  What Did You Do To Your Fiero...TODAY ? (Page 173)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7014 (223353 views)
Last post by: Vintage-Nut on 01-07-2026 10:25 PM
Report this Post09-08-2024 06:13 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed Fierostore ABS door panels with 6 1/2" Alpine speakers:
richard in nc
Report this Post09-08-2024 08:15 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i opened the hood?to make sure the short block wasn't rusting.i have the reconditioned 2.5 head and am studying how to reinstall it.
richard in nc
Report this Post09-10-2024 06:19 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i wire wheeled the block and exhaust manifold.i wiped the block and head down with rubbing alcohol.i set the head and gasket onto the block.i put some of the parts into the cleaning tank.
richard in nc
Report this Post09-12-2024 08:01 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i torqued the 2.5 head down.i hate these 'new' torque to yield bolts.torque to 22 foot pounds and then turn two flats....I HATE THIS.i hope i got it right.if not i got a 3800 ready to go in.not the one you are thinking of though.
larafan
Report this Post09-18-2024 07:52 PM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced my clutch master and slave with Rodney aluminum units. Has an 84 master and 86 V6 style slave on the hybrid Muncie trans. Used his bleeder kits. Slave line was a real problem but finally got it. 60 k car with L67 swap and clutch has always been low and not felt good. It drives like a new car now and only adds to the swap experience. Rodney has done a great service for years for the Fiero community! Thanks !!!
[This message has been edited by larafan (edited 09-18-2024).]
richard in nc
Report this Post09-21-2024 07:55 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i started cleaning and painting the parts to go back on.
Report this Post09-22-2024 06:13 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Attended an all Pontiac show in Pontiac, IL. Rained off and on all day, but the Fieros were out in force.
coltswalker
Report this Post09-23-2024 07:13 PM Click Here to See the Profile for coltswalkerSend a Private Message to coltswalkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I finished installing a new alternator in my 1987 Fiero. It has been sitting in storage several years. Drove it yesterday and today. This is my 3rd Fiero I have had over the years. I wish I still had my 84 Fiero, it was my first and I drove it back in the 90s.
Today I jacked up the front of the Fiero and checked the front end. I am getting a wobble when I am driving so I wanted to see of there was a problem in the front end. Things are a tad sloppy but not enough to explain the vibration I am getting.
In summary, today I worked on my old Fiero. There is a lot to do on it. At least it now drives again!
TheDigitalAlchemist
Total ratings: 94
Report this Post09-26-2024 11:36 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
OMG that is SOOOO clean...
richard in nc
Report this Post11-03-2024 02:48 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i finally got my 1987 2.5 head reinstalled and that poorly designed quick heater hose connector wouldn't quit leaking.i looked everywhere online for an oring kit for it but found nothing.i couldn't even find it mentioned in the service manual.so my thought was to change it to a normal hose fitting and jury rig the hose.so i go to remove the fitting and it breaks right off.so i just ordered a new intake manifold gasket.
richard in nc
Report this Post11-07-2024 06:22 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i removed the intake manifold again.i squirted whats left of the fitting with pb blaster.there was 3/16 of the fitting still sticking out.i tried a pipe wrench on it.it kept crushing.so i used a 3/4 drill bit to drill most of it away.it was aluminum.i took a chisel and tried to collapse it.the outer parts just broke off.i finally took a punch and collapsed it a bit at the time.its out but theres still metal remaining in the threads.i bought a hose fitting at autozone that should work if i can clean out the threads.i don't have a tap that big.
richard in nc
Report this Post11-09-2024 05:49 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok. its back togetter now.it seems good.im hoping.
richard in nc
Report this Post11-10-2024 04:12 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i put the thermostat back in.i drove about 50 miles around home.it didn't overheat anymore.the temp guage didn't jump around.it idled reasonably.i hooked the egr valve back up where the po plugged it.im cautiously optimistic.only downside is i smelled antifreeze when i turned the heat on.i just replaced the heater core last year.
richard in nc
Report this Post11-13-2024 05:59 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
the brakes are much better.just like a normal car now.i assume i have more vacuum.
sleek fiero
Report this Post11-13-2024 09:39 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Richard I am posting something completely separate even though it is somewhat same subject. Today I started building mounting brackets for my new vacuum pump for my brake booster. Vacuum pump you say, yes with my performance cam I can run low on vacuum so I am doing like GM does with camaros and corvettes and adding a brake booster vacuum pump in parallel to the engine Vacuum. I will post pictures when completed.
so I have it installed but not wired into the ignition yet but will run through a relay and fuse. There is a vacuum switch in the circuit to turn the pump on between 14 and 18 inches of vacuum. sleek
[This message has been edited by sleek fiero (edited 11-15-2024).]
richard in nc
Report this Post11-18-2024 07:47 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i bolted in cavalier seats today to replace the ratty fiero seats. i used the fiero mounts.
Stingray92
Report this Post11-18-2024 09:07 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Last week this time dropped her off.
From a couple days this,
Tonight rockers and lower trim.
More to come...
sleek fiero
Report this Post11-21-2024 05:44 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed and straightened my clutch pedal today. I machined and installed new pivot pin and did the Rodney Dickman reinforcement. Also because of the aluminum pedal shaft I added a tab and bolted everything together . installed new pivot bushings and reinstalled. great day of accomplishment. sleek
rbell2915
Report this Post11-28-2024 04:40 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
The only thing I miss from Illinois is the Fiero Club and Portillo's. I really enjoyed those shows and meetings when I was a participant.
Stingray92
Report this Post12-01-2024 08:16 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok all, I've been lurking for a long time, finally getting my ride in order, too many details but here is a photo of the back glass, critiques?
sleek fiero
Report this Post12-01-2024 08:22 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stingray your back glass looks great. Your interior could use a little tweeking. LOL sleek
Stingray92
Report this Post12-02-2024 06:43 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Sleek, yeah the car quite literally needs a dressing room, thanks for the laugh.
Bumpers come home tomorrow.
so-gtover
Report this Post12-03-2024 04:42 PM Click Here to See the Profile for so-gtoverSend a Private Message to so-gtoverEdit/Delete MessageReply w/QuoteDirect Link to This Post
After picking it up the Friday before last and putting it in storage, I went to check on it today. It's a tiny bit rough, needs the passenger mirror put back on and new cylinders for the door locks, but it seems happy. It's a silver 86 SE with the V6. And with 65k miles, I'm not sure whether to keep it stock or fiddle with it a bit. I'll see what my wallet says lol
Stingray92
Report this Post12-03-2024 08:23 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Christmas early?
Anyway a lot further along.
Stingray92
Report this Post12-07-2024 06:57 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
A little more progress, 1st time I've had the glass up v with the door shut.
ADT88
Report this Post12-13-2024 02:59 PM Click Here to See the Profile for ADT88Send a Private Message to ADT88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Picking up my donor car tomorrow, 1999 Park Ave.
falcon_ca
Report this Post12-13-2024 03:21 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Vintage-Nut
Report this Post12-28-2024 03:46 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Refurbishing my Fiero is a 'hobby' and 'spare time' is always 'out of stock'!
So, I finally got the time to work on my GT which I started to tackle the ball joints back in Sept. 2023.....
I wanted to contribute so I spend extra time to write a "How-To" for members who doesn't know the ABC's of changing the front ball joints.
I'm happy that the car is on the ground again; the last chapter - the interior.
HAPPY NEW YEAR to ALL!
Report this Post12-28-2024 05:42 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the drivetrain for the Haltech Rebel LS ecm install and weight reduction (trying to get under 2900 lbs):
[This message has been edited by fieroguru (edited 12-28-2024).]
Frenchrafe
Report this Post01-07-2025 06:55 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove the car to work today, for the first time in a long time!
Must be refitting the road going tyres that give me the incentive to drive the thing more often.😉
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
ContinentalGT
Report this Post01-21-2025 04:32 PM Click Here to See the Profile for ContinentalGTSend a Private Message to ContinentalGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
I have a radio/cassette player from my 1985 Fiero GT that has stopped working. I’m hoping to either purchase a fully functional original radio or find a repair shop that specializes in restoring these units.
If anyone has recommendations for where I might find a replacement or know of a reliable repair service, I’d greatly appreciate your input!
Thank you in advance for your help!
IMSA GT
Total ratings: 250
Report this Post01-21-2025 05:11 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ContinentalGT:
Hello,
This needs to be removed from this thread.
1985 Fiero GT
Report this Post01-21-2025 05:50 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Technically today, I stopped at 2:30 am, dropped my cradle, removed my 4 speed transmission, next steps are to take the 2.8 out, put my 3400 in, reinstall the Fiero top end, put my f23 transmission in, and put back in the car, all of this is being done by hand with a floor jack and jack stands, no engine hoist.
La fiera
Report this Post02-04-2025 01:38 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.youtube.com/wat...cmVpIG1vbG9vbg%3D%3D
Finally had some nice weather and took the opportunity to break-in the camshaft in the new engine. Do another oil and filter change and if off to the dyno to break in the rings.
NightMare Cruiser
Report this Post02-04-2025 08:30 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got rid of the flush headlights and went back to stock!
gregr75
Report this Post03-22-2025 05:13 PM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
torqued the rear axle nut and fired the car up and drove around for the first time since a spectacular rear ball joint failure while driving last year…
Kitskaboodle
Report this Post03-22-2025 07:00 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been wanting for years to fix this annoying Fiero problem, namely the hideous gap that develops over the years between the bottom of the tail lights and the black moulding & upper rear bumper. I have seen many Fiero’s with this gap so I will assume it’s a common problem. 🙁
Anyways, here is the back of my 85 GT after
I fixed the problem. I just finished it yesterday. (see Technical Section if you want to see my thread on how it’s done)
Kit
Kitskaboodle
Report this Post03-22-2025 07:04 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kitskaboodle
Member since Nov 2004
Kit
Report this Post03-29-2025 01:26 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished this:
Newbfiero
Total ratings: 78
Report this Post03-30-2025 03:10 PM Click Here to See the Profile for NewbfieroSend a Private Message to NewbfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished this:
Very nice 👍
