  What Did You Do To Your Fiero...TODAY ? (Page 155)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223305 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
BrittB
Report this Post03-21-2015 06:43 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had to buy a new battery and decided to do something about the old battery tray. I had a marine style battery box that I bought for another project and never used so I measured up 3" from the bottom and cut off the upper part of it leaving a nice tray. I cut a couple slots for the strap in the floor and bolted in the tray to the chassis and it worked out great, good to go!
Charlie64
Report this Post03-21-2015 09:27 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got to take it out after it's long winter nap
Neils88
Total ratings: 56
Report this Post03-21-2015 10:42 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Prepped to pull the engine tomorrow. Everything is ready now, just have to hoist the back end and roll her out. The big day has come....cutting the car in half tomorrow for a 11.85" stretch! Wahoooo!!!!!
88cryan
Report this Post03-22-2015 09:57 AM Click Here to See the Profile for 88cryanSend a Private Message to 88cryanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by maybenot:
can you explain this cheating method of dew wipe replacement? have to do mine this spring and have been looking at a lot of methods.
Thanks
(This is on power windows, I don't know if this is the same on manual windows)
Normally you have to drill the big rivets out of the window glass and remove the glass to gain access to the two phillips screws that are blocked by the window, this method you mark and remove the "window stops" which are an L shaped bracket that stop the window from rolling up to far. You then carefully roll then window up pretty much till it stops and you will have gained access to the middle screw under the window glass, after removal you grab the window and move it carfully toward the back of the car and that gives you access to the other screw.
BrittB
Report this Post03-22-2015 01:33 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's one hell of a stretch!
steve308
Total ratings: 58
Report this Post03-22-2015 04:25 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Saturday attended the season opening C&C of a local 'Motorsports' dealership. Parked my 308 replica two cars away from a Ferrari 360 --- He was not pleased.
dobey
Total ratings: 371
Report this Post03-22-2015 05:33 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the headlights and doors out (to make room for the future HID projectors using doublec4's kit). Also drained the radiator and removed the fan/shroud, and started pulling the headlight harness and bits out.
Anyone know what a complete working Gen 2 headlight setup is worth (both lamps, motors, brackets, plastic shrouds, module, relay, and harness)? Also have two pretty much perfect headlight doors and brackets; just a few surface nicks in the paint on top, but would need to be prepped and painted to match any car (or just install as-is on a med red metallic car).
Danyel
Total ratings: 169
Report this Post03-22-2015 07:17 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mostly the harness, motors and module are sought after items... I sold that set up a little while back for 150$
Danyel
solotwo
Total ratings: 62
Report this Post03-24-2015 10:16 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil change and some minor maintenance.
FieroTony
Report this Post03-25-2015 03:42 PM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heater core finally went. Been smelling a faint antifreeze for a while. No more smell and no more fogged glass. That was about 2 weeks ago. T-stat went up Monday. Froze closed. Can't wait to see what next week brings.
tshark
Report this Post03-28-2015 01:29 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the seals on my air cleaner housing.
BrittB
Report this Post03-28-2015 02:38 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Speedo quit working, going to have to start searching out that problem as well as the distributor O ring that failed. I'm not pleased that it needs replacing even though it's a brand new distributor!
RACE
Total ratings: 157
Report this Post03-28-2015 04:24 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Couple of days late posting but figured out why my car was wobbling from 30-50 mph under power. Drivers right rear inner wheel bearing was completely blown out. Zero bearings. New bearing assembly and driveshaft and it's perfect again
jonrev
Report this Post03-29-2015 12:15 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Painted brake dust shields. Cooling line clamps arrived yesterday and will go in tonight. Old ones are practically nonexistent.
mafv8
Report this Post03-29-2015 04:31 PM Click Here to See the Profile for mafv8Send a Private Message to mafv8Edit/Delete MessageReply w/QuoteDirect Link to This Post
changed my headlight motors over to the gen 2 system, as the old motors were getting very touchy, new system works so much better, quieter as well, I did not swap the harness over but rewired the module and motors into the current harness per Dodgerunners post from 2007
solotwo
Total ratings: 62
Report this Post03-30-2015 09:39 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the summer tires & wheels on, lubed the front end. Stored the winter tires
turbo86se
Report this Post03-31-2015 03:30 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yanked out the stained greasy nasty rear "trunk" carpet. Little bit of rust on the bottom. How much is too much?
tshark
Report this Post03-31-2015 04:02 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Too much for what? If I see it, it's too much for me.
jonrev
Report this Post04-02-2015 01:37 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picked up front hubs from Rodney, pulled the old ones off with a hammer claw and BFH then put the new ones on finger-tight, for now. Pending ebay sales will determine how soon I can resume/finish brake job.
jonrev
Report this Post04-03-2015 04:16 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced cooling line clamps... or at least what was left of them. Trans cooling lines aren't yet leaking but are definitely on the list for next year.
D/S:
P/S:
css9450
Total ratings: 86
Report this Post04-03-2015 07:48 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL I had to take my steering knuckles off the car and take them to the shop to have the hubs pressed out. Rears of course were no problem.
Are you doing parking brake cables too? I'm going to tackle that chore next.
jonrev
Report this Post04-03-2015 03:19 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably; I think mine just needs to be adjusted, though. The cables at the calipers don't feel loose/broken when I tug at them but I'm also not entirely sure what I'm looking for.
LornesGT
Report this Post04-03-2015 09:13 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
D/S:
Where did you find them? Are they new?
dobey
Total ratings: 371
Report this Post04-03-2015 09:20 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut the radiator hoses up front with a hacksaw, so I could pull the radiator out in preparation for the new one to go in. Will be replacing the hoses with new high quality hoses anyway, and just wanted to get it out. I probably need to fix or replace the coolant tubes as well, but haven't gotten down to them yet. Need to get the A/C condenser and all the A/C lines up front out now.
jonrev
Report this Post04-04-2015 12:24 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brand new from Fiero Store.
dobey
Total ratings: 371
Report this Post04-04-2015 06:16 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled a bunch more stuff out of the engine bay area. Slowly getting to the point where I can pull the cradle out and start making the necessary changes to fit the LS4/F40 combo.
BrittB
Report this Post04-04-2015 10:29 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since the original covering was trashed I recovered the bulkhead panel using a shade darker headliner material. I went a shade darker because that's all I could find locally!
tom10122
Report this Post04-05-2015 12:43 PM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
One of the t 50 torx on my water pump loosen enough to start leaking, had to tighten that, fun.
tshark
Report this Post04-07-2015 02:53 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Fiero went under the knife. More specifically, the knife went into my car. No more mess of wires.
turbo86se
Report this Post04-08-2015 09:20 AM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed gas charcoal canister and firewall tubes (will relocate) gave the frame shock towers a good cleaning and a nice coat of rust-proofing paint. Looking good! Now I need to figure out how to get the welded-in stock battery tray and bracket outta there. That should be next.
solotwo
Total ratings: 62
Report this Post04-08-2015 10:23 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had the summer wheels/tires balanced. Made a difference.
jediperk
Report this Post04-11-2015 04:12 PM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
A good washing and waxing... Spent some time with the 1000 grit wet sanding the scratches in driver and passenger side windows. Making progress but a long way to go I'm afraid...
css9450
Total ratings: 86
Report this Post04-11-2015 05:47 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my TXGOOD cupholder/armrest today. Looks great!
[/QUOTE]
tshark
Report this Post04-11-2015 06:52 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed cabin air filters.
87GT2M6
Report this Post04-12-2015 12:20 AM Click Here to See the Profile for 87GT2M6Send a Private Message to 87GT2M6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Wow, was thinking the same thing when I read the post.
pcgold
Report this Post04-12-2015 11:34 AM Click Here to See the Profile for pcgoldSend a Private Message to pcgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove her. Picked her up from storage and let the boy drive her the 20 miles back home. Gonna change the oil today and give her a wash.
spcearle
Report this Post04-12-2015 01:56 PM Click Here to See the Profile for spcearleSend a Private Message to spcearleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced shocks and struts after a 2 day ordeal of tracking down new spring top hats for the rear because the bad struts were hitting so bad that the springs mangled the old tired seats....now to just wait a cpl months and hopefully I can exchange the old ones for new set and recoupe a lil funds
Detainabull
Report this Post04-12-2015 08:48 PM Click Here to See the Profile for DetainabullSend a Private Message to DetainabullEdit/Delete MessageReply w/QuoteDirect Link to This Post
I gave the car a good wash...got all the pollen off. Then covered her up
jonrev
Report this Post04-13-2015 08:31 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally pulled rear calipers off once I figured out how to disconnect the p-brake cable. Found torn piston boot on the passenger side so I know at least one was probably on its way out. Ordering replacements for all four tomorrow, along with pads/rotors so I can finally finish this.
[This message has been edited by jonrev (edited 04-13-2015).]
lorennerol
Report this Post04-13-2015 09:02 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went to visit my Fiero in the body/paint shop today.
Almost time to start putting it back together
[This message has been edited by lorennerol (edited 04-13-2015).]
