  What Did You Do To Your Fiero...TODAY ? (Page 36)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6920 (219125 views)
Last post by: Doggo on 03-30-2025 09:15 PM
Tony Kania
Total ratings: 305
Report this Post03-16-2009 04:53 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I really like the aluminum and black look of the vents. I know that i will be doing mine here before too long.
Anybody that needs a motor built should definately look into S&S of Spokane, WA. Nice to hear that others have used them, and are just as satified as me. I only have about 1500 miles now on the new engine, and am completely satisfied with their work.
I also have made arrangements with my brother-in-law to stay with them during the week of June 7th for the Arlington event. Can't wait to take the drive out there. I have already mapped out the longest, twistiest route available.
My first page ownage!
[This message has been edited by Tony Kania (edited 03-16-2009).]
Jarhead 2m4
Report this Post03-16-2009 10:46 PM Click Here to See the Profile for Jarhead 2m4Click Here to visit Jarhead 2m4's HomePageSend a Private Message to Jarhead 2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got a lot done today. I put together my low-profile headlight buckets and put them in for a test fit. They look great and I put my own twist on them for a special effect. I can't talk too much about it, but I can't wait to show you guys! I finished making the wiring harnesses for them. That took a lot more work than I thought they would be.
I mocked up my speaker setup for a test fit and to see what it would look like. There is still some interior work going on.
Doing a special brake light mod. Again, can't spill the beans, but it is going to look awesome!
"Semper Fiero"
Brother Rat
Report this Post03-17-2009 11:29 AM Click Here to See the Profile for Brother RatSend a Private Message to Brother RatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by falcon_ca:
Done this.
A vey good idea of Brother Rat. Thanks Pete for the inspiration.
They will be installed on my Formula as soon as it will roll out of the paintshop.
Great job!!!
You're more than welcome, glad I could help.
Pete
LT188GT
Total ratings: 100
Report this Post03-17-2009 07:22 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started installing LED lights in the engine compt so people can see the engine at Miami's night time shows.
ShockWave
Report this Post03-18-2009 08:10 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ordered new door outer glass seals.
Tanlrat
Report this Post03-19-2009 12:19 PM Click Here to See the Profile for TanlratSend a Private Message to TanlratEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled three codes today on my 86 v6; 32, 34, 44. Thinking that it's the MAP is screwed since it is the common denominator between the three.
I also removed the battery checked out the corrosion, pretty bad will have to install the new tray soon. Reinstalled the battery put anti-seize on the the hold down and replaced the plastic shield.
unboundmo
Report this Post03-19-2009 03:16 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finish painting all mounts, brackets and heat shields last night plus started to do a final sanding on my stage II scoops. I'm on 220 grit paper and I want to sand it in 400 grit before I send to the painter. Tonight I will finish sanding and since I already have the gas tank dropped, I was thinking about swapping my fuel pump to the holley high flow one that I bought.
[This message has been edited by unboundmo (edited 03-19-2009).]
BoostedSeries1
Report this Post03-19-2009 07:35 PM Click Here to See the Profile for BoostedSeries1Send a Private Message to BoostedSeries1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got the motor in for wiring and pluming mock up.
Sorry it's kinda fuzzy...it didn't look fuzzy on my iphone
katatak
Total ratings: 82
Report this Post03-20-2009 03:18 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took my clear coat peeling, paint faded, slightly scratched up wing off the Formula to get rehabilitated.
unboundmo
Report this Post03-20-2009 04:33 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finish one scoop last night with a first coat of Auto primer after the days of sanding to a 400 grit... While that one was drying, I started to sand again on the other scoop panel. I'm on 220 grit work up to 400 grit.
Should finish these soon ,,,,,, I hope... NO MORE SANDING PLEASE!!
I didn't get to the fuel pump yet
Old Lar
Total ratings: 214
Report this Post03-20-2009 05:14 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed a better driver's side seat belt in the IMSA and reinstalled B pillar interior panel. I still need to re attach the B speaker cover as I snapped it off removing the panel.
I connected up the radio (am/fm/cd) into my 88GT. It works better than the one I took out. A "junk yard" find from a Pontiac Sunfire some 90's version.
ca420
Report this Post03-20-2009 06:23 PM Click Here to See the Profile for ca420Send a Private Message to ca420Edit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up my freshly powder coated cradle and put Rodney's bushing on.
ca420
Report this Post03-20-2009 06:25 PM Click Here to See the Profile for ca420Send a Private Message to ca420Edit/Delete MessageReply w/QuoteDirect Link to This Post
ca420
Member since Mar 2008
Tony Kania
Total ratings: 305
Report this Post03-20-2009 08:12 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mmmmmmmmmmmmm.....candy!
Spynx
Report this Post03-20-2009 08:20 PM Click Here to See the Profile for SpynxClick Here to visit Spynx's HomePageSend a Private Message to SpynxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced my front turning signal bulb. Wooooh!
katatak
Total ratings: 82
Report this Post03-21-2009 04:01 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finished porting and ceramic coating a set of V6 logs fof Gocart today. Then got my wing for the Formula back on the car. That's enough for one day.
Pat
falcon_ca
Report this Post03-21-2009 06:56 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried, for the forth time, to paint the black on the taillights of my Formula. I have to sand them again.
I hate rattle can paint !
""I'm not driving too fast, . . . I'm just flying too low."
Home of the Thestral Fiero[
VirtualShowCar
4.9 ongoing project
[This message has been edited by falcon_ca (edited 03-21-2009).]
shawnk
Report this Post03-21-2009 07:00 PM Click Here to See the Profile for shawnkSend a Private Message to shawnkEdit/Delete MessageReply w/QuoteDirect Link to This Post
i spent three hours in a pick and pull today tearing apart 3 separate fieros just to make my baby whole
GTCONVERSION
Report this Post03-21-2009 07:10 PM Click Here to See the Profile for GTCONVERSIONSend a Private Message to GTCONVERSIONEdit/Delete MessageReply w/QuoteDirect Link to This Post
finished almost all the int.
Tom Slick
Report this Post03-21-2009 08:19 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
i put on EGR valve cover that blakeinspace pull off a car in the junkyard today.
www.northtexasfieroclub.org
My Cars For Sale
johnyrottin
Total ratings: 85
Report this Post03-21-2009 10:31 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed a small crack starting in the RHS wingstand. Remounted it after a 24 hour cure time. Then took the cars for a meetup with a few other Fiero owners!!!
Jarhead 2m4
Report this Post03-21-2009 10:47 PM Click Here to See the Profile for Jarhead 2m4Click Here to visit Jarhead 2m4's HomePageSend a Private Message to Jarhead 2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I tried to get my subwoofer to work. No success. I will figure it out soon enough.
Spynx
Report this Post03-22-2009 12:51 PM Click Here to See the Profile for SpynxClick Here to visit Spynx's HomePageSend a Private Message to SpynxEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's pretty sharp, it really gives it an updated look.
fordmuddin27
Report this Post03-22-2009 08:29 PM Click Here to See the Profile for fordmuddin27Send a Private Message to fordmuddin27Edit/Delete MessageReply w/QuoteDirect Link to This Post
kicked it in the ass
NCTyphoonKid
Report this Post03-22-2009 09:08 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I buffed it and put a water pump on
86soon3.4
Report this Post03-22-2009 09:54 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just finished up the exhaust system. Installed a flowtech muffler, larger pipes and new tips. It has a nice rumble to it!
I would post a sound clip but I don't have anyway to record it and post it.
Steve
Gokart Mozart
Total ratings: 159
Report this Post03-23-2009 08:13 AM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
not today but yesterday I brought one home.
https://www.fiero.nl/forum/Forum1/HTML/075067.html
I've already backed it up on the ramps to see what and where it's leaking.
[This message has been edited by Gokart Mozart (edited 03-23-2009).]
pontiackid86
Total ratings: 344
Report this Post03-23-2009 08:15 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
i actuley started it and took her for a nice lil ride around where i live.
whodeanie
Total ratings: 120
Report this Post03-23-2009 10:48 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finaly got my wheels installed among other things
Fiero84Freak
Report this Post03-23-2009 03:26 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took the spoiler off.
Cleaned it up.
Got a new right side taillight.
Tomorrow some more misc. stuff.
gaas88
Report this Post03-23-2009 07:59 PM Click Here to See the Profile for gaas88Click Here to visit gaas88's HomePageSend a Private Message to gaas88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took the toy out of its deep long 5 month winter nap - removed the winter covers - dropped in the battery - started on the 1st crank - washed it up and took it for a spin. AHHH finally, spring is back and lookin forward to the Wednesday night cruise nights.
mattwa
Total ratings: 88
Report this Post03-23-2009 08:50 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuilt my headlight motors! Much faster now.
Total ratings: 403
Report this Post03-23-2009 09:27 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put it on jack stands and pulled the oil filter relocation adapter so I could fix the leak.
fastblack
Total ratings: 50
Report this Post03-23-2009 09:32 PM Click Here to See the Profile for fastblackSend a Private Message to fastblackEdit/Delete MessageReply w/QuoteDirect Link to This Post
changed oil, added sea foam to oil, new plugs, wires, cap, and rotor...then found the battery to be dead, gonna go get it tested tomorrow tore driver's door apart (didn't get put back together though).
Onefiero
Report this Post03-23-2009 10:46 PM Click Here to See the Profile for OnefieroSend a Private Message to OnefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went to Monroe Muffler and Brake to "Steal" back my lug nut key.....(after a week of searching at my house, and ding! "oh yea, they never gave it back!!!) lol
Edaw 0
Report this Post03-26-2009 11:14 PM Click Here to See the Profile for Edaw 0Send a Private Message to Edaw 0Edit/Delete MessageReply w/QuoteDirect Link to This Post
An alignment! Man, this thing was way outta whack. I was like , when the monitor came on. OMG, I drove from DC to Frederick, MD then to Hagerstown, MD like like that? And survived? Bonebrake Alignment Shop did a great job, the ride back to Frederick was nice. No more driving on marbles, soooo stable.
NCTyphoonKid
Report this Post03-27-2009 09:10 AM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I fixed some warped interior pieces I still have a cooling problem and it leaks antifreeze
Tony Kania
Total ratings: 305
Report this Post03-27-2009 10:33 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I spent about 8 hours yesterday polishing, and waxing her. Then I went for a drive.
thismanyfieros
Total ratings: 120
Report this Post03-27-2009 11:00 AM Click Here to See the Profile for thismanyfierosSend a Private Message to thismanyfierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
i posted my 88 coupe for sale
NCTyphoonKid
Report this Post03-27-2009 02:27 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I fixed my exhaust and have a gutted cat on it
