  What Did You Do To Your Fiero...TODAY ? (Page 25)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7010 (223187 views)
Last post by: Newbfiero on 12-06-2025 10:12 PM
doublec4
Total ratings: 150
Report this Post08-28-2008 07:31 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
parked it. waterpump is toast on my 3800SC
Larryh86GT
Report this Post08-30-2008 03:18 PM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found this air deflector at the junkyard today. It was missing on my GT. $3.75 total cost. Cleaned up real nice. Woo Woo
helmet1978
Report this Post08-30-2008 04:46 PM Click Here to See the Profile for helmet1978Click Here to visit helmet1978's HomePageSend a Private Message to helmet1978Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished at about 1:00am so that counts as today
More info here:
https://www.fiero.nl/forum/Forum1/HTML/072448.html
http://www.raceme.cc/helmet/
mikejhjr
Report this Post08-30-2008 08:57 PM Click Here to See the Profile for mikejhjrSend a Private Message to mikejhjrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced the water pump and changed the belts. Then flushed the system and refilled it. I'll be driving and washing it tomorrow.
katatak
Total ratings: 82
Report this Post08-30-2008 11:38 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started tearing the cradle/trans apart for reconditioning!
americasfuture2k
Total ratings: 105
Report this Post08-31-2008 04:24 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced my HO2 sensor cause the other one was toasted. the ecm saw no signal, so it dumped every bit of gas that walbro 255 and 3800 sc injectors could put out. sucked almost a whole tank in 7 miles.
1987 Fiero GT built by my brother, merlot566jka, 3500 LX9 from 06 Malibu, WOT-TECH.com 1280 grind stage 3 cam, LS6 valve springs, 1227730 ECM conversion, Darrel Morse solid aluminum cradle mounts, Truleo headers modified to fit the 3500, 36# inectors, 70mm 4.3 throttle body adapted to 3500 intake, ported heads, upper and lower intakes, lightly polished, tcemotorsports.com crank trigger wheel, CenterForce dual friction clutch, Flowtech Afterburner muffler, 2.5" piping, cat deleted, EGR deleted, SinisterPerformance tuning, C6 Corvette exhaust tips. projected to be 35 MPG with a guesstimate of 250 hp to the wheels
Stubby79
Total ratings: 58
Report this Post08-31-2008 08:54 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Painted LH rear supension parts; held up "new" headlights to give me an idea of how they'll look and fit, test-fitted coolant overflow bottle for engine compartment (perfect fit, btw!) and measured seats for swap. The day is young yet!
Madscanner
Report this Post08-31-2008 01:17 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday, swapped my old 14" Tech alloys for the 15" Diamond Spokes with new rubber and had the brake fluid changed.
Today, went for an early morning drive with a few like-minded people - interesting to compare the Moving Average speed with the Maximum Speed...
'85 SE 2M6 automatic w WS6 suspension, factory sunroof, slightly modded interior, after-market cold air induction kit, rear spoiler, original Tech alloys, component speakers instead of the 4x10s.
Outstanding tasks - adding electric windows, locks, and mirrors (all the bits sitting around in a box, awaiting time...), new wheels and rubber, as well as rear adjustable coilovers, and poly bushings all 'round.
Madscanner
Report this Post08-31-2008 01:23 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Madscanner
Member since Dec 2004
Some of the like-minded.....
topher_time
Total ratings: 64
Report this Post08-31-2008 01:59 PM Click Here to See the Profile for topher_timeSend a Private Message to topher_timeEdit/Delete MessageReply w/QuoteDirect Link to This Post
TVR Wish I could get one over here... they won't even let me import one
Back on topic, I looked at my Fiero and got a few more ideas for body work. It is sitting on jack stands waiting for the suspension bits I purchased from KEV to get here, once that is done I can take it for a drive and find out how the new 3500 does, may need to tweak the tuning a bit more but should be ok for now.
Madscanner
Report this Post08-31-2008 02:32 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took it easy today, as I haven't finished fettling the suspension yet. I've got new KYBs on the front, but need to do the poly bushes, finish off the adjustable coilovers for the back, and then get a proper alignment done. Ideally, I'll need to look at the problem with the front end lift over 100 mph before I'll be keen on taking it to the limit. I'd be keen on something subtle like venting the radiator area to the wheel wells rather than something obvious through the bonnet...
Why can't you import a TVR?
BTW - out of the 18 cars out this morning, 4 failed to make the cafe at the end - the Lambo (electrical fault), Sebring (snapped throttle cable - car is 10 months old...) the 4.3l pre-cat Griffith (blown manifold gasket), and the Chimera 400 (electrical problems causing mis-firing) - Looks like the ghost of Joe Lucas, aka the Prince of Darkness, was hanging around - anyone who has ever had a car with Lucas electrics will know what I mean
'85 SE 2M6 automatic w WS6 suspension, factory sunroof, slightly modded interior, after-market cold air induction kit, rear spoiler, component speakers instead of the 4x10s, poly bushes on the cradle, swapped the 14" Tech alloys for 15" Diamond Spokes...
Outstanding tasks - adding electric windows, locks, and mirrors (all the bits sitting around in a box, awaiting time...), as well as rear adjustable coilovers, and poly bushings all 'round.
[This message has been edited by Madscanner (edited 08-31-2008).]
katatak
Total ratings: 82
Report this Post08-31-2008 04:04 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed the tierods, knuckles, a arms, motor mount, trans mounts, heat shileds, etc from my cradle and test fitted the rear poly bushings. This afternoon, I will remove the rubber bushings from the fron of the cradle and the A arms.
White Spyder
Report this Post08-31-2008 04:30 PM Click Here to See the Profile for White SpyderSend a Private Message to White SpyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Painted the wheel well and calipers BLACK.
cunninghamsean
Report this Post08-31-2008 08:50 PM Click Here to See the Profile for cunninghamseanSend a Private Message to cunninghamseanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced all the brake lines from the Master Cylinder to each caliper. The old ones were super rusty. I also replaced the shocks and struts, also rusty and totally shot.
Sean
Report this Post09-01-2008 02:01 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had rebuilt my distributor, so I needed to time the engine when I put the distributor back in. I had never worked on a 2.8L engine before I bought this ‘86 GT in March (as my other Fieros are Dukes), so everything/anything I’m doing on this engine is new to me.
Well, no matter what I did I couldn’t get the dog-gone engine timed properly. When I followed the proper procedure, the engine would stall at 10 degrees BTDC.
To make a LONG story short, it appears the outer hub of the harmonic balancer has spun on its rubber mount. Just my luck the FIRST time I ever try to time a 2.8L engine, the timing marks are all screwed up.
Anyway, just for now I've inscribed a new timing mark on the harmonic balancer. This mark really is at TDC. Once I did that, timing the engine was a piece of cake.
If anyone has a good used harmonic balancer in their stockpile of spare parts, please give me a shout!
americasfuture2k
Total ratings: 105
Report this Post09-01-2008 02:04 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
i tightened up my loose header bolts, replaced the missing ones, replaced my OPSU with one that still didnt work like it should and realized my LR caliper has been leaking. got another LR caliber from bubbajuju.
katatak
Total ratings: 82
Report this Post09-01-2008 12:18 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent 50 bucks on degreaser and the pressure washer cleaning my trans, cradle and suspension parts. What a mess...... It's done now. I can start the rebuild...
americasfuture2k
Total ratings: 105
Report this Post09-01-2008 02:19 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
i bet just seeing that all clean looks outstanding
Stubby79
Total ratings: 58
Report this Post09-01-2008 02:34 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did all that....just to start removing the rust! It's worth it though, when you compare what was to what is.
katatak
Total ratings: 82
Report this Post09-01-2008 03:03 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fortunately, No Rust! But lots of grease and dirt from rear main leak and trans leak. Tomorrow the cradle, knuckles and a arms are off to the bead blaster. I will powder coat the knuckles and por15 the cradle and arms.
Can't decide wether to paint the trans or not? After all, this will be the daily driver. I hate to put too much detail in it cause once it's back up and running, I doubt I'll give it much attention other than routine maintenance. I do like everything to be clean and neat though. Nieghbors are already asking if I will paint the calipers, clean up the wheel wells, etc. I really just want to get it back together so I can drive it but you never know!
Stubby79
Total ratings: 58
Report this Post09-01-2008 03:16 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
The oil will come off of paint easier than it will bare metal. If it's already clean enough, it'll only take 5 min. to paint.
zero2sixtyin2pt8
Report this Post09-01-2008 03:40 PM Click Here to See the Profile for zero2sixtyin2pt8Send a Private Message to zero2sixtyin2pt8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ordered a bunch of parts... I only have two weeks before I head home and can drive it for the first time.
falcon_ca
Report this Post09-01-2008 04:49 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed a battery relocating box under the spare tire
"So, let me get this straight, Your Honda has 1.6 liters, whereas my bottle of Pepsi has 2 ?"
Curlrup
Report this Post09-01-2008 05:56 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
New O2 sensor, and oh guess what? Turns out the car has not had a thermostat for the last year, even though the PO told me he put one in. Never trust a redneck with a unique car. Hopefully this is the last Redneck Engineered cooling system tweak I will have to reverse. If I ever see that man again I swear he willnot be a happy person.
ShockWave
Report this Post09-01-2008 09:16 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
New Spark Plugs and Yellow wires.
Back On Holiday
Report this Post09-01-2008 09:30 PM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice clean engine
87notchie4
Report this Post09-03-2008 01:51 AM Click Here to See the Profile for 87notchie4Send a Private Message to 87notchie4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got my Hobbyist Liscense plates in the mail today, they are now on my car. They are good for LIFE, I never have to pay registration again!
For you guys in who are wondering what the heck a hobbyist plate is, here in Wisconsin we have:
Antique- Lifetime registration, for stock vehicles, one time fee, must be 50 years or older, NOT VALID during the month of January.
Collectors- Lifetime registration, for stock vehicles, one time fee, must be 20 years or older, NOT VALID during the month of January. Hobbyist- Lifetime registration, For street modified vehicles, one time fee, must be 20 years or older, NOT VALID during the month of January.
In order to qualify for any of the above plates you must already have a regular Wisconsin registration(they want their yearly money from everyone), if your married you both must have one regular Wisconsin registration(If I register before marriage, my registrations are grandfathered). Pay attention here comes the loophole- since we also have collectors available for motorcycles, a regular motorcycle registration qualifies. Motorcycle registration is Bi-annually(every other year) and it's only $23(or $11.50 a year), unlike the $75 a year for the standard auto plate.
So you might be asking yourself, What does he do in January? Good question, me and my woman share her truck all winter, but if I had to the DMV has temp plates for the month of January for $36. If you are caught in Jan on the road without one the law will issue a citation for an unregistered vehicle. The down side is she wants me to share my Fiero all summer, which I guess is fair... grumble, grumble, grumble.
katatak
Total ratings: 82
Report this Post09-03-2008 04:14 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Split the 4 spd case and inspected for wear and tear. None noted. Will replace the axle seals, output shaft seal and reseal the case halves tonight.......
Old Lar
Total ratings: 214
Report this Post09-03-2008 07:44 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I pulled my 88GT out and put some gas in the car...first time since June, coming back from the Dells Run. $3.669/gallon today. Getting ready for a cruise in up in Titusville on Saturday as it looks like Hanna ig blowing east of the Florida penninsula.
Larryh86GT
Report this Post09-03-2008 09:29 PM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Applied pegasus decals to my hubcaps.
OHNIKO
Report this Post09-03-2008 09:36 PM Click Here to See the Profile for OHNIKOSend a Private Message to OHNIKOEdit/Delete MessageReply w/QuoteDirect Link to This Post
...installed a Mr Mike's red leather console cover, loooks nice.
Stubby79
Total ratings: 58
Report this Post09-03-2008 11:24 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's one nice looking car!
pswayne
Report this Post09-04-2008 01:43 PM Click Here to See the Profile for pswayneSend a Private Message to pswayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
ITo make a LONG story short, it appears the outer hub of the harmonic balancer has spun on its rubber mount. Just my luck the FIRST time I ever try to time a 2.8L engine, the timing marks are all screwed up.
Maybe you don't have a stock balancer on your car. Later ones have the timing marks in a different place.
Stubby79
Total ratings: 58
Report this Post09-04-2008 03:12 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Painted some more rear suspension/drivetrain parts!
katatak
Total ratings: 82
Report this Post09-04-2008 03:18 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing yet but the day is still young - will install new seals and put the trans back together this evening - I hope......
Pat
Report this Post09-05-2008 02:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's possible I suppose, but I would've thought if that was the case that whomever replaced it would've also inscribed a TDC mark in the proper location (for a Fiero) before installing it. I've gone on the assumption that the outer ring of the balancer has spun on the inner hub, and I don't want this engine vibrating any more than necessary.
Here's a picture that JazzMan posted ages ago of the relationship between the keyway on the inner hub and the TDC timing mark for number 1 & 4 cylinders on the outer ring (at 9 o'clock). When I take my crank pulley off I guess I'll know for sure whether my balancer has spun or if it's simply a balancer for a non-Fiero 2.8 engine.
Anyway, I have a replacement harmonic balancer off a seized 2.8 coming from another PFF member. I love this forum!
[This message has been edited by Patrick (edited 02-04-2018).]
Englishrafe
Report this Post09-05-2008 02:33 PM Click Here to See the Profile for EnglishrafeSend a Private Message to EnglishrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed my battery gauge.
It's been reading 18V since I got the car in Febuary and it was starting to annoy me!
Simple really - just pulled off (carefully) the needle while the engine was running and pushed it back on at (my estimate) 14.2V.
Rev counter next --> I'm just waiting to get a 1Mohm variable resistance.
falcon_ca
Report this Post09-05-2008 09:32 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed my 91 Grand-Prix leather steering wheel.
Because of an injury to my left hand I needed a bigger grip
""I'm not driving too fast, . . . I'm just flying too low."
Report this Post09-06-2008 03:37 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a code 44 (lean exhaust) to check out, so I did a number of things. I replaced the fuel filter (the car had been sitting for six years), adjusted the TPS sensor voltage at idle (was .89 instead of .55), and swapped out the O2 sensor from one of my Dukes (which hasn’t run for five years). The O2 sensor I took out of the GT is the one on the left. The one from the Duke that I used to replace it is on the right.
After doing the above procedures and clearing the codes, I went for a half-hour drive on the freeway. No check engine light, no codes. WOO HOO...
Can you guess what’s going on here?
I had a new heater core that was “suspect” (because of some shipping damage), so PFF member Watts suggested this little trick of using a bicycle inner tube to put some air pressure in the core and then checking for bubbles. Great idea, eh?
americasfuture2k
Total ratings: 105
Report this Post09-06-2008 05:24 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
burned a new chip, popped the INJ 2 fuse multiple times, so it stays parked till daylight.
1987 Fiero GT built by my brother, merlot566jka, 3500 LX9 from 06 Malibu, WOT-TECH.com 1280 grind stage 3 cam, LS6 valve springs, 1227730 ECM conversion, Darrel Morse solid aluminum cradle mounts, Truleo headers modified to fit the 3500, 36# inectors, 70mm 4.3 throttle body adapted to 3500 intake, ported heads, upper and lower intakes, lightly polished, tcemotorsports.com crank trigger wheel, CenterForce dual friction clutch, Flowtech Afterburner muffler, 2.5" piping, cat deleted, EGR deleted, SinisterPerformance tuning, C6 Corvette exhaust tips. projected to be 35 MPG with a guesstimate of 250 hp at the motor
