  What Did You Do To Your Fiero...TODAY ? (Page 35)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223291 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
Report this Post03-03-2009 10:04 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wouldn't just the senor have done it?
RCW
Report this Post03-03-2009 03:55 PM Click Here to See the Profile for RCWSend a Private Message to RCWEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, probably but the threads in the manifold were stripped from P.O. New unit would not screw in. The manifold looked like it had been repaird a few times. Thought what the heck, as long as I am here I may as well put on the new one I already had.
It did not run any different as it still had a intermittant stumble at idle. So, I thought what the heck, I am already here so go ahead and reseal the intake and throttle body as they were not the cleanest looking anyway.
You know the rest of the story.
I am still trying to get a smooth, stable idle but from what I here on the forum I may be chasing the end of the rainbow.
Just in case you were thinking it. It is not the EGR valve as it tested out just fine and I even removed it and installed a block off plate. Soooo, no leaking EGR.
TPS is good, MAP sensor is good, (test good and is the same as one in 86 GT, even swapped em to make sure) Engine temp sensor checks out. Fuel pressure is good.
The coil packs are new and check out. The ignition module is new and checks out as is the crank position sensor. New wires and AC plugs.
Last thing to check is a leakdown test. Compression is awsome at 160 PSI in all four holes.
Except for the intermmitant stumble at idle it pulls strong and does not miss a beat.
Guess I will just drive it and be happy.
ShockWave
Report this Post03-03-2009 11:30 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fought with emblems and glue today, and later hit 88,888.8
telefragg3d
Report this Post03-04-2009 12:25 PM Click Here to See the Profile for telefragg3dSend a Private Message to telefragg3dEdit/Delete MessageReply w/QuoteDirect Link to This Post
well this weekend i'm going to replace my sway bar bushings, endlinks, and wheel bearings!
Jarhead 2m4
Report this Post03-04-2009 02:05 PM Click Here to See the Profile for Jarhead 2m4Click Here to visit Jarhead 2m4's HomePageSend a Private Message to Jarhead 2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I painted my cracked and chipped engine vents with some BBQ grill & stove paint. They turned out alright. Could use some sanding, but I am happy enough with them being all one color.
Total ratings: 463
Report this Post03-07-2009 01:20 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally finished with the 4.9 timing cover and water pump re-gasket (for the second time. Long story. )
Put the car back on its wheels last night. Moved it around in the garage and checked for leaks.
Drove it to the local Mexican joint tonight for waaay too much food.
88 4.9 Formula IMSA Fasback..........................88 3.4 coupe -soon to be something other than red
Read Nealz Nuze! Praise the Lowered!
Solid Hex
Report this Post03-07-2009 06:52 PM Click Here to See the Profile for Solid HexSend a Private Message to Solid HexEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swapped out the front brakes (calipers and all) from the 84 to the 86 since the 86 was pulling to the left and now all is fine!
Checked the back ones while I was at it and have come to the realization that some people should not be allowed to play with impact guns! If someone had ever had a flat and had to use just the tire tool I doubt they could have gotten the rear wheels off!
After taking it for a spin I believe it'll be ready for a return to service once I take care of a couple of little things.
[This message has been edited by Solid Hex (edited 03-07-2009).]
Old Lar
Total ratings: 214
Report this Post03-09-2009 11:23 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time for a tune up on my 87 GT. It has been a couple of years and maybe 10K miles since the last tune up.
Guess which plugs are the firewall side.
I don't drive the car in that much rain.. Check your plugs!!!
I also took the car to the AC shop that converted the system 134a in 05. It checked out fine, ready for summer cruising.
unboundmo
Report this Post03-09-2009 03:44 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
double post.....??????
[This message has been edited by unboundmo (edited 03-09-2009).]
unboundmo
Report this Post03-09-2009 03:45 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
unboundmo
Member since Sep 2006
Triple post...???? WTF
unboundmo
Report this Post03-09-2009 04:41 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
unboundmo
What the heckkk.... NO POST
Anyway.. Here we go again....
I'm trying to get my stage II scoops finished to get them out of the way for..........
see how high the GT body line is compared to the new scoop..... NEEDS TO BE FIXED
I WANT IT DONE ALREADY!!!!!! I WANT TO START SOMETHING ELSE.... SOMETHING LIKE
AND ALL THE PORT AND POLISH TO GO WITH IT -- IS DONE TOO!!!!! All I want is some spare time in-between the 2 jobs that I have to finish it....... PLEASE!!!!
rebuilt long block was done by S&S Engines even with using my custom components--- www.hiperformer.com
americasfuture2k
Total ratings: 105
Report this Post03-09-2009 05:20 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
just pulled my harness again for the umpteenth time and found even more mistakes. blasted! im going by my GM sources for the wiring conversion rather than darths setup. sorry man, but your stuff just isnt "clicking" with me.
First LX9 Fiero GT, 1987
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
My Fiero Fuel Economy
Videos of My GT
Google Videos of My GT
MPG Display for OBD I
Tony Kania
Total ratings: 305
Report this Post03-09-2009 05:23 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You mention S&S as being your builder. Is it the company out of Spokane, WA? Just curious, because S&S built my 3.1 stroker short block last summer. Very happy with them. You made me pull out my paperwork to make sure that I remembered correctly.
unboundmo
Report this Post03-09-2009 05:51 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes... S&S Engines is in Spokane Washington.... I would recommend them to anyone wanting ANY engine done.. Reed was my sales and contact guy there and nothing but TOP NOTCH from him.. Very professional and knowledgeable. They were even interested in my set-up because they never came across anything like that - not like others.... Plus they were willing to use my supplied components and since everything picked out was by their guide lines, they have a warranty on my block too.
It's a 3.4 P/R bored 0.030 over. They ported and polished the heads - very nice I might add (looked like a CNC did it, Honest), precision ground crank and balanced with the flywheel and pressure plate, ARP bolts, Ross pistons, ARI connecting rods, SI stainless valves, 260 comp computer cam with performance springs, Clevite bearings, crane 1.6 gold series rockers, chrome moly pushrods.
DID I MENTION THAT I'M SO HAPPY ON HOW EVERYTHING HAS TURMED OUT!!!!
GET IT RUNNING ALREADY!!!!
Brother Rat
Report this Post03-09-2009 07:20 PM Click Here to See the Profile for Brother RatSend a Private Message to Brother RatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the rear vent covers done as far as polishing goes, and I got them clearcoated. The left front brake has been pulled for new pads and paint. The left front suspension was painted in low gloss black.
I'll have some pics tomorrow of the vent covers.
Pete
Tony Kania
Total ratings: 305
Report this Post03-09-2009 08:45 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to see pics of your vents. I will be watching.
Spoon
Total ratings: 61
Report this Post03-09-2009 09:46 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I replaced the battery in my Fiero. It went dead over winter and apparently turned to water enough to freeze. It was all swelled up.
Thats it...
Spoon
1MohrFiero
Total ratings: 157
Report this Post03-10-2009 07:08 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the headlight control module with another used one from a junk yard. I really need to buy a new the last one only lasted 5 years. Now my right hand looks like I have been in a cat fight from fighting with the wheel well cover and the fender. Why did GM stick this thing under the fender when it would have been fine under the front bonnet???
Brother Rat
Report this Post03-10-2009 08:00 AM Click Here to See the Profile for Brother RatSend a Private Message to Brother RatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the vent covers so far.
Pete
falcon_ca
Report this Post03-10-2009 08:37 AM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pete
Wonderfull job !!!
""I'm not driving too fast, . . . I'm just flying too low."
Home of the Thestral Fiero[
VirtualShowCar
4.9 ongoing project
Tony Kania
Total ratings: 305
Report this Post03-10-2009 10:08 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
As stated above, wonderful job. I like when folks do things like that. Just shows that you care about your things. Got any pics with them on the car? Sorry to be so pushy. I just really like that idea.
Mickey_Moose
Total ratings: 145
Report this Post03-10-2009 01:05 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Leave it in the garage:
Current Weather Updated: Tuesday, March 10, 2009, 11:00 MDT - Edmonton City Centre Arpt
-26°C -14°F
Wind: SW 6km/h
Sunrise: 7:59
Sunset: 19:29
Relative Humidity: 69%
Pressure: 103.86 kPa
Visibility: 11.0 km
Ceiling: unlimited
...help your northern neighbours, contribute to 'global warming' and burn some tires and styrofoam today.
thismanyfieros
Total ratings: 120
Report this Post03-10-2009 01:14 PM Click Here to See the Profile for thismanyfierosSend a Private Message to thismanyfierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
big baby ^^^^^^...hehe tim
unboundmo
Report this Post03-10-2009 03:37 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the two tone concept with the vents.. Very original. --- I do see black with polished metal right?
Brother Rat
Report this Post03-11-2009 09:09 AM Click Here to See the Profile for Brother RatSend a Private Message to Brother RatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tony; Thanks, I have pics of them on the car but the car looks crappy right now, so they don't look as nice. But here's a couple of pics with them in place.
Yes they are polished and black.
Got the left front caliper painted last night and the left sfront shock mounted back in place. Ordered new front flew hoses from the Fiero Store.
Mickey_Moose
Total ratings: 145
Report this Post03-11-2009 09:28 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
you better believe it...and if I recall, your car is in a similar spot...
[This message has been edited by Mickey_Moose (edited 03-11-2009).]
Tony Kania
Total ratings: 305
Report this Post03-11-2009 11:48 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Brother Rat. I have fabricated several aluminum pieces for mine, and really like the twotone black and polished look. I understand about your pics with the vents on the car. Work in progress. I may do this here soon. Thanks for the inspiration. Peace!
unboundmo
Report this Post03-11-2009 12:07 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did the final spread of fiber glass resin jelly on the imperfections that I can see on the panels last night.
Question... When I'm done with all the sanding and what not - shaping, my next step that I would take......
I like the smooth glass look for a final finish and then sanded with 400-800 grit. If I pour liquid resin with hardener onto the panels for strength and to fill in the pin holes and imperfections that I can't see... Hoping for NO runs laying the panels flat and not upright to allow drying.... Would this be correct to do? Or do most people just lay down bondo style resin and spread it all over heavy and then sand it back?
I'M TIRED OF SANDING
Second question....... What "sandable" primer should I use knowing that they will be painted professionally with the maroon car acrylic paint..... Or should I just leave it to the body shop?
I did what I explained above to some mod low profile headlights that I'm fabbing too sometime back and it work perfect... still in progress )
thismanyfieros
Total ratings: 120
Report this Post03-11-2009 07:46 PM Click Here to See the Profile for thismanyfierosSend a Private Message to thismanyfierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah but my garage isnt heated...and my 88 is buried in a snow bank ....lol...i win...tim
Mickey_Moose
Total ratings: 145
Report this Post03-12-2009 01:12 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wish mine was too - maybe this summer it will finally get done.
Madscanner
Report this Post03-15-2009 07:45 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Repaired the fuel filler flap release mechanism on the '84.
Swapped three clean marker lights on the '84 for three cracked ones on the '85.
Bolted the fuse box in place on the '84 (left dangling since the previous owner converted it to right-hand drive).
Swapped the '84's cheapy 195/70-14s on scabby rims for 205/60-14s on my spare rims.
Tightened the loose fanbelt on the '84.
Removed the engine cover grille on the '84 to clean and paint.
johnyrottin
Total ratings: 85
Report this Post03-15-2009 08:29 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Uncovered the OEM 88 and checked to make sure the rubber band on the jack was still there...it is. Checked its oil and all other fluids. All levels good and clean but going to change the oil due to time its been in. (6 months)
Drove the 88 4.9 to church. Found a small crack in thewingstand so I need to sort that one out. Smiled at the V8 growl. Checked the oil and fluid level. Need to sort out a tiny squeek in the front left side of the beast.
falcon_ca
Report this Post03-15-2009 06:46 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Done this.
A vey good idea of Brother Rat. Thanks Pete for the inspiration.
They will be installed on my Formula as soon as it will roll out of the paintshop.
VirtualShowCar
4.9 ongoing project
topher_time
Total ratings: 64
Report this Post03-15-2009 06:50 PM Click Here to See the Profile for topher_timeSend a Private Message to topher_timeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those look pretty good!
I took delivery of my newest and installed a shorter shifter, the stock one just wasn't working for me.
johnyrottin
Total ratings: 85
Report this Post03-15-2009 08:31 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I really like those grills!!!!
chucks85fastback
Report this Post03-15-2009 08:32 PM Click Here to See the Profile for chucks85fastbackClick Here to visit chucks85fastback's HomePageSend a Private Message to chucks85fastbackEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced my auto transmission cooler lines. it took about 6 hours. i got the stainless ones from the fiero store so i wont have to do it again, they'll last longer than the car.
RCW
Report this Post03-15-2009 09:39 PM Click Here to See the Profile for RCWSend a Private Message to RCWEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just had to add a real big thumbs up for S&S and a little plug for thier business. I used to buy and sell thier engines in very large quantities. We are talking 100 small block Chevy at a time, and can tell you folks that the quality is as good as you can get. I am out of that business now but would not even consider having anyone but S&S touch an engine for me.
Just tell them that Ed from Cummins sent you.
infinitewill
Total ratings: 85
Report this Post03-15-2009 10:14 PM Click Here to See the Profile for infinitewillSend a Private Message to infinitewillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Falcon, those grills look sweet! Did you clear them as well?
pontiackid86
Total ratings: 344
Report this Post03-16-2009 08:26 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
my outer GT door pannels are finaly comming off. got one done so far. getting the other done today after work.
falcon_ca
Report this Post03-16-2009 04:41 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I did, with DupliColor clear Enamel.
VirtualShowCar
4.9 ongoing project
