  What Did You Do To Your Fiero...TODAY ? (Page 170)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7010 (223177 views)
Last post by: Newbfiero on 12-06-2025 10:12 PM
JMTUT
Report this Post09-25-2018 12:09 PM Click Here to See the Profile for JMTUTSend a Private Message to JMTUTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That looks great! Did you have to modify the fender hole for size?
rbell2915
Report this Post12-31-2019 10:29 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, been awhile since I've posted here! I left the Marines a few months ago and finally got home and I put LEDs in the dash and courtesy lights and I also upgraded the side markers with LEDs. I just installed a Bluetooth transmitter behind the radio and removed the antenna. I've been busy!
FieroMaster88
Total ratings: 168
Report this Post01-01-2020 12:57 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Getting the 3800 ready to go in and got the car in place to remove the cradle:
solotwo
Total ratings: 62
Report this Post01-01-2020 04:35 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Master 88 you are going to enjoy the 3800!
Tony Kania
Total ratings: 305
Report this Post01-02-2020 10:59 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
300 mile New Year head clearing run. 👌
MrDronenut 14
Report this Post01-20-2020 04:20 PM Click Here to See the Profile for MrDronenut 14Send a Private Message to MrDronenut 14Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just traded for a 1985 SE,with modifications to look like a GT,but when checking the vin,it's an SE.
Anyway, it wouldn't start when i got it. It would spin, but no fire. Then when i got it home,it wouldn't spin???!!!. I did all the required testing.,but no go. I was thinking ignition switch, so i went to the back,at the battery compartment, cut back some of the "pink"wire,and touched it to the battery, using a jumper cable. BINGO!!! Fired right up.
Here's the crazy part.........now it starts fine with the ignition switch. Crazy,huh?
Any thoughts?
MrDronenut 14
Report this Post01-20-2020 04:22 PM Click Here to See the Profile for MrDronenut 14Send a Private Message to MrDronenut 14Edit/Delete MessageReply w/QuoteDirect Link to This Post
MrDronenut 14
Member since Jan 2020
Any thoughts?
Vicophine
Report this Post01-21-2020 02:52 PM Click Here to See the Profile for VicophineSend a Private Message to VicophineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed the old "jute" insulation from the back of the Fiero interior in preparation for Dynamat and some nice speakers!
Awalker W02
Report this Post02-06-2020 08:44 PM Click Here to See the Profile for Awalker W02Send a Private Message to Awalker W02Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sooooooooo. This happened today.
Starting with a blank canvas now. so many ideas not sure where I want to go with this.
nosaint
Report this Post02-06-2020 09:13 PM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fine tuning the new nose
Notorio
Report this Post02-07-2020 12:13 AM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Working on the engine harness, dreaming of the day when I can drive my Fiero again ...
FieroMaster88
Total ratings: 168
Report this Post03-08-2020 05:44 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Washed the dust off the 88:
Later I’m going to work on the 3800 swap in my wide body Fiero:
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo, water/meth injection
84 Indy #64: Restoration Project
84 IMSA wide body SE: 3800 Swap in progress
Report this Post03-11-2020 11:22 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Recently: Removed old cracked up front header and replaced with cast stainless Tru Ram, replaced alternator with modified new alt, replaced alt lead wire with heavier gauge, customized and re routed coolant crossover pipe and hoses, ended up using two modified Mitsu Evo hoses, replaced leaking output shaft seal and tie rod boot. (The V8 car)
[This message has been edited by 2.5 (edited 03-11-2020).]
Old Lar
Total ratings: 214
Report this Post03-11-2020 12:56 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took my 87 to the shop yesterday to recharge the AC.. It was recharged, but they found a slow leak in the compressor, so I'll take it back next month and get another compressor.
Report this Post03-11-2020 01:55 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pic of more of the car?
nosaint
Report this Post03-11-2020 09:20 PM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats all i got at the moment, Car is getting a major overhaul. Took a lot of mods to make this front end work.
[This message has been edited by nosaint (edited 03-11-2020).]
exoticse
Total ratings: 106
Report this Post03-12-2020 03:26 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
NoSaint have always loved your car, can’t wait to see the new progress. Please keep posting ! What other mods you have in store?
nosaint
Report this Post03-12-2020 08:36 AM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
glad your still here!
im modding everything! new hood vent, rear vent, side skirts, side vents, interior, rear wing, tail lights,side mirrors, fender flares, exhaust tips...
the usual stuff
jonrev
Report this Post03-12-2020 10:33 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yanked front wheels + brakes, soaked suspension with PB Blaster. Rebuild time.
[This message has been edited by jonrev (edited 03-12-2020).]
Total ratings: 463
Report this Post03-16-2020 08:09 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had to jump off the Ghost, in order to move it out of the garage, so that we could get to the trash that needed to go to the dump.
Once I pulled it back in, I wired up a battery tender pigtail, and plugged that sucker in. We'll see if it charges and holds.
FieroMaster88
Total ratings: 168
Report this Post03-19-2020 10:44 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove the 88 over the weekend!
Here’s a short video.
Frenchrafe
Report this Post03-20-2020 03:24 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unplugged the battery and put the car cover over the Fiero. Shut the garage.
Won't be using the car for at least 1 month while the restrictions are in force for the Coronovirus!
No cars circulating except for essentiel trips. And absolutly no car meets (or any other type of gathering) untill further notice here in France.
Stay safe and stay healthy.
Best regards,
Rafe
'87 Fiero GT. 3800 turbo. Sticky tyres. Driven hard!
GTGeff
Report this Post03-20-2020 10:37 PM Click Here to See the Profile for GTGeffSend a Private Message to GTGeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Un-winterized Petey II today. Dropped in new battery and turned over immediately. Short drive over to my mechanic to re-build the alternator. Mileage hit 25960 on the drive over.
Taken during a warmer day.
[This message has been edited by GTGeff (edited 03-20-2020).]
solotwo
Total ratings: 62
Report this Post03-21-2020 11:09 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recognize the Desoto so I think I now who you are. I was wondering if you still had the car. I think we did a trip years ago to 2 Seat Garage so that you could pick it up. Glad to see you are still enjoying it.
larafan
Report this Post03-21-2020 11:47 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Last weekend got new shocks and struts that were badly needed and oil change followed with an alignment. 5k on the engine since the build and it runs great.
BadNewsBrendan
Report this Post03-21-2020 06:11 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got the front lowered about an inch and a half.
Here is what it was like before.
Edit: ok after looking again at the before and after pictures it looks more like 2 inches or more.
"America is all about speed, hot nasty bad-ass speed" - Eleanor Roosevelt
Tetanus
1984 3800 II SC Build
[This message has been edited by BadNewsBrendan (edited 03-21-2020).]
FieroMaster88
Total ratings: 168
Report this Post03-21-2020 06:17 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got everything hooked up on the 3800 swap. Cleaned up the wiring. Made an exhaust. Loaded the tune in the computer. Once the new ignition module shows up it will be ready for its first drive!
Total ratings: 463
Report this Post03-21-2020 06:20 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday, I drove the 4.9 car (aka Cookie Monster) to its new home, south of Carrollton GA.
Sorry. No pics. We've been moving, and are completely covered up with stuff to do.
GTGeff
Report this Post03-22-2020 10:20 AM Click Here to See the Profile for GTGeffSend a Private Message to GTGeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
???? It is a Minnesota car. The picture was taken at an employee picnic and car show.
solotwo
Total ratings: 62
Report this Post03-22-2020 11:15 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow there is a DeSoto over here in GR that is the same color & I gave him a owners booklet that I saved from the 56 DeSoto that I drove as my first car. Hand me down from mom & dad. And I helped Pete I think his name is to get his red Formula from 2 Seat Garage. His Formula had about 29,000 miles on it. LOL
solotwo
Total ratings: 62
Report this Post03-22-2020 11:17 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
solotwo
Member since Jun 2002
Looking good!
DrXtreme
Report this Post03-22-2020 12:32 PM Click Here to See the Profile for DrXtremeSend a Private Message to DrXtremeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Discovering the nest of wiring that comes with a N* and Dakota Digital gauges. Did find the OBD1 connector and based on the PCM the engine is a 1994-95 and not a 96 as that is a OBD2 connector. Fun times!
Dr Xtreme
NCTyphoonKid
Report this Post03-23-2020 07:43 AM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I swapped out oil pans and installed a new gasket on my car so far I have a nice dry oil pan so hopefully this will take care of the oil hemorrhage it had.
SamanthaM
Report this Post03-24-2020 01:07 PM Click Here to See the Profile for SamanthaMSend a Private Message to SamanthaMEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced the outer dew strips on both doors and reinforced the mirror adjuster on the driver's side with the plate from Rodney. Still need to clean the door and put her all back together but it's a start.
FieroMaster88
Total ratings: 168
Report this Post03-24-2020 01:21 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put up another YouTube video on the wide body 3800 swap. Link to video!
Today I’m cleaning and organizing the shop and putting the interior back together on the wide body. I have an exhaust to finish, dew wipes to install and a new steering wheel. I have at least 3 weeks off of work so let’s get some stuff done!
FieroMaster88
Total ratings: 168
Report this Post03-27-2020 05:28 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Washed the wide body. Have the exhaust together, have to finish weld and heat wrap it still. I got the tach and temp gauges working. I worked on the file for the pcm and got rid of all the transmission codes then programmed the pcm. Relearned the crank position sensor now no ses light. Took it for a ride around the neighborhood, runs great. Hopefully tonight I can finish weld and wrap the exhaust. Still have to wrap the wiring harness too. It’s about 95% complete!
solotwo
Total ratings: 62
Report this Post03-27-2020 05:47 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Somebody is having fun in dads car.
Habanera Hal
Report this Post03-28-2020 04:37 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got my personalized plate!
'88 Formula T-Top. Custom made hood, side scoops, taillights, Z/28 spoiler. Mr. Mike's seats, RM Upholstery door panels, shift and brake boots, custom glove box, PW/Remote PL, Monsoon AM/FM/CD/Bluetooth
NCTyphoonKid
Report this Post03-29-2020 08:58 AM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed new hinge pins and bushings on the drivers door and readjusted the striker. Door shuts like a dream now. Also looking at the Fiero store exhaust systems thinking about getting one.
creaky78
Report this Post03-30-2020 02:14 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally pulled the non-functioning radio out of my '87 GT, pleased to find that the only things wrong were detached antenna, poor connection on right speaker wires. Installed new speakers, sounds good for a stone age radio.
[This message has been edited by creaky78 (edited 03-30-2020).]
