  What Did You Do To Your Fiero...TODAY ? (Page 22)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223314 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
Madscanner
Report this Post07-15-2008 04:42 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took my car in for it's MOT (annual test required in the UK for all cars over 3 years old).
The Madscanner
Cajun
Report this Post07-15-2008 05:36 AM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the Gen I headlight motors to Gen II motors in my 86GT.
Madscanner
Report this Post07-16-2008 09:15 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my car back from the garage - found out that it failed the test on service brakes and handbrake, but not by much, so I guess I'll have to spend my weekend trying to sort it out before it goes back in for a re-test next week...
The Madscanner
CenTexIndy
Total ratings: 59
Report this Post07-16-2008 11:34 AM Click Here to See the Profile for CenTexIndySend a Private Message to CenTexIndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it 220 miles to see how it would handle after some exhaust things had been changed. Still needs some work. (and I need a dang hair cut)
But it is FUN to drive...even in 101 degree temps.
[This message has been edited by CenTexIndy (edited 07-16-2008).]
americasfuture2k
Total ratings: 105
Report this Post07-16-2008 02:04 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
WILL BE DOING AFTER WORK TODAY
replacing OPSU with correct OPSU, changing fuel filter, changing spark plugs, replacing header X-over pipe bolts n nuts, changing headlight bulbs, putting center console back together. driving it hopefully.
1987 Fiero GT built by my brother, merlot566jka, 3500 LX9 from 06 Malibu, WOT-TECH.com 1280 grind stage 3 cam, LS6 valve springs, 1227730 ECM conversion, Darrel Morse solid aluminum cradle mounts, Truleo headers modified to fit the 3500, 36# inectors, 70mm 4.3 throttle body adapted to 3500 intake, ported heads, upper and lower intakes, lightly polished, tcemotorsports.com crank trigger wheel, CenterForce dual friction clutch, Flowtech Afterburner muffler, 2.5" piping, cat deleted, EGR deleted, SinisterPerformance tuning, C6 Corvette exhaust tips. projected to be 35 MPG with a guesstimate of 250 hp to the wheels
Fiero Owner
Report this Post07-16-2008 03:59 PM Click Here to See the Profile for Fiero OwnerSend a Private Message to Fiero OwnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I moved onto the inside of the car to do the inside wiring needed to hook up the 3800SC, just need a few more things done with the wiring and it should be running this weekend.
americasfuture2k
Total ratings: 105
Report this Post07-16-2008 04:39 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
yea, we have all said that it SHOULD be running this weekend.
CenTexIndy
Total ratings: 59
Report this Post07-16-2008 05:00 PM Click Here to See the Profile for CenTexIndySend a Private Message to CenTexIndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just waved "Goodbye" to my Indy. It has found a new and loving home.
Old Lar
Total ratings: 214
Report this Post07-16-2008 07:31 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finished taking off the wheels/tires for thorough cleaning and power washed the wheel wells and suspension components to get rid of a couple years of built up crud, then greased the balljoints. Then the rains came and came and put a damper on the rest of things planned.
Still need some polishing, vacuuming the inside. I then have to move the GPS system into the car and make sure I have the emergency tools, coil, ignition module etc get packed away.
JesseM
Report this Post07-17-2008 10:05 AM Click Here to See the Profile for JesseMSend a Private Message to JesseMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Talked my parents into giving me the 85gt next year after college, went over rebuild plans and purchases with em as well. hopefully by next august it'll have a fresh 2.8l with fierostore performance and fresh paint and brakes
The H1 my father, brother and I built.
www.suburbangorilla.com
My Myspace
BAD87FIERO
Report this Post07-17-2008 10:57 AM Click Here to See the Profile for BAD87FIEROSend a Private Message to BAD87FIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my first ride home my fiero broke , the cradle had some rust on it so when I took the first turn the part where the A-Arm meets the cradle broke on both sides, which was my steering issue. Got the new cradle in, hope to have it finished tonight!
katatak
Total ratings: 82
Report this Post07-17-2008 11:52 AM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Left it sitting in the garage when I went to work.... Looked so sad that I was not taking it. Maybe tomorrow if it does not rain....
americasfuture2k
Total ratings: 105
Report this Post07-17-2008 11:00 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced my fuel filter (man that was a btch!) and broke a gt decklid vent on the drivers side some one sell me a new one! at an affordable price
fiero86_gt
Report this Post07-17-2008 11:08 PM Click Here to See the Profile for fiero86_gtSend a Private Message to fiero86_gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looked at a picture of it and wished it was on the road.
ss85fiero
Report this Post07-17-2008 11:56 PM Click Here to See the Profile for ss85fieroSend a Private Message to ss85fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made a set of smoke tinted covers for my flushmount headlights
Before
After
87 fiero gt 4.9
99 trans am ls1
86 fiero se 2.8 (eventually to be a 3.8sc)
Total ratings: 436
Report this Post07-18-2008 12:11 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing today--yesterday, drove to Gatesville, Tex, and picked up the Indy I bought a few months ago. #2 for me.
http://www.cafepress.com/pffshop
84 se auto-supposedly sold.
84 se 4 spd
88 4 cyl 5 spd
84 Indy #1578
84 Indy #1656
RCR
Total ratings: 102
Report this Post07-18-2008 10:40 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Spending too much time reading Forum. Yesterday I worked on the console, wired up the power mirrors, and started new work on the door panel.
Bob
whodeanie
Total ratings: 120
Report this Post07-18-2008 12:32 PM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I worked on the front end, cut the trunk out,
got my F1F headlights today and waited on parts
now it's Monday and I just got my widebody kit from Archie.
I cant wait to get home and play!!!!
[This message has been edited by whodeanie (edited 07-21-2008).]
ARKaiser
Total ratings: 62
Report this Post07-18-2008 04:37 PM Click Here to See the Profile for ARKaiserSend a Private Message to ARKaiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
New seats for Anni (86 GT). Picked them up at the u-pick for $50.
New hoops for Rose T (87 T-top coupe). I bought 2 and the dealer bought 2. The last set I got from them started distorting so they pick up the cost of the two worst ones.
katatak
Total ratings: 82
Report this Post07-18-2008 06:05 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
My son blew the motor.......... Trying to decide on another 2.8 or go for the 3.4. Need it to be a reliable daily driver. Any suggestions? Thanks
Pat
edit - looking for info / threads on a 3.4 swap......
[This message has been edited by katatak (edited 07-18-2008).]
Cheever3000
Total ratings: 178
Report this Post07-18-2008 09:37 PM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got it back from the shop today. Fuel problem fixed, and a/c working!!!
Check out my web site:
Tallahassee Fiero News
Madscanner
Report this Post07-21-2008 06:38 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorted out the sticky caliper piston on the right rear - now the handbrake sticks on...
The Madscanner
Madscanner
Report this Post07-23-2008 06:44 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped my car off for a re-test - last night, about 10pm I finally worked out that the external part of the handbrake cable (where it goes the equaliser/adjuster) was damaged, with the result that it stuck a) going on, so didn't go fully on, and b) coming off, so didn't come fully off. Hopefully the tester will give me an "advisory" rather than a "fail" for it.
Have just ordered a replacement, along with a set of front brake pads... more fun for this weekend.
The Madscanner
whodeanie
Total ratings: 120
Report this Post07-23-2008 08:10 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the picture shows it better than I can
Madscanner
Report this Post07-26-2008 06:58 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Topped up my cooling system and burped it...
The Madscanner
Blacktree
Total ratings: 350
Report this Post07-26-2008 10:57 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally finished the V5 A/C compressor conversion on my V6. Now my A/C puts a constant load on the engine, so the idle doesn't bounce up and down. With the HR6 compressor (which is stock on the 2.8 V6), the clutch constantly cycles on and off, causing the engine idle to bounce up and down like a metronome.
The conversion is pretty straightforward. If anybody is interested in the details, let me know.
Macs86GT
Report this Post07-26-2008 11:42 AM Click Here to See the Profile for Macs86GTSend a Private Message to Macs86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
yelled at my mechanic
topcat
Total ratings: 148
Report this Post07-26-2008 05:04 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started it up for the first time in at least a month... Vacation, work and time spent out of town has not lent itself to enjoying the Fiero... But it sure did sound good idling.
avengador1
Total ratings: 571
Report this Post07-26-2008 05:52 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I put a new distributor in yesterday, the cap and ignition module holes got stripped on the old one somehow. I took it for a nice drive today as the weather was beautiful.
katatak
Total ratings: 82
Report this Post07-26-2008 10:02 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drove from El Paso to Albuquerque and picked up my New To Me 1988 Formula. One of the nicest Formulas I have come across so I had to buy it. Will post pics later.....
Edit - pics added
http://s525.photobucket.com...current=IMG_1534.jpg
http://s525.photobucket.com...current=IMG_1535.jpg
http://s525.photobucket.com...current=IMG_1536.jpg
[This message has been edited by katatak (edited 07-26-2008).]
Jakesdads86gt
Report this Post07-27-2008 03:02 AM Click Here to See the Profile for Jakesdads86gtSend a Private Message to Jakesdads86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Extremely interested. Knowing what was done in advance would cut the down-time a lot.
Total ratings: 436
Report this Post07-27-2008 04:13 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took Indy #2 up to the local Sonic-/juvenile delinquent hangout for ice cream tonite. We sat at a table under their awning, ate our banana splits, and watched all the local heathens "ooh and aah" over the 1st pace car they had ever seen. Wife gave me a knowing/dirty look when a young girl asked if she could sit in it. Not much to do in this sawmill town.
RCR
Total ratings: 102
Report this Post07-27-2008 07:45 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Made some early morning parts runs and built up two axles for my 4.0 swap. Also, went to the 25'th show and posted a bunch of pics. Then made another parts run, cleaned the axles and put one in to verify fit. Also worked on finishing the door panel (It's not fitting).
Bob
Edaw 0
Report this Post07-27-2008 09:14 AM Click Here to See the Profile for Edaw 0Send a Private Message to Edaw 0Edit/Delete MessageReply w/QuoteDirect Link to This Post
This happened yesterday: washed it, then took it for a quick spin and yeah, someone who knows what they're doing is going to have to set this thing's camber.
katatak
Total ratings: 82
Report this Post07-27-2008 12:34 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed the wing on the 88 Formula. This is not the original wing. The original has a stand that the mounting screws are stripped and the stand is loose on the wing. This wing is off an 86 GT. Learned something new today. The mounting bolts are spread wider on the GT stands vs the Formula stands. The narrow screw boss is on the GT stands so I had to move the mounting screw/bolt. I think it is due to the configuration of the GT decklid vs the Notchie deck lid.
Without the wing
With the wing
FieroGT-Lithuania
Report this Post07-29-2008 07:01 AM Click Here to See the Profile for FieroGT-LithuaniaSend a Private Message to FieroGT-LithuaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by FieroGT-Lithuania (edited 07-29-2008).]
larini74
Report this Post07-29-2008 08:36 AM Click Here to See the Profile for larini74Click Here to visit larini74's HomePageSend a Private Message to larini74Edit/Delete MessageReply w/QuoteDirect Link to This Post
I started working on my hood...
http://www.fierocountry.us/myproject1.html
large pics - 56k be forewarned....average size is 1.8mb....
Englishrafe
Report this Post07-30-2008 05:28 PM Click Here to See the Profile for EnglishrafeSend a Private Message to EnglishrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced my dead O2 sensor.
I even had time to fix the broken wires on my cruise control - not that it actually made it work, but I suppose it's one less thing to sort out!
Regards,
Rafe
'77 Bandit Trans Am - Tyre shredding modified 403 ci injection motor - don't even think about it, unless you're packing 400+ HP!!
'87 Fiero GT - Now operational - MR2 and other small sportscars beware!!
psychosurfer
Report this Post07-30-2008 05:46 PM Click Here to See the Profile for psychosurferSend a Private Message to psychosurferEdit/Delete MessageReply w/QuoteDirect Link to This Post
I DROVE IT!!! First time in 5 years!!! My wife and I have 3 places we call home because of the nature of our work. We are rarely around the house with the projects Well after a few very short trips down our driveway and back (its about 100 yards long) a few of my friends and I sorted out a few bugs and I took it out for a nice long cruise! Still have a few minor adjustments to work out, and it will be my daily driver again.
For those of you who don't know this car was originally a 88 bas coupe auto, then an LT-1 getrag, then an overdrive auto older tpi 350, (added my first nitrous kit ever to that set up. hence the next approach). Removed all that and sold it to a member from up north in the states. Bough a bad (sold to me as good) 88 2.5 while planning to return to stock.
THen got a great deal on a complete swap from an 88 gt from another member/ friend and several months later...ta-da! A cruise around town!!!
jstricker
Total ratings: 370
Report this Post07-30-2008 10:54 PM Click Here to See the Profile for jstrickerSend a Private Message to jstrickerEdit/Delete MessageReply w/QuoteDirect Link to This Post
The last 2+ weeks have been nothing but work on the race car.
Accusump and remote filter installed. Final details for the Northstar. New transmission. New driver's harness. New Wilwood brakes and EBC Rotors. New front wheel bearings and seals. The list goes on and on and on. I'll try to post some pics when we get back from SORC. Hopefully the car will be running well for it.
John Stricker
