  What Did You Do To Your Fiero...TODAY ? (Page 142)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219388 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
spcearle
Report this Post03-12-2014 01:32 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took my seats back out and installed the fiero tracks on them after a lot of cleaning and oiling.... Much better height now... Replaced the pump motor on passenger side and repaired a broken wire from the harness I had to build for it so now the bolsters work on drivers and passenger seats... Then I wiped down the interior to clean the years of yuck out of it
Boostdreamer
Total ratings: 98
Report this Post03-12-2014 03:03 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
The wind shredded my car cover so I went out and gathered the pieces and removed the whole thing from my parts car. Now I need to either buy another cover, part it out, or try to get it running. It doesn't look good sitting in the driveway as is.
Stubby79
Total ratings: 58
Report this Post03-12-2014 03:07 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got the console skeleton out in one piece. Got the auto shifter out and the cable, plus the ecm and wiring. Not a whole hell of a lot, but its progress.
Neils88
Total ratings: 56
Report this Post03-15-2014 06:39 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed the new stage 3 clutch on my 4.9 build. Engine is now back on the cradle.
Neils88
Total ratings: 56
Report this Post03-16-2014 06:45 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorted through a pile of parts from the Caddy to see which ones were needed and which weren't required for the 4.9L swap. Basically a clean up...you really end up with a pile of junk when you start pulling stuff off the engine getting it ready to go in.. Then started building the exhaust. Just working on the crossover right now.
1MohrFiero
Total ratings: 157
Report this Post03-16-2014 07:19 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed the middle intake and cleaned the lower intake. Removed the front exhaust manifold for porting and installed studs. I got lucky all of the old bolts and old studs came out with out breaking.
BrittB
Report this Post03-16-2014 09:01 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled off the 18" TSW wheels and put the 14" alloys back on after checking the adjustment of the wheel bearings. I may be replacing the wheel bearings and seal's when I do the brakes next month. Also noticed the shocks were shot so I ordered them today. Now I have a pretty good idea why the bigger wheels were a bear to drive with!
johnyrottin
Total ratings: 85
Report this Post03-18-2014 11:31 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turned 55,555.5 on the way to work this morning!
yellowstone
Total ratings: 250
Report this Post03-18-2014 05:22 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the fuel pressure gauge.
ShockWave
Report this Post03-20-2014 06:45 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished replacing rear tri-link pieces and most of the hardware tonight. Biggest project I've tackled myself on this car, so I am happy.
Driver side sucked, on the control arm I barbecued a bushing and still had to do some drilling (lost a few bits in the process) because the bolt fused to the sleeve. Then I got sick last weekend so I doused everything on the passenger side with PB Blaster while I was out. Came home from work tonight, everything broke-loose nicely and I replaced everything, then cleaned piles of grease thrown from a leaking CV boot (from a few years ago) and cleaned a few other things while I was in there - found the frame rot isn't bad and the cradle is actually pretty clean. Calling the shop whenever I wake up later for the alignment. Old pieces need to go out for core refund, too.
| [jonrev Photography]
[This message has been edited by ShockWave (edited 03-20-2014).]
css9450
Total ratings: 87
Report this Post03-20-2014 09:05 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ShockWave:
Cool, are those new parts?
I have new-in-the-box trailing arms but need a source for the lateral and adjusting arms. Either that, or just the bushings.
Snapperhead
Report this Post03-22-2014 09:06 AM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put the battery in her started her up and gave her a good look over to get her ready to sale.
You tube Video of a cold start today 3/21/14
Snapperhead Performance - Custom Hot Rods & Accessories
Stainless & Acrylic Deck Lid, Hood, Trunk & Door Sill Plate Mirrors - Vette Brake Swap Consentric Rings - Powder Coating Service - Hidden Trailer Hitch - PnP Trailer Hitch Wiring Harness - LED Reverse Lights
Threads:
Used Fiero Parts - Custom LED Back Up Lights - Hidden Trailer Hitch - Mirror Panels - Door Sill Mirrors - Vette Brake Swap Consentric Rings
Rides:
85 Fiero Gt, Green "Grasshopper", 86 Fiero GT, Blue, V8 " Snapperhead" 2013 Fierorama Best of Show Non-Stock, 87
GT Met Orange, 88 Formula White stock soon to be 4.9 met Blue like Snapperhead--- 10 Camaro, 99 K2500 Suburban,
04 Trailblazer
Marine1981
Report this Post03-22-2014 11:26 AM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well Thursday I got it to crank and run for the first time in who knows how many years since I bought it. Last night I patched a coolant tube until I can figure out how to get the replacement in. Today I will take it on a drive to test it out!
turbo86se
Report this Post03-22-2014 11:40 AM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just washed the Fiero for the first time. Been sitting in the garage since October without a good bath. Not that the faded burgandy paint looks great, but at least it is clean. Also cleaned up the engine compartment. Major improvement.
Just got the lower ground effect and quarter panel off. There was one rivet at the bottom. Drilled that out, now I can get the water separator out and do some more cleaning.
[This message has been edited by turbo86se (edited 03-22-2014).]
85red2m6
Report this Post03-22-2014 04:55 PM Click Here to See the Profile for 85red2m6Send a Private Message to 85red2m6Edit/Delete MessageReply w/QuoteDirect Link to This Post
not sure if it's allowed, being 2 days behind, but I installed my new LED taillights from Chris at Embrace Racing Thursday night and bought and installed the new flasher module for them yesterday after work...
1986 Fiero SE 2.8 Auto - Blackie
1985 Fiero GT 2.8 4-spd - Goldie II - To be driveable this season
1985 Fiero GT Convertible - 3.8SC 4-spd - long term project
1987 Cavalier Z24 2.8 5-spd - daily driver - 300k miles and still goin
1993 Bonneville SSEi - 3800SC parts/wiring donor for 85 Vert
ShockWave
Report this Post03-23-2014 03:49 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is this kit off eBay; blasted and painted with new bushings pressed in. I believe he sells the bushings by themselves, too.
tonycampbell86gt
Report this Post03-23-2014 05:08 PM Click Here to See the Profile for tonycampbell86gtClick Here to visit tonycampbell86gt's HomePageSend a Private Message to tonycampbell86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the amp and sup back in.....
Tony
FFIEROFRED
Report this Post03-23-2014 07:58 PM Click Here to See the Profile for FFIEROFREDSend a Private Message to FFIEROFREDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Loaded the fiero on the trailer to go to Daytona tomorrow.
gwg1995
Report this Post03-24-2014 10:55 AM Click Here to See the Profile for gwg1995Send a Private Message to gwg1995Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the current state of the Fiero! Its the first time I've posted my car on the forum. Me and dad put lowering ball joints, adjustable upper ball joints and new shocks on it over the weekend. We're still waiting on the Zero-lash end links because the wrong links were sent but it was an honest mistake Then I went ahead and put my new wheels and tires on it. They're XXR 521's wrapped in Cooper Zeon RS3-A tires! I'm taking it to cars and coffee in Baltimore for the first time on the 29th.
Kurtmylar702
Report this Post03-24-2014 11:19 PM Click Here to See the Profile for Kurtmylar702Send a Private Message to Kurtmylar702Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got some new shoes 19" Axis wheels 19x8 and 19x9.5 . I needed a new strut so I had them put one on and they forgot to hang the brake line on the stut and it rubbed the rim and put a hole in the brake line. I got off the freeway and hit my brakes and I did not have any so I took a very hard right on to the street and coasted to a stop hart pounding. I got lucky the car handles well. It took 10 minutes to calm back down. They sent a tow truck to pic the car back up and take it to the shop to fix the damage and give me the other stut for the other side for my trouble.
FieroTony
Report this Post03-25-2014 10:49 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been there before but my own stupid fault. Hopefully you didn't get brake fluid on the paint.
hnthomps
Total ratings: 51
Report this Post03-25-2014 11:37 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
While preparing the car for Daytona, I tried to start it and went from lights on to an electrically dead vehicle. I hope that it is just a battery issue since I have a new one in the basement. Charging both the old battery and the spare as this is being written. The installed battery checks out good wrt cranking amps and voltage. Now comes the search for the real issue. I do not want to swap vehicles at this stage of the game or give up on the Daytona trip but that is a possibility.
I resolved the car issue this morning and was ready to head to Daytona tomorrow with a clean and polished car. Unfortunately I will now be a "no show" due to attending a funeral several hundred miles south of the car show. I hope that everyone has an excellent show with decent weather.
Nelson
[This message has been edited by hnthomps (edited 03-26-2014).]
yellowstone
Total ratings: 250
Report this Post03-25-2014 04:57 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Washed and polished/waxed it.
TXOPIE
Report this Post03-25-2014 05:05 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by TXOPIE (edited 03-25-2014).]
TXOPIE
Report this Post03-25-2014 05:06 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
TXOPIE
Member since Mar 2012
Kolja...Looking Awesome! You seeing any of those low flying helicopters...with the DOD drills down there?
TXOPIE
Report this Post03-25-2014 05:10 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
TXOPIE
Purchased Another:
exoticse
Total ratings: 108
Report this Post03-25-2014 09:31 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice wheels kurt !
Look similar to my HRE wheels.
zmcdonal
Report this Post03-25-2014 09:55 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice looking ride. I really like your rockers, are those one off custom? Almost looks like another GT rocker was used, upside down maybe?
Also do you have any tricks to getting it on a tow truck? Flatbed, I'm assuming. Any time I need to get mine towed they bring a couple boards but each driver does it different, and none of them around here seem to know what they are doing. Some time this spring I will be installing my fiberglass 512 bumper from Amida, and I cringe at the possibility of having to get it towed at some point, so I'd like to be prepared and either carry some boards in the car, or know the best method in advance so I can instruct them.
Synthesis
Total ratings: 294
Report this Post03-25-2014 10:09 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed two new rear tie-rod outers on the 86GT...
10 degrees outside while I did it.
FieroMaster88
Total ratings: 168
Report this Post03-26-2014 05:34 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the fuel pump:
yellowstone
Total ratings: 250
Report this Post03-26-2014 09:11 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
For some reason, this looks photoshopped to me (look at the bottom of the rear bumper). Also, the color of the ground effects doesn't match the rest of the car.
Kurtmylar702
Report this Post03-26-2014 09:55 PM Click Here to See the Profile for Kurtmylar702Send a Private Message to Kurtmylar702Edit/Delete MessageReply w/QuoteDirect Link to This Post
It is not photo shopped. The ipad did not do well for a photo. The ground effexs that are my creation are rattle can so they don't match.
TXOPIE
Report this Post03-26-2014 09:57 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to see a picture of the rear please and thank you!
jim94
Report this Post03-26-2014 10:19 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I detailed 4 tires and cleaned my wheel Wells. Electric tooth brush does wonders with tire jell. Tomorrow it gets washed and detailed for Daytona on Saturday.
jimbolaya
Total ratings: 114
Report this Post03-28-2014 05:20 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed Rodney Dickman's belt tensioner and alternator support bracket on my sons car yesterday.
Jim
86soon3.4
Report this Post03-30-2014 05:54 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed new stainless steel brake lines, new park brake cables, used no rust clutch line and bled the brakes on my 88 Formula.
Steve
NightMare Cruiser
Report this Post03-30-2014 06:00 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thought about selling it!
Grantman
Report this Post03-30-2014 07:48 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
went to visit my baby in storage make sure there are no flat tires, planning to bring her home next week or two. will be time to replace the crappy 4T60 in it now, install the Truelo intake and headers, magnaflow cat do a proper dyno tune, install the addco bars, and charge the A/C. will be ready in plenty of time for the Frazee trip.
1986 Fiero GT Fastback 3.4Lpr with 4T60
1998 Jeep Grand Cherokee with "big boy" 5.9 motor
1983 Honda Goldwing 1100 Interstate
solotwo
Total ratings: 62
Report this Post03-30-2014 09:35 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed summer wheels & tires. Lubed front suspension. Oil change, with synthetic oil. Installed new exhaust gasket and missing nut. Boy was that a lot of fun with no room to get a socket on the nut .
Steve W
Grand Rapids, MI
87 GT 3800SC
[This message has been edited by solotwo (edited 03-31-2014).]
BrittB
Report this Post03-30-2014 10:44 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the front shocks today, they only lasted 29 years. They were shocks in name only!
