  What Did You Do To Your Fiero...TODAY ? (Page 152)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219388 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
runner92
Report this Post09-28-2014 11:33 PM Click Here to See the Profile for runner92Send a Private Message to runner92Edit/Delete MessageReply w/QuoteDirect Link to This Post
I
tempted to mount my 3800 on my 88 cradle using mounts bought from a forum member just to figure out they don't line up
88 formula with t-tops
JCircs
Report this Post09-29-2014 09:20 AM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I cut my deck so my intercooler fits under it.
[This message has been edited by JCircs (edited 09-29-2014).]
solotwo
Total ratings: 62
Report this Post09-29-2014 09:18 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed new spark plugs, Autolite 606, took out 605's. The 605's were very dark which tells me they were just to cold of a plug for a stock 3800SC.
dbober
Report this Post10-01-2014 01:56 PM Click Here to See the Profile for dboberSend a Private Message to dboberEdit/Delete MessageReply w/QuoteDirect Link to This Post
Autocrossed it on Sunday. Not one of my better days, but fun none-the-less.
http://youtu.be/HWF6hInz7As
nosaint
Report this Post10-01-2014 10:06 PM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
started cleaning and detailing engine bay..removed vapour canister and hooked up cold ram air to turbo
1986 Fiero GT/T intercooled turbo
Notorio
Report this Post10-03-2014 07:59 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed Rodney's new clutch Master Cylinder, bled the Slave Cylinder, and finally got to Test Drive my new Fiero. My left leg is a bit wobbly after 4 yrs w/o a manual trans but I'm looking forward to building up again.
Notorio
Report this Post10-04-2014 11:12 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Next day ... changed the transaxle fluid, oil & filter. Uuggh, prior oil changers created a real mess under there on the block, cross members, starter, etc. Anyone know a good way to degrease the bottom end at home?
Total ratings: 461
Report this Post10-05-2014 04:12 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally finished rebuilding my A/C system.
Vacuumed it for about an hour and turned off the pump. If it still shows a vacuum in the morning, I'll call it good, and charge it.
Edit - All charged up, and cooling like a fiend. Just in time for winter.
Praise the Lowered!
[This message has been edited by Raydar (edited 10-05-2014).]
northeastfiero
Report this Post10-06-2014 03:57 PM Click Here to See the Profile for northeastfieroSend a Private Message to northeastfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally started the long process of sanding and filling the body pannels
A quick spray to help pick out the high/low spots
Still a few little low spots to fill
A shot from the rear should have cleaned the lense
Notorio
Report this Post10-08-2014 11:53 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed the spark plugs. Gotta say that taking the deck lid off made getting to the 3 inside plugs a Piece of Cake. Holy Frijoles! were those inside plugs in terrible shape.
FieroMaster88
Total ratings: 168
Report this Post10-09-2014 01:06 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
New wheels:
solotwo
Total ratings: 62
Report this Post10-12-2014 09:18 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a nice looking engine/bay area.
solotwo
Total ratings: 62
Report this Post10-12-2014 09:20 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
solotwo
Member since Jun 2002
Fixed the passenger side power door lock.
1MohrFiero
Total ratings: 157
Report this Post10-13-2014 08:53 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished installing the CS alternator upgrade. Seems to be running just fine.
JCircs
Report this Post10-13-2014 08:56 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you.
virtuetovice
Report this Post10-14-2014 12:27 AM Click Here to See the Profile for virtuetoviceSend a Private Message to virtuetoviceEdit/Delete MessageReply w/QuoteDirect Link to This Post
DAMN SON!!! That is a gorgeous engine bay! Just throwing a wild idea out there, has anyone ever tried cutting the "FIERO" badge out of the top of the stock upper intake and finding a nice clean way to attach it to the supercharger? I think it would look awesome. Perhaps a lot of work but if I did an l67 swap that would be something I'd do.
Anyway, what I did to my Fiero...yanked the tank and pulled th pump out to find someone wired the pump backward. LOL that would probably be why the pump is cooked....
nosaint
Report this Post10-25-2014 09:44 AM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
Testing out a few styles of fender stripes
[This message has been edited by nosaint (edited 10-25-2014).]
notwohorns
Report this Post10-25-2014 06:28 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I liked the first one
notwohorns
Report this Post10-25-2014 06:29 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
notwohorns
Member since Jul 2009
I like the first one
Jarhead 2m4
Report this Post10-25-2014 07:18 PM Click Here to See the Profile for Jarhead 2m4Click Here to visit Jarhead 2m4's HomePageSend a Private Message to Jarhead 2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I cleared away the brackets and steering rack to drop the crossmember in the morning. From there we can install the rest of the suspension kit on to the crossmember. I'll worry about the brakes later. I just want to get the car back on the ground for now.
LorenBateman
Report this Post10-25-2014 07:33 PM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ordered quarter windows for my 88GT and that 3rd brakd light thingie
batousai666
Report this Post10-26-2014 11:56 AM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
well....it seems I need a front wheel bearing. sooooo that's on the agenda for today.
to bad, too. I really wanted to clean the yard of leaves. NOT!
off to the fixin store.........
wayneman
Report this Post10-26-2014 04:23 PM Click Here to See the Profile for waynemanSend a Private Message to waynemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it ! No problems this week
RED87SE
Report this Post10-26-2014 06:40 PM Click Here to See the Profile for RED87SESend a Private Message to RED87SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just put these on yesterday. 245/45/18 all around.
Jarhead 2m4
Report this Post10-26-2014 08:09 PM Click Here to See the Profile for Jarhead 2m4Click Here to visit Jarhead 2m4's HomePageSend a Private Message to Jarhead 2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got the front end back on the ground!
Here's the X-member off the car with the new UCAs.
Got both CAs on with spindle and hub mated.
On the car with coil-overs mounted!
MASSIVE rotors!
I still need to mount the calipers, lines, change out the MC, and get the tie-rods connected before even thinking of going anywhere. There is some ridiculous camber with the current alignment. I'll play with that and get new LCA bolts to replace the old worn ones.
huracan2015
Report this Post10-26-2014 10:21 PM Click Here to See the Profile for huracan2015Send a Private Message to huracan2015Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dipped my wheels orange, then photoshopped in a window tint, taillight tint, and lowered it.
[This message has been edited by huracan2015 (edited 10-26-2014).]
hairballrm
Report this Post10-27-2014 12:33 PM Click Here to See the Profile for hairballrmClick Here to visit hairballrm's HomePageSend a Private Message to hairballrmEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well Friday, Saturday, and Yesterday.
Raced Chumpcar at Portland International Raceway.
"Now you too can see in the dark."
http://projectorretrofit.com/ Please Like me on Facebook
Lots of good info on my original sales thread FS: Projector Retrofit Headlamp Buckets
JCircs
Report this Post10-27-2014 01:30 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drag raced it!
LornesGT
Report this Post10-27-2014 02:11 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is almost a wheelie!
Fiero Vampire
Report this Post10-27-2014 06:04 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
With some help pulled a sunroof top panel off a parts car so I can later install it on my daily driver. Was surprised how well my window puller kit I picked up at Harbor Freight made getting the panel off.
davylong86
Report this Post10-27-2014 08:00 PM Click Here to See the Profile for davylong86Send a Private Message to davylong86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I drag raced it!
That is a great pic! Love the wheels on your car, and that is as close as you can get to a wheelie.
jediperk
Report this Post11-08-2014 01:58 PM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wiped it down and drove it to the local Cars and Coffee. Only Fiero there. It was quite popular Saw a really nice RX7 there with an LS2 swapped into it.
mckaymotoworks
Report this Post11-08-2014 02:17 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very clean! That's the way it should be, nice work.
LorenBateman
Report this Post11-08-2014 05:50 PM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed oil,, tightened transmission pan bolts
Fierotom86
Report this Post11-08-2014 09:37 PM Click Here to See the Profile for Fierotom86Send a Private Message to Fierotom86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I went to work today and there was another red Fiero in the parking lot!!! And it belonged to another employee!! What are the chances that employees at the same store drive the same kind of car!! Mine is an 86 SE, the other fellows is an 88 Formula. Mine is in much better shape!! Note the license plate on the Formula!!
Tom StJohn
86 Red SE
RJS525
Report this Post11-09-2014 12:21 AM Click Here to See the Profile for RJS525Click Here to visit RJS525's HomePageSend a Private Message to RJS525Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my updated radio/CD/MP3 player and then took it for a drive to listen to some tunes.
turbo86se
Report this Post11-09-2014 10:03 AM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wasn't today but the other day I went out to a local u-pull it and grabbed a real nice passenger seat, strut top-hats, and a cradle bolt. I know, nothing too exciting.
jediperk
Report this Post11-09-2014 01:50 PM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took mine to the Airborne and Special Operations Museum. In case you are wondering, that's Iron Mike in the back ground
[This message has been edited by jediperk (edited 11-09-2014).]
Charlie64
Report this Post11-11-2014 09:10 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaned her up and took her for a spin...let her stretch her legs a little
JCircs
Report this Post11-12-2014 05:05 AM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I painted my new Gen V blower.
