  What Did You Do To Your Fiero...TODAY ? (Page 156)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7010 (223177 views)
Last post by: Newbfiero on 12-06-2025 10:12 PM
batousai666
Report this Post04-19-2015 05:47 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
broke them out of storage and took the Black V8 for a spin!!
solotwo
Total ratings: 62
Report this Post04-19-2015 07:55 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed drivers side rear coolant tube bracket.
jaybug56
Report this Post04-19-2015 11:53 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got a couple of motors ready to install
pontiackid86
Total ratings: 344
Report this Post04-20-2015 12:23 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
thought about them.. how one is 1500 miles away from me and how another is 1800 miles away from me lol
jonrev
Report this Post04-20-2015 06:56 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got my calipers and pads; ready for re-assembly, possibly driving it this week I hope.
johnyrottin
Total ratings: 85
Report this Post04-21-2015 09:41 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dreamed about it mine, 7362 miles from me now. Sigh...
Tuna Helper
Report this Post04-22-2015 10:28 PM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped the cradle to change some clutch parts, found that the clutch fork was bent and the release lever has cracks in it. New parts installed, along with a new throwout bearing, and was getting stuff hooked back up when I had to stop for the day. Back on it tomorrow. If this doesn't fix my clutch, then I don't know what will. So far I've replaced the master, slave, clutch pedal, throwout bearing, release arm, clutch fork, pressure plate, friction disk, had the flywheel resurfaced...
seq
Report this Post04-23-2015 11:17 PM Click Here to See the Profile for seqSend a Private Message to seqEdit/Delete MessageReply w/QuoteDirect Link to This Post
I brushed it off, and had the scariest drive to work I've ever experienced.
The weather was better last weekend
Seq
1987 Fiero GT : Information | Gallery
jonrev
Report this Post04-25-2015 06:01 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tightened all connections for brake plumbing; routed flex hoses and secured, carefully raising and lowering wheels with a jack to riding position to confirm we won't have any pulls, rubs or binds. Lost R-R bracket for hose-to-line connection but was able to find one at a yard (for one of the fronts but close-enough). Also cut new wheel well splash guards out of a rubber carpet I salvaged from work; sprayed edges and back with black plasti-dip to prevent fraying. Bleeding and adjusting rears tomorrow, and then testing next week so-long as we have no leaks.
Also pulled interior b-pillar panels from the yard car; my rear speaker covers rattle (tried to pry them off LONG ago in an idiot-move) so once these are cleaned-up they will go in sometime.
jonrev
Report this Post04-26-2015 05:50 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bled and installed master, started pumping fluid through system. Found and tightened a leak at rear proportioning valve and that should be it. Tried to bleed calipers but I can't get the el-cheapo vacuum pump to hold vacuum due to crappy attachments. Had to get a piece of clear tubing because the one that came with it was black and the clear one's a smidge too big, I think.
solotwo
Total ratings: 62
Report this Post04-26-2015 09:10 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed new shocks and forgot to take a pic, so I took one after.
Repaired hole in seat.
lorennerol
Report this Post04-26-2015 09:43 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Masking, sanding, sanding, sanding, sanding (80 to 2000 grit), polishing/buffing. Drink beer.
Masking because I feared my clumsiness.
Powder coat sanded off two of the valve covers.
All six pieces complete.
Close up of complete intakes. Well, at least as complete as I'm making them
This was my first time trying to polish aluminum. It didn't turn out quite how I imagined (a perfect mirror), but I'm happy. The intakes were much more difficult- there was substantially more little pits and voids...almost like they were cast from a different grade of aluminum. I'd give myself about a 6.5/10 on this.
I used a random orbital sander with grits from 80-2000. I initially tried to use 220 to take off the powder coat, but that was just a waste of time and sanding discs. Mother's polish and a disc buffing wheel on a drill to finish up. Rubbed out with microfiber towels. About 3.5 hours, all-in.
danielsjc20
Report this Post04-27-2015 08:38 PM Click Here to See the Profile for danielsjc20Send a Private Message to danielsjc20Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped the stock exhaust and removed the starter
Quad GT
Report this Post04-27-2015 08:49 PM Click Here to See the Profile for Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got the DGP IMSA over the border and she is tucked nicely in her new garage
Pictures to follow soon
jonrev
Report this Post04-30-2015 05:49 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally put it on the ground and got to drive it hard tonight to test the brakes. Drove it hard around some corners and hit the brakes hard a bunch of times: quiet, no pulling, no vibrations, locks the seatbelts up (first time it's done so in the 8 years I've owned it) and it stops a hell of alot quicker than before. Damn I missed that car!
The bad news is that I probably have a bad MC out of the box because there is brake fluid slowly seeping out of the rear reservoir gasket; and at F-L I found a rub spot for the hose against the A-arm but I've already corrected it. Beyond swapping the MC again I'll just be monitoring everything as I move into the next project: oil leak.
[This message has been edited by jonrev (edited 04-30-2015).]
FieroTony
Report this Post04-30-2015 09:05 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
New tires on the rear. P215/70R 14. Speedo off by about 1mph at 60mph, (GPS). Have to replace all the front control arm bushings. Got the parts, just need the time. Then new front tires and alignment.
New plugs & wires.
solotwo
Total ratings: 62
Report this Post04-30-2015 10:20 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
installed a basic cold air tube to blow air into engine compartment to cool it off.
jonrev
Report this Post05-01-2015 05:52 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the front compartment back together and gave the car a good spitshine. First cruise of the year tomorrow!
TheDigitalAlchemist
Total ratings: 94
Report this Post05-02-2015 09:14 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put in a new battery and took it for a spin.
NightMare Cruiser
Report this Post05-03-2015 09:55 AM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Install almost mint '88 grey seats in my '87 notchback. Looks great!!
jonrev
Report this Post05-05-2015 12:43 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Switched-out interior B-pillar panels; doubled-up the insulation by stripping it from the old ones so they won't rattle so much.
solotwo
Total ratings: 62
Report this Post05-05-2015 10:28 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced a Leaking Thermostat housing cap. White smoke just a rolling out of the engine vents. Got if off of 28th ST waited for it cool down and drove to NAPA that was real close by.
Every Day is a new adventure when driving a Fiero!
[This message has been edited by solotwo (edited 05-05-2015).]
lorennerol
Report this Post05-05-2015 11:07 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Listened to my daughter tell me about the odd behavior and sounds it was making. Got home to take a look and noticed a perfect line of leaked fluid down our 100+ foot driveway. Started it, pulled it out of the garage, and looked underneath to see fluid running out of it (not dripping). Rolled it away from the large puddle to observe that it was red and oily. Barely made it to the tranny shop as the transmission was starting to slip. They called in the afternoon to tell me it was just a worn-through cooling tube. $200 is much better than a tranny rebuild. Now I have some cleanup work to do on the underside of the car.
Kune
Report this Post05-06-2015 02:53 AM Click Here to See the Profile for KuneClick Here to visit Kune's HomePageSend a Private Message to KuneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made some new doorpanels för my 88
My thread on the swedish Fiero forum
notwohorns
Report this Post05-06-2015 08:39 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Kune:
Too bad I couldn't read the words but the pictures are good. I like your interior and your dash is cool. Good work
Navyfierodriver81
Report this Post05-06-2015 10:02 PM Click Here to See the Profile for Navyfierodriver81Send a Private Message to Navyfierodriver81Edit/Delete MessageReply w/QuoteDirect Link to This Post
Getting close to being done.
[This message has been edited by Navyfierodriver81 (edited 05-06-2015).]
solotwo
Total ratings: 62
Report this Post05-07-2015 08:04 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
New tires to replace the bad ones that came with the car. Dropped the rear diameter by an inch and front just a little, now the car is just about level taking some stress off of the front. Now the tires don't rub and man does it ride better.
no2pencil
Report this Post05-08-2015 07:43 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the dirty throttle body with one that I polished up over the winter :
[This message has been edited by no2pencil (edited 05-08-2015).]
tshark
Total ratings: 68
Report this Post05-08-2015 11:41 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is that thing that looks like a scratch on the left fender? Why are there so many broken LF side markers?
lorennerol
Report this Post05-08-2015 11:47 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like a street light reflection to me.
Mine was busted on the right. Wifey cut too hard coming out of the garage in 1993 and knocked a chunk of molding off and a complete whole in the fender.
Oh, to be on-topic, today I picked up the refurbed snowflake wheels and took them to Costco to get the tires swapped onto them. Costco condemned my tires (9 years old but less than 15k miles) and they didn't have set to sell me, so off to a very friendly Les Schwab store. $40 swap turned into $600 in tires. Owie, but progress. Will post some pics when I get the new center caps next week.
JCircs
Report this Post05-09-2015 07:36 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed my new Infinitewill trunk seal and my Russ88TTop trunk cover.
jediperk
Report this Post05-11-2015 10:30 PM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I swapped out the shocks and gave the ball joints some grease while I was in the neighborhood. Then I took her for a drive to enjoy the fruits of a labor of love...
no2pencil
Report this Post05-13-2015 08:03 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Timed it. Hopefully got the threads to the throttle tight enough to not leak.
jonrev
Report this Post05-14-2015 06:43 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced brake master again, waiting for neighbor to come over and help bleed system again.
solotwo
Total ratings: 62
Report this Post05-14-2015 08:41 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is that mesh in the engine cover above the supercharger? Looks like something I need to do.
FieroFastBackL67
Report this Post05-14-2015 09:58 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bought an L67 for my 87 gt with 88 cradle.
GTGeff
Report this Post05-15-2015 06:01 PM Click Here to See the Profile for GTGeffSend a Private Message to GTGeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my 65,000 mile 88 GT back from the shop.
Replaced heater core
Recharge A/C system
New rear struts
New rear wheel bearing
New front upper arm bushings
Full alignment
Replace fluids
Needs a new battery and then it is ready for the Dells!
Yeah!
Jeff
no2pencil
Report this Post05-15-2015 08:23 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaned the corrosion & re-soldered the connections on a replacement EGR Solenoid. Replaced with mine, which is a train wreck in comparison. Will thoroughly test tomorrow & do the same to this one.
css9450
Total ratings: 86
Report this Post05-16-2015 12:58 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I recovered a headliner board and finally installed it in the car today. I did this same project a year ago but used my old board which had a lot of cracks and peeling areas. I had tried to patch it with fiberglass mat and resin but unfortunately everywhere I fixed it was still visible through the new headliner fabric. In my naivety I'd assumed the new fabric would hide it all! Evidently not. Plus I wrinkled the fabric by making it too loose when I glued it into the head wells. So after a year of watching the junkyards I finally found a nicer headliner boards and I recovered it a couple weeks ago. This time I made sure the few repairs I did need to do were nice and smooth! Looks much better.
Orig88GT-NC
Report this Post05-16-2015 07:13 PM Click Here to See the Profile for Orig88GT-NCSend a Private Message to Orig88GT-NCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Test fitted / Installed an Audi TT Fuel Filler door, used the Fiero's OEM door release lever and cable....
