  What Did You Do To Your Fiero...TODAY ? (Page 160)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7010 (223186 views)
Last post by: Newbfiero on 12-06-2025 10:12 PM
fierobug
Report this Post09-06-2015 05:45 AM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Washed and waxed it after completing grueling bushing replacement of the engine and cradle plus oil pan seal. Happy is not the word. &&&&&& real happy is! Thanks everybody.
FIEROBUG!!!!!!!!!!
Old Lar
Total ratings: 214
Report this Post09-15-2015 03:39 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was using some detail spray and dropped the plastic spray bottle which split apart, dumping all the liquid on the floor. So I just wiped the car down and drove over to get some gas something that hadn't been done six months. I'm getting the car ready for my trip to Helen, GA.
mrfiero
Total ratings: 150
Report this Post09-16-2015 04:34 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just removed the old, crappy tint from both side windows......much better! I still need to do the rear window, but that'll have to wait until I remove the headliner so I have more room to work with. It needs to be redone anyway, so it just makes sense to go ahead and get it out of the way.
That'll be my project for tomorrow.
LorenBateman
Report this Post09-18-2015 02:15 AM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took a chisel to her!! well an oil pan bolt haha
adatr
Report this Post09-22-2015 01:46 PM Click Here to See the Profile for adatrSend a Private Message to adatrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I checked the battery to make sure I have the amp draw problem fixed..... We're good!!!
turbo86se
Report this Post09-23-2015 05:53 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got some work done on her for the first time in well over a month.
1. Removed the positive battery cable
2. Removed the negative battery cable, (now that was a pita)
3. Removed the starter.
Have new battery cables and will move to the front of the car same time gas tank is out to replace the dead fuel pump. The starter is good (I think), but I'll upgrade it from a newer used 3800.
Time for an Octoberfest.
TopNotch
Total ratings: 60
Report this Post09-23-2015 06:27 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just missed one.
jonrev
Report this Post09-24-2015 05:01 AM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made exhaust leak better than it was - replaced trashed donut gasket where Y and downpipe join but can still feel a peep of hot air coming out. May need to get on it with an impact - it's as tight as I can get it by-hand.
Tomorrow I'll deal with the leaking EGR hose and shot EGR valve - already got the hose from Rodney, I'll get the valve from a yard.
[jonrevProjects] | HAVE YOU SEEN ME?
Fiero Vampire
Report this Post09-24-2015 12:44 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
After experiencing the master clutch cylinder fail at a stop light on my daily driver, which was a little scary when all of a sudden the car lunges forward and stalled out. I replaced it using the one off my project car and ordered a replacement aluminium one from Rodney along with a 3rd brake light plate (couldn't resist). Note someone in the past had installed the bango upside down which appears to have caused wear and the earlier failure of the seals.
cmechmann
Report this Post09-25-2015 09:37 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rebuilt the nose/snout of the M90 and replaced lower Ball joints this past weekend. Wrapped up most of the swap harness 2 weeks ago.
Lubed the front end up and went for a cruise. Still need to replace the belt tensioner pulley(noisey). The wife had no idea I peeked over 100 mph getting on I83 in town. She just said " yeah I heard the vacuum cleaner, stop burning up your fuel". I'm getting very close to long distance reliability.
I'm getting 25mpg mixed and that was with crappy sp wires. They go tomorrow.
FieroMaster88
Total ratings: 168
Report this Post09-25-2015 09:55 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Peeked at the 88 under its cover and dreamed about working on the Indy. That's about all I do anymore these days...
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo, water/meth injection
84 Indy #64: Restoration Project
01 BMW 525i: daily driver
Silvertown
Report this Post09-27-2015 02:13 AM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove my 88gt up and down the las vegas strip. Think I broke a koni shock on a speed bump somewhere. Installed a jvc . And a Corvette zo6 blew my doors off. When lambo's started coming out around 10 I left.
ltlfrari
Total ratings: 127
Report this Post09-27-2015 08:15 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installing a backup camera so building a new center console front part to accommodate the screen.
Dave
www.ltlfrari.com
Danyel
Total ratings: 169
Report this Post09-27-2015 08:41 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaned and waxed her..... took a Sunday cruise ..... beautiful sunny day too ....
Fiero Vampire
Report this Post09-28-2015 12:40 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel, that is one beautiful car!
After trying not to, I ended up installing the rear coilovers for my project car onto my daily driver, so now I need to buy another set for the project car.
Silvertown
Report this Post09-28-2015 01:48 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getting the windows tinted and headliner and visors recovered.
87RedRum
Report this Post10-01-2015 10:47 AM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now that I got my car running (previous chat ICM issue), I was able to fix a few smaller issues today:
Replaced turn signal/wiper switch
Changed all lights interior and exterior to LED bulbs (Flasher and resistors too)
Replaced both door locks and buttons, and got power DL to lock & unlock with 1 touch
Got all the factory speakers replaced with new ones
got my trip-ometer working
Replaced the PVC valves & gaskets
Added a button on the dash for a horn
Tomorrow I just need to do a good scrub on the interior and wax the exterior; then time to install the new shock, struts, springs, brakes, rotors and bearings this weekend!
jim94
Report this Post10-15-2015 11:52 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rear sway bar removed and repainted. Bushings cleaned and lubed. My bar faces toward the rear and was rubbing on the center so I made spacers for under the bushings. Time to go for a ride tomorrow. It took me 2 days to do that, I don't move to fast because most of it was watching paint dry with a hair dryer. Next week the front bushings
Steel
Report this Post10-16-2015 06:03 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced my front wheel bearings on my '88.. got it aligned. Going for a dyno tune tonight.
pcgold
Report this Post10-25-2015 01:28 PM Click Here to See the Profile for pcgoldSend a Private Message to pcgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put her away for the winter
solotwo
Total ratings: 62
Report this Post10-25-2015 06:26 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced passenger side lower ball joint. Here is the start. Strange to see two nuts on the ball joint.
No lock ring
No need to remove caliper or shock.
Its out and hole is clean and ready for new frozen ball joint. This is the old ball joint. The new one was still in the freezer.
New ball joint is in and unfrozen by this time. Tools used to get it in.
One problem down. Now onto the next ones. LOL
[This message has been edited by solotwo (edited 10-28-2015).]
fierojunky
Report this Post10-26-2015 10:51 AM Click Here to See the Profile for fierojunkySend a Private Message to fierojunkyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Moved it. First time I sat in the car in years. Moved it from storage to a friends garage while I contemplate my next move.
Formulator8800
Report this Post10-26-2015 09:47 PM Click Here to See the Profile for Formulator8800Send a Private Message to Formulator8800Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stared at it and dreamed about a new paint job... and made my first post!
BrittB
Report this Post10-26-2015 10:24 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Starting last Friday I decided to just go driving it after it sat for a while. I always keep it ready to roll so it was a jump in and go sort of deal, damn that car is fun to drive!
tesmith66
Total ratings: 135
Report this Post10-27-2015 11:28 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Been thrashing on mine to get it on the road before my truck completely dies (those familiar with 6.0 Powerstroke head gaskets know what I'm talking about ).
Got my CO2 / Argon bottle filled yesterday so I can weld up a new and hopefully quieter exhaust, am in the middle of a LeBaron brake swap (waiting on parts), have half of the interior parts cleaned and ready to go back in, and am trying to get some stuff painted, but fall weather is moving in fast. Planning to work on the exhaust today after I get home, or clean some more interior parts, or finish wiring up the speakers, or put the rest of the sound deadener in, or...
Then, as soon as I get the Fiero done, I have to fix the truck before it gets too cold to work. If I only had time to insulate my barn
1986 SE Aero coupe.
Jason88Notchie
Report this Post10-27-2015 11:45 AM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I kinda wish I could. My daughter has been driving my Fusion for work and school. My Formula has been my daily driver since May. She's getting a car in December, so that is when I can put mine up. If we start getting some early snow I'm going to be spending some serious coin on undercarriage car washes. I just ordered some BF Goodrich T/A's with RWL sidewalls. I loved the look when my other 88 had the RWL Goodyear Eagle GT's when it was new. However the T/A's are a much better tire.
solotwo
Total ratings: 62
Report this Post10-28-2015 10:36 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Packed the front wheel bearings and adjusted the tire pressure down.
turbo86se
Report this Post10-29-2015 04:50 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent a little time with a hand pump draining the foul old gas from the tank. Still about a gallon down there. Guess I can get to that when the sending unit is out? Removed the rusted lower radiator bracket/support too. That was bad. Now I need to find a replacement. Eh, also removed the windshield washer reservoir, coolant reservoir, and bracket for the jack. Washed the Civic too.
Horse
Report this Post10-29-2015 05:30 PM Click Here to See the Profile for HorseSend a Private Message to HorseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed a shift knob.
fierobug
Report this Post10-29-2015 06:28 PM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it inspected today. Valvoline guys really enjoyed getting it done. Have 1 month left to drive unless it snows.
FIEROBUG!!!!!!!!!!
LorenBateman
Report this Post10-30-2015 02:07 AM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Piston rings and a oil pan gasket, Starter back in , engine back in the front engine mount
tesmith66
Total ratings: 135
Report this Post10-30-2015 05:38 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Headed out in a bit to finish the exhaust and brake swap, then triple check the alignment and start on the interior. Wish it wasn't 34 degrees out
Formulator8800
Report this Post10-30-2015 07:14 AM Click Here to See the Profile for Formulator8800Send a Private Message to Formulator8800Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took it out for a cruise this morning.
Fie Ro
Total ratings: 132
Report this Post10-30-2015 04:05 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got it home after 5 years in storage
https://www.fiero.nl/forum/F.../HTML/000095-18.html
Xexyz
Report this Post10-31-2015 10:00 AM Click Here to See the Profile for XexyzSend a Private Message to XexyzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looked wistfully at my 85 GT because I don't know if I'm going to have it much longer. I bought it in 1995 and it has always been somewhat of a project car (mostly because the guy I bought it from beat the hell out of it) but I could never really devote the time and money to fix all the little issues with it. It's been sitting in my garage for the last 5 years, but now that I do have the time and money to fix it up I just don't have the motivation. So my thoughts are to pass it along to someone who will appreciate it, but I'm not sure how much it's worth or if I'd be better off parting it out.
Detainabull
Report this Post10-31-2015 03:21 PM Click Here to See the Profile for DetainabullSend a Private Message to DetainabullEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the front fenders, rockers, bumper, and hood from my parts car and put them in storage for my fastback swap. Organized my mess and covered it all back up
LornesGT
Report this Post11-01-2015 11:16 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the drivers door hinge and roller pins, what a pain in the arse. I really thought I could do all that in about 4-5 hours but I doubled that. I really don't see how the lower door hinge bolts come out without removing the front quarter panel. I may have went about it the wrong way but I removed the door skin to remove the lower hinge bolts on the door first. I still need to do the passenger door .
FieroTony
Report this Post11-02-2015 09:15 AM Click Here to See the Profile for FieroTonySend a Private Message to FieroTonyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clutch time again -- well actually throw-out bearing. Started making that dreaded, "Let me out of here", dry bearing sound a few weeks ago.
While it's out, I'll be cleaning and painting her up as well as the engine bay. Replacing oil pan, timing cover and valve cover gaskets, rear and front main seals, axle seals, [cracked] exhaust manifold and rear tranny mounts.
1MohrFiero
Total ratings: 157
Report this Post12-14-2015 07:11 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed, cleaned, lubricated and reinstalled the passenger door latch. Now my power locks work again, first time-everytime.
FieroJuice
Report this Post12-14-2015 06:01 PM Click Here to See the Profile for FieroJuiceSend a Private Message to FieroJuiceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance you're still around and can explain how? Anyone else?
Originally posted by rbell2915:
I modified my radio to use MP3s, pretty simple to do, just frustrating at times. Well worth it though
