  What Did You Do To Your Fiero...TODAY ? (Page 162)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223204 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
exoticse
Total ratings: 106
Report this Post04-02-2016 10:38 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by nosaint:
Fired it up and moved it for spring!
https://www.youtube.com/watch?v=M_ma8Q6hALU
Nosaint your car is sick ! 👍
exoticse
Total ratings: 106
Report this Post04-02-2016 10:40 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
exoticse
Member since Jun 2003
Pulled her out and washed her off, only to find out afterward the front brake calipers had frozen up.
solotwo
Total ratings: 62
Report this Post04-02-2016 11:42 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by FieroMaster88:
Today I installed koni red struts on the rear, poly bushings on all suspension components, installed a larger throttle body, wrapped my exhaust and installed an expansion tank on my water to air intercooler setup. Very productive day!
Nice!
JCircs
Report this Post04-02-2016 04:42 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I started installation of this.
[This message has been edited by JCircs (edited 04-02-2016).]
LornesGT
Report this Post04-02-2016 10:39 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fix toe the rear was just a little out, no wonder ther PO put new tires on it before selling.
[This message has been edited by LornesGT (edited 04-02-2016).]
FastOwen2XLL
Report this Post04-03-2016 04:58 PM Click Here to See the Profile for FastOwen2XLLSend a Private Message to FastOwen2XLLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaned up 20 years of warehouse dirt off the DOHC crate motor! Mounted solid on a 2,000 lb. HF stand!
jim94
Report this Post04-05-2016 10:51 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped off the car at the mechanic to have the ac belt put on.
tshark
Report this Post04-09-2016 11:07 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced my trunk seal. The old one was OK, except for a worn spot. When I removed the old seal, I found lots of silicone on the driver's side half of the seal. It took a while to get that off. Not perfect, but off. The new seal took about 10 minutes to install. I didn't cut out the area around the latch. I was expecting the decklid to make a firmer close for a while. No such. The seal fits nice and even, with only one small ripple. The corners aren't quite square; the one on the left rear by the ripple won't go in further, and the one on the right rear just won't go further in. I had to cut and pry to get it in as it is. I'm pleased, so far, but will have to wait for wet to test over time.
The old deal was of an entirely different construction.
JohnWPB
Total ratings: 144
Report this Post04-09-2016 11:08 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bolted up some more stuff to the 3800 today, long way to go but getting there.
LINK TO THE BUILD THREAD
Total ratings: 463
Report this Post04-10-2016 01:20 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally finished rebuilding the headlight motors and replaced the right side mounting bracket / back hinge half. (Thanks, Fierofool!)
Painted the cowl, and cleaned and reinstalled the black cowl trim panel.
Unpacked the new shocks and struts, and inspected. (Last new pair of struts I bought, one of them was "flat". No gas pressure to speak of. These are fine.)
Next is to either replace the valve cover gasket and tighten the pan and timing cover bolts (It marks its spot like a Harley) or to start rebuilding the suspension.
(Have two boxes of poly, and the previously mentioned shocks and struts; and a 12" brake kit. All sitting in my shop. Also a pair of Rodney's lower ball joints.)
Total ratings: 463
Report this Post04-10-2016 01:22 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Oct 1999
Purdy!
You do nice work!
mrfiero
Total ratings: 150
Report this Post04-10-2016 01:55 AM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
It looks like someone found a WO2 coupe.....nice! What are your plans for it?
mrfiero
Total ratings: 150
Report this Post04-10-2016 02:09 AM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
mrfiero
Member since Mar 99
As for me.....I picked up a pair of T-Top Formulas today (long story....will have to post it later). One was sort of running and the other not running at all.....both sitting for more than a year. The sort of running one idled OK and ran fine until you get to the upper RPM range, where it coughs and sputters. I think it's a combination of bad gas and ignition issues. I didn't spend much time on it today.
I expected a lot of issues with the non-running one, since I had no clue why it stopped running. After hooking up a battery I cranked it over, but it wouldn't start. I could hear the fuel pump prime up and was getting good fuel pressure too. I checked for spark and was getting none. The coil and coil wire were corroded, so I swapped them out, but still nothing. I took off the distributor cap and had a look, but everything looked good. I was about to swap out the ICM when I noticed something curious.....the plug to the pick-up coil wasn't secured. I plugged it in and she fired right up! It ran rough though and then I remembered the "Superchips Power Chip" box in the trunk. Sure enough it had one installed. I swapped it out for the stock chip and she purrs like a kitten. I couldn't be happier!
So now I am back up to 3 Fieros (7 cars overall)....time for a bigger garage!
**EDIT to add that maybe the sort of running one also has a Super Chip installed. I really have no idea why they even sell those things anymore.....all they do is screw up the timing. Anyway.....off to Phoenix for the week, so I'll have to play with it next weekend.
A couple of pictures.....the one with the chrome wheels is the "sort of running one".
[This message has been edited by mrfiero (edited 04-10-2016).]
exoticse
Total ratings: 106
Report this Post04-10-2016 03:01 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
John every project you do is amazing ! Great attention to detail. 🏆
Total ratings: 463
Report this Post04-10-2016 01:11 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats on the twin Formulas! Sounds like you found some pearls.
The body will remain mostly stock. Haven't made up my mind on the rockers, but the white rear fascia extension has probably got to go.
The suspension will receive a full poly rebuild with new Sensatracs on all 4 corners. (It handles pretty much like a steamship, now. The contrast between this and my "worked" Formula was stunning. And a little frightening. Tammy followed me home and said it looked like it was wagging its tail.)
Have a set of Borbet wheels in the back room, that will go on it. They're the ones that were on my red coupe.
At some point, the Duke and Isuzu will probably get replaced. Aside from not really having the room to do a swap just now, I hate to mess with them, because it's the quietest Duke I've ever heard, and the Isuzu shifts like butter. Just leaks oil worse than my old Triumph Bonneville motorcycle.
The replacement engine will be an LFX (3.6 DOHC DI V6) and a Beretta Getrag - or maybe an F23. If that doesn't work out, I'll probably do an LZ9 pushrod V6.
Oh yeah... the fuel pump sounds like a Cessna.
[This message has been edited by Raydar (edited 04-10-2016).]
mrfiero
Total ratings: 150
Report this Post04-10-2016 06:22 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks....it's been a long time since I've owned a T-Top Formula. I told myself I'd never own another one and here I am with two. There is a story behind these though....when I get the time to write it up right I will start a new post explaining the situation. It's a sad story and the truth be told, I would rather not own these cars, but all things considered I am glad I could "save " them from an unknown fate.
I've had a few Fieros that wagged their tail.....not a pleasant experience!
I really like the painted rockers, but I can see where there's a little too much white happening there on the rear end. I'm still an engine swap noobie......I'm planning an LQ1 swap soon on my '88 GT. I really like the sounds of the LFX though. Good luck with it!
Tom Slick
Report this Post04-10-2016 09:34 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plasti-dip my newest GT, it ain't easy being green...
FieroMaster88
Total ratings: 168
Report this Post04-10-2016 09:46 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I like it!
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo, water/meth injection
84 Indy #64: Restoration Project
01 BMW 525i: daily driver
fireboss
Total ratings: 58
Report this Post04-11-2016 04:23 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by fireboss (edited 04-11-2016).]
Jfrost
Report this Post04-13-2016 04:36 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dipped the lower trim to match the rest of the car. Left a few parts black as an accent. Also adjusted the upper control arm shims for more positive caster, car feels completely different and more confident.
Project L67 Fiero
Marcopolo
Report this Post04-13-2016 06:00 PM Click Here to See the Profile for MarcopoloClick Here to visit Marcopolo's HomePageSend a Private Message to MarcopoloEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished my interior with new A Pillars and LED lighting!
Marco
FieroMaster88
Total ratings: 168
Report this Post04-14-2016 10:26 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my new rear bumper emblem.
SSN669chris
Report this Post04-19-2016 04:37 PM Click Here to See the Profile for SSN669chrisSend a Private Message to SSN669chrisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Old wiring
New wiring
going to to a stainless line for the brake booster and re-paint the engine.
Spiders1
Report this Post04-19-2016 05:09 PM Click Here to See the Profile for Spiders1Send a Private Message to Spiders1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Running the 93 octane out so I can put in GT 100 and check for the knock.
Replace the door lock actuator and door panel.
Richjk21
Report this Post04-19-2016 06:11 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got my state inspection knocked out for another year, topped up the tank and took it for a little cruise!!
CavScout
Report this Post04-19-2016 08:49 PM Click Here to See the Profile for CavScoutSend a Private Message to CavScoutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice! Great afternoon for it.
I got my alternator belt replaced. Seems to have stopped the squeaking at low RPM and eliminated the crazy charging issues. Time will tell.
rice.1
Report this Post04-19-2016 10:05 PM Click Here to See the Profile for rice.1Send a Private Message to rice.1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished my d@m-!! alternator replacement! Holy mother! Don't wish that job on anyone!
But my battery came back to life, so I guess it's all good
FieroMontreal
Report this Post04-19-2016 10:08 PM Click Here to See the Profile for FieroMontrealSend a Private Message to FieroMontrealEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where did you get it? I need one!
FieroMaster88
Total ratings: 168
Report this Post04-19-2016 10:38 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Found it on EBay! I've needed one for a while and jumped when I found it.
Fiero 88
Report this Post04-24-2016 09:26 AM Click Here to See the Profile for Fiero 88Send a Private Message to Fiero 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Washed it for the first time after buying it last weekend.
Paint is still reasonable looking at 10-15' for being 30 years old and having 135k on the clock.
Supracoupe
Report this Post04-24-2016 10:50 AM Click Here to See the Profile for SupracoupeSend a Private Message to SupracoupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took it for a drive to test out the new steering rack and stopped at a Sonic. It was closed.
mrfiero
Total ratings: 150
Report this Post04-24-2016 04:25 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drove a T-Top Fiero for the first time in 12 years. It was just around the block, but I had the windows down and the T-Tops off.....I had forgotten how much fun they are with the roof off. It still needs tires, brakes, shocks & struts and an alignment, but she runs great!
JCircs
Report this Post04-24-2016 09:00 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed a new 4" aluminum intake.
[This message has been edited by JCircs (edited 04-25-2016).]
solotwo
Total ratings: 62
Report this Post04-24-2016 10:01 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like you set up. I see you have a screen attached to the engine cover,. What does your vent look like. I need one to get rid of the heat.
LornesGT
Report this Post04-24-2016 11:59 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks good, what is the chin spoiler you have there?
JCircs
Report this Post04-25-2016 06:13 AM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Reverse Mustang scoop,
Supracoupe
Report this Post04-25-2016 03:59 PM Click Here to See the Profile for SupracoupeSend a Private Message to SupracoupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ebay
http://www.ebay.com/itm/400...e=STRK%3AMEBIDX%3AIT
Oregon88
Report this Post04-27-2016 07:49 PM Click Here to See the Profile for Oregon88Send a Private Message to Oregon88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks awesome man
What did you do with your hood there?
notwohorns
Report this Post04-27-2016 08:52 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today, I'm just waiting for the transmission shop to get done with my transmission so I can put it back in.
Supracoupe
Report this Post05-04-2016 12:10 AM Click Here to See the Profile for SupracoupeSend a Private Message to SupracoupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Oregon88:
Looks awesome man
Thats the hood vent sold by Embrace Racing. Double4C is a member here and has a thread on them (somewhere). It's made specifically for the Fiero to allow improved cooling through the radiator and follows the lines of the car. Pretty simple to install and a quality product.
[This message has been edited by Supracoupe (edited 05-04-2016).]
