  What Did You Do To Your Fiero...TODAY ? (Page 23)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219389 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
Valkyrie
Report this Post07-30-2008 11:52 PM Click Here to See the Profile for ValkyrieSend a Private Message to ValkyrieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took it to town and filled it. (Without registration or safety, oooh, bad bad.)
Total ratings: 206
Report this Post07-30-2008 11:52 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took a Sawz-All and cut it into little pieces and piled it under a tree!
Seriously!
(It's a parts car, and there were no parts left to take off of it anymore - got to haul it off)
katatak
Total ratings: 82
Report this Post07-31-2008 11:51 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I picked up a new motor for my 86 SE. The motor has been sitting on a stand for awhile. After I got it home, and I looked at it a little closer, I noticed that a piece of the lower intake was broke off. I posted pics in another thread and asked for some advice. Most said to replace it while it was out of the car. So, this evening, I decided to remove it and I though while I was at it, I would take the pab off and inspect the bottom end a little too. Here are some pics of what I found.
The broke manifold.
The cruddy cold start Inj
A plastic tip on the Inj. is broke. Can I get this somewhere? or do I need the whole injector?
Assembly lube on Cam.
Assembly Lube on Crank.
Cylinder Hone.
And Old Yeller - with a siezed motor.
The pistons appear to be new as well as the valve's and valve springs. The heads are very clean and appear to be redone. The oil pump appears to be new. The timing chain looks new as well as what I can see of the cam. H20 pump looks new but, I am thinking of putting a new one on due to the length of time it has been sitting. What do you guy's think? I think I can button her back up, install a new H20 pump, repair the one broke injector tip/replace the injector and clean up the cold start injector and it will be good to go.
Comments, ideas, suggestions?
Thanks
Pat
katatak
Total ratings: 82
Report this Post08-01-2008 01:20 AM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before I head to bed, I bought an EGR tube for the 86 and 2 sets of dew wipes from Stu...... I am glad I quit drinking and smoking so I could support the Fiero addiction....LOL
pumpkincarriage
Report this Post08-01-2008 01:27 AM Click Here to See the Profile for pumpkincarriageSend a Private Message to pumpkincarriageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Attempted to remove the intake on my DOHC so I can replace the gaskets which I'm hoping have failed and are the cause of my 4000 rpm idle.
Unfortunetely, the bolts are torqued too tight for me to get out, so I have to wait for a strong manly man to come along and loosen them.
Probably get it tomorrow, but I at least got all the accessories off today which is pretty good considering it was 104 degrees outside.
avengador1
Total ratings: 571
Report this Post08-01-2008 12:52 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've been using my Fiero as my daily driver since I left my Subaru in Florida. I actually used the Fiero to go get a haircut today, but it still spends most of it's time in the garage.
Madscanner
Report this Post08-05-2008 04:04 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
On Friday, put my new front calipers on, and on Sunday, put my new e-brake cables on.
The Madscanner
'85 SE 2M6 automatic w WS6 suspension, factory sunroof, slightly modded interior, after-market cold air induction kit, rear spoiler, original Tech alloys, component speakers instead of the 4x10s.
Outstanding tasks - adding electric windows, locks, and mirrors (all the bits sitting around in a box, awaiting time...), getting some 15" lace alloys and some more useful rubber, am also looking at converting the rear struts to proper coilovers (just 'cause I fancy another project!).
MstangsBware
Total ratings: 459
Report this Post08-05-2008 04:33 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I:
On a parts 86 SE I tweaked on it and got it running. Car was bought as a parts car but the motor runs pretty good so it might get put into another car.
Pulled my LS4 setup out of my 88 GT to finish up on the motor mounts. Had to re-drill some holes for the mount so the motor would sit str8 in the engine bay. Got them drilled and put back on and now the motor/trans is poly mounted and str8.
Fieromaniac
Report this Post08-05-2008 01:32 PM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
installed a set of stainless steel mirrors in the trunklid of my 87 notchie
1984 Fiero Sport
1987 Fiero
1984 Fiero SE
1999 Chrysler Grand Voyager 3.3 LX LPG
*** nuclear winter cures global warming ***
americasfuture2k
Total ratings: 105
Report this Post08-05-2008 02:52 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
i did this all in the last week, just never got around to posting it.
dropped tank, emptied gas, replaced pulsator, tested pump (and probably killed it ) reassembled, put tank in car, filled with 5 gallons only to find fuel pressure was at 5 psi. fuel pump is DEAD. ordered a walbro 255 and fuel pump harness install kit all for $$140. installed optima redtop, awaiting TFS's console tray and new ebrake switch.
1987 Fiero GT built by my brother, merlot566jka, 3500 LX9 from 06 Malibu, WOT-TECH.com 1280 grind stage 3 cam, LS6 valve springs, 1227730 ECM conversion, Darrel Morse solid aluminum cradle mounts, Truleo headers modified to fit the 3500, 36# inectors, 70mm 4.3 throttle body adapted to 3500 intake, ported heads, upper and lower intakes, lightly polished, tcemotorsports.com crank trigger wheel, CenterForce dual friction clutch, Flowtech Afterburner muffler, 2.5" piping, cat deleted, EGR deleted, SinisterPerformance tuning, C6 Corvette exhaust tips. projected to be 35 MPG with a guesstimate of 250 hp to the wheels
Reality
Total ratings: 64
Report this Post08-05-2008 03:11 PM Click Here to See the Profile for RealityClick Here to visit Reality's HomePageSend a Private Message to RealityEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put new rotors and pads on the front And drove the car for the first time in probably three months. I always forget how wonderful driving a Fiero makes me feel.
leppy_89
Report this Post08-05-2008 06:49 PM Click Here to See the Profile for leppy_89Send a Private Message to leppy_89Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put new belts on my friend's 88
Total ratings: 403
Report this Post08-05-2008 08:33 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
New battery. Tired of push starting it, not bad when I was able to park on the hill but cant get lucky every day.
Fieromaniac
Report this Post08-08-2008 04:14 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
i replaced the springs of the trunklid with nice stainless steel hoodlifts
1984 Fiero Sport
1987 Fiero
1984 Fiero SE
RCR
Total ratings: 102
Report this Post08-08-2008 08:03 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday: Bought new rotors, calipers, and pads for the back. Returned one caliper because I recieved to left's. Painted the other. Also bought a set of new stainless steel brake lines (master cylinder back) from Inline Tube.
Today's agenda: Pick up right caliper and brake lines. Paint some more and get stuff mounted.
Bob
katatak
Total ratings: 82
Report this Post08-08-2008 08:02 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just finished pushing the 86SE into the garage for a much needed engine transplant. Let the games begin....Stay tuned.
Uaana
Total ratings: 138
Report this Post08-08-2008 10:08 PM Click Here to See the Profile for UaanaClick Here to visit Uaana's HomePageSend a Private Message to UaanaEdit/Delete MessageReply w/QuoteDirect Link to This Post
New tabs, (been sitting for 3 yrs)
Put new seat covers on, and took it for a freeway cruise to blast the gunk out of it.
BTW has anyone noticed how close the gears are on a Fiero?
I'm out of practice on one.. and damn.. waaaay to easy to hit 2nd instead of 4th.. 3rd was more of a "that would be cool" than an actual gear I could select.
The 3.4 makes 1st more of an ooohh look how loud I can be, than a real gear, actually easier to take off in 2nd for a smooth take off than first.
Philphine
Total ratings: 54
Report this Post08-08-2008 11:32 PM Click Here to See the Profile for PhilphineSend a Private Message to PhilphineEdit/Delete MessageReply w/QuoteDirect Link to This Post
worked on getting my 86gt back on the road after waiting for a radiator for over a month. did my rear brakes too. got it all together, did the first cooling system fill and let it run a couple minutes, but i had to leave for work so topping it off and checking my brake work will be tomorrow.
golden dragon
Report this Post08-09-2008 04:35 PM Click Here to See the Profile for golden dragonSend a Private Message to golden dragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished putting on dew wipes yeah! At least that headache is put to bed for twenty more years
ducattiman
Report this Post08-09-2008 06:33 PM Click Here to See the Profile for ducattimanSend a Private Message to ducattimanEdit/Delete MessageReply w/QuoteDirect Link to This Post
today i started bending and some welding my tubular control arms.
katatak
Total ratings: 82
Report this Post08-09-2008 08:18 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just got back from a little West Texas Fiero Cruise with some of the local El Paso Fiero folks. It was great to finally meet a few of the West Texas folks. We satrted off the day setting a 66 Vette body back on the chassis which I have to say is pretty impressive. Blown SBC, polished T400, polished alum headers, custom aftermarket suspension, 4 wheel discs, polished alum fuel tank, etc. all the good stuff. Then we drove over to the steak house, had some lunch then went for a quick drive up to the mountains. Short and sweet but lots of fun.
Attack of the Notchies. The burgandy one is a 4.9. The red formula is mine and the white one is getting a nose job and paint soon.
avengador1
Total ratings: 571
Report this Post08-09-2008 09:12 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I drove mine to Penns Grove, NJ, tomorrow I drive it to Lorton, VA to catch the auto train. On monday I drive from Sanford, Fl to our new home in Orlando.
LT188GT
Total ratings: 100
Report this Post08-09-2008 10:27 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took it to a car show at Hooters in West Palm Beach. Photos in O/T.
americasfuture2k
Total ratings: 105
Report this Post08-10-2008 04:58 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced my fuel pump with a walbro 255. that brought out some new problems that will need to diagnosed and tracked down
mikejhjr
Report this Post08-10-2008 05:49 PM Click Here to See the Profile for mikejhjrSend a Private Message to mikejhjrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped the tank, replaced the fuel pump, pulsator, and strainer. Good way to spend the afternoon.
Greg Z
Report this Post08-10-2008 09:50 PM Click Here to See the Profile for Greg ZSend a Private Message to Greg ZEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL, I know exactly where that picture was taken. Thats Trans Mountain RD.
And the cool part is back in like 1992 I took my girlfriends girlfriend to that spot in a red 86 Fiero Notchie and lets say I got to homebase. It was the first and last time in a Fiero!!!
oh and BTW: Just to stay on topic, I started my Indy today and moved it up 20ft in the garage so I could sweep under it. Thats all I did Fiero related today.
91 NSX
99 TT C5
89 ESPRIT SE
96 IMPALA SS 383 76mm
84 INDY FIERO
94 INDY GMC S10BLZ
95 MERCEDES SL
86 PORSCHE 928 S
[This message has been edited by Greg Z (edited 08-10-2008).]
Larryh86GT
Report this Post08-11-2008 07:24 AM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to the local u-pull-it yesterday in the rain and found a power mirror switch. Looks to be in much better shape than what is on the GT.
Englishrafe
Report this Post08-13-2008 05:15 PM Click Here to See the Profile for EnglishrafeSend a Private Message to EnglishrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bit late I know, but there was a car and bike show this week end.
Here's mine next to a nice Challenger:
'77 Bandit Trans Am - Tyre shredding modified 403 ci injection motor - don't even think about it, unless you're packing 400+ HP!!
'87 Fiero GT - Now operational - MR2 and other small sportscars beware!!
Cheever3000
Total ratings: 178
Report this Post08-15-2008 06:11 AM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Had a flat tire Tuesday. Couldn't get the wheel off cause the lock-lug key would not get enough bite on the lug nut. It must have been used so much it got rounded off, or someone in the past ignored the label about not using an impact wrench on it.
So I had AAA tow it to a shop, where they took all the lock-lugs off. Got 2 new tires and an alignment. No more vibration at high speeds now!
Check out my web site:
Tallahassee Fiero News
whodeanie
Total ratings: 120
Report this Post08-15-2008 09:53 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got my LS6 today and worked on my widebody kit and rear bumper
americasfuture2k
Total ratings: 105
Report this Post08-16-2008 01:00 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
i got my new chips in from darth, and all is still a no go gotta keep working at it on his side since he knows what he is doing and what to do.
RCR
Total ratings: 102
Report this Post08-16-2008 07:24 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed all new brake hardlines, stainless steel. The caliper lines and trunk floor are next.
Bob
fierofinder
Report this Post08-16-2008 06:14 PM Click Here to See the Profile for fierofinderSend a Private Message to fierofinderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Switched my coil wire and found a vacuum line loose that I am guessing was the culprit of my code 32. Yesterday I installed a new distributer, cap, rotor, coil and I ordered trueleo's intake.
Khw
Total ratings: 134
Report this Post08-17-2008 01:21 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tested the amp and speakers I bought, along with the fit. Power and speaker wires are only temporary to make sure everything is working right. Next pull it all out, install the sound deadener on the floor, run permanent wiring and carpet it.
Intel
Total ratings: 53
Report this Post08-18-2008 10:58 AM Click Here to See the Profile for IntelSend a Private Message to IntelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the random code 32 EGR today... again.
Removed every ounce of EGR system from the car. Plugged the EGR->Plenum. Put custom heat wrapped y-pipe without egr outlet. Painted the aluminum y-pipe covers.
Now waiting for an EGR delete memcal. Looks a whole lot better without all that piping.
Over here they just test the CO and on idle.
katatak
Total ratings: 82
Report this Post08-18-2008 11:09 AM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just looked at it sitting in the garage - engine about out of it. Crawled under to disconnect the ac. Found the brand new comp leaking. If it's not one thing, it's 10 others.
Pat
MarineFiero
Report this Post08-18-2008 11:35 AM Click Here to See the Profile for MarineFieroSend a Private Message to MarineFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paid for it!
Now I'm headed to register it. It's killing me cause the previous owner works near me and he parked it in the lot across from my barracks. I can see it out my window but I can't drive it yet!
Cpl Mamalis, USMC
katatak
Total ratings: 82
Report this Post08-18-2008 04:24 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picked up a Winaldl cable from Dodgerunner, setup my laptop with Winaldl and made a run yesterday just to test it out. Made a few more runs today and it has already paid off. The newly acquired data showed that I might have a lean condition. I swapped out the O2 sensor with a known working one and also found a leak in the fuel pressure regulator. Repaired that too and now the 88 seems to be running much better. I learn something new about Fiero's everyday - amazing! Thanks Dodgerunner for all your help!
Pat
avengador1
Total ratings: 571
Report this Post08-18-2008 08:23 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I registerred my Fiero last Friday, here in Florida. It's now officially a Florida car.
Total ratings: 259
Report this Post08-18-2008 09:07 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its not for one of my Fieros, but I finished the fabrication for this accessory drive today:
