  What Did You Do To Your Fiero...TODAY ? (Page 69)
This topic is 176 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 7011 (223273 views)
Last post by: Vintage-Nut on 12-16-2025 04:33 PM
katatak
Total ratings: 82
Report this Post04-09-2010 11:30 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my 1 penny MP3 amp thingie in my V8 Coupe.
Pat
Oh Yeah - I own page "69"!
[This message has been edited by katatak (edited 04-09-2010).]
ShockWave
Report this Post04-10-2010 12:46 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picked it up from the shop. I'll be brief, but this was a hell of a week.
Sunday night: Dropped off. For the last few weeks it's been having rough startups when the motor was cold; I would turn the key to "ON" so the fuel system pressurizes, then turn the key to crank like normal. It would fire but immediately kill, and to restart it required alot of cranking to get the motor to fire up again.
Monday: Go-figure it ran perfect for them. Told them to keep it another day.
Tuesday: Finally shows hard start symptoms. Fuel system tested and is running flawlessly and at the correct pressure. Kept another night.
Wednesday: Ignition system checked, distributor pulled and I guess it was so bad that parts of it crumbled when they pulled the thing out. Distributor and ignition module would not come in until Thursday.
Thursday: Distributor and ignition module replaced. During testing there were vacuum leaks found in the EGR tube going from the valve to the intake, and the vacuum lines under plenum were also leaking. Both repaired. They test-drove it and as I'm getting ready to go pick it up I get a call that it died 3/4 of a mile from the shop and would not re-start. Rode the towtruck and spent another night.
Friday: New ignition module was a dud, and was replaced. Tested fine throughout the day. Picked it up, drove it a bit and it ran fine. Fueled up and parked it. We'll see how it runs tomorrow. Needs a bath.
I have to go back on Monday to pay, I'll see what my old distributor looks like then.
Blacktree
Total ratings: 350
Report this Post04-11-2010 04:28 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
This morning, I re-installed the hood, after fiberglassing in a pair of vent scoops.
katatak
Total ratings: 82
Report this Post04-11-2010 06:49 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed a huge vacuum leak on the V8 Coupe, cleaned up some wiring. Adjusted the choke and carb. Let it idle for an hour. after 30 minutes, the temp climbed to 200. I turned the fan on and it quickly dropped to 180 and sat there for the last 30 minutes. Looks like I will not have any overheat issues? Finally got the interior back in the car! Just have to finish the doors!
Pat
ShockWave
Report this Post04-11-2010 08:40 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found this on my windshield
Dracor
Report this Post04-12-2010 11:18 AM Click Here to See the Profile for DracorSend a Private Message to DracorEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ha, nice.
I rebuild one side of the hinges on my 355 hood, just need to do the other side. Bolted down the passenger seat bottom and seatbelt, as I am missing a bolt for the back rest...
'84 3800SC, XP cam, 3.2 pully, HPTuners, N* TB, 4sp, SPEC 3+ clutch, Aluminium flywheel, pacesetter headers, F355 body kit, weight reduction
Bry73
Report this Post04-12-2010 08:14 PM Click Here to See the Profile for Bry73Send a Private Message to Bry73Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished tearing down my serie 1 3800sc that I picked up a few months ago. Found 2 pistons with frozen rings, 2 cylynders had some orings sitting ontop of the piston. Other than that the top end was clean, but the bottom end lots of sludge in oil pan, front main bearing was discoloring. Now have to wait another month before I start putting it back together.
Reason is that is the next time I wil be home for a weekend.
GT86FASTBACK
Report this Post04-12-2010 08:35 PM Click Here to See the Profile for GT86FASTBACKSend a Private Message to GT86FASTBACKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am not a fan of notchies but i like this little guy. Very cool!
Marko
Report this Post04-12-2010 10:56 PM Click Here to See the Profile for MarkoSend a Private Message to MarkoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pat
What the ..........?
Low tech retro, maybe?
Bargin bin day at Radio Shack perhaps?
exoticse
Total ratings: 106
Report this Post04-13-2010 01:28 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
played around with a few different looks.
No wing.
Bow tie wing.
low rise
Stripped screw delayed my test of my 5" raised wing stands.
what it looks like regular (stock)
Taijiguy
Total ratings: 244
Report this Post04-13-2010 03:34 PM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
*sigh* I walked past mine in the garage with all 4 corners torn apart, the interior completely gutted, the 4.9 in a thousand pieces and the transmission and cradle on a trailer out back, knowing I'll have no time to work on it again for God-knows-how-long. Then I sobbed a little.
Genopsyde
Report this Post04-13-2010 03:39 PM Click Here to See the Profile for GenopsydeClick Here to visit Genopsyde's HomePageSend a Private Message to GenopsydeEdit/Delete MessageReply w/QuoteDirect Link to This Post
checked the balljoints and tie-rods for "play" because I started hearing some noises yesterday. all seems well though.
Fie Ro
Total ratings: 132
Report this Post04-13-2010 05:11 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made a sparkplugwire mount thingie last night....
round teflon stock milled, drilled and sanded..with recessed mounting screws and an extra passage for other wiring..It was fun to do but I still wonder if this stuff can be painted easily ?
thedrue
Report this Post04-13-2010 05:18 PM Click Here to See the Profile for thedrueSend a Private Message to thedrueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you all tell what I did?
is this how you know your car is too low? You drive on grass and it rubs your belly.
Nah, just means the grass is too tall!
Snapperhead
Report this Post04-13-2010 07:32 PM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I powder coated my axles on Snapperhead. Candy red over silver sparkle, I like it.
Hop Till You Drop!!
www.worldwidefieros.com
"Uniting Fiero Owners Worldwide"
Add Your VIN's to the Worldwide Fieros Registry!!
Add Your Car Shows to the Worldwide Fieros Show Dates!!
86 GT " Snapperhead" .. Lambo Doors, ZZ4 FI 350, 5sp, Car pc, Laser Blue
87 GT "Whipersnapper" .. 2.8, Auto.. Planning a LS4 Conversion
88 Formula.. 2.8, Auto, Stock, White... Wife Ride
85 Gt Black, 2.8, 4sp, Lowered and ready for paint.
99 K2500 Suburban, 454, 4X4, The Tow Rig
04 Trailblazer, 4x4, Green, Wife Ride
[This message has been edited by Snapperhead (edited 04-13-2010).]
americasfuture2k
Total ratings: 105
Report this Post04-13-2010 11:10 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
drove my fiero as far to the right as i could in a one car garage and parked it on ramps. getting ready to drop the cradle for its.. 9th engine in almost 4 years time
First LX9 Fiero GT, 1987 | My Fiero Fuel Economy | MPG Display for OBD I
Youtube Videos of My GT | modernize your fiero with technology!
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
katatak
Total ratings: 82
Report this Post04-13-2010 11:23 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
And your point is?
randye
Total ratings: 204
Report this Post04-14-2010 12:55 AM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
low rise
You know I'm a * wingless* fan, but....
THAT looks good!
Check out the the "stealth" wing stands that Oslo has.
Low roof + Low wing = Sleek and modern
ShockWave
Report this Post04-14-2010 02:02 AM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to go pay the shop and see what happened to my distributor... here's whats left of the magnets near the top:
[This message has been edited by ShockWave (edited 04-14-2010).]
BHall71
Report this Post04-14-2010 09:01 AM Click Here to See the Profile for BHall71Send a Private Message to BHall71Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, Monday morning I was frantically looking for my keys and when I found them I proceeded to get in my truck and back into my fiero. Messed up my roll pan and scratched the primer on the fiero bumper. No too concerned about the fiero because body work is in process, but I am not too happy about the truck.
Brian
2mEV
ShockWave
Report this Post04-14-2010 11:52 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my junkyard-find radio; finally have a working tape deck again!
Need to hit Best Buy tomorrow for an antenna adapter.
Danyel
Total ratings: 169
Report this Post04-15-2010 12:28 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Assembled my wing with TLG struts ...repainted and tested the 3rd brake light.....
pontiackid86
Total ratings: 344
Report this Post04-15-2010 12:33 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove the red one out my neighborhood since the ICM issue.
dobey
Total ratings: 371
Report this Post04-15-2010 12:26 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's it getting this time?
Larryh86GT
Report this Post04-15-2010 12:39 PM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled her out of the garage this morning, dusted her off and took a quick drive around the block. Parked her back in the garage.
Danyel
Total ratings: 169
Report this Post04-15-2010 01:44 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
bought these .........
http://www.blackwidowfiero.com
Snapperhead
Report this Post04-15-2010 04:35 PM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the rear control arms off for powder coating. Also time to replace the trans after breaking the case.
Newbfiero
Total ratings: 78
Report this Post04-15-2010 05:00 PM Click Here to See the Profile for NewbfieroSend a Private Message to NewbfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got myseft a New windshield put in today ..
ShockWave
Report this Post04-15-2010 06:50 PM Click Here to See the Profile for ShockWaveSend a Private Message to ShockWaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought an antenna adapter and re-attached the fascia; audio upgrades are done!
Also did an exterior detail:
RACE
Total ratings: 157
Report this Post04-15-2010 11:57 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I replaced my driver's side front wheel bearings, races and grease seal. No more gravely noise when turning right. Odometer 155,533.
[This message has been edited by RACE (edited 04-16-2010).]
Easy8
Report this Post04-16-2010 12:05 AM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled my bent clutch pedal, took a large aligning tool (sledge Hammer) made some minor adjustments and reinstalled the pedal. Now the clutch will engage and disengage like it should. No more hard shifts into first or reverse. Thanks Archie for the tips and pics on your site.
1986 Fiero GT
Total ratings: 54
Report this Post04-16-2010 01:20 AM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 Fiero GT
Total ratings: 54
Report this Post04-16-2010 01:22 AM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 Fiero GT
Member since Mar 2005
I'm intrigued...details?
jimbolaya
Total ratings: 114
Report this Post04-16-2010 11:38 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the fan switch and I am about to change my 85 headlight motors for 88's. A buddy pulled the harness for me from the junkyard about a month ago and I already had the motors from a trade.
Jim
kooljess
Report this Post04-16-2010 12:39 PM Click Here to See the Profile for kooljessSend a Private Message to kooljessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I did this? My LED SIDEMARKERS....
http://members.cardomain.com/koolflip
katatak
Total ratings: 82
Report this Post04-16-2010 06:57 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I did not plan on putting a stereo in this car - it's really just a toy that will see most it's action at the strip but I was surfing around EBay and found this MP3 amp thingie. It had no bids so I bid 1 cent and what do you know, I won it for a penny. Shipping was like 6 bucks. All I ever listen to in my other cars is my IPod so I thought I'd put it in the Coupe. I hooked it up to 5.25 two way's and 1" tweeters up front and 4" round 3 wats in the B pillars. Also installed a Pyle 5.25" 200W sub in the stock sub box as the MP3 amp has a seperate bass output. It's not a earth moving system but it sounds pretty good. I think I have less than 50.00 in the whole thing. It's lo tech stuff and kind of matches the "theme" of the car. I have another plan for a new console and the amp will be "hidden" to give it a more simple look. It's just an experiment.
Pat
exoticse
Total ratings: 106
Report this Post04-16-2010 09:25 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice.
Jess your GT is one of my favorite fieros on the entire forum.
jim94
Report this Post04-17-2010 01:32 AM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
yesterday i replaced the front speakers with panasonic 4"x10". wow sounds much better and today i did the seafoam thing. took the car for a ride around the loop in jacksonville and the car turned 31,000 miles. wow it's still a new car, but it's 23 trs. old oh, the car runs a little rough. rpm is 800 to 1,000, it starts out smooth but after a minute it starts to wander. the car keeps you thinking.
Philero
Report this Post04-17-2010 02:55 AM Click Here to See the Profile for PhileroSend a Private Message to PhileroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut the holes for the vents and taillights on my custom rear end buck.
Phil
Always trying to create something new!
'88 SE
'86 GT
'87 GT Extreme body mod and 2.8L Turbo Propane powered (in the garage and getting closer to being completed)
T-top87gt
Report this Post04-17-2010 04:29 AM Click Here to See the Profile for T-top87gtClick Here to visit T-top87gt's HomePageSend a Private Message to T-top87gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
removed the cradle .. took me 5 hours on the front rusty P0$ bolts... but its out and almost ready for a new crank.
