  What Did You Do To Your Fiero...TODAY ? (Page 37)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219388 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
unboundmo
Report this Post03-31-2009 07:22 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
finished my stage II scoops for the painter
andddddddd..........
I finished putting my engine bay back together ---- I replaced most of the bolts/screws with either stainless steel or a grade 5 anodized which is better than grade 8 and I also replaced the gas tank cross member bolts with a 10.9 grade 5 anodized for long life and strength. All little brackets for the fuel/vacuum lines have been replaced too.
first was the gas tank... new hiflow "Holley" pump and stainless lines
new ... well refinished the vacuum lines and cruise control area
Nilknarf
Report this Post03-31-2009 07:27 PM Click Here to See the Profile for NilknarfSend a Private Message to NilknarfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the drivers side carpeting and steam cleaned it. 20 years worth of dirt, yuck!
NCTyphoonKid
Report this Post03-31-2009 07:31 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cleaned up my original wheels
Macs86GT
Report this Post03-31-2009 09:31 PM Click Here to See the Profile for Macs86GTSend a Private Message to Macs86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the shifter know with a nice billet aluminum one, got new floor mats and repainted and repaired my shifter console as well as removed the gt gauges for clean up and repair. I may leave em out as i like the look better since i will be going with pillar gauges.
[This message has been edited by Macs86GT (edited 03-31-2009).]
FieroBobo
Report this Post03-31-2009 09:46 PM Click Here to See the Profile for FieroBoboSend a Private Message to FieroBoboEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took it to DMV for the annual inspection.
Good news: She passed emission testing with flying colors.
Bad news: She flunked for one headlight that wouldn't pop up, and for "YELLOW HEADLIGHTS"
It seems that in the great state of New Jersey, all headlights must be white. Unfortunately I have the Hella conversion headlight with the yellow tinted bulbs so they failed me. Bah Humbug!
~Bob
"Its nice to be important.
Its more important to be nice."
Madscanner
Report this Post04-01-2009 06:07 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent 4.5 hours taking the front left suspension apart - only snapped one control arm bolt...
Will see how long it takes to do the other side tomorrow.
Ciao!
'85 SE 2M6 automatic (Left-hand drive)
'84 SE 2M4 manual (Right-hand drive)
'98 Ford Mondeo Si
'73 Peugeot 304 S Cabriolet
Madscanner
Report this Post04-02-2009 06:35 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
2.5 hours to nearly strip the other side... still have the lower front control arm bolt to remove - looks like I'm going to have to shift the steering rack out of the way to get a socket on to the bolt head...
my86fiero
Report this Post04-02-2009 08:09 PM Click Here to See the Profile for my86fieroSend a Private Message to my86fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok i'm doing my first build ever.... none other than a 1986 FIERO GT fastback I have a dirt driveway so i've bolted 10 skid together and am going to put down 3/4 plywood to keep me out of the mud and dirt. it should be done this weekend woohoo !!!!!!
Tony Kania
Total ratings: 305
Report this Post04-02-2009 11:06 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unboundmo........Clean! That is how you clean up an engine bay. Mine is nice, but yours, me so jealous.
[This message has been edited by Tony Kania (edited 04-02-2009).]
Madscanner
Report this Post04-04-2009 06:10 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took the rack off and managed to unbolt the last control arm bolt
Unfortunately, I still can't get the bolt out - looks like it is rusted solidly onto the metal bushing insert...
Not sure what to do next with it, so took the old bushings out of the other three control arms, wire-brushed them, painted them with Hammerite (POR15 being difficult to find here), put the new ball joints in, and cut the springs down 1 coil.
So just the last (lower) control arm to sort out...
Edited to add - bushings in to the upper arms, cut one (inside) end of the last lower arm bolt, but no clearance to get at the other end, so spent 30 mins making the bushing insert shiny with a hacksaw blade... Not happy.
[This message has been edited by Madscanner (edited 04-05-2009).]
katatak
Total ratings: 82
Report this Post04-04-2009 06:31 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished repainting the wing and got 4 new shoes installed on my Formula................Ready for some driving fun now!
Pat
[This message has been edited by katatak (edited 04-04-2009).]
americasfuture2k
Total ratings: 105
Report this Post04-05-2009 08:07 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
spent another 7 or 8 hours in the garage working on and perfecting(correcting my mistakes) on my 7730/3500 harness. almost ready to go in the car! but am waiting for the next warm day (70+)
First LX9 Fiero GT, 1987 | My Fiero Fuel Economy | MPG Display for OBD I
Youtube Videos of My GT | 87 GT Inside Test Run | 3500 Fiero GT Test Run 01
3500 Fiero GT Test Run 02 | 3500 Fiero GT Test Run 03 | 3500 Fiero GT Test Run 04
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
GTCONVERSION
Report this Post04-05-2009 08:13 PM Click Here to See the Profile for GTCONVERSIONSend a Private Message to GTCONVERSIONEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wiped down the new black paint,I think it gets dusty evryday just sitting inside
Tanlrat
Report this Post04-06-2009 01:31 AM Click Here to See the Profile for TanlratSend a Private Message to TanlratEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today i painted primer on the trany mounts for the 88 5 speed i'm putting in my 86 SE.
katatak
Total ratings: 82
Report this Post04-06-2009 01:55 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent more money - ordered more parts - my usual Monday morning routine. Not complaining! It is just normal for me to work on the Fiero all weekend only to find by Sunday evening, I need another part! I wonder if Camaro guys have this same problem?
Pat
Tony Kania
Total ratings: 305
Report this Post04-07-2009 12:37 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did a lot today.
1. Oilchange. 4th one in the last 2,000 miles. New engine, and being a bit anal retentive.
2. Transaxle fluid change.
3. Fixed the hose for the washer fluid.
4. Buffed out the aluminum transmission dipstick.
5. Took about 15 gallons of used oil to the recycle place.
6. Rechecked just about every nut and bolt under the car.
7. Ran DOT 5 brake fluid through the system.
8. Hooked up my parking brake that I did not finish last fall after the engine install. Put the Blue Dingy Thingy back in now that the brake is hooked up.
9. Took her for a ride.
topher_time
Total ratings: 64
Report this Post04-07-2009 12:51 AM Click Here to See the Profile for topher_timeSend a Private Message to topher_timeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got the major issues worked out of the new pcm on my turbo LX9 87 GT. At least it runs, for the most part. I'll take it to the dyno later next week for final tuning and baseline runs before I really start playing with the boost levels and intake/exhaust set ups. Currently using the stock 3500 intake, and stock 3400 manifolds/crossover with 350z cat and muffler. Really good sound out of this one. Thing hauls ass with only 7lbs of boost and a base tune, can't wait to do the fine tuning and see what it can really do. Hopefully I can push it to 15 lbs of boost once the miss and cylinder 2 drop out is taken care off. And I found the 85 SE needs an engine, no saving the 2.8 in this one, I'll probably do an Ecotec swap, and it'll be my daily driver. Still have a set of race cams and an itb set up off of the Cavalier demo car
Tanlrat
Report this Post04-07-2009 01:09 AM Click Here to See the Profile for TanlratSend a Private Message to TanlratEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I final painted the 5-speed tranny parts. The tranny mounts, clutch arm, the end plate, gear selector parts and the bolts. Red of course to go with the car. using rustoleum 500degree primer and paint. kinda gets hot here in AZ
whodeanie
Total ratings: 120
Report this Post04-07-2009 08:44 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
more body work for me, I hate sanding!
randye
Total ratings: 210
Report this Post04-07-2009 06:56 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my new Corvette C6 exhaust tips.
unboundmo
Report this Post04-07-2009 07:24 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Tony for your comment.... I got a couple more pictures to share...
got my cradle together again with new motor mounts "poly" and newly painted mount brackets. I also wire wheeled all bolts and nuts.
I did these several weeks ago but didn't post it
Uncovered something special ---- transplantee'
ported and polished from the engine builder
started assembling finally
AAAWWWHHHH . Don't be jealous old guy you''ve been swell all these years.... I'm not going to give you away. You will always be apart of the family.....
oh.... bought a lot of new bolts today to finish the top end, timing cover, waterpump... I also had to paint some more of the engine hoist brackets because I forgot them the first time around.
ManMadeChickens
Report this Post04-07-2009 08:39 PM Click Here to See the Profile for ManMadeChickensSend a Private Message to ManMadeChickensEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero and I were invited over by "the girl next door" for a joint car wash... clean car, cute girl... what more can I ask for?
pocket dude 411
Report this Post04-07-2009 08:42 PM Click Here to See the Profile for pocket dude 411Send a Private Message to pocket dude 411Edit/Delete MessageReply w/QuoteDirect Link to This Post
New fuel filter. Still tryin to find why its stumbling on accel=[
ShockWave
Report this Post04-07-2009 10:05 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my Rodney Dickman exhaust tips and hangers.
And last week I finally installed new sail panel emblems...
[This message has been edited by ShockWave (edited 04-07-2009).]
Brother Rat
Report this Post04-08-2009 06:23 AM Click Here to See the Profile for Brother RatSend a Private Message to Brother RatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ordered new rear rotors, and calipers.
Found a problem with the throttle cable (see thread in Tech section). Started to pull out console to work with the throttle cable.
Pete
johnyrottin
Total ratings: 85
Report this Post04-08-2009 07:31 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still trying to figure out what the hell is going on with my 4.9 engine....gremlins....blah!!!
ShockWave
Report this Post04-08-2009 10:34 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced my outer door dew strips; I like driving with my window open again.
unboundmo
Report this Post04-09-2009 04:27 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had a chance last night to continue some of the build... I've got the fuel rail, injectors and some of the lines in place.
For the fuel pressure gauge, I located it where the fuel pressure release valve was.. You know, the tire inflathion device on the fuel rail... WILL THIS BE AN OKAY LOCATION TO GET THE CORRECT READINGS?????
Tony Kania
Total ratings: 305
Report this Post04-09-2009 08:54 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is called a schrader valve fine sir. And yes, it is a great spot to pull readings from. Did I mention that I hate you? Your build is too amazing!
falcon_ca
Report this Post04-09-2009 09:57 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will you be able to reinstal the plenum with that ne gauge ?
Nice engine BTW.
I've done a little on mine too.
[This message has been edited by falcon_ca (edited 04-09-2009).]
americasfuture2k
Total ratings: 105
Report this Post04-09-2009 10:59 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
did more wiring. took my time and made sure i had all the BA12's made and ran.
FieroGT42
Total ratings: 67
Report this Post04-09-2009 11:09 PM Click Here to See the Profile for FieroGT42Send a Private Message to FieroGT42Edit/Delete MessageReply w/QuoteDirect Link to This Post
I attempted to contact ExpertTire corporate yet again to complain of damages they've caused to my Fiero over the last few years including a broker rocker panel, smashed coolant pipe, shattered quarter window scoop, bending all of my wheels and then saying I hit potholes bad enough to bend them WITHOUT EVEN FEELING IT, and tearing a hole in my custom leather seats!. Let's see if I can get anywhere this time around....
gtxbullet
Report this Post04-10-2009 10:12 AM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed, a new oil pan, poly dogbone busings, removed most of the insulation from the engine bay last night, installed my 3-gauge pod in the place of the Voltmeter and Oil Pressure gauges (pictures coming soon), getting ready to put my new poly cradle bushings on, going to fix the exhaust leaks (hopefully), I fixed my drivers headlight issue (the retainer clip was missing so it woulod smack down randomly), I'm also going to be using an orbital buffer on the whole body and waxing her to a glissening shine!!
that's all for today and yesterday.
stay tuned for my build thread (with pictures)
1970 Monte Carlo 400 Frame-off Restoration 456whp 514wtq
1986 FIERO SE V6 Auto Power everything with all options
1990 Z24 3.1L 5 speed (SOLD)
1990 ASC Mclaren Grand Prix TSTE (Turbo 3.1) (SOLD)
1992 Firebird T-Tops V-8 24k original Florida miles(collectors car)
1999 Pontiac GTP Grand Prix Silvermist Coupe - runs easy mid 13's all day (SOLD)
unboundmo
Report this Post04-10-2009 12:12 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the answers Tony.... Heah... only some people like me I guess
I think if the plenum doesn't fit I'll use so more fittings to make the gauge reach outside a little more.... I've made some 1/2" spacers too for a little more torque and clearance for when adjustments to the fuel regulator are in need. We'll see --- Trial and error --- Hopefully Trail and success. I've got my fingers crossed...
Here's a peek of my cnc spacers that I'm going to try out.. If it doesn't work o-well - I still feel that they were a good design --- I wanted to keep them a secret though... so World,,,, shhhh! Just remember ( I had them first! )
falcon_ca
Report this Post04-10-2009 05:14 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
unboundmo
Report this Post04-10-2009 05:50 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Falcon... Isn't it nice to put things back together when they are new or restored. Sometimes I lose track of time because of this puzzle and how I'm seeing the end resort appear before my eyes. It's like you don't want to stop but got to sleep sometimes....... but I'm definitely having a great time doing it.
Nice set up you have too. The under pulley kit that you have--- do you find that the volt light comes on at the starting of the car but once you rev it a little the light goes off..... Until you start the car again? Is that Rodney's.... I bought the same one if it is and just curious about some rumors. --- Did you notice an improvement in using them. I like the theory about less rotating mass for faster spool up and acceleration but I've heard other benefits too.
[This message has been edited by unboundmo (edited 04-10-2009).]
americasfuture2k
Total ratings: 105
Report this Post04-10-2009 07:15 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
i am finishing up my harness corrections. jjust hafta connect the grounds and trim the DIS 5 pin connector wire length and it should fire up. i just need to get some zip ties to hold some wires back...
Nohbdy
Report this Post04-10-2009 08:10 PM Click Here to See the Profile for NohbdySend a Private Message to NohbdyEdit/Delete MessageReply w/QuoteDirect Link to This Post
more sanding for the paintjob im doing... also washed the car.
joeveto
Report this Post04-10-2009 08:31 PM Click Here to See the Profile for joevetoSend a Private Message to joevetoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a good wash and detail, and I untangled my seat belt. Woo Hoo!
Spent my days with a woman unkind Smoked my stuff and drank all my wine...
Ratfink
Report this Post04-10-2009 09:04 PM Click Here to See the Profile for RatfinkSend a Private Message to RatfinkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuilt My drivers side headlamp motor ,with a Rodney Dickman gear!
