  What Did You Do To Your Fiero...TODAY ? (Page 78)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219389 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
turbotoad
Report this Post07-06-2010 05:02 PM Click Here to See the Profile for turbotoadSend a Private Message to turbotoadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the 88 2.5 Duke back together with new lifters, pushrods, also a ported/polished/rebuilt head w/new springs & valves. Got it all back together and it fired right up and ran! Unfortunately it's still making the same awful noise that I thought was due to bent pushrods. Guess something in the bottom end is on it's way out....dammit. I really don't want to..... a.) tear the motor down. b.) put anymore money into the damn thing. So I think I might sell it while it's still drivable.
unboundmo
Report this Post07-07-2010 01:58 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
While I'm still waiting for my fuel pump to come back from walbro--- hopefully defective so I can get a new one from them, I installed my 3 core aluminum radiator. It's a champion radiator and it fits very snug. As mentioned in some other post, the only thing I had to was trim the rubber cushin holders to accomodate the thinker core and trim the filler neck area of the shroud bracket. Very smooth and it looks great! Just need a fuel pump so I can go around the neighborhood and see how it works out.
Old Lar
Total ratings: 214
Report this Post07-07-2010 03:56 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still trying to get a stud into the wing stantion. It came loose, so the wing was loose. Trying Liquid nails to hold the replacement stud into the hole.
johnyrottin
Total ratings: 85
Report this Post07-07-2010 04:36 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Indy got a new headliner. After 26 years it was sagging a load and had gotten thin in spots. Right back to factory fresh! Next, the visors need done.
katatak
Total ratings: 82
Report this Post07-08-2010 08:06 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
A while back I made a "arm rest" pad to place on the console - I made a fiberglass shell and covered it with head liner material.
I made it because I was tired of throwing a towel on the console to keep my forearm from burning to a cinder during these hot days of summer here in El Paso. The first one I made, I used some leftover black headliner material from my V8 Coupe rehab. The black looked OK in my Formula with tan interior.
The black arm rest migrated to the XTC so I decided last night to build a new one for the Formula - I had about a yard of brown/tan headliner material and plenty of fiberglass supplies so I went to work. I made 2 becuase I had the material and supplies and this afternoon, I covered them.
The only thing I do not like is that the headliner material had some creases in it and even though I tried to pull the material tight to pull the creases out, they are still visible. I'm going to try a hair dryer on them to see if I can get the creases out. Here's one installed in the Formula.
Before:
After:
If I can get the creases out of the second one, I will give it to my buddy Rick for his Mera. I have to make 4 in grey or charcoal for the rest of the El Paso Fiero's! I have about 1.5 hours in each and about 10 bucks in material for each. They make a big difference when you climb in a car that has been sitting in 100* heat all day. Plus they are nice on a long drive - keeps you from sticking to the console.
Pat
[This message has been edited by katatak (edited 07-08-2010).]
topher_time
Total ratings: 64
Report this Post07-08-2010 09:13 PM Click Here to See the Profile for topher_timeSend a Private Message to topher_timeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found the source of my unusual noise and handling, both the upper control arm mounts have broken on the 84 Did some work to the RX-7 instead. might be parting the Fiero out, might not...
unboundmo
Report this Post07-09-2010 04:38 AM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
After reading a while back on how the air traps in the nose at high speeds and , though I've haven't been there, the fact the head light door slamming upward... I decided to make up a way for the air to escape. Found some louvers at home depot that were long but I cut them to fit. Dremelled some rectangles out just below the headlights in the cars steel followed by priming and painting the louvers before I put them in. Turned out good .....and I was also thinking that after my aluminum radiator install this too could be a way of cooling... meaning that hot air getting out. The louvers are 5 inches x 3.5 inches.
[This message has been edited by unboundmo (edited 07-09-2010).]
CowsPatoot
Total ratings: 84
Report this Post07-10-2010 03:18 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swapped a rear wheel hub/bearing on the convertible. Is it bad when they come out in 4 pieces?
20 minutes from the time I pulled the jack out to the time I put it away....air tools are a gift from the Gods.
unboundmo
Report this Post07-10-2010 03:39 AM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been on a roll so I'd thought I'd continue.
Tanks out if you didn't know. Fixed my sender unit so no more 1/4 tank empty reading. I'm reading 3.1 ohms empty and 97.1 full.
I also been chopping up a second front bumper. I'm doing a chin spoiler with the flipped upside down look. It's now all cut, filed and lightly sanded. Great start for now. I always hated how the front bumper goes in the upward direction from the front wheels . This will add a new style and around 3 inches. It tappers around to the sides to 1 3/4 inches... Best thing about it. I got the spare bumper at the local pick a part for 32 bucks.
Closer to looking like my sig now!
DanFiero
Total ratings: 96
Report this Post07-10-2010 11:14 PM Click Here to See the Profile for DanFieroSend a Private Message to DanFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put rear Grand Am brakes on today, this finishes off the complete grand am swap. Still need to adjust one of the brake lines as I feel it's to close to the tire (about a fingers width away). Also tried readjusting the starter as it sounds like it's slipping or catching...something it made some weird noises.
All in all a good day wrenching.
Dan
NCTyphoonKid
Report this Post07-10-2010 11:29 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a 3.4 out of a 93 Firebird for my gold SE since the stock 2.8 finally decided to die
johnyrottin
Total ratings: 85
Report this Post07-11-2010 01:05 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced a crap headlight switch. Nothing too cosmic but I did manage to find an original ac delco switch for 30 bucks.
donnie072003
Report this Post07-11-2010 01:28 AM Click Here to See the Profile for donnie072003Click Here to visit donnie072003's HomePageSend a Private Message to donnie072003Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sprayed hood and spoiler today. Still have to do headlight doors.
Getting closer every day!
https://www.fiero.nl/forum/Forum1/HTML/080998.html
Donnie
Irvin Green
Report this Post07-11-2010 08:11 PM Click Here to See the Profile for Irvin GreenSend a Private Message to Irvin GreenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put in a new steering wheel
psychosurfer
Report this Post07-11-2010 08:27 PM Click Here to See the Profile for psychosurferSend a Private Message to psychosurferEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulled the sail panels, sanded, prepped, primed and painted sail panels, exposed unibody, drilled engine vent grill rivets, painted both parts of grills, same treatment to the inner plastic surrounding the rear window, and am currently waiting patiently for everything to be dry to put it all back together.
fierofrenzy
Report this Post07-11-2010 09:32 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed a vented hood that I've been working on all week. Tested drove the car at very high speed and it worked excellent. I strongly recommend this alteration. Only thing, while testing it out at twice the legal limit, one of my side "turbo" quarter window scoops blew off !!! NOT PART OF THE PLAN ! I have yet to find it. Thats the Pontiac Fiero for ya....always keeping you busy...but I love the car...definately.
FieroMaster88
Total ratings: 168
Report this Post07-11-2010 11:39 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I guess it wasn't really today but within the last 2 weeks I reupholstered and fixed the lumbar seats in the 88. Thursday night I replaced the clutch in my 87GT.
madcurl
Total ratings: 314
Report this Post07-12-2010 12:36 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Friends don't let their friends drive stock."
DIY_Stu
Total ratings: 111
Report this Post07-12-2010 01:34 AM Click Here to See the Profile for DIY_StuClick Here to visit DIY_Stu's HomePageSend a Private Message to DIY_StuEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced my exhaust gaskets and this time used some copper sealer too. Hope they'll last longer this time.
Also ran the wiring needed for my new headlights so I don't burn up my wiring harness or switch on my Minnesota run. I'll be the white glow you see coming in.
unboundmo
Report this Post07-12-2010 01:17 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Madcurl.. That looks nice
unboundmo
Report this Post07-12-2010 01:40 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
unboundmo
Member since Sep 2006
Yesterday I mounted the chin spoiler on for fit. I like it. Couple more tweeks and I'll sand it all down, fix old license plate holes and scrapes before the paint... I was thinking to go with the stock maroon color for this. Some of my friends have gone with black for a colored car... What do you guys think?
doublec4
Total ratings: 150
Report this Post07-12-2010 03:14 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
On your car, match it to the rest of the paint otherwise it will look out of place. Pictures please
As for me... today I drove mine in the rain!
Check out my build!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
unboundmo
Report this Post07-12-2010 07:34 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay.. here's a couple pictures of the things that I've been doing
with Photoshopped color - I'm hoping that as it relaxes with the upside down bends that it fit the lines better.. plus when it is actually painted that it'll help too with shadows and stuff
the radiator
and the louver idea
[This message has been edited by unboundmo (edited 07-12-2010).]
unboundmo
Report this Post07-12-2010 07:36 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
unboundmo
I can't wait to see it planted on the ground again..... I hope I can get out of the driveway
Fiero88GT
Report this Post07-12-2010 07:39 PM Click Here to See the Profile for Fiero88GTSend a Private Message to Fiero88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow great looking car! i really like those rims and the brakes.
unboundmo
Report this Post07-12-2010 07:42 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
I'd thought I'd give you a picture of it outside though.. garage is messy
Fiero88GT
Report this Post07-12-2010 07:46 PM Click Here to See the Profile for Fiero88GTSend a Private Message to Fiero88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
looks good on the ground. what size rims are those?
unboundmo
Report this Post07-12-2010 07:52 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
18x7 in the front - 215/40/18
18x8 rear - 225/45/18
Blacktree
Total ratings: 350
Report this Post07-13-2010 09:27 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today, I installed my new fiberglass console. I removed the passenger seat, to make it easier to get in there. Here are a few photos.
As you can see, the dash isn't done yet. I'll be working on that next.
Fierosmith
Report this Post07-13-2010 10:14 PM Click Here to See the Profile for FierosmithSend a Private Message to FierosmithEdit/Delete MessageReply w/QuoteDirect Link to This Post
^^^ Wow! That is HOT! Nice touch of old and new school!
Man That looks soooo good, I've never really been a fan of wood interior/dash before, but that could change my mind..
Great JOB.. can't wait to see more..
Jim
[This message has been edited by Fierosmith (edited 07-13-2010).]
donnie072003
Report this Post07-13-2010 10:50 PM Click Here to See the Profile for donnie072003Click Here to visit donnie072003's HomePageSend a Private Message to donnie072003Edit/Delete MessageReply w/QuoteDirect Link to This Post
I started wiring up the fog lights today. Too stinking hot though today. Got the wires ran through into headlight bay and got it grounded before I quit for the night. I think I am just going to wire them into my parking light circuit instead of having an out of place switch in the car that does not match the rest.
Donnie
Blacktree
Total ratings: 350
Report this Post07-13-2010 11:19 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by donnie072003: I think I am just going to wire them into my parking light circuit instead of having an out of place switch in the car that does not match the rest.
That's what I did. The parking light circuit activates the relay for the driving lights. My reasoning was that I only turn on the parking lights when visibility is reduced. So I might as well have the driving lights on, too.
yellowstone
Total ratings: 250
Report this Post07-19-2010 02:09 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been thinking of my Fiero, thousands of miles away, slowly rusting in the salty breeze...
[This message has been edited by yellowstone (edited 07-19-2010).]
yellowstone
Total ratings: 250
Report this Post07-19-2010 02:12 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
yellowstone
Member since Jun 2003
double post
Finally_Mine_86_GT
Total ratings: 99
Report this Post07-19-2010 08:55 AM Click Here to See the Profile for Finally_Mine_86_GTSend a Private Message to Finally_Mine_86_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Painted it... from...
to....
Still a lot of work to do on it but the idea is there now.
tgmchuck
Report this Post07-19-2010 12:44 PM Click Here to See the Profile for tgmchuckSend a Private Message to tgmchuckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Working on sanding down the body to paint. Getting ready to start on a 3.4 swap. Going to be a busy couple of weeks.
First car love - Fiero 86 SE 2.8 - RIP
Next Car love - The Chuck'n Fiero - soon to be work in progress
Larryh86GT
Report this Post07-19-2010 12:56 PM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got her inspected. Needed a tail light bulb.
"Life is short.
Drink the good wine first"
Fiero88GT
Report this Post07-19-2010 02:50 PM Click Here to See the Profile for Fiero88GTSend a Private Message to Fiero88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
ordered some stuff from the fiero store
http://www.fierostore.com/P...px?s=54406&d=391&p=1
http://www.fierostore.com/P...px?s=54408&d=391&p=1
http://www.fierostore.com/P...aspx?s=50356&d=7&p=2
tomorrow ill be putting new pads on all around and probably pulling the front bumper off and then hopefully my new stuff comes Wednesday and i can put all that on.
NCTyphoonKid
Report this Post07-19-2010 04:02 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I pulled the motor out of my gold car
tbone42
Total ratings: 128
Report this Post07-19-2010 04:19 PM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
I added a 2 gallon red plastic gas can to the ever growing pile of tools and stuff in my trunk, and not by choice... Once you have one in every car you drive, there is no need to buy another when you run out of gas.
