  What Did You Do To Your Fiero...TODAY ? (Page 44)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6920 (219125 views)
Last post by: Doggo on 03-30-2025 09:15 PM
doublec4
Total ratings: 150
Report this Post06-07-2009 08:38 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Worked on my custom slim pop up HID headlights
carbon
Total ratings: 132
Report this Post06-08-2009 01:54 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was yesterday, but water pump(fixed on stripped and on broken bolt, was sucking in air)... tranny filter and gasket... oil pan gasket (previous owner cut the old gasket to install, lazy, and tried to use RTV to patch the seams.... leaked like a siv...), motor mount (so far gone that it was being held in by the failsafe... just a bolt and a loop basically )
Lilchief
Report this Post06-08-2009 09:12 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well got good news and bad, The good news, Finally completed my front speakers. Wow what a difference over the old 4x10. Be glad when I get the clearwaters and the tang band in. The bad, got to take the heater system apart again. I believe the screen filter on the evaporator is stopping the heat control from opening all the way. And the floor/defrost/vent control is not work. I can hear the servo running but no changes and it seems to run for an extended period. Eventually I'll know this car really well.
85 GT 3.4
14.9 @ 90 1.9 60' Old TH125/3.06
Unknown New 4T60/3.42
Atakicat
Report this Post06-09-2009 04:41 PM Click Here to See the Profile for AtakicatSend a Private Message to AtakicatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally decided to pull off the car cover and pull her out of storage, where she's sat since just after Fiero Roundup 9...Time to get back to work, but I have NO idea where to start.
Robert 2
Report this Post06-09-2009 07:52 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump
my86fiero
Report this Post06-09-2009 08:20 PM Click Here to See the Profile for my86fieroSend a Private Message to my86fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed my engine on sunday and am starting to seperate the engine and the tranny fromthe cradle. WOO-HOO, that was awsome!
RWDPLZ
Total ratings: 306
Report this Post06-09-2009 08:52 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took out the steering rack, replaced the inner and outer tie rod ends on both sides, and boot on driver's side. It would be back in by now but one of the rack mounting bolts broke off.
1984 Fiero SE
ShockWave
Report this Post06-12-2009 04:50 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced distributor cap and rotor, ignition module, and ignition coil.
kyp
Report this Post06-12-2009 04:55 PM Click Here to See the Profile for kypSend a Private Message to kypEdit/Delete MessageReply w/QuoteDirect Link to This Post
pulled the motor out for the 3800sc swap
greasemonke50613
Total ratings: 168
Report this Post06-12-2009 06:13 PM Click Here to See the Profile for greasemonke50613Send a Private Message to greasemonke50613Edit/Delete MessageReply w/QuoteDirect Link to This Post
lets see...went to replace my alternator 'cause i thought it was bad...turned out to be a wire that broke off it's terminal. replaced valve cover gasket (84 fiero took an 88 valve cover gasket
Robert 2
Report this Post06-12-2009 07:03 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Transfered to technical discussion and question .
Thanks
[This message has been edited by Robert 2 (edited 06-13-2009).]
Edaw 0
Report this Post06-12-2009 09:04 PM Click Here to See the Profile for Edaw 0Send a Private Message to Edaw 0Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to work.
doublec4
Total ratings: 150
Report this Post06-12-2009 09:17 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed boost and fuel pressure gauges in a dual A-pillar set up
topher_time
Total ratings: 64
Report this Post06-13-2009 10:29 AM Click Here to See the Profile for topher_timeSend a Private Message to topher_timeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looked at it and thought how much I could get from parting it out. Can't drive a stick no mores due to a broken foot. Wasn't healin right so they fused the bones together then I managed to crush several previously injured vertabrae in my back after a minor car accident Thursday morning. Hard enough getting into the Land Rover, Fiero will be impossible for me to get into now
sjmaye
Report this Post06-14-2009 06:34 AM Click Here to See the Profile for sjmayeSend a Private Message to sjmayeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took out AC compressor for replacement.
never2old
Total ratings: 68
Report this Post06-14-2009 06:36 AM Click Here to See the Profile for never2oldSend a Private Message to never2oldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well............actually last night.
Got to drive my recently changed SE to a GT to the West Michigan Whitecaps {AA I believe} baseball game.
Was honored through a drawing to throw out a ceremonial first pitch for the company I work part time for.
Got to take my 8 year old granddaughter.
I gave her a choice "Trans AM or Fiero?"
She ain't no dummy................She said "THE FIERO !!!!!!!!!"
We had a blast.
I like the GT rear lighting so much better.
Several honks along the way.Believe it was for the car. I don't drive that eratic.
A thrilling come-from behind win for the Whitecaps. They played the team from South Bend, Indiana
johnyrottin
Total ratings: 85
Report this Post06-14-2009 08:40 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Transmition fluid leak - sorted! Recharged AC with dye injected R134 - found leak - sorted!
infinitewill
Total ratings: 85
Report this Post06-14-2009 08:51 AM Click Here to See the Profile for infinitewillSend a Private Message to infinitewillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed the factory wing/spoiler (now I have to reset the rear deck lid torsion bars) and restored the "shorty" antenna that the P.O. had put on with a factory antenna. Surprise, I can actually hear a radio station again. Stripped the window tint from rear window as well, now I can actually see whats behind me when backing out at night. I never understood why anyone would sacrifice functionality for style, after all we still have to drive these things, sorta.........
[This message has been edited by infinitewill (edited 06-14-2009).]
kevin
Report this Post06-14-2009 09:52 AM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rotated my tires
Kevin
icemanmike
Report this Post06-14-2009 10:13 PM Click Here to See the Profile for icemanmikeSend a Private Message to icemanmikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the clutch pedal hoping to cure the clutch system woes I've been experiencing.....HOLY MOTHER OF GOD!!!!!! is this ever a job!!...Actually, not that bad, just close, non ventilated area to work in and I'm glad I shed 20+ pounds lately so I could fit.....Had that issue where it was hard to get into gear and car moved the instant the pedal came off the floor.....Wouldn't even begin to go into reverse with the engine running.....Oh, Yeah...The pedal cured it and I FINALLY get to drive my first Fiero tomorrow....I'm kinda stoked....!!! Thank You Fiero store!! I have an extra clutch master and fork arm on the shelf...Well, I know that day's gonna come... There'll be another one runnin around Grand Rapids, Michigan now!!!....Mike
americasfuture2k
Total ratings: 105
Report this Post06-15-2009 08:41 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
ganked my engine harness to see what damage was done form the evap can catching fire. just melted loom. back pinned every wire. everything is good. 0.00 ohms on all pins! guess that is my new pump going out.
First LX9 Fiero GT, 1987 | My Fiero Fuel Economy | MPG Display for OBD I
Youtube Videos of My GT | 87 GT Inside Test Run | 3500 Fiero GT Test Run 01
3500 Fiero GT Test Run 02 | 3500 Fiero GT Test Run 03 | 3500 Fiero GT Test Run 04
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
Tinker
Report this Post06-15-2009 10:45 AM Click Here to See the Profile for TinkerClick Here to visit Tinker's HomePageSend a Private Message to TinkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero season has begun for me. I renewed my plates and got it out on the road for the first time in over a year. Kevin
CorvetteFan86
Report this Post06-15-2009 03:36 PM Click Here to See the Profile for CorvetteFan86Click Here to visit CorvetteFan86's HomePageSend a Private Message to CorvetteFan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally took my car to a car show this weekend after finishing it a few days ago. Runs like a champ. Just a little more tweaking to get it just right.....
By corvettefan86 at 2009-06-01
<b>My pics and videos: www.corvettefan86.com</b>
-1986 GT
-Swapped 2001 GTP motor Series II with 40k miles
-Auto Meter gauge pod (Oil, Boost, Battery)
-2.8 Pulley
-Stage III Heads
-Full-Stack ZZP Intercooler
-ZZP XPZ Cam
-True cold air intake, 3" inlet
-Machined LIM
-LS1 Throttlebody
-42# Injectors
-180* Thermostat
-Double-Roller Timing Chain
-Flowmaster 80 series
icemanmike
Report this Post06-21-2009 11:22 PM Click Here to See the Profile for icemanmikeSend a Private Message to icemanmikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took mine for a ride for the third time....Yep third time riding/driveing a Fiero...Motor ate itself up...Sounds like a spoon in a blender at 1500-2000RPMS....Decision time.....Bummer.......Mike
1969 GTO..474CI..10:90's..All motor, street legal
1971 LeMans Sport Convertible...Just a cruiser
1977 TA..14 point Roll cage..GTO replacement
1997 Grand Prix GT...For sale
1985 Pontiac Fiero GT..Stock...For the moment
SCCAFiero
Report this Post06-21-2009 11:26 PM Click Here to See the Profile for SCCAFieroSend a Private Message to SCCAFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
This.
Fiero84Freak
Report this Post06-22-2009 03:01 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chased down a slight idle surge and rich condition I've had. I've only had my Formula for a little over three months. Without checking most anything else, I assumed that the cause was likely bad spark plugs. I removed the decklid, pulled one front and one rear plug and sure enough the plugs were the fault. They were Autolite's and weren't even gapped. One had a gap as little as .027! I got AC Delco Rapidfires, gapped to .045, installed, and now it's running like a champ. No idle surge, and I'm thinking it helped the fuel a bit, although I won't be able to tell until I drive it a bit.
Also did an oil change. 5 quarts Castrol and one AC Delco PF52. Ready to go.
ARFiero
Report this Post06-22-2009 03:09 PM Click Here to See the Profile for ARFieroSend a Private Message to ARFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worked on fitting the Corvette C6 mirrors to the body. Fiero84Freak came over to help and we sanded till we had to give up and call it a night. Also started to remove body panels for the repaint.
Shelby
whodeanie
Total ratings: 120
Report this Post06-22-2009 03:15 PM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did this............................
LS3 / F40 part 1
and Will did this for me
mid engine monsters
Report this Post06-22-2009 04:23 PM Click Here to See the Profile for mid engine monstersSend a Private Message to mid engine monstersEdit/Delete MessageReply w/QuoteDirect Link to This Post
i installed my battery box in the front today and i threw some wheels on, and pulled the tailights for my ZR1 tailight install ...little bit by little bit ,she wont look or run the same soon! poor girl shes ugly right now,i bought this a couple of weeks ago from a member here and im ready to get cranked up on this baby
http://i242.photobucket.com...obinson/96a387b9.jpg
[This message has been edited by mid engine monsters (edited 06-22-2009).]
Old Lar
Total ratings: 214
Report this Post06-22-2009 04:35 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took the 88GT to my mechanic to locate the AC leak, one hose bad and a couple of "O" rings. Hose is a hard one to find. The my alternator took a dump while at the shop.. That goes out for a rebuild. I got a drive home.
1MohrFiero
Total ratings: 157
Report this Post06-22-2009 04:56 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished installing the 3 core aluminum radiator I bought off of eBay. It wasn't very difficult but I replaced all the hoses and cleaned and painted a few things along the way, which took some time like changing out all the hoses including the two heater lines that were molded on. No more 22 year old time bombs ticking away.
On the test drive the temp stayed steady well below 220. I changed the fan switch out with a low temp one while I was at it. The fan works real well now.
[This message has been edited by 1MohrFiero (edited 06-22-2009).]
fiero67
Total ratings: 107
Report this Post06-22-2009 08:27 PM Click Here to See the Profile for fiero67Send a Private Message to fiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
did this to the headlights..... that was fun, now I gotta finish this thing up so I can drive it to the shows.
Gokart Mozart
Total ratings: 159
Report this Post06-22-2009 09:53 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changed my auto trans filter and gasket, now it's going to sit until I can get into it after my surgery.
Fieromaniac
Report this Post06-24-2009 11:56 AM Click Here to See the Profile for FieromaniacClick Here to visit Fieromaniac's HomePageSend a Private Message to FieromaniacEdit/Delete MessageReply w/QuoteDirect Link to This Post
my black 87 got new wheel bearings , new discs new breakpads and steel flex brake hoses
NCTyphoonKid
Report this Post06-26-2009 11:23 AM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I fixed my exhaust got a new air filter side scoop
katatak
Total ratings: 82
Report this Post06-26-2009 06:22 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
New wheels & tires on the XTC!
Earl-R
Report this Post06-26-2009 09:36 PM Click Here to See the Profile for Earl-RSend a Private Message to Earl-REdit/Delete MessageReply w/QuoteDirect Link to This Post
I put a set of lowering spindals on the the front for a total of 3.5" drop front, 2" rear. I need to finish bolting up the front facia on the underside and get it off the jack stands so I can see how much better it's going to look now.
Next I need to take the non-cross drilled 11.26" rotors off and put the cross drilled rotors on so I can get the extra Zettner set-up ready for shipping.
chrismclubm
Report this Post06-26-2009 10:14 PM Click Here to See the Profile for chrismclubmSend a Private Message to chrismclubmEdit/Delete MessageReply w/QuoteDirect Link to This Post
today? simply appreciated it
1986 GT Fiero Owner & Enthusiast
For Fiero updates, visit my site http://educatorstop15.com/fieropage.htm
ShockWave
Report this Post06-27-2009 01:25 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to a cruise night, then drove it home, went over a bump, and the fuel pump went to hell. Just got back from having it towed. What a hell of a week.
justa6
Total ratings: 61
Report this Post06-27-2009 03:15 AM Click Here to See the Profile for justa6Send a Private Message to justa6Edit/Delete MessageReply w/QuoteDirect Link to This Post
drove it about 160 miles to my parents house and parked it till the Car Craft Summer Nationals
