  What Did You Do To Your Fiero...TODAY ? (Page 32)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223256 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
hookdonspeed
Total ratings: 131
Report this Post12-22-2008 10:01 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
i started to give mine a tuneup and change all the sensors to try to get it to run right...
got the front 3plugs changed, new cap/rotor, the wires changed, and new TPS.
i started to freeze before i got to do anymore, trying to reach behind the the block to do the rear plugs, while my hands are going numb just wasnt gona happen... and i couldnt find my larger socket set to get the IAC or CTS.
i did findout that i have a rather nasty oilleak on the front valvecover that coated the old plugs/wires pretty nicely... yay for that....
Spoilt_87fiero
Report this Post12-22-2008 07:16 PM Click Here to See the Profile for Spoilt_87fieroSend a Private Message to Spoilt_87fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by topcat:
Detailed it
1. Clay Bar
2. McGuires Car Polish
3. McGuires Wax
Looks great!
I agree did you get your stripes put on yet?
topcat
Total ratings: 148
Report this Post12-22-2008 09:16 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, notyet. I had originally planned on getting it done last week, but as it turns out I worked a lot of hours before the holiday break, and the shop can not take the car until after the New Year.
Cheever3000
Total ratings: 178
Report this Post12-22-2008 09:50 PM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got mine back from the shop (again) today. This time it was the fusable link by the starter.
The pickup lost its water pump and I had it towed home to fix another day, so the 84 Fiero is my only ride now. But I'm not complaining.
falcon_ca
Report this Post12-27-2008 07:14 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I completed the front end rebuild.
Everything including cross-member has been sandblasted and painted with POR-15
All new ball joints. Lower are Rodney's 1 inch "Knuckle raiser".
New exterior tie-rod end
Poly bushings.
New KYB GR-2 shocks.
Most of the bolts and nuts are new.
""I'm not driving too fast, . . . I'm just flying too low."
Restoration pictures
VirtualShowCar
4.9 ongoing project
katatak
Total ratings: 82
Report this Post12-27-2008 08:56 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
NOTHING!
Freaking called into work!
Report this Post12-27-2008 09:40 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dug mine out of a snowdrift.
neph
Report this Post12-29-2008 12:16 PM Click Here to See the Profile for nephSend a Private Message to nephEdit/Delete MessageReply w/QuoteDirect Link to This Post
Peered out my front window at it sitting on my front lawn, with a fried clutch
Madscanner
Report this Post12-31-2008 05:13 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed one of my home-built adjustable coilovers...
-5, working outdoors, on the side of the street - yuk!
Will try to get the other one done tomorrow... (start the year as I intend to finish it!).
Ciao!
'85 SE 2M6 automatic
'84 SE 2M4 manual
'98 Ford Mondeo Si
'73 Peugeot 304 S Cabriolet
mrfiero
Total ratings: 150
Report this Post01-02-2009 12:21 AM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a brake job on the '88 coupe today. New pads and rotors up front (went on without any problems) and a new left rear caliper and new pads & rotors out back too. I only ordered the left rear caliper because it was obviously seized (got very hot when driven), but as luck would have it, teh right rear caliper was also seized. It was seized, but not contacting the rotor so it didn't get hot like the drivers side. So now I have 3 out of 4 new brakes!
The kicker is when I had the caliper loose and attempting to screw in the piston, I actually wound up pushing it out further and it would not go back in. Then, in a vain attempt to press it in, I used a big clamp and busted off that little plastic button on the piston and it leaked fluid everywhere. I had to borrow an old core from a friend just to get it back together! It works, but has a small leak somewhere.....I can't get all of the air out so the pedal is spongy.
Tomorrow I get to go back and get the alignment done for a third time. Maybe they'll torque down the upper control arm bolts this time.
Oh well.....I'll have it figured out soon.
Total ratings: 463
Report this Post01-02-2009 01:20 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bolted the engine back into the cradle.
(Dropped the 4.9 to repair multiple oil and coolant leaks.)
Going to drop the tank tomorrow to replace the fuel pump and recalibrate the sender. (Sucks wind at ~1/4 tank indicated.)
88 4.9 Formula IMSA Fasback..........................88 3.4 coupe -soon to be something other than red
Read Nealz Nuze! Praise the Lowered!
Sharkman
Report this Post01-02-2009 01:47 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Working on my F355 front. Want it to fit correct.
Regards SHARKMAN
Europe # 1 choptop
http://www.fieroforum.se/fo...=1342&st=0&sk=t&sd=a
http://www.fieroforum.se/fo...topic.php?f=10&t=173
[This message has been edited by Sharkman (edited 01-02-2009).]
RCR
Total ratings: 102
Report this Post01-02-2009 04:21 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Hung some shelves in the garage so I can get at the car.
Bob
2hot2handle
Report this Post01-02-2009 04:56 PM Click Here to See the Profile for 2hot2handleSend a Private Message to 2hot2handleEdit/Delete MessageReply w/QuoteDirect Link to This Post
i cut all my fenders, cut out the trunk , and are working on mounting a set of 31.10.50 super swampers on it
randye
Total ratings: 204
Report this Post01-03-2009 08:37 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got these installed today.
More paint on them tomorrow and then cut & buff, install trim and wait for hex screen mesh material to arrive to finish em'.
katatak
Total ratings: 82
Report this Post01-04-2009 12:34 AM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rebuilt the front calipers, Rebuilt the rear calipers, installed new rotors in the rear, new hub/rotors in front, stainless braided lines all four corners, flushed the lines Finish it up tomorrow.
RWDPLZ
Total ratings: 305
Report this Post01-09-2009 10:50 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Basic tune-up, including
R43TS6 spark plugs
plug wires
distributor cap and rotor
Air filter
PCV valve
breather filter
fuel filter
oxygen sensor
purchased new positive battery cable, waiting for negative cable from dealer.
pontiackid86
Total ratings: 344
Report this Post01-10-2009 08:27 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
what did i do to my fiero day hmmm i bought her
fordmuddin27
Report this Post01-10-2009 08:33 PM Click Here to See the Profile for fordmuddin27Send a Private Message to fordmuddin27Edit/Delete MessageReply w/QuoteDirect Link to This Post
walked a mile in 10 degrees to a parts store for some dot 3 because my clutch decided to spring a leak
red84fieroman
Report this Post01-10-2009 08:34 PM Click Here to See the Profile for red84fieromanSend a Private Message to red84fieromanEdit/Delete MessageReply w/QuoteDirect Link to This Post
having just bought her jan. 1st, she seems to have been sitting for at least a decade (only 80k miles)
took 2.5 carburetor out and cleaned it, im gonna need to buy a rebuild kit since the injector and everything around it is dirty messed up looking, my dad said he noted rust but i didnt see anything bad, he;s the mechanic though. Cleaned the spark plugs, one was so bad the car was only running off 3 cylinders. Now the car almost feels like a new car, the engine is pushing me even smoother, even when it was 3 cylinders the car was smooth so now its even more dreamy.
Cleaning the carb got the idle down a bit but it still idles high when cold
White Spyder
Report this Post01-11-2009 08:23 AM Click Here to See the Profile for White SpyderSend a Private Message to White SpyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the starter for replacement.
RCR
Total ratings: 102
Report this Post01-12-2009 07:03 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely nothing, and that's the way it will stay until I get my full wages back..Just got hit by cut-backs today at work, and I was just going to buy all the parts to finish the front suspension (15% off at the Fierostore tomorrow)..Lucky I still have a job and internet...
Bob
[This message has been edited by RCR (edited 01-12-2009).]
mrfiero
Total ratings: 150
Report this Post01-12-2009 07:12 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I repaired a bad splice job on a fusible link that had me running only on battery juice. I'm glad it wasn't a bad alternator like I suspected......MUCH easier to resplice in a connector than remove an alternator from a quad-4!
Knock on wood, I think I have everything fixed well enough to actually start using the coupe as a daily driver, which was my intent when I bought it. Cross your fingers.
Robert 2
Report this Post01-12-2009 09:05 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tried the car , after a 37795 with a MR2 piston swap on my 88 GT with a gétrag .
Had no choice of using it , part store gave me the wrong piece for my other car and i was stuck at home with it dismantled , and no other car than the Fiero to move along .
[This message has been edited by Robert 2 (edited 01-12-2009).]
Sharkman
Report this Post01-13-2009 09:19 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Home made LED parking lights and H3 lamp with LED.
[This message has been edited by Sharkman (edited 01-13-2009).]
avengador1
Total ratings: 571
Report this Post01-13-2009 10:15 AM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I took all my personal stuff out of it, so that it can be picked up for transport to it's new owner.
americasfuture2k
Total ratings: 105
Report this Post01-13-2009 12:45 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow, i like that white LED look from that lens. i should go for the f355 front..... now where do i attain one of these?
First LX9 Fiero GT, 1987
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
My Fiero Fuel Economy
Videos of My GT
Google Videos of My GT
86fierofun
Total ratings: 62
Report this Post01-13-2009 03:51 PM Click Here to See the Profile for 86fierofunSend a Private Message to 86fierofunEdit/Delete MessageReply w/QuoteDirect Link to This Post
I changed the heater core outside in -9 degree windchill.
*shivers*
Wisconsin is fun......
Snapperhead
Report this Post01-13-2009 04:15 PM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was doing some trans work on the blue V8 GT at the shop this weekend and when unloading it off the trailer at home it slipped off the winch and rolled down the yard to nicely wack into the barn wall. It was a very nice moment in life. Just took out a right fender and the front bumper. I'm looking for the replacements now 86 GT aero style smooth moulding if you have one. Must be in good condtion not worried about the paint as it will be repainted.
Thanks, Vince
Sharkman
Report this Post01-13-2009 04:30 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The European f355 fronts are hard to get hold of. I got mine 3-4 years ago and havent got it on the car until now.
Mine is the same as Yellowstones.
Fieroking
Total ratings: 78
Report this Post01-13-2009 10:54 PM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed this
In the car but not hooked up
Other side
Getting closer
Happy New Year
Joe Sokol
85 SE Daily driver with a 3.4 DOHC build underway
88 Formula/GT 4.9 Allante Intake (My Baby)
hookdonspeed
Total ratings: 131
Report this Post01-14-2009 05:52 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
bout to goto the shop and finish the last corner of my suspention
new bushings, new shocks/sturts. new springs, ball joints, tie rods, etc
and possibly install the rear swaybar
h
Cdn2m4
Report this Post01-14-2009 06:04 PM Click Here to See the Profile for Cdn2m4Send a Private Message to Cdn2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got a bunch of parts ready to be installed, Rodney Dickmans comp shifter II with new boot/ring and cold air intake kit, a pillar gauge and gauges, k&n air filter, the fiero store gold ion head light kit and clear front signal lights. Now i just have to wait for all the snow up here to melt and i can maybe start installing these.
katatak
Total ratings: 82
Report this Post01-14-2009 11:07 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well lets see.....
Finally received my parts form the Fiero Store and got all the calipers rebuilt and installed.
topher_time
Total ratings: 64
Report this Post01-14-2009 11:17 PM Click Here to See the Profile for topher_timeSend a Private Message to topher_timeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it back. New owner decided he didn't want it, after a couple weeks. There are some parts missing
FieroJam
Report this Post01-15-2009 06:58 AM Click Here to See the Profile for FieroJamSend a Private Message to FieroJamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the Manifold Air Temperature sensor, the Idle Air Control Valve and the o-rings on the fuel injector. Will be pulling the coil packs today and inspecting the spark plug wires to see what is causing cylinder 1 not to fire intermittently.
joeveto
Report this Post01-15-2009 09:40 PM Click Here to See the Profile for joevetoSend a Private Message to joevetoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did the unthinkable, and cranked it over when it was near zero in the garage, just so I could drag my butt to the gym. Never feels right.
Spent my days with a woman unkind Smoked my stuff and drank all my wine...
wlftmldr
Report this Post01-19-2009 11:26 PM Click Here to See the Profile for wlftmldrSend a Private Message to wlftmldrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed the oil and worked on making my poor brakes look a bit better.
Yuck!
Much better.
PS... Red caliper paint adds at least 10 hp.
americasfuture2k
Total ratings: 105
Report this Post01-22-2009 07:47 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
tested some more wiring on the DIS side now. still a no go back to work on either the next warm day (HA!) or when i get it into a garage when i move next month. cant wait!
Videos of My GT
americasfuture2k
Total ratings: 105
Report this Post01-22-2009 07:50 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
americasfuture2k
Member since Jan 2006
Originally posted by Fieroking:
good luck with your coilpack right there. unless you have completely covered vents and will never drive in the rain or after you wash it.
Videos of My GT
