this Post02-23-2014 10:54 PM Click Here to See the Profile for BZAnathemaSend a Private Message to BZAnathemaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just adjusted the headlamps.
spcearle
Report this Post02-24-2014 12:38 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced a balljoint that I just replaced in July thanks to brooklyn craters in the road.... Tightened down my driver wheel bearing.... Went ahead and ordered inner/outer tie rods front and back and rack bushing since I can't find a rebuilt rack anywhere because the crater also caused some play in the rack so now is a good time to rebuild it... And spent a cpl hours online looking for a th440 tranny to swap in
fierogtlt1
Report this Post02-24-2014 07:24 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got some Center Console Skeleton parts in the mold waiting for the silicone rubber to cure then will pour the resin tonight.
https://www.fiero.nl/forum/Forum1/HTML/092166.html
solotwo
Total ratings: 62
Report this Post02-24-2014 08:43 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replace headlight and washed the K & N air filter. I moved the K & N air filter out of the wheel well where it sucks up a lot of dirt and into an area that will not get all the road crap.
fierobug
Report this Post02-25-2014 03:50 AM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished bushings, ball joints, tie rod on left side. Cleaned and painted arms and area. Now to freeze arse off with right side.
FIEROBUG!!!!!!!!!!
turbo86se
Report this Post02-25-2014 06:58 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picked up a spare hood, $10. For experimenting with hood scoops.
Chieftan63
Report this Post02-25-2014 10:20 PM Click Here to See the Profile for Chieftan63Send a Private Message to Chieftan63Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put in new seats from junk yard and cleaned the carpets (Daily Driver) 1987 Silver GT
tonycampbell86gt
Report this Post02-26-2014 10:12 PM Click Here to See the Profile for tonycampbell86gtClick Here to visit tonycampbell86gt's HomePageSend a Private Message to tonycampbell86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put it on skates, pushed it out of the garage, and started it up for the first time this year. Other than a dead battery, purred like a very loud angry kitten!!!
Tony
Fiervette
Report this Post02-27-2014 01:08 AM Click Here to See the Profile for FiervetteSend a Private Message to FiervetteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replace the fuse for power locks. (my son had held the button down too long)
Ordered sardonyx247's Brake Booster Upgrade.
spcearle
Report this Post02-28-2014 06:08 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got all my parts in today to work on my steering rack( new inner/outer tierods,bellows, bushing, and damper) new rear inner/outer
Masked off and painted stuff to match the rest if the stuff I sprayed
Now tomorrow I buck up and start tearing stuff out of the car / clean and spray the rack and hope the mount bushings are still good or venture to the parts store to see what I can scrounge up to work
Neils88
Total ratings: 56
Report this Post03-01-2014 12:24 AM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ordered my stage 3 clutch.
TheDave
Report this Post03-01-2014 12:31 AM Click Here to See the Profile for TheDaveSend a Private Message to TheDaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glued a yellow hotwheel Fiero over top of the radio surround. This part was originally painted black by a PO. I needed something to cover a quarter sized imperfection on the paint job. 1 Fiero hotwheel and some hot melt glue and presto the imperfection is gone! This will do until I find a better gray radio surround plastic piece!
RACE
Total ratings: 157
Report this Post03-01-2014 03:11 AM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I muśt finished installing an iPod jack into my stock radio. I'll test it with an expendable radio tomorrow.
If this works, it will be awesome.
spcearle
Report this Post03-01-2014 07:28 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my rack pulled and rebuilt sitting on my kitchen table... Tomorrow I get to put it back in and do a home alignment till I can get it into a shop
Snapperhead
Report this Post03-02-2014 10:15 AM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still trying to find my barn that has the Fiero in it? SNOW
Vince
Snapperhead Performance - Custom Hot Rods & Accessories
Stainless & Acrylic Deck Lid, Hood, Trunk & Door Sill Plate Mirrors - Vette Brake Swap Consentric Rings - Powder Coating Service - Hidden Trailer Hitch - PnP Trailer Hitch Wiring Harness - LED Reverse Lights
Threads:
Used Fiero Parts - Custom LED Back Up Lights - Hidden Trailer Hitch - Mirror Panels - Door Sill Mirrors - Vette Brake Swap Consentric Rings
Rides:
85 Fiero Gt, Green "Grasshopper", 86 Fiero GT, Blue, V8 " Snapperhead" 2013 Fierorama Best of Show Non-Stock, 87
GT Met Orange, 88 Formula White stock soon to be 4.9 met Blue like Snapperhead--- 10 Camaro, 99 K2500 Suburban,
04 Trailblazer
ShockWave
Report this Post03-06-2014 04:50 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced both headlamp motors + gave it a start.
Replacing most of the rear tri-link components next, I expect those to arrive tomorrow or Friday.
jimbolaya
Total ratings: 114
Report this Post03-06-2014 07:03 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not my Fiero, but my son's, and not today, but yesterday. I had a hose clamp bust on one of the coolant hoses. Lost all my coolant and had to pull over on the interstate. Thank God I had an extra clamp in the trunk. I repaired it on the side of the road, and just as I finished, the V-Dot truck pulled up and topped me off with water. Tomorrow I will drain the water and fill her back up with 50/50.
Jim
AL68
Report this Post03-06-2014 09:52 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
Picked up a rebuilt Camaro rack for my power steering conversion & stripped down an extra crossmember, ready to make the mounts this weekend.
solotwo
Total ratings: 62
Report this Post03-07-2014 09:02 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Washed it and installed a 19" wiper blade on the passenger side.
spcearle
Report this Post03-08-2014 05:06 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took the camaro seats from my camaro out of the fiero and installed a pair of big headrest lt1 style transam seats w/ lumbar control...
hercimer01
Report this Post03-12-2014 01:03 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started going through her new engine!
turbo86se
Report this Post03-12-2014 09:32 AM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I went out to Harbor Freight in York, PA (spotted a red notchie on 30 with custom wheels) and got the wheel dollies so I can move the Fiero. Now it's on the other side of the garage and I have so much room! I also put on the replacement hood and fender, looks like a Fiero again!
