  What Did You Do To Your Fiero...TODAY ? (Page 42)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6920 (219020 views)
Last post by: Doggo on 03-30-2025 09:15 PM
wolf63
Report this Post05-13-2009 12:26 AM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
yep, thats the critter:-) i made one similar by cutting out a section of the middle, welding in 2 bolts sized to work with the hex shaped tensioner for a fence gate, works perfect! the pedal was all the way to the firewall when i got the car...i should have done this sooner :-)
unboundmo
Report this Post05-13-2009 02:30 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
IT'S IN !!!!! IT'S IN !!!!!!!!!
I've started to hook everything up again. A couple hoses to go, make a heat shield for the hydraulic clutch thingy, put the interior console back together, mount the seats, add all fluids, and rivet my side scoop panels back on...... I didn't do the oil cooler yet. I figure to get everything going and then add the goodies
YYYYYYEEEEEEAAAAAAAHHHHHHH baby!!!!!!!!!!! been a long time.
Tony Kania
Total ratings: 305
Report this Post05-13-2009 07:09 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
unboundmo
Report this Post05-13-2009 07:12 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Tony... A couple more days I hope....
kooljess
Report this Post05-15-2009 01:30 PM Click Here to See the Profile for kooljessSend a Private Message to kooljessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Starting to look nice again Derek....can't wait to see it in person....hopefully we can all get together again before Westfest....keep up the good work buddy.
http://members.cardomain.com/koolflip
americasfuture2k
Total ratings: 105
Report this Post05-16-2009 08:32 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
added a bosch HO2 sensor. now i go into closed loop quicker. yay less fuel consumption when waiting to go closed!
First LX9 Fiero GT, 1987 | My Fiero Fuel Economy | MPG Display for OBD I
Youtube Videos of My GT | 87 GT Inside Test Run | 3500 Fiero GT Test Run 01
3500 Fiero GT Test Run 02 | 3500 Fiero GT Test Run 03 | 3500 Fiero GT Test Run 04
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
ferrobi
Report this Post05-17-2009 07:38 PM Click Here to See the Profile for ferrobiSend a Private Message to ferrobiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bleed clutch today - 22 year old fluid had a few bubbles and wasn't very clean. Went with Valvoline Syn 4. After all the horror threads on how hard it is to do I was a little hesitant, but it went fine. Combination of push clutch/open:close bleeder and then went to gravity bleed. Works like new now.
wolf63
Report this Post05-18-2009 01:38 AM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
definitely no pics of today's work. now that the motor is running again we've started back on the body work, pulled the hood again and did some more finishing work trying to get it ready for paint. skim coated the roof to get rid of the flaws and pulled the fenders. Getting them ready for paint and doing the antenna delete on the other side. It'll look nice when its done but tonight, I'm really glad we have a car cover:-)
unboundmo
Report this Post05-19-2009 12:41 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's so close now to firing it up I'm kind of scared..... Here's the latest. Axcel's 8mm wires (cut to fit), riveted my side scoops on, got all fluids in, hooked up the battery and center console, raised the front in 1/4" so definitely no rubbing, double checked EVERYTHING, finished with the suspension.... Waiting on an adjustable dogbone, long rivets for the rocker panels, need to bleed the brakes and attach the E-brake (not looking forward to that one {{{{ anyone know an easy way to attach it}}}}..... need to buy some gas. Bought a couple chrome caps too.
In this pic below I grabbed a little dump pipe for the air intake using the stock air box with no silencer.
Austrian Import
Report this Post05-19-2009 04:31 PM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are these Fieroaddiction's Wilwood's?
Doni Hagan
Total ratings: 127
Report this Post05-19-2009 04:55 PM Click Here to See the Profile for Doni HaganSend a Private Message to Doni HaganEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only thing I've done to my Fiero today is save it from my girlfriend! She and one of her buddies decided to take it out for a quick spin while I was at Menard's in the house car.
The keys are now back in my pocket and the GT is SAFELY parked in the driveway!!!
unboundmo
Report this Post05-19-2009 05:10 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Austrian --- They are Held/HT Motorsports "Wilwoods" They are really nice and stops a lot better than the stock 88... No spongy feel now either --- solid
[This message has been edited by unboundmo (edited 05-19-2009).]
americasfuture2k
Total ratings: 105
Report this Post05-19-2009 08:57 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
loaded a better bin file i got from a member on 60*v6 forums. the last one he told me had a rev limiter at 2500. ???? dont know why on that one. but the bin file i am using now allowed me to pull the car out of the garage and drive it around my apartment complex. that was nice. my fiero got to "stretch its legs" so to speak.
IFLYR22
Report this Post05-19-2009 11:03 PM Click Here to See the Profile for IFLYR22Send a Private Message to IFLYR22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I added my old Unit's (Military) patches to my Corbeau seats.
Army 140th and AF 310th Squadron on driver seat
AETC and 56th Wing on passenger seat
And... I drove it.
JohnWPB
Total ratings: 144
Report this Post05-19-2009 11:43 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I simply sat in my newly acquired, and first Fiero, in the passenger seat. I had a sketch pad and pencil, and sat there for almost an hour just staring at the dash trying to come up with a design that would accommodate my 10" touch screen for the CarPC.
Preliminary ideas put the screen above the HVAC controls, and relocate the A/C vents to another location... still working on that part... The top of the touch screen will be almost the exact same height as if the 2 optional gauges were on top of the center console. It will require a custom center console, and I will go ahead and extend the dash flush from the console in front of the passenger seat to incorporate a glove box. , and I have never done anything like this, so will be a good learning process for sure!
Tony Kania
Total ratings: 305
Report this Post05-21-2009 03:40 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, yesterday, I replace the two remaining rubber hoses for the radiator that I did not do last fall during the engine build. All new clamps. Did a flush and fill of the coolant. Everything is nice and pretty now. Replaced the two radiator caps. Thermostat is a few months old, so not worried on that one. Oh yeah, also polished the two caps on my benchtop buffer. A little shine can't hurt. Now, I am just waiting on DIY-Stu for my shipment of outer window wipes. If they get here today, then that will be my project for tonight.
larini74
Report this Post05-21-2009 03:42 PM Click Here to See the Profile for larini74Click Here to visit larini74's HomePageSend a Private Message to larini74Edit/Delete MessageReply w/QuoteDirect Link to This Post
IFLYR22 when were you with the 56th? I was at NKP in 74/75 56sow/sps
85SEnochie
Total ratings: 58
Report this Post05-21-2009 03:46 PM Click Here to See the Profile for 85SEnochieSend a Private Message to 85SEnochieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finished painting the roof or buffing the piss out of the rattle can job I did on the roof
Love The Excitement!
87antuzzi
Total ratings: 228
Report this Post05-21-2009 04:50 PM Click Here to See the Profile for 87antuzziSend a Private Message to 87antuzziEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to have mine towed home.
transamman
Report this Post05-21-2009 04:53 PM Click Here to See the Profile for transammanSend a Private Message to transammanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I painted it.
Old Lar
Total ratings: 214
Report this Post05-21-2009 05:03 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had www.replacementradios.com fix my late 90's am-fm/cd and i stuck it back into my 88GT. Volume control now works..
Tony Kania
Total ratings: 305
Report this Post05-21-2009 05:16 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
85SEnochie.....Nice two tone. More pics please.
unboundmo
Report this Post05-21-2009 07:00 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put gas in it yesterday!!!!!!! Primed the fuel rail. re-attached the e-brake, replaced some of the suspension bolts to my HT setup to longer ones. riveted all of the rocker panels on and finished the side scoops for good. While leaving the stock air box as the pics show above, I did take out the air cleaner and replaced it with a K&N that sits right next to the side scoop...... CAN'T WAIT TO HEAR IT SUCKING IN THE AIR. I loved my old set-up which was similar but this new way will pass smog. I also mounted my new dog-bone from Rodney.... I finish putting the interior and seats back in too.
The list is short now ----
Bleed the brakes
wheel well covers --- after I clean them - ANYONE KNOW A GOOD WAY TO DO THIS AND WITH WHAT PRODUCT?
trunk lid and wing
remount the muffler from the cat back
mount the tires
lower the car back on the ground
pull the distributor to prime the oil pump before starting
START HER UP!!
[This message has been edited by unboundmo (edited 05-21-2009).]
johnyrottin
Total ratings: 85
Report this Post05-21-2009 07:21 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ran out of gas! E means Empty...not Enough to get to the gas station!
unboundmo
Report this Post05-21-2009 07:33 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not saying that you getting stranded is funny..... but funny because 1/4 tank left of gas means empty with mine...
sjmaye
Report this Post05-22-2009 03:57 AM Click Here to See the Profile for sjmayeSend a Private Message to sjmayeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced passenger and driver side door hinge bushings and pine. Replaced both door glasses. Replaced inner and outer dew wipes. Replaced driver side window motor. Cleaned all the window regulator tracks and relubed.
85SEnochie
Total ratings: 58
Report this Post05-22-2009 11:03 AM Click Here to See the Profile for 85SEnochieSend a Private Message to 85SEnochieEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
Madscanner
Report this Post05-23-2009 02:27 PM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaned off, primed and repainted the centre engine cover on the 2M4 and re-installed it - not a great job, but much better than the peeling mess that was there when I bought it, and good enough to pass muster from 20 feet away
Swapped in one of my spare wheels on the 2M4 - I've had a slow leak for a couple of weeks - no obvious damage to the tyre, so suspect it just needs to be taken off, the rim cleaned, and put back on, same as I've had to do a couple of times before, with other wheels.
Tried to sort out the loose alternator belt on the 2M4 - gave up after half an hour (I could hear the BBQ calling, with a steak and a couple of tinnies providing harmony in the background)...
Ciao!
'85 SE 2M6 automatic (Left-hand drive)
'84 SE 2M4 manual (Right-hand drive)
'98 Ford Mondeo Si
'73 Peugeot 304 S Cabriolet
N3M3S1S
Total ratings: 51
Report this Post05-23-2009 03:15 PM Click Here to See the Profile for N3M3S1SSend a Private Message to N3M3S1SEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took it out for a drive in this 85 degree weather after bypassing the heater core after it committed suicide. It was actually running cooler than it ever has before, meaning that heater core was ever so slowly dying for a while. She still runs great and the cruise was awesome. Now I gotta order brake parts.. Any ideas on what rotors are the best for an 88? And right front caliper.. It keeps sticking and eating through pads.
FieroMatt
Report this Post05-23-2009 08:41 PM Click Here to See the Profile for FieroMattClick Here to visit FieroMatt's HomePageSend a Private Message to FieroMattEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to a local wrecking yard and pulled off the brake fitting that directs fluid to both rear wheels and the gas door opener lever. Now I can get rid of the piece of wire that I use now.
White Spyder
Report this Post05-24-2009 09:24 AM Click Here to See the Profile for White SpyderSend a Private Message to White SpyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The "Copper Top" scored a top 20 in a show on Saturday!!!
americasfuture2k
Total ratings: 105
Report this Post05-26-2009 08:21 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
i got it driveable and managed to drive across the street to the car wash. sprayed it off from the winters snow and other crap. fixed the catching problem when my window goes down and did some tuning.
FieroMatt
Report this Post05-26-2009 12:56 PM Click Here to See the Profile for FieroMattClick Here to visit FieroMatt's HomePageSend a Private Message to FieroMattEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sjmaye:
Replaced passenger and driver side door hinge bushings and pine. .
You shouldn't pine over your new hinge bushings. The old ones really don't care.
unboundmo
Report this Post05-26-2009 06:03 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
STARTED THE CAR!!!! 22 minute break-in period at 2000 rpm..... Idles at around 950 with no hunting.. Fixed some leaks that I had..... WE ARE A GO!
I will say that I had the timing 180° off but I anticipated it.. Easy fix. Got the car back together and it fired right up with no problems. I Timed it at 10 degrees but I think the 260 cam that's in it says other.
One problem that I did run into with the 3.4 block --- If I slightly loosened the distributor just enough so I can turn it for tuning, oil would start to come out of the top where the distributor sits on the block. There is an o-ring installed around the shaft but I added an extra one at the top to help stop the leak. I may look for a slightly bigger one still... Other than that ------- IT RUNS!!!!!!!!!!!!!!!!!
Things left to do:
put the rear tires on,
tighten the axle nuts to 200 lbs.
lower the car,
put the deck lid on.
DRIVE!
unboundmo
Report this Post05-26-2009 06:05 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
unboundmo
Member since Sep 2006
I've got a video made but my flickr album only does 90 sec of it.... It's compressed to 6.6mb but I don't know where to upload it so everyone can see if they want.
Any suggestions?
americasfuture2k
Total ratings: 105
Report this Post05-27-2009 04:06 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
i think tinypic.com allows you to upload vids
Ikester
Report this Post05-27-2009 05:42 PM Click Here to See the Profile for IkesterSend a Private Message to IkesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed the oil. Had to buy ramps to do it. You know they make ramps out of plastic now?? Once under the car, could not believe how clean it looks underneath. I also could not get my hand on the filter, so I had to remove a heat shield from the converter. I was impressed that the many people who changed the oil before I bought the car actually put the stuff back on (or had tiny hands/ a pit to work out of). T installed new hardware on the heatshield (so THAT was the rattle on start-up!). Washed it, so of course, it is now raining....
unboundmo
Report this Post05-27-2009 06:25 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay... I got the video to work.... Sorry, It's a really slow start. We'll just call it drama. And sorry that I cut out all the action spills, fire burning on the heat shield, me getting electrocuted with 30,000 volts trying to time the engine --- What? I slipped.... Don't worry - I'm okay!
Anyway ----- Here's something for the Oscars!!
I can't figure out how to play it through Pennocks?
View My Video
Tony Kania
Total ratings: 305
Report this Post05-27-2009 06:40 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Always great to see a fella accomplish his goals. I am betting that the GT was liking the "Paul Revere" at startup. A little inspirational music for the masses.
unboundmo
Report this Post05-27-2009 06:56 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was going to mention something about Metallica "One" on the idling portion of the vid at the end.. But I'll go with the Beatles too....
[This message has been edited by unboundmo (edited 05-27-2009).]
