  What Did You Do To Your Fiero...TODAY ? (Page 48)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6920 (219125 views)
Last post by: Doggo on 03-30-2025 09:15 PM
Robert 2
Report this Post08-05-2009 05:51 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bet 200.00$ that next week you gonna install a right lense and the GT logo in the back LOL .
Tinton
Total ratings: 295
Report this Post08-05-2009 06:57 PM Click Here to See the Profile for TintonSend a Private Message to TintonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hooned my '86 SE like f**k and showed some SUV-drivers what handling is really about, that's about it. I also might drive my '88 GT in a bit to go pick up some food .
Finally_Mine_86_GT
Total ratings: 99
Report this Post08-05-2009 07:59 PM Click Here to See the Profile for Finally_Mine_86_GTSend a Private Message to Finally_Mine_86_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
got a picture with the bass guitarist from Sick Puppies... first full day on the road with the car!
Alibi
Report this Post08-05-2009 08:11 PM Click Here to See the Profile for AlibiSend a Private Message to AlibiEdit/Delete MessageReply w/QuoteDirect Link to This Post
^^ That belongs in the "girls with Fieros" thread, if its not already.
Edit: NVM! ~
[This message has been edited by Alibi (edited 08-05-2009).]
DefEddie
Report this Post08-05-2009 10:29 PM Click Here to See the Profile for DefEddieSend a Private Message to DefEddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel,
Looking great!
I got a box of 1156's today,and swapped all the rest of the bulbs in the tailights and the front turn signals (of course using fresh dielectric)
Also sprayed penetrating oil on all the bolts under there again, and on the engine.
Did some measuring to give me an idea what I need to do to make billet grille/covers for the front turn signals.
Also made up a new ground cable to go from the engine ground on the trunk hinge to the battery box body ground
and put it on.
Got another one made up to go from engine to body underneath when I put it up in the air again.
[This message has been edited by DefEddie (edited 08-05-2009).]
Danyel
Total ratings: 171
Report this Post08-06-2009 11:17 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Robert 2 ----- yep thanks to you ++ will go to you on receiving the items......
DefEddie --- thanks....... post some pics of your work I would like to see :-)
[This message has been edited by Danyel (edited 09-14-2009).]
unboundmo
Report this Post08-06-2009 04:36 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I welded up an oil cooler bracket for the passenger side wheel well area behind my stage II scoops. I think it'll work... 1/8" steel and it mounts with 3 bolts... 2 under the battery tray and below the fuel lines and one on the wheel well undercarriage. Oil feed is from a sandwich between the oil filter and block
I have a B&M cooler with a temp controlled fan. measures like 8" X 9"... It does fit FYI
Irvin Green
Report this Post08-06-2009 07:18 PM Click Here to See the Profile for Irvin GreenSend a Private Message to Irvin GreenEdit/Delete MessageReply w/QuoteDirect Link to This Post
waiting to get mine back!!! water pump want up and the dammm bolts are struck in the block. Was told down to one bolt still not wanting to come out.
ShockWave
Report this Post08-06-2009 07:36 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried to replace the front shocks and when I opened the boxes up I got one 88 Fiero shock and the other shock was for a completely different car. Figures.
NOW IT WON'T START AGAIN!
[This message has been edited by ShockWave (edited 08-06-2009).]
Finally_Mine_86_GT
Total ratings: 99
Report this Post08-06-2009 08:06 PM Click Here to See the Profile for Finally_Mine_86_GTSend a Private Message to Finally_Mine_86_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got some GT wheels on, fixed the out license plate lamp now i just noticed one of my brake lights are out! DOH!
Alibi
Report this Post08-06-2009 08:33 PM Click Here to See the Profile for AlibiSend a Private Message to AlibiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my heads back so I bolted on my exhaust manifolds. Looks like I'll bolt the AC compressor in first, then the heads and then get the motor timed (to adjust lash).
Now I'm just waiting on my crossover tube from Mr. Dickman before I put the intake back on (I hear its a PITA with everything in the way).
FieroMaster88
Total ratings: 168
Report this Post08-06-2009 08:39 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Washed it and took a picture.
wirthy
Report this Post08-06-2009 09:29 PM Click Here to See the Profile for wirthySend a Private Message to wirthyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got mine to pass emissions. Second time was a charm!
larini74
Report this Post08-06-2009 09:44 PM Click Here to See the Profile for larini74Click Here to visit larini74's HomePageSend a Private Message to larini74Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got one registered today....cost $207 , but now it's legal.....
kevin
Report this Post08-07-2009 10:58 AM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jeezus Kriss FieroMaster... that is one excellent looking Fiero. Tremendous wheel choice and stance. You make us Notchie guys look smart. Got any pics of the inside?
Cordially,
Kevin
Bry73
Report this Post08-07-2009 09:07 PM Click Here to See the Profile for Bry73Send a Private Message to Bry73Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bought a 3800SC Series I W/ transmission from a 93 Buick with 63000 miles on it for $200.
Now time to find a Cradle and start gathering all the rest of the parts for the puzzle.
Sundowner
Report this Post08-07-2009 09:19 PM Click Here to See the Profile for SundownerSend a Private Message to SundownerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got home late and washed the formula after dinner. Was going to take some "before" pictures but it got too dark out. I'll shoot some tomorrow and post em.
GTCONVERSION
Report this Post08-07-2009 09:21 PM Click Here to See the Profile for GTCONVERSIONSend a Private Message to GTCONVERSIONEdit/Delete MessageReply w/QuoteDirect Link to This Post
spent a hour trying to get the dipstick tube back in,Then broke it off
Alibi
Report this Post08-08-2009 11:55 AM Click Here to See the Profile for AlibiSend a Private Message to AlibiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heads are back on the block and ready to be bolted down. After that its time to drop in the distributor (set the motor to TDC on cyl 1 before I put the head on) and then adjust valve lash. I'm totally new to this stuff but I gotta learn someway I guess.
ShockWave
Report this Post08-08-2009 06:14 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's dead. Again. Turn the key to ON and I get no fuel pump and no SES light, but the fuel pump is fine because I got it to work when I hotwired it. Wondering if this is an electrical issue.
FieroGTguy
Total ratings: 101
Report this Post08-08-2009 06:45 PM Click Here to See the Profile for FieroGTguyClick Here to visit FieroGTguy's HomePageSend a Private Message to FieroGTguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I regretfully listed the wife's 1988 GT on Ebay for a low price. She wants a 3800SC swap, and it's to nice mechanically to mess with.
http://cgi.ebay.com/ebaymot...em&item=330350904850
Greg
americasfuture2k
Total ratings: 105
Report this Post08-09-2009 02:36 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
ive been swapping out my console skeleton fofr a good one i found in a junk yard. nothing broken on it. i was amazed. and running wired and fitting my wideband. thats a pain. i just now depinned a set of wires on the fuse block. more work to go. yippie.
First LX9 Fiero GT, 1987 | My Fiero Fuel Economy | MPG Display for OBD I
Youtube Videos of My GT | 87 GT Inside Test Run | 3500 Fiero GT Test Run 01
3500 Fiero GT Test Run 02 | 3500 Fiero GT Test Run 03 | 3500 Fiero GT Test Run 04
modernize your fiero with technology!
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
Madscanner
Report this Post08-09-2009 06:40 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Friday, got my new Formula through it's annual test, paid the annual vehicle tax, insured it, and drove it!
Saturday, sorted out the 3 flat tyres on my '84.
Today, will (hopefully) sort out the alternator on my '84.
If that all goes well, will start on replacing the 2 cracked sail panels on my '85.
topcat
Total ratings: 148
Report this Post08-09-2009 09:09 AM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed Loyde's dress up covers on the BBV, PCV and EVAP ports. Then I pulled it out of the garage for the first time in three months and washed all the dust off of it. Taking it out for a drive later this afternoon.
LT188GT
Total ratings: 100
Report this Post08-09-2009 03:50 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Waxed it.
FieroGTguy
Total ratings: 101
Report this Post08-09-2009 05:40 PM Click Here to See the Profile for FieroGTguyClick Here to visit FieroGTguy's HomePageSend a Private Message to FieroGTguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just my wife's 88 GT on Ebay and craigslist in search for a 3800SC swap.
Greg
Earl-R
Report this Post08-09-2009 05:41 PM Click Here to See the Profile for Earl-RSend a Private Message to Earl-REdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the LeBra on today, and a little polishing.
Also a pic after the lowering spindals on the front. I need to get the car out for a photo shoot.
topcat
Total ratings: 148
Report this Post08-09-2009 06:06 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put a coat of wax on it, then took it for a drive and a few pics.
[This message has been edited by topcat (edited 08-09-2009).]
GTCONVERSION
Report this Post08-09-2009 06:40 PM Click Here to See the Profile for GTCONVERSIONSend a Private Message to GTCONVERSIONEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made a new dipsticl and dipstick tube,Put a few small parts back on next week i will send in my insurance app at soon be on the road for the first time
Alibi
Report this Post08-09-2009 11:16 PM Click Here to See the Profile for AlibiSend a Private Message to AlibiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bolted my heads back on the block and got my distributor in at TDC for #1. Time to do valve lash and then I'll be ready to stick the lower intake back on.
Old Lar
Total ratings: 214
Report this Post08-10-2009 01:44 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got off my duff and changed the oil and filter on my 87. Its too friggen hot to do much of anything this time of year in Florida.. I then cleaned the spilled oil on the garage floor. I always spill some getting the filter off. I had to take a cool shower, now I'm just hanging watching NASCAR at the Glenn keeping cool.
[This message has been edited by Old Lar (edited 08-11-2009).]
ShockWave
Report this Post08-10-2009 02:37 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
It rode the towtruck.
pontiackid86
Total ratings: 344
Report this Post08-10-2009 02:39 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put in my new rodney dickman slave cylinder had andrew help me bleed the system and took her out for the night. it drives like a champ now.
Fiero84Freak
Report this Post08-10-2009 04:56 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaned the interior and both the front trunk and the rear trunk/drivetrain. Getting ready for a car show this Friday. Friday morning I'll clean and detail it real good to get ready for the show.
Also drove it to work
Old Lar
Total ratings: 214
Report this Post08-10-2009 05:35 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is my next project, plus reinstalling my new master.
Cheever3000
Total ratings: 178
Report this Post08-10-2009 10:15 PM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine wouldn't start after I came out of the convenience store this morning on the way to work. The engine turned but didn't fire. Had AAA tow it to the shop. On the bright side, now I can have a couple other things taken care of at the same time.
hksteck84
Report this Post08-10-2009 11:06 PM Click Here to See the Profile for hksteck84Send a Private Message to hksteck84Edit/Delete MessageReply w/QuoteDirect Link to This Post
I put in a new tach filter and a new right side front marker light. Then I took her for a nice stroll around the park to show her off.
Danyel
Total ratings: 171
Report this Post08-11-2009 12:17 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well today got busy caused received a whole bunch of stuff hehehehehe here are some pictures of the mods of the day of my Black Widow ... to be continued...
New V8 emblems
Installed almost new RH tail light and GT emblem (thanks to Robert 2) also looking for a LH tail light now to match the RH
Installed new POD faceplate made by chrishahn87
(The tach on the left of the POD is now installed in the stock fiero tach location)
Shad0wguy
Report this Post08-11-2009 06:18 PM Click Here to See the Profile for Shad0wguySend a Private Message to Shad0wguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the fuel pump, so my Fiero finally runs after owning it for 3 years.
Tony Kania
Total ratings: 305
Report this Post08-11-2009 07:28 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Phew! After the Northwest Fierofest, my GT decided that it is time to get a new alternator. The only accessory that I did not replace last year during the engine transplant. You see, the parts store gave me the wrong one. So, after putting in the old one, I got another 3000 miles out of it. After the show, I started to get a chirping sound from the bearings. Greg and Aaron drove me up to the Richland Autozone to get a rebuilt one. Thanks guys. Planned on replacing it in the morning before the 150 miles home. But, the chirping went away, and I was feeling lucky. So, today I swapped it out. Guage is steady as can be. Before she shook like a recovering meth addict.
While that went on, I decided to put a bit of high temp caliper paint on the heat shields throught the engine bay. This was something that I had been putting off for a while now. The rusty shields were bothering the piss out of me. I think that they came out pretty good.
[This message has been edited by Tony Kania (edited 08-11-2009).]
