  What Did You Do To Your Fiero...TODAY ? (Page 67)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223314 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
2m4dude
Report this Post03-25-2010 10:18 PM Click Here to See the Profile for 2m4dudeSend a Private Message to 2m4dudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
just installd the short shifter i urge u all to get one
ShockWave
Report this Post03-26-2010 07:33 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fueled up and washed it, 35-degrees is warm enough for me. Between the wind and rain from yesterday I had tree crap all over the car. Installing new wipers next. Oil change Monday.
[This message has been edited by ShockWave (edited 03-26-2010).]
Sharkman
Report this Post03-26-2010 08:21 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
My friend made me a new short shift with one more mod. The marked area are now longer. That makes the stroke shorter as well.
jim94
Report this Post03-26-2010 10:17 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
i drove my car from jacksonville to daytona and went to the hot rod show in the speedway. i turned the ac on and it worked, dam what a day.some real nice but i did not see any fieros from any club, but lots of smoking hot rods.
2m4dude
Report this Post03-26-2010 10:23 PM Click Here to See the Profile for 2m4dudeSend a Private Message to 2m4dudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
by adding that does it throw ure gear placement off ?
2m4dude
Report this Post03-26-2010 10:30 PM Click Here to See the Profile for 2m4dudeSend a Private Message to 2m4dudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
2m4dude
Member since Feb 2010
had to thuroughly test the short shifter i insalld last night and it works so nice
proff
Total ratings: 87
Report this Post03-27-2010 03:11 AM Click Here to See the Profile for proffClick Here to visit proff's HomePageSend a Private Message to proffEdit/Delete MessageReply w/QuoteDirect Link to This Post
still nothing
cost to much
No Job
yet
dobey
Total ratings: 371
Report this Post03-27-2010 08:46 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If by placement, you mean the position of the gear numberings in the shift gate, then definitely not. The position of the part of the shifter above the pivot point doesn't change. Lengthening the part below the pivot point also doesn't change any gear positions. What it does do, is reduce the amount of effort it takes to move the shifter into, or out of, a gear. Depending on the angle of the lower shifter, and the amount of increase in the length of the lower shifter, you might end up needing slightly longer shift cables, though.
Another thing that would reduce shift effort, is a newer transmission, which has a huge shift assembly with counterweights. The counterweights help by tending to 'pull' the gear selector; once the weight moves a certain amount.
Sharkman
Report this Post03-27-2010 08:55 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should only make the stroke shorter. Have it in the car but have not been out yet.
Feels good and I don´t think there will be any problem
[This message has been edited by Sharkman (edited 03-27-2010).]
ManMadeChickens
Report this Post03-28-2010 05:23 AM Click Here to See the Profile for ManMadeChickensSend a Private Message to ManMadeChickensEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed a Keyless entry system into my '86 SE. Not as bad of an install as I expected, and the results are pleasing!
87antuzzi
Total ratings: 228
Report this Post03-28-2010 05:28 AM Click Here to See the Profile for 87antuzziSend a Private Message to 87antuzziEdit/Delete MessageReply w/QuoteDirect Link to This Post
looked at it.
Madscanner
Report this Post03-28-2010 09:59 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swapped one of my Formula's headlight motors for another one - decided that the replacement is even worse than the original, so have ordered a rebuild kit from Rodney...
Also, have worked out that the immobiliser/alarm is what is draining my battery overnight. Grrr...
Curlrup
Report this Post03-28-2010 10:29 AM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wrestled with motor mounts after pulling the pan. Man they are tough to line up again.
Tom Slick
Report this Post03-28-2010 11:48 AM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
did this mod (replaced the turn signals with driving lights with build in turn signals) just in time for NTFC's Spring Fling.
thanks to fierocarparts for the photo
tonycampbell86gt
Report this Post03-28-2010 12:24 PM Click Here to See the Profile for tonycampbell86gtClick Here to visit tonycampbell86gt's HomePageSend a Private Message to tonycampbell86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Washed the car now that the sun has made an appearance!
Tony
Frizlefrak
Total ratings: 72
Report this Post03-28-2010 06:20 PM Click Here to See the Profile for FrizlefrakSend a Private Message to FrizlefrakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started adding the aux gauges to my 88 4.9 coupe that Katatak found for me in the junkyard on Saturday. Gotta do a little console skeleton repair while I'm in there too.
redwingshat
Report this Post03-28-2010 06:42 PM Click Here to See the Profile for redwingshatSend a Private Message to redwingshatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had a friend replace my right back lower ball joint, man its such a smoother ride now thats changed
katatak
Total ratings: 82
Report this Post03-28-2010 07:10 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went on a headliner material seach today - found nothing that I liked as much as the previous material. The search continues!
NCTyphoonKid
Report this Post03-28-2010 07:49 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
i bought parts for my goldie
Korey "Plastic Makes It Possible"
"Christine"86 Pontiac Fiero SE gold on black options incl luggage rack,power windows,power door locks,sunroof,4 spd,body colored wheels
"Brooke"86 Fiero base coupe 2.5 4cyl/5speed
86 Fiero GT black,grey ground effects (in pieces)
86 Buick Grand National bone stock
93 GMC Typhoon #1710 black on black bone stock
Blacktree
Total ratings: 350
Report this Post03-28-2010 08:07 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sat in the house and watched the rain pour down on the Fiero.
Hopefully, the weather will be clear tomorrow afternoon.
2m4dude
Report this Post03-28-2010 08:11 PM Click Here to See the Profile for 2m4dudeSend a Private Message to 2m4dudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
i got to get in my fiero with a soak'd seat damn rain lol' i had to leave my window crackd the night it rains
topcat
Total ratings: 148
Report this Post03-28-2010 08:15 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it from Daytona - the rain chased us all the way to SC.
Made it home, and washed the bugs off just as the clouds opened up and the rain started coming down hard.
Pulled her in the garage and dried it off... will detail it tomorrow.
Boostdreamer
Total ratings: 98
Report this Post03-28-2010 09:27 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to church this morning, put on my rear Fiero Store sway bar, then drove back to church tonight for a test drive. It DEFINATELY helps the bump steer. I totally still need an alignment, though.
Jonathan
ARFiero
Report this Post03-28-2010 10:51 PM Click Here to See the Profile for ARFieroSend a Private Message to ARFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finnished prepping the engine and trans for cradle removal..and for the 3rd day in a row soaked the front cradle bolts in PB Blaster to aid in removal...hope it helps!
Shelby
jgeis
Report this Post03-28-2010 11:38 PM Click Here to See the Profile for jgeisSend a Private Message to jgeisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just drove it back from a weekend at Purdue, my Fiero's "maiden voyage". 250 miles without so much as a hiccup. Friday I got stuck in stop and go traffic on I-65 due to a car fire, and the Fiero didn't overheat or anything. Averaged 30mpg even on the trip.
Sharkman
Report this Post03-29-2010 06:42 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
More info on that?
Genopsyde
Report this Post03-29-2010 06:58 AM Click Here to See the Profile for GenopsydeClick Here to visit Genopsyde's HomePageSend a Private Message to GenopsydeEdit/Delete MessageReply w/QuoteDirect Link to This Post
finally installed a new exhaust in the duke from manifold back. so nice to have a quiet car again.
justa6
Total ratings: 61
Report this Post03-29-2010 11:21 AM Click Here to See the Profile for justa6Send a Private Message to justa6Edit/Delete MessageReply w/QuoteDirect Link to This Post
(yesterday) pulled the car out of storage, changed the oil, drove it hime to wash it.
(today) drove it to work waaay to fast
My Photography 2009 Calendars now available! PM me
My Designs
My Videos
87 Fiero GT 5-speed.
98 Golf K2 5-speed 2.0
Minivan Drivers; they're good for fertilizer. Thats all.
ShockWave
Report this Post03-29-2010 12:33 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil change
| Jon | Member: NIFE, Mis-Shifts | Facebook | Fiero Blog |
| Photography | Great America Zone | Dixie Square Mall
SC Coupe
Report this Post03-29-2010 07:17 PM Click Here to See the Profile for SC CoupeSend a Private Message to SC CoupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the High Mounted Brake Light after driving without it down I-95 to Daytona and back....
Lowcountry Fiero
South Carolina Fiero Club
'88 Coupe "Plain Vanilla"
'86 GT "Black Pearl"
falcon_ca
Report this Post03-29-2010 10:27 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I modified 3 Miata round vents to have them fit in the back of an aluminum radio/ac dash bezel with 3 x 2-1/16 holes.
This will look better with the three gauges aluminum panel I already have.
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08
Work done 08-09
Work done 09-10
4.9 ongoing project
redwingshat
Report this Post03-30-2010 08:44 PM Click Here to See the Profile for redwingshatSend a Private Message to redwingshatEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced my alternator it charges so much better now but its making a cool whistling noise now kinda sounds like a supercharger
Spynx
Report this Post03-30-2010 09:14 PM Click Here to See the Profile for SpynxClick Here to visit Spynx's HomePageSend a Private Message to SpynxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Calculated my MPG.... currently at 14.8. That's about .5 better than before.... still no idea why it's getting such bad mileage. My dad who is a mechanic, his mechanic friend, and others have not been able to figure it out. :/
randye
Total ratings: 204
Report this Post03-30-2010 10:33 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally figured out how to reprogram my Viper keyless entry system to NOT lock the doors automatically when the ignition key is turned on.
Yes, I have shut the doors with the car running and windows up at least 3-4 times before finally fixing this little annoyance.
Lucky I had the spare remote and another set of keys tucked away.
pontiackid86
Total ratings: 344
Report this Post03-30-2010 10:44 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
They both sat. in the rain.
ShockWave
Report this Post03-30-2010 11:30 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Detailed it; weather is going to be awesome tomorrow!
dobey
Total ratings: 371
Report this Post03-31-2010 09:10 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Haha. Having the sunroof popped up, and not entirely out can be a savior for times like that.
dobey
Total ratings: 371
Report this Post03-31-2010 09:15 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
2.8? If so, I only get about 16 around town if I drive it hard, in a pretty flat area. If you're on hills, you'll obviously get less. Though I got a lot less on my last tank... My e-brake seems to be keeping the brake on the driver side a little closed. Enough to rub metal, and create friction to waste power, but not enough to stop the car from moving, or slowing down terribly. Needless to say, she's sitting in the garage until I can pull the wheel and brakes and see what's going wrong exactly.
ShockWave
Report this Post03-31-2010 10:49 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took it to Dog n Suds...
OM NOM NOM
randye
Total ratings: 204
Report this Post03-31-2010 11:15 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
IF I had a sunroof.....
Mine's a hardtop.
