  What Did You Do To Your Fiero...TODAY ? (Page 51)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219388 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
doublec4
Total ratings: 150
Report this Post08-29-2009 10:09 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by infinitewill:
It's about time! I have seen your posts for months wanting someone to make a diffuser and I always wondered why you haven't made your own? Your work has always looked terrific! Definitely got skills
Thanks! I was hoping I could inspire someone to make a fiberglass one because my fiberglass skills are non-existant. However, Im making the cardboard mock up which I will then take to a shop that can bend and cut the shape out of aluminum. I'll paint it black and mount it I also have some plans for the exhaust tunnel areas.
Check out my build!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
infinitewill
Total ratings: 85
Report this Post08-29-2009 10:56 AM Click Here to See the Profile for infinitewillSend a Private Message to infinitewillEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by infinitewill (edited 01-02-2016).]
grkboy707
Report this Post08-29-2009 11:42 AM Click Here to See the Profile for grkboy707Send a Private Message to grkboy707Edit/Delete MessageReply w/QuoteDirect Link to This Post
im about to go clean my calipers, and soon comes paint
katatak
Total ratings: 82
Report this Post08-29-2009 06:42 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a headlight problem the other day on my Formula. Headlight did not want to come up without some help. I had rebuilt the motor a few months ago so I was at a loss as to why. I was in a hurry and had a spare motor on the bench so we slapped in the spare. I opened up the "bad" motor to see what the problem was. When I rebuilt the motor, I used the bushings from the "help" section at AZ - the ones for the Ford power windows. I have used these several times in the past with no issues. Here's what I found when I took it apart.
So today I picked up another set of the "help" bushings and installed them. The ones in the pick are way softer than the ones I just picked up. Looks like I got a bad set of bushings. What are the odds? Anyway, wanted to pass it on.
Pat
grkboy707
Report this Post08-29-2009 09:00 PM Click Here to See the Profile for grkboy707Send a Private Message to grkboy707Edit/Delete MessageReply w/QuoteDirect Link to This Post
painted the rears, lookin very nice!
qwikgta
Total ratings: 84
Report this Post08-29-2009 11:31 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
painted the bumper, installed it and got the lights all working, well all except for one that I need to trouble shoot tomorrow. Now I just need to paint the rest.
Rob
88 TTop coupe (96 3.4DOHC/5 speed)
03 Vibe GT. 6spd (stock)
05 GTO, LS2, 6spd (not stock)
84 SE "Vert" (oh boy, what did I do now)
Total ratings: 461
Report this Post08-30-2009 03:28 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob
I like that! The car and the color!
[This message has been edited by Raydar (edited 08-30-2009).]
Total ratings: 461
Report this Post08-30-2009 03:39 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Oct 1999
I just rebuilt my right side headlight motor. It was going about 2/3 open and then stopping.
When I took it apart I discovered that the gear had cracked and was binding when that side rotated around to the drive gear.
First time I ever saw that.
Repaired my trunk popper. Had a wire that had fatigued where it goes through the rubber grommet into the decklid.
I'm still trying to figure out why my oil pressure sender or plug is causing the fuel pump to mysteriously run.
After I parked the car last Saturday, I came back down a couple hours later to hear the fuel pump happily humming along. (It was NOT running when I stopped the car.)
I opened the decklid and unplugged the sender connector. The pump immediately stopped.
The really strange thing is that it is a brand new sender. I had replaced the old one because it was leaking oil into the connector and, strangely enough, had run the fuel pump until it killed my battery the previous week.
88 4.9 Formula IMSA Fasback..........................88 3.4 coupe -soon to be something other than red
Read Nealz Nuze! Praise the Lowered!
Gokart Mozart
Total ratings: 159
Report this Post08-30-2009 08:08 AM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sat in it for the first time in 3 weeks. Got a couple parts and started to tinker...
A few years ago I picked up a cup holder. I set it in and it was a great fit. I'll be attaching it with velcro for now. I got it from the plant that made them, it was a reject but hard to tell, but I can't remember what vehicle it went into.
Larryh86GT
Report this Post08-30-2009 01:44 PM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the side air intake vent with the FS side air scoop.
Looks pretty good. (15% off sale)
Give a man a fish and he will eat for a day. Teach him how to fish and he will sit in a boat & drink beer all day.
Denial is not just a river in Egypt.
LT188GT
Total ratings: 100
Report this Post08-30-2009 05:38 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took it to a car show and walked around in the 95* heat.
1988holleyformula
Total ratings: 68
Report this Post08-30-2009 08:31 PM Click Here to See the Profile for 1988holleyformulaSend a Private Message to 1988holleyformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
went from this
to this
zigaroo
Report this Post08-30-2009 08:56 PM Click Here to See the Profile for zigarooSend a Private Message to zigarooEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed the rattling in my steering wheel. The plastic peice that held the rod and spring in place for the horn "unlocked" itself and was just moving around freely, making an aweful lot of noise on every bump. Now I get to listen to the squeeking of the axles for a little bit.
pete 2m4
Report this Post08-30-2009 10:56 PM Click Here to See the Profile for pete 2m4Send a Private Message to pete 2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
i waxed installed the water deflector in the rear and enjoyed a drive in the country
Sofa King
Report this Post08-31-2009 08:51 AM Click Here to See the Profile for Sofa KingSend a Private Message to Sofa KingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi All,
Just bought an 88 a little over 2 weeks ago. I don't have any pics (sorry) but this is what I've done so far
1) Replaced worn 88 Steering Wheel with new leather wrapped GT style from Dallas Custom Steering Wheel
2) Replaced the trunk lock
3) Replaced the headlight switch inc. trim
4) Replaced wipers
5) New brakes
6) Alignment
7) Plugs, Wires, Filters & Fluids
8) Replaced Pontiac Logos near sail panels
9) Lot's of knicky knacky things from "The Fiero Store"
10) Masked off car and sanded, primed & painted side mirrors
Spent the last 3 days sanding the entire car with 1000 grit sand paper (lots of oxidation & tree sap) and then polished with foam pad and polishing compound - whew... My arms are killing me! She's now SMOOOOTH as glass and I can see myself. The best part... gets great gas mileage (a clean car runs better)
Getting ready to replace:
1) Power Window Motors
2) Window Switches
3) Remove Cat Conv and replace with straight pipe
4) Replace Inner & Outer Tie Rods (basic front end rebuild)
5) Power Lock install
6) Power Trunk Install
Lot's to do and so little time
RCW
Report this Post08-31-2009 09:10 PM Click Here to See the Profile for RCWSend a Private Message to RCWEdit/Delete MessageReply w/QuoteDirect Link to This Post
Leaking valve cover on the duke has been bothering me for months. Purchased the FelPro VS50179T kit that has the rubber gasket, bolts and spreaders. Installed and no more leaks!
RCW
Report this Post09-01-2009 03:23 PM Click Here to See the Profile for RCWSend a Private Message to RCWEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure if this went wrong or got fixed
A/C blowing warm.
Evacuated and charged the A/C with our nifty automatic machine at work. No leaks so recharged it and It really blows cold air now. Must have had some mosture or air in the system from the R12-R134 conversion last summer.
I will post in what went wrong with your Fiero too. Jsut make sure all bases are covered.
americasfuture2k
Total ratings: 105
Report this Post09-02-2009 08:53 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
was finally able to retract the piston into the new caliper. it compresses, not screws in like it looks. now to get back to working on the car. oh, and fixed that clinking noise. it was the compressor. came loose. D'oh!
First LX9 Fiero GT, 1987 | My Fiero Fuel Economy | MPG Display for OBD I
Youtube Videos of My GT | 87 GT Inside Test Run | 3500 Fiero GT Test Run 01
3500 Fiero GT Test Run 02 | 3500 Fiero GT Test Run 03 | 3500 Fiero GT Test Run 04
modernize your fiero with technology!
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
[This message has been edited by americasfuture2k (edited 09-02-2009).]
doublec4
Total ratings: 150
Report this Post09-02-2009 11:42 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took delivery of my sway bars
Check out my build!
Danyel
Total ratings: 171
Report this Post09-02-2009 07:30 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I cut out thedecklid vent and installed a 1979 Mustang scoop with the Black Widow's distinctive mark .
[This message has been edited by Danyel (edited 09-14-2009).]
CowsPatoot
Total ratings: 84
Report this Post09-02-2009 08:27 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Love the hourglass.....
Converted the interior back to stock. Really hate that ricer look of having all the trim painted. Here are some before and after shots. I have a new dash waiting, but I want to modify it for 6x9 speakers before I put it in. Still need to redo the steering wheel...and Fierfly doesn't get to keep my 6 ball shifter, she will have to order a 1 or 9 ball from Carver herself.
[This message has been edited by CowsPatoot (edited 09-02-2009).]
Shad0wguy
Report this Post09-02-2009 11:37 PM Click Here to See the Profile for Shad0wguySend a Private Message to Shad0wguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my Walker exhaust from the Fiero Store. Gonna try to install it tomorrow.
ktthecarguy
Total ratings: 167
Report this Post09-03-2009 02:45 AM Click Here to See the Profile for ktthecarguyClick Here to visit ktthecarguy's HomePageSend a Private Message to ktthecarguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tightened the alternator belt. No more squeal. And, for the first time in 2 years, I GOT TO DRIVE IT!!! What fun, rowing through the gears again.
Steve25
Report this Post09-03-2009 04:19 PM Click Here to See the Profile for Steve25Send a Private Message to Steve25Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought it a Series III 3800 SC with 23,000 miles on it.
Steve AT 88GTP DOT com
88 GT
Tinker
Report this Post09-03-2009 11:33 PM Click Here to See the Profile for TinkerClick Here to visit Tinker's HomePageSend a Private Message to TinkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
To be honest it wasn't today, but over the past week I got some work done. I fixed the wiring to the trunk light, it was sparking every time it moved as the plastic thingie that holds it in has broken off. Then the car wouldn't start, did some troubleshooting and found the previous owner had wired in a kill switch. The toggle was inside the lamp recess and ran to the coil which was flicked when I moved the wiring around. It was a half a**ed job using heater cord and a cheap plastic 110v toggle switch needless to say it all came out and the wiring repaired. I also put in an electronic air horn, I dare anyone to cut me off now
Kevin
High speed, low drag
1987 Fiero GT auto
2005 Crown Victoria Police Interceptor
Ditkaphile
Report this Post09-04-2009 03:05 PM Click Here to See the Profile for DitkaphileSend a Private Message to DitkaphileEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got it out of the shop and got to drive it for the first time!
grkboy707
Report this Post09-04-2009 03:09 PM Click Here to See the Profile for grkboy707Send a Private Message to grkboy707Edit/Delete MessageReply w/QuoteDirect Link to This Post
finished the calipers!!!! yay!!!!!
Old Lar
Total ratings: 214
Report this Post09-04-2009 03:39 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Washed and spray waxed my 87GT, getting ready for a car show at Melbourne Airport scheduled Sunday. It is still too hot to do a lot...
sk8rfiero
Report this Post09-04-2009 09:09 PM Click Here to See the Profile for sk8rfieroSend a Private Message to sk8rfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my exhaust system reinstalled on the car. It had been ripped loose & bent up while putting it on the flat bed trailer to haul it home after my wreck on I75. Late last night I got the rear control arm replaced it was bent @ a 45' angle. Spent the rest of the mornin in search of 4 used tires, which were no where to be found I may have to bite the bullet & buy new....."Honey, no eating for the next 2 weeks ." lol
Member of Suncoast Fieros of Tampa Bay [URL=http://photobucket.com/albums/y29/sk8rfiero/My%20Fieros/
85 2M4coupe
86 SE 2M6
85 SE 2M6
zigaroo
Report this Post09-04-2009 10:08 PM Click Here to See the Profile for zigarooSend a Private Message to zigarooEdit/Delete MessageReply w/QuoteDirect Link to This Post
Used ICE Clay Bar kit and Meguiar's NXT Wax. Spent four hours doing so. Also, a lesson learned---clay bar the entire car... amazing how much difference there was between the parts I skipped as it was getting dark outside. Went from super smooth to an abrupt halt.
I think that's about the end of the road with what I am going to do in trying to revive the original car paint. Although, the NXT has put a rather nice mirror finish and deepend the color a bit.
I also cleaned the engine bay a bit, but need some of the engine cleaner spray to finish it off.
Dgzfiero
Report this Post09-04-2009 10:32 PM Click Here to See the Profile for DgzfieroSend a Private Message to DgzfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got about half the exhaust reinstalled on my GT. Gonna get the rest of it put on tomorrow, and work on reinstalling the intercooler setup.
Tony Kania
Total ratings: 305
Report this Post09-04-2009 10:48 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to take off the top half of my enginethis week due to a gasket leak. Heads come off in a few days. I figured that I would do a bit of cleaning up. I also decided to gasket match my intakes.
ShockWave
Report this Post09-05-2009 01:47 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced all four speakers:
| Fiero Blog | CarDomain Page | Member: NIFE, Mis-Shifts |
| Photography | Like RollerCoasters? |
"There's Nothing Worse than a Smartass Automobile" -- KITT
[This message has been edited by ShockWave (edited 09-05-2009).]
Daredevil05
Report this Post09-05-2009 06:37 PM Click Here to See the Profile for Daredevil05Send a Private Message to Daredevil05Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed both rebuilt rear calipers. Now I have to wait for the wife to come home so I can bleed the brakes.
I installed a new driver side headlight and while I had it apart I replaced the gear with another nylon gear from Fiero Store. I'm tire of seeing it sit in my driveway paying insurance and not being able to drive it around. It's depressing,
Steve25
Report this Post09-05-2009 06:50 PM Click Here to See the Profile for Steve25Send a Private Message to Steve25Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Series III 3800 SC I bought the other day fell through so...................................................
I found a Series II 3800 SC with 25,000 miles on it and put down a deposit. Pick it up next Saturday.
GS Jon
Report this Post09-05-2009 08:39 PM Click Here to See the Profile for GS JonClick Here to visit GS Jon's HomePageSend a Private Message to GS JonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put the driver's side from knuckle back on and hand tightened the lug nuts on the wheel, essentially completing the suspension upgrade on that corner. I then moved on to the front passenger's side and disassembled everything and pulled off the control arms. The bushings are burned out and the sleeves are reasy to have the poly bushings pressed in. If luck is on my side I'll have everything put back together in the front with the new shocks and ball joints by noon tomorrow.
Then it's time to tackle my rear suspension upgrade in earnest.
ShockWave
Report this Post09-07-2009 01:03 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hooked up a wiring harness and mounting hardware to this 91 Bonneville radio that's going in the car in the morning. Got the radio for a buck and shipping (>$10). If it works I'll pick up an antenna adapter and I'll be happy!
mrfiero
Total ratings: 150
Report this Post09-07-2009 03:35 AM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced the fuel pump in the coupe on Sunday. Runs much better now!
[This message has been edited by mrfiero (edited 09-07-2009).]
Ditkaphile
Report this Post09-07-2009 04:59 PM Click Here to See the Profile for DitkaphileSend a Private Message to DitkaphileEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced this (AC Delco part...maybe even the original, which would make it 22 years old).....
With this....
Broke in half while I was trying to get it loose. Thank God for PB Blaster...lol
[This message has been edited by Ditkaphile (edited 09-07-2009).]
americasfuture2k
Total ratings: 105
Report this Post09-09-2009 11:07 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
put the new speed bleeder on the new LR caliper, bled it in 5 or so pumps. love those little buggers.
replaced the ebrake cable connector that shattered. yes, it actually shattered good temp fix till i replace the entire ebrake cable system.
ran the battery cable from the norms kit as far as i can get it till i can jack the front of the car up. now i need a long negative cable to run from the engine ground location to the battery. soon she shall be up and running again ready to get welded and tuned.
