  What Did You Do To Your Fiero...TODAY ? (Page 24)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7014 (223344 views)
Last post by: Vintage-Nut on 01-07-2026 10:25 PM
ShockWave
Report this Post08-18-2008 11:14 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dealt with more coolant problems. Coolant was spilling over the resivoir cap and leaking all over at the cruise night I went to in Winthrop Harbor. Fiero Thomas was able to help over the phone, and a certified mechanic happened to have a car at the show tonight, the car and I got home OK.
Might be a bad thermostat, and/or might be the water pump (again).
| Fiero Blog | NIFE Member |
"A drink with ice refills itself"
Larryh86GT
Report this Post08-19-2008 09:10 AM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to the local u-pull Sunday and found this set of allmost rust free sunroof gasket channels.
Report this Post08-19-2008 10:03 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
reinstalled the cradle/drivetrain in an 88 Duke auto - took 3 1/2 hours to get the cradle bolts to line up (just missed it by that much) evidently one of the front bolt tubes is tweaked a bit and that's the one I put in first, throwing everything else of a bit.
Finish it up today, and get it running!
LT188GT
Total ratings: 99
Report this Post08-19-2008 11:32 AM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I covered it up in case T.S. Fay decides to pour more water on Miami.
84 Fiero SE
Report this Post08-19-2008 01:11 PM Click Here to See the Profile for 84 Fiero SESend a Private Message to 84 Fiero SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wiped down the engine block...Got alot of that old grease and grime off....
Then..."Gave my Fiero a Hug"
cerulean
Report this Post08-19-2008 08:50 PM Click Here to See the Profile for ceruleanSend a Private Message to ceruleanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the old after market radio/cassette that came with my Car with an MP3/CD/radio from a Pontiac Vibe.
katatak
Total ratings: 82
Report this Post08-19-2008 09:46 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well after much procrastination, I finally got the motor out of my 86. I can't believe how easy it was once I grew a spine and dove in. Thanks to all that have helped so far and thanks in advance to those that will help in the coming days.
katatak
Total ratings: 82
Report this Post08-20-2008 10:04 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
After a crappy day at work, I took out my frustrations on my poor Ol Yeller 86 SE. Got the trans & engne seperated. Now for the clean up.....
ShockWave
Report this Post08-20-2008 11:01 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got her back from the shop today after they repaired what caused the incident on Monday. Bad radiator cap and bad thermostat make for a messy arrival at a car show about 40mins away. They also did an oil change.
katatak
Total ratings: 82
Report this Post08-23-2008 01:09 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Starrted swapping parts from the smoked motor to the new one!
americasfuture2k
Total ratings: 105
Report this Post08-23-2008 07:10 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
put in a new chip by darth, v2.2. car is running much better, put 76 miles on it. and sucked down 1/2 a tank still got lots more tuning to do.
EDIT: i drove it some more, and fouled all my plugs. 7 miles from home. that sucked. they fouled out in the middle of driving. that sucked.
1987 Fiero GT built by my brother, merlot566jka, 3500 LX9 from 06 Malibu, WOT-TECH.com 1280 grind stage 3 cam, LS6 valve springs, 1227730 ECM conversion, Darrel Morse solid aluminum cradle mounts, Truleo headers modified to fit the 3500, 36# inectors, 70mm 4.3 throttle body adapted to 3500 intake, ported heads, upper and lower intakes, lightly polished, tcemotorsports.com crank trigger wheel, CenterForce dual friction clutch, Flowtech Afterburner muffler, 2.5" piping, cat deleted, EGR deleted, SinisterPerformance tuning, C6 Corvette exhaust tips. projected to be 35 MPG with a guesstimate of 250 hp to the wheels
[This message has been edited by americasfuture2k (edited 08-24-2008).]
D_sensitized
Report this Post08-23-2008 07:15 PM Click Here to See the Profile for D_sensitizedSend a Private Message to D_sensitizedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rolled it out of the dusty garage and gave it a nice wash. Now it's nice and clean
Hopefully it can stay that way a little longer this time.
HC
Report this Post08-24-2008 03:03 AM Click Here to See the Profile for HCClick Here to visit HC's HomePageSend a Private Message to HCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just replaced the front shocks on my '84. I ran out of daylight today so I have to get up early tomorrow and finish what I started. Work for tomorrow: rear struts, brake pads and new brake fluid.
ShockWave
Report this Post08-24-2008 08:42 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car show today in downtown Grayslake! About to go clean the car up in a few minutes.
LT188GT
Total ratings: 99
Report this Post08-24-2008 03:41 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove to Ft Lauderdale at a state park and parked the car along the inter-coastal waterway and watched the boats and roller blading girls skate by as I waxed the car,
RumbleB
Report this Post08-24-2008 05:22 PM Click Here to See the Profile for RumbleBSend a Private Message to RumbleBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Modified an 84 cradle for an engine swap.
ltlfrari
Total ratings: 127
Report this Post08-24-2008 05:29 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the tacho/oil pressure gauge in instrument panel of the 85 v6. At least I know it has good oil pressure now (50+psi), old gauge used to show maybe 10 psi on a good day!
Next job is replace drivers side door hinge bushings and all the locks. Oh joy....
P.S. Nice work on that cradle, what's going on there?
Dave
www.ltlfrari.com
[This message has been edited by ltlfrari (edited 08-24-2008).]
RumbleB
Report this Post08-24-2008 05:51 PM Click Here to See the Profile for RumbleBSend a Private Message to RumbleBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! It might seem a little over kill. But it is a 3800SC. I want a full size muffler to tone down the engine a bit.
I am building my exhaust like Fieroguru built his. Now, I have to redesign the bumpsteer issue.
https://www.fiero.nl/forum/Forum2/HTML/087174.html
[This message has been edited by RumbleB (edited 08-24-2008).]
dudewithoutfiero
Report this Post08-24-2008 06:54 PM Click Here to See the Profile for dudewithoutfieroSend a Private Message to dudewithoutfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
all i did to the fiero is drive it and give it a bath and a wax.
Khw
Total ratings: 134
Report this Post08-24-2008 07:02 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished up the sub enclosure. Now I need to figure out what to do around the amp, LOL.
I'm thinking maybe a grill of sorts covered with speaker grill cloth. Something to kinda hide it but still allow airflow.
[This message has been edited by Khw (edited 08-24-2008).]
MarineFiero
Report this Post08-24-2008 07:15 PM Click Here to See the Profile for MarineFieroSend a Private Message to MarineFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sexy setup!
MordacP
Report this Post08-24-2008 09:45 PM Click Here to See the Profile for MordacPSend a Private Message to MordacPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Performed the pegging temp gauge fix. It works!! If you dont know what i'm talking about, search for fiero temp gauge fix on google.
85LAMB
Report this Post08-24-2008 10:49 PM Click Here to See the Profile for 85LAMBSend a Private Message to 85LAMBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I painted both valve covers and the upper intake manifold and I am very happy with the results.
Toddster
Total ratings: 504
Report this Post08-24-2008 11:00 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
The other day I pulled the engine and tranny in an 88 Coupe. Today I replaced the clutch, put in a new tranny (the old one had beautiful metal flakes in the 90 weight ), Welded-up a crack in the exhaust, replaced the water pump, pressure washed the whole thing and tossed it all back up into the car and had it back on four wheels before the sun went down.
my hands hurt.
katatak
Total ratings: 82
Report this Post08-24-2008 11:36 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
You go Toddster. I pulled the TB of my 88, cleaned it all up, cleaned the IAC, inside the upper intake, the tube from the TB to the lower mainfold, etc. etc. etc. Made a big difference for Idle and acceleration. Also spent a lot of time looking at the 86 with the motor out. Gotta gather some parts begore I can install the new motor. Thinking about rebuilding the whole rearend. Got the poly bushings for the a arms and cradle. Al ready installed new struts. It needs rotors and pads (thinking of upgrading). Maybe next weekend!
Toddster
Total ratings: 504
Report this Post08-24-2008 11:59 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good katatak. I see you wasted no time with the engine removal guide.
Have a + outta petty cash.
Khw
Total ratings: 134
Report this Post08-25-2008 12:22 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by MarineFiero:
Sexy setup!
I'm guessing that was for me.
Thank you
[This message has been edited by Khw (edited 08-25-2008).]
White Spyder
Report this Post08-25-2008 07:11 AM Click Here to See the Profile for White SpyderSend a Private Message to White SpyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to the paint booth and changed the color .
Shad0wguy
Report this Post08-25-2008 09:57 AM Click Here to See the Profile for Shad0wguySend a Private Message to Shad0wguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally finished removing the aftermarket wiring that was entangled into my wiring harnesses. Now to get working on getting the engine running again. Realized my custom one-off sub box I bought doesn't quite fit right.
Kitskaboodle
Report this Post08-25-2008 10:58 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed Norm's Fiberglass front-mount battery box.
This project was a LOT of work and took a full 9 hours.
Man, am I glad this project is done with!
Kit
avengador1
Total ratings: 571
Report this Post08-25-2008 06:21 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is sitting in it's new home. I put up some racks to get all the boxes out of the way, so I could have access to it again. It was "boxed" in literally.
BlackGT Codde
Report this Post08-25-2008 09:13 PM Click Here to See the Profile for BlackGT CoddeSend a Private Message to BlackGT CoddeEdit/Delete MessageReply w/QuoteDirect Link to This Post
drove it ...
had some one throw rocks at it
got pissed off in it...
decided its not worth the waste of gas just for revenge when
people cant throw
Edaw 0
Report this Post08-26-2008 01:26 PM Click Here to See the Profile for Edaw 0Send a Private Message to Edaw 0Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally drove it! It was great! I'm loving this, the A/C and cruise controll still work!
I had to eyeball the rear camber since it's now too low to get on the auto shop's rack for a proper set up. After going up and down 395 afew times it seems safe enought to make the trip to Fort Detrick, my next duty station, and now the problems:
the steering wheel is not straight and the seems to be a bit of play in the steering overall
the headlights come on but don't pop up. huh? they just worked!
the tach seems to work from 0-1000 to 2700 and above. anyone seen this before?
not really a problem, but after getting some seat time, finally, a bit more power is needed. a 3.4 doesn't seem like a bad idea now and a 4.9 sounds even better, don't have to go whole hog with a 350 or LS, but that LS4 thread does sound pretty sweet, but I have a cradle modified to accept an Ecotec, so I'm going with that. I'll have plenty of time at my new duty station to get a motor, transmission and other parts, but the wiring is scaring me.
cerulean, do tell, was that a straight forward install? is there an AUX jack? I don't see one but I'm just making sure.
http://home.townisp.com/~mc...w/fiero/IMG_2411.JPG
looks better than the double din Pioneer I have now.
[This message has been edited by Edaw 0 (edited 08-26-2008).]
3.6lvvt6spdgt
Report this Post08-26-2008 02:35 PM Click Here to See the Profile for 3.6lvvt6spdgtSend a Private Message to 3.6lvvt6spdgtEdit/Delete MessageReply w/QuoteDirect Link to This Post
INSTALLED MT NEW 30# INJECTORS!
come see my build
https://www.fiero.nl/forum/F...2/HTML/087040-3.html
Madscanner
Report this Post08-27-2008 02:02 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got an adjustable sleeve on to one of my new struts - after getting it stuck on once, I cleaned every last bit of paint off, and filed down the edges of the part number stampings, heated the sleeve in the oven, and whacked it on!.
Time to get started on the other one...
The Madscanner
'85 SE 2M6 automatic w WS6 suspension, factory sunroof, slightly modded interior, after-market cold air induction kit, rear spoiler, original Tech alloys, component speakers instead of the 4x10s.
Outstanding tasks - adding electric windows, locks, and mirrors (all the bits sitting around in a box, awaiting time...), new wheels and rubber, as well as rear adjustable coilovers, and poly bushings all 'round.
Blacktree
Total ratings: 350
Report this Post08-27-2008 03:15 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I fixed the A/C... again. The schraeder valve in the high-side service port failed, and vented all the refrigerant. Since my system is converted to r134a, the service ports have adapters screwed onto them, with plastic caps. The plastic cap on the high-side port may not be strong enough to hold in the refrigerant, but a steel bolt should be.
In case anyone is interested, the proper bolt size to plug the high-side service port (with the r134a fitting installed) is M8 x 1.0mm.
chrismclubm
Report this Post08-27-2008 09:50 PM Click Here to See the Profile for chrismclubmSend a Private Message to chrismclubmEdit/Delete MessageReply w/QuoteDirect Link to This Post
oil and oil filter change with 3.8 L of 10w-30
1986 GT Fiero Owner & Enthusiast
For Fiero updates, visit my site and don't forget to click on the ads!
http://educatorstop15.we.bs/fieropage.htm
Madscanner
Report this Post08-28-2008 04:03 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried bleeding my brakes again...
Still too soft - will have to spend some quality time on it this weekend!
Fiero Owner
Report this Post08-28-2008 06:15 PM Click Here to See the Profile for Fiero OwnerSend a Private Message to Fiero OwnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I finally got to do the first startup of my 3800SC swap, no exhaust on it yet and still a few things that need finishing it up, but my wiring seems to work and it runs!
86stealthfiero
Report this Post08-28-2008 07:13 PM Click Here to See the Profile for 86stealthfieroSend a Private Message to 86stealthfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
umm messing with the breaks and a bad ignition module
