  What Did You Do To Your Fiero...TODAY ? (Page 149)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6920 (219020 views)
Last post by: Doggo on 03-30-2025 09:15 PM
BrittB
Report this Post07-05-2014 01:07 AM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed the side cover from the transmission and replaced the TCC solenoid and 3rd gear pressure switch. That was a bit harder than it first appears, a lift would have been helpful!
paulcal
Total ratings: 96
Report this Post07-05-2014 05:38 PM Click Here to See the Profile for paulcalSend a Private Message to paulcalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I replaced the stock 4.9 starter with a new Allente starter. That solved my problem with it not starting when warm. After a test drive, I started tackling taking off all the body panels of my parts car. My future plan is to do a panel off paint job on them then just switch the panels on to my car.
spcearle
Report this Post07-05-2014 11:04 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
finally completed the 4t40 swap and other lil odds and ends.....needs a lil tweaking but between that and the new flexplate car runs great.....
unfortunately i must have nicked the drivers side seal somehow cause its leaking pretty good there..so now i get to pull stuff back apart after reordering new ones
solotwo
Total ratings: 62
Report this Post07-05-2014 11:59 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to Ludington and back. Longest trip yet. 96 miles one way,
Heretic
Report this Post07-06-2014 12:10 AM Click Here to See the Profile for HereticSend a Private Message to HereticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cursed at it! Those damn strut bolts are a PITA! Taking it to a shop on Monday.
mrfiero
Total ratings: 150
Report this Post07-06-2014 02:37 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just scored a Fiero Store poly dogbone at a local junkyard for $5, so I installed that today on my GT. It's nice not having the sloppy, worn out rubber bushings anymore!
notwohorns
Report this Post07-06-2014 02:43 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cleaned out the puke that my wife deposited last night
jimbolaya
Total ratings: 114
Report this Post07-06-2014 05:51 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Headliner and new speakers at all 4 corners. It's so pretty and sounds so nice.
Jim
BrittB
Report this Post07-06-2014 06:34 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which strut bolts?
RWDPLZ
Total ratings: 306
Report this Post07-06-2014 07:26 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Charged the battery overnight, aired up the tires, and took it for a drive earlier.
FieroMaster88
Total ratings: 168
Report this Post07-06-2014 07:38 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installing some low profile headlights. I got the passenger side done:
JMNRunningFiero2M6
Report this Post07-06-2014 10:32 PM Click Here to See the Profile for JMNRunningFiero2M6Send a Private Message to JMNRunningFiero2M6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took apart my headlight motor assembly. The green bumbers were completely deteriorated and had worn down parts of the plastic gear. Time to order a rebuild kit.
no2pencil
Report this Post07-08-2014 02:47 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Received this photo for proof that it was dropped off at the Jim & Son's Transmission shop by one of my employees. Hopefully I can fly back to get it next month!
** Edited to add url for Jim & Sons **
They've always done top notch work on anything I've taken them. First time taking the Fiero there.
[This message has been edited by no2pencil (edited 07-08-2014).]
tshark
Total ratings: 68
Report this Post07-08-2014 03:12 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
The story comes out!
FieroMaster88
Total ratings: 168
Report this Post07-08-2014 07:09 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Aligned the 88. Drives like a new car.
solotwo
Total ratings: 62
Report this Post07-08-2014 10:23 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks good!
fireboss
Total ratings: 58
Report this Post07-09-2014 01:47 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes those low profiles are NICE!!
rbell2915
Report this Post07-09-2014 05:10 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
I modified my radio to use MP3s, pretty simple to do, just frustrating at times. Well worth it though
solotwo
Total ratings: 62
Report this Post07-09-2014 10:58 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
What did you have for the "old" lights? Interesting very interesting. Hey on a different note, I am trying for a position at the local
BMW dealer. Could be real fun! I am going to PM you.
JCircs
Report this Post07-10-2014 02:27 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed my Fierofreak fuel rails.
[This message has been edited by JCircs (edited 07-10-2014).]
Synthesis
Total ratings: 294
Report this Post07-10-2014 03:52 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday:
Front upper/lower ball joints, upper control arm bushings.
What a PITA.
rbell2915
Report this Post07-10-2014 09:14 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is one of the most beautiful engines I have ever seen.
JCircs
Report this Post07-11-2014 08:39 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, that is one of the nicest things anyone has ever said to me. Lol
solotwo
Total ratings: 62
Report this Post07-13-2014 11:34 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Waxed the car and my wifes car
RJS525
Report this Post07-14-2014 09:10 AM Click Here to See the Profile for RJS525Click Here to visit RJS525's HomePageSend a Private Message to RJS525Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed new dogbone. (black rubber from Rodney) Noticeably tightened up the engine movement.
Installed new dew wipes for the very first time. I had been putting this off after reading what a PITA it can be. It went fine, but took me much longer than many more experienced had told me it would.
I recommend using Rodney's tool and a magnetic pick up. Both came in handy.
Synthesis
Total ratings: 294
Report this Post07-14-2014 09:38 AM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday seajai and I replaced the clutch and flywheel in my 86 GT and fixed the loose/broken exhaust hangers.
Lunatic
Report this Post07-17-2014 08:28 PM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
In hopes of finding a "nice" rad saddle, and not having any luck, I decided to just make one.
Ooh, aah, stainless too! No crusty crap here any more.
[This message has been edited by Lunatic (edited 07-19-2014).]
FieroMaster88
Total ratings: 168
Report this Post07-17-2014 11:01 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Detailed it. Sure gets dirty when used as a daily driver.
solotwo
Total ratings: 62
Report this Post07-17-2014 11:23 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced bad spark plug wire, rerouted the front wires, installed some conduit over some wires for protection
mrfiero
Total ratings: 150
Report this Post07-19-2014 10:41 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I popped out the distributor and changed the O-ring as well as the pick-up coil. The ICM still works fine, so I just cleaned it up and put on some fresh heat sink compound. I also lubed the door hinges and clutch pedal.....both were squeaking incessantly. I can't believe how nice the doors open now.....who knew?!?
FieroMaster88
Total ratings: 168
Report this Post07-20-2014 03:18 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled it outside to clean it's parking spot(garage). Took a picture since I detailed it a couple days ago.
Taijiguy
Total ratings: 244
Report this Post07-20-2014 09:02 PM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Un-buried it and got it ready to roll a temporary cradle under it so I can move it out of the garage for my motor build. Fixing to do a 350 swap.
[This message has been edited by Taijiguy (edited 07-20-2014).]
PatrickTRoof
Report this Post07-21-2014 04:26 PM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today's project is priming and painting my side mirrors, and sandblasting my engine deck vents.
FieroTony
Report this Post07-22-2014 09:59 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
(Sorry for the blurry pix. One handed picture taking.)
CAT heat shield rubbed through the A/C line. Got it welded up, new orifice tube, accumulator, O rings and R134. 57° A/C yesterday. Good to go for now.
(Beware of previously converted R134 systems. Easy O rings were replaced, but I found some that weren't.)
Neils88
Total ratings: 56
Report this Post07-22-2014 09:55 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Reinstalled my clutch master cylinder and installed a new slave cylinder. I was struggling to bleed the system before...it was sucking air into the slave cylinder. Had the whole system bled, by myself, in a few minutes. Feels great! Having said that, I'll consider this a cheap temp fix ($16) since I'm going to be replacing both slave and master cylinders with Rodney Dickman parts soon.
Funkicidal
Report this Post07-23-2014 09:16 PM Click Here to See the Profile for FunkicidalSend a Private Message to FunkicidalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Title transfer / Registration / Tags
A big day! Now I'm all legal and everything.
It was previously registered in Maryland, which requires a front tag. Delaware doesn't so I have a clean nose except for the holes
1988 Fiero Formula - White - Stock 2.8/Auto - 156,000 miles and counting
2008 Patriot - Black - 2.4/CVT/FDI - 110,000 miles and counting
JCircs
Report this Post07-26-2014 03:30 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finished up my 3800 swap, except for exhaust.....
And I mounted my new wheels and tires.
jim94
Report this Post07-27-2014 12:07 AM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
The wife and went for a nice ride .the car hit 60,000 miles. Still going strong. A little sun and a little rain that is a ride in Florida
FieroMaster88
Total ratings: 168
Report this Post07-27-2014 04:46 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Recovered my speaker covers. The red had faded badly over the last 6 or 7 years.
fireboss
Total ratings: 58
Report this Post07-27-2014 07:03 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
NICE RIMS!!
