  What Did You Do To Your Fiero...TODAY ? (Page 76)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219388 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
katatak
Total ratings: 82
Report this Post06-15-2010 11:26 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
First off, I put the spare tire and jack back in the Formula after some AC work last week. Then I jacked up the back to take some measurements for an exhaust system I am building for the 3800SC project I am working on. Once I got the measurements I needed, I mocked up the trunk wall using a 2X6 and then used some of the exhaust pieces I had left over from the XTC project. It's just a mock up to give us a visual of what is possible.
Then I had to do some repairs to the driver's door panel for the XTC. The other day, after we installed rebuilt door hinges, we shut the door, locked it and then it would not open. We had to remove the inner door panel with the door closed - it was not good for the door panel. We did manage to get the door open but I had to straighten out the door panel and fix some of the clip holders. I think that's enough for one day!
Pat
HA - Page 76 is mine!
[This message has been edited by katatak (edited 06-15-2010).]
pontiackid86
Total ratings: 344
Report this Post06-16-2010 04:00 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took the green fiero out for the 1st time in close to a month.. man i miss how fast that thing is.
Blacktree
Total ratings: 350
Report this Post06-16-2010 07:50 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today, I tore apart the transmission, so I could replace the input shaft seal. Oh, what fun!
Maybe now, my clutch won't be getting soaked with oil.
katatak
Total ratings: 82
Report this Post06-16-2010 10:19 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
What sealer did you use to put the case halves back together? I used the GM recomended gasket maker on a 4spd:
I used extra care in cleaning the surfaces and made sure everything was right but I still had a "seapage" issue. Maybe it was a warped case half? I remember hearing something about something called "super grey"? Just looking for an alternative as I have to reseal the getrag in my Formula.
Pat
Blacktree
Total ratings: 350
Report this Post06-16-2010 10:28 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used grey RTV silicone on the case halves, but the black stuff will work too. I ran a 1/8" bead all around, and completely around each bolt and dowel hole. You have to use something "goopy" to seal the tranny case, because the thin stuff may not build up thick enough to do the job.
[This message has been edited by Blacktree (edited 06-16-2010).]
yellowstone
Total ratings: 250
Report this Post06-16-2010 11:11 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed 13" Viper brakes with C4 Corvette calipers.
[This message has been edited by yellowstone (edited 06-16-2010).]
Blacktree
Total ratings: 350
Report this Post06-16-2010 11:57 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
SWEEET!
Does it stop on a dime, and give you change now?
helmet1978
Report this Post06-17-2010 12:23 AM Click Here to See the Profile for helmet1978Click Here to visit helmet1978's HomePageSend a Private Message to helmet1978Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got my new rear swaybar end links on today. The old ones had been on there for around 10 years and one broke when I tightened it.
I also found out that the last time the rear end was put together the end links were not put on and tightened correctly!
Combined with a new rear lower ball joint on the drivers side and a ghetto home alignment (done Memorial Day weekend) I finally have my handling back
http://www.raceme.cc/helmet/
madcurl
Total ratings: 314
Report this Post06-17-2010 01:04 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did some tweaking;
exoticse
Total ratings: 108
Report this Post06-17-2010 02:38 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by madcurl:
Did some tweaking;
sweeet !
Spynx
Report this Post06-17-2010 04:15 AM Click Here to See the Profile for SpynxClick Here to visit Spynx's HomePageSend a Private Message to SpynxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took to amusement park, broke down in, and yelled at my Fiero today. We're on okay terms again, though.
https://www.fiero.nl/forum/Forum1/HTML/081439.html
Torch-Red87
Report this Post06-17-2010 02:58 PM Click Here to See the Profile for Torch-Red87Click Here to visit Torch-Red87's HomePageSend a Private Message to Torch-Red87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ja das sind Bremsen , Great done !!!!!!!
dobey
Total ratings: 371
Report this Post06-17-2010 03:14 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not done yet, but need to fill up the gas tank, put new radiator supports on, and give her a bath and detailing. Probably will do the gas and supports tonight, and bath tomorrow. And hopefully drain all the coolant out the other side of the LS4 tonight, now that I have one of the enormous allen head wrenches to do so with.
Then I can start pulling the heads and oil pan. Anyone know a good place to get engine/component storage bags?
FieroDev
Report this Post06-17-2010 11:39 PM Click Here to See the Profile for FieroDevSend a Private Message to FieroDevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I was off school early so i decided to get to work! I finished most of the sanding on my Decklid scoop and decided to throw a little primer on it just to see it all one colour! what do ya think?
edit: Hoping to enter in a local show 'n shine this weekend with my dad for fathers day
[This message has been edited by FieroDev (edited 06-17-2010).]
Driven5
Report this Post06-18-2010 12:02 PM Click Here to See the Profile for Driven5Send a Private Message to Driven5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the engine out of my Fiero...
-Justin
The Loco-Fiero Build Log: Presented by NoCones Garage
katatak
Total ratings: 82
Report this Post06-18-2010 12:58 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did some tweaking;
Madcurl is a big Tweaker!
Those look great - fit the car's lines well.
Fieroseverywhere
Total ratings: 89
Report this Post06-18-2010 01:07 PM Click Here to See the Profile for FieroseverywhereSend a Private Message to FieroseverywhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
He he. I was going to say... That stuff will kill you! Its highly addictive and can cause a lack of sleep and health problems.
Talking about fiero body work of course!
dobey
Total ratings: 371
Report this Post06-18-2010 08:00 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gave her a bath. And will be cleaning up the interior and wheels/tires tomorrow morning, before I head to VA Beach for the VA FIeros meeting.
Fierfly
Report this Post06-18-2010 08:58 PM Click Here to See the Profile for FierflySend a Private Message to FierflyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put my first scratch on it....
Not its first scratch, but the first one I inflicted on it.
Ok, here is my story....
We were about to start the engine swap (now that a fire has been lit under our asses in the form of the Poker Run to benefit Rob) so we needed to tow the car up the yard to the basement (read: garage is too full).
Why not drive it? Wasn't it running yesterday? Well, yes until we tried to drive it in to get it inspected in case we don't make the 7/31 deadline now that you cannot renew registration in NC without an inspection first. Long story short, it died on the way, AAA towed it home.
So anyway, he was pulling me up the yard and i was gently riding the brakes (I swear) til we got to the dip. Suddenly the brakes weren't doing anything and i started rolling toward a very large tow hitch and bumper. Pressing harder didn't help. Profanity didn't help. I went right..hard right... right into the big rusty 55 gallon burn barrel. My front quarter panel flashed before my eyes, fiberglass ripping, rusty metal digging its fangs into yellow paint, pieces flying off everywhere as the barrel overturned making horrible metal-on-paint screeching noises....
The dust settled....
Greg got out of the truck and looked at the damage.
"At least i didn't hit the truck" i asserted weakly, several times.
I got out to survey the carnage.....
So really all i did was add a few feet to my 10 foot paint job. That'll buff right out.
I swear it was the brake. Really.
A good man is hard to find...but a good Fiero mechanic is "rare".
CowsPatoot
Total ratings: 84
Report this Post06-18-2010 09:13 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ummm.....the brake would have worked better than the clutch, Sharon....
But at least she didn't hit my truck.
Danyel
Total ratings: 171
Report this Post06-18-2010 10:20 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Parts car ready for the crusher ... did the old "stand in the engine bay" pic before calling the recycler !!
http://www.blackwidowfiero.com
FieroDev
Report this Post06-18-2010 11:25 PM Click Here to See the Profile for FieroDevSend a Private Message to FieroDevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ready for the show tomorrow!
yellowstone
Total ratings: 250
Report this Post06-19-2010 10:15 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed LED bulbs in front driving lights and rear license plate lights.
[This message has been edited by yellowstone (edited 06-19-2010).]
yellowstone
Total ratings: 250
Report this Post06-19-2010 10:18 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
yellowstone
Member since Jun 2003
Das Leben ist gut ohne TÜV!
87antuzzi
Total ratings: 228
Report this Post06-19-2010 10:23 PM Click Here to See the Profile for 87antuzziSend a Private Message to 87antuzziEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can your car get any better?
DIY_Stu
Total ratings: 111
Report this Post06-19-2010 10:29 PM Click Here to See the Profile for DIY_StuClick Here to visit DIY_Stu's HomePageSend a Private Message to DIY_StuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished My Carrier. Hitch needs a little revision but it's good for now.
Not bad for $40 in the Hitch and $20 in the Carrier
AND YES It's getting paint. Drying right now. Rustoleum Hammered Silver.
[This message has been edited by DIY_Stu (edited 06-19-2010).]
dobey
Total ratings: 371
Report this Post06-19-2010 10:54 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finished up detailing, and drove her out to the VA Fieros meeting in VA Beach. Nothing like driving around in a cleaned up Fiero.
yellowstone
Total ratings: 250
Report this Post06-19-2010 11:08 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh yes, it can! I spoke to Dave at Haus of Guru yesterday...
FieroDev
Report this Post06-20-2010 01:48 AM Click Here to See the Profile for FieroDevSend a Private Message to FieroDevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Entered in my first car show today!
Met another Fiero owner, found out there are only 7 on the road in regina and that mine and his are the only modded fieros in the city!
And at the end of the show, I won first place!
N3M3S1S
Total ratings: 51
Report this Post06-20-2010 02:10 AM Click Here to See the Profile for N3M3S1SSend a Private Message to N3M3S1SEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed my brakes and did a lot of driving. Also found that my dizzy cap was just.. sitting on there. The screws weren't threaded into the distributor. So we used a larger screw and made sure it was secure. It took care of a hesitation problem the car was having from launch(go figure).
All in all, I'm happy, the car's happy.
nosaint
Report this Post06-20-2010 05:43 PM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
still plugging away with door/stereo..
notwohorns
Report this Post06-20-2010 06:26 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
finished with the sanding of all the body panels. next week end it gets primered. transfered the power mirror parts to different housings. boy is it hot and humid today. it won't be long now and it will be on the road. hope all is done for the feirorama
Curlrup
Report this Post06-20-2010 06:34 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally, finally, finally...drove it and introduced it to the Chesapeake Bay right outside my condo.
Love it..needs some more tweaks but it is getting there.
[This message has been edited by Curlrup (edited 06-20-2010).]
batousai666
Report this Post06-20-2010 06:38 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
drove the crap out of it.
held me own against a late 80's Camaro, in my stock V6 Mera....Represent!!
we got this traffic light on a highway....131 North at U ave...the speed limit after a 2nd light is 70 MPH
so a friendly little race to 70 ensued.....i totally won
dan
[This message has been edited by batousai666 (edited 06-20-2010).]
Boogaloo
Report this Post06-20-2010 08:05 PM Click Here to See the Profile for BoogalooSend a Private Message to BoogalooEdit/Delete MessageReply w/QuoteDirect Link to This Post
What kind of bulb are these, I have the same lights that converted to 1157 park and turn but don't have a clue as to the bulb for the driving lights.
blkcofy
Report this Post06-20-2010 08:46 PM Click Here to See the Profile for blkcofySend a Private Message to blkcofyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got around to painting the LS4 engine cover. Sanded everything down with 800 grit, then painted (can) with grey primer for plastics, several coats (5) of red, then a few coats (4) of gloss. I tapped the lettering using a knife tool.
Put some Pontiac GXP badges on the front side markers.
And for the final touches, I decided after much debate, to put the spoiler back on the car. I bought the Fiero Stealth Wing Stands for TLG and painted them flat black. It took a bit of effort to get the holes aligned...but a few curse words later, it was bolted on and looks fantastic.
Then, since it was Father's Day, took it out for a long cruise and stopped for a few candid photos! Only thing missing is a high heeled, long legged, mini-skirt wearing, car model....
[This message has been edited by blkcofy (edited 06-20-2010).]
yellowstone
Total ratings: 250
Report this Post06-20-2010 08:48 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine are H3 bulb LED replacements but (obviously) are not stock...
bsinnest
Report this Post06-20-2010 08:51 PM Click Here to See the Profile for bsinnestSend a Private Message to bsinnestEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today, I finished putting led marker lights on both front and back. Do not have pictures right now, but will post.
Made them myself with led strips and bridge rectifiers.
Brian
Rallaster
Total ratings: 84
Report this Post06-20-2010 09:08 PM Click Here to See the Profile for RallasterSend a Private Message to RallasterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Considered driving it into a lake with my laptop in the passengers seat, but I opted to shoot my computer and put a new belt on the Fiero.
No, Serously.
Pennock's Official Thread Killer
GT86FASTBACK
Report this Post06-21-2010 03:40 AM Click Here to See the Profile for GT86FASTBACKSend a Private Message to GT86FASTBACKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love the Mopar Six-Pack scoop! Looks great! Did your scoop have the mounting flanges on the inside or outside of the scoop??? I found a few with the flange on the outside, but i am not sure if it will fit between the bodylines on my decklid...
