  What Did You Do To Your Fiero...TODAY ? (Page 88)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6920 (219125 views)
Last post by: Doggo on 03-30-2025 09:15 PM
NCTyphoonKid
Report this Post11-03-2010 05:43 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
decided to keep my GT
Blacktree
Total ratings: 350
Report this Post11-03-2010 07:39 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today, I installed a pair of LEDs to use as trunk / engine bay lights. I used a couple light fixtures, pulled from a dome light assembly in a salvage yard, with a pair of bright white LED bulbs that I got from TLG Auto. The LEDs are mounted next to the license plate lights, facing inward, so they shine down on the engine bay and trunk when the rear lid is opened (my Fiero has a clamshell rear end).
The LEDs are wired into the trunk light switch. So they come on when the trunk is opened.
Unfortunately, my camera doesn't do very well in low light. So bear with me. First, here are a couple daytime shots, for reference.
Now, here's a night-time shot, with the trunk lights on.
The LEDs are actually nice and bright. But the camera makes them look really dim.
Total ratings: 403
Report this Post11-06-2010 02:03 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the alternator. Driving it out of town tomorrow about an hour trip and my old alt was putting out 10 V so I think the voltage regulator is bad.
The old one is a single wire so I will probably get it fixed and hang on to it.
DkGryGhost
Report this Post11-06-2010 07:46 PM Click Here to See the Profile for DkGryGhostSend a Private Message to DkGryGhostEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced the fron ttwo calipers. The driver's side was locked up, and the passenger's side wasn't clamping enough. The rears are next.
tbone42
Total ratings: 128
Report this Post11-06-2010 10:41 PM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drove it to Chipotle. Its just about time to put her up for the year.
Total ratings: 461
Report this Post11-13-2010 11:27 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jump started it after leaving one of the map lights on, three days ago when I parked it, and trying to turn the battery into a doorstop.
88 4.9 Formula IMSA Fastback
Read Nealz Nuze! Praise the Lowered!
johnyrottin
Total ratings: 85
Report this Post11-14-2010 12:25 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced both transmission lines at the Fiero Factory...well, had them do it because I was up there having a leak fixed.
dobey
Total ratings: 371
Report this Post11-14-2010 02:33 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wished I was driving it. Failing to find compressed fuel injector cleaner (with a tube that screws onto the valve on the fuel rail), and hoping that if I get in-tank cleaner, i can get it primed up into the rails, and get the injectors cleaned, and that the issue with #3 cylinder being so lean is that there is some dirt causing partial blockage on that injector, and it's not something worse.
Rafe Zetter
Report this Post11-14-2010 02:49 PM Click Here to See the Profile for Rafe ZetterClick Here to visit Rafe Zetter's HomePageSend a Private Message to Rafe ZetterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rebuilt and fitted my newly ported heads, ported and fitted lower intake manifold.
Took the other Fiero out for a spin.
Danyel
Total ratings: 171
Report this Post11-14-2010 05:20 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sent to the friends garage for engine removal
http://www.blackwidowfiero.com
rchofey
Report this Post11-15-2010 09:17 AM Click Here to See the Profile for rchofeySend a Private Message to rchofeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since the weather this weekend was great in the northeast, I took my GT for a maybe last ride before she gets hibernated for the winter.This is the reason why we do what we do. DRIVE, DRIVE, ENJOY !!!
thedrue
Report this Post11-15-2010 11:52 AM Click Here to See the Profile for thedrueSend a Private Message to thedrueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Performed the temp gage fix! Good stuff, car is running great!
Fiero88GT
Report this Post11-15-2010 03:29 PM Click Here to See the Profile for Fiero88GTSend a Private Message to Fiero88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
put the cover on it. its to cold to drive it in the mourning now so but im still gonna drive it on the weekends until it really starts to get cold.
aim- Fiero88GT12
Daredevil05
Report this Post11-15-2010 05:01 PM Click Here to See the Profile for Daredevil05Send a Private Message to Daredevil05Edit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't do anything at all because I spent the day looking for my work gloves. If I don't wear them I end up at the ER everytime.
I was in the process of removing the panel below the battery tray from my spare Fiero only to find out that I can punch my hand through it. I hate rust.
I sent an email to TFS about making patch panels for our cars. I hate forming them by hand very time consuming because the wheel well hugs that panel so it has to be perfect.
The Riv
[This message has been edited by Daredevil05 (edited 11-15-2010).]
katatak
Total ratings: 82
Report this Post11-15-2010 06:31 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went out to the Formula to go to the mail box and click - nothing! The positive battery cable / post was big time corroded! Funny part was that it looked clean on the outside but the minute I started turning it, the dry acd/corrosion made a mushroom cloud! Cleaned it up and vroom vroom.......
Pat
Cheever3000
Total ratings: 178
Report this Post11-15-2010 09:32 PM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped insurance coverage on it today. Breakdowns have been one after another, and we finally decided to stop the cycle. It's in the PFA auction (84SE) but that ends in a few days, and then I'll just post it in the Mall.
thumper_64735
Report this Post11-16-2010 09:49 PM Click Here to See the Profile for thumper_64735Send a Private Message to thumper_64735Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, these are from last saturday. My son and I went up to the Fiero Farm to look for some parts, look at Indy #4, and socialize. Well, I made a deal for the Indy, bought an 85 for the wife's car (the Anti-Indy project) and looked at some other things. Well, anyway, here are some pics of the Indy, the 85, and my son helping me find a sunroof for my 87. Enjoy
The wife's 85
my son....I am starting him out early
and the Indy
Trinten
Report this Post11-17-2010 12:03 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Passed inspection! Buying my plate sticker tomorrow! .. and priced out a new (reman) HR6 A/C compressor... :/
falcon_ca
Report this Post11-17-2010 09:16 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started the installation of Jesse's Bolt on Lambo Door Hinges
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 |
4.9 ongoing project | Parts for sale
solotwo
Total ratings: 62
Report this Post11-17-2010 10:08 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by wmorse:
Swapped the wheels from my 84 onto my new 87. Looks pretty good if i don't say so myself.
Wow looks nice!!
Steve W.
NE Grand Rapids, MI
88 Coupe
tbone42
Total ratings: 128
Report this Post11-17-2010 10:40 PM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wired in a new plug for my fuel injector. That was not the problem solver I was hoping for. Shoot.
tgmchuck
Report this Post11-19-2010 08:57 PM Click Here to See the Profile for tgmchuckSend a Private Message to tgmchuckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my new Wheels and tires delivered, mounted and ready to be mounted. When I finish putting it back together.
The new wheels, Drifz 202 Jade black with machined accents with Michelin pilot sport A/S plus tires.
And the whole set in the back of my POS truck I'm using until I get the fiero fixed.
First car love - Fiero 86 SE 2.8 - RIP
Next Car love -MiniViper - work in progress
CowsPatoot
Total ratings: 84
Report this Post11-20-2010 12:21 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kento stopped by and helped me strip her. Clearing out a parts car to make room for another project.
Before:
After:
86GTFastback
Report this Post11-20-2010 10:42 AM Click Here to See the Profile for 86GTFastbackSend a Private Message to 86GTFastbackEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got my spoiler back on! I painted my car two or three months ago, messed up the spoiler and because I was so excited to get my car back I didn't get around to fixing it until last week.
thumper_64735
Report this Post11-21-2010 04:21 PM Click Here to See the Profile for thumper_64735Send a Private Message to thumper_64735Edit/Delete MessageReply w/QuoteDirect Link to This Post
Over the weekend, my wife and a friend of ours helped me drop the cradle out of my 87 and my 85 and swap them. The tranny and ball joints on the 85 cradle was having some issues, and the 87 is down for an engine swap, so I figured I would swap the cradles and rebuild the 85 cradle with a getrag and rodney's suspension parts, and put the low mile 87 cradle in my DD. Pics to follow
pontiackid86
Total ratings: 344
Report this Post11-21-2010 05:06 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
put stocker GT wheels on the IMSA to go to the shop tomorrow..... it looks ugly
elitopr
Report this Post11-24-2010 10:11 PM Click Here to See the Profile for elitoprClick Here to visit elitopr's HomePageSend a Private Message to elitoprEdit/Delete MessageReply w/QuoteDirect Link to This Post
my 88 formula with 20 inch rims black!!!!!
katatak
Total ratings: 82
Report this Post11-25-2010 03:52 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the new SBC mounted to the cradle!
Happy T Day!
FirstDrCar
Report this Post11-25-2010 04:29 PM Click Here to See the Profile for FirstDrCarSend a Private Message to FirstDrCarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my new radio from replacementradios.com
Happy Thanksgiving
Alibi
Report this Post11-25-2010 04:39 PM Click Here to See the Profile for AlibiSend a Private Message to AlibiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed a new pick up coil and GM ignition module into my dizzy, re-crimped some loose wires, re-timed the motor and drove it over to my brother's fiance's mother's place for turkey day. The car seems to be running rather happily now
Ended up over at my dads to make cookies and help him make apple crisp and stuffing while my other brother was making mashed sweet potatoes.
Om nom nom
White Spyder
Report this Post11-26-2010 08:43 AM Click Here to See the Profile for White SpyderSend a Private Message to White SpyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is parked in the garage which is under the bonus room where my nephews were sleeping while visiting. That Cherry Bomb Extreme makes a great alarm clock!
RCR
Total ratings: 102
Report this Post11-26-2010 09:10 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Disassembled the 88 front suspension (yesterday). Broke 2 bolts, had to cut the sway bar end links off, two bolts holding the shocks (one on each side), both upper shock nuts, and two bolts holding the upper arms (one on each side).
Still have 3 of 4 lower arm bolts to remove and at least one isn't cooperating, and the rotors appear to be welded to the hubs.
- It was fun turning a wrench again.
Bob
[This message has been edited by RCR (edited 11-26-2010).]
americasfuture2k
Total ratings: 105
Report this Post11-29-2010 01:05 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
clutchnet clutch came in... almost a month after ordering. geeze.
boxes from ZZP, TFS and Rodney Dickman have been flowing in this past month. now i need to start mock fitting everything before getting stuff powder coated.
rchofey
Report this Post11-29-2010 01:27 PM Click Here to See the Profile for rchofeySend a Private Message to rchofeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally put the cover on it until after christmas when I will be putting all the presents on her. Will have more time in the dead of winter.
americasfuture2k
Total ratings: 105
Report this Post11-29-2010 01:30 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
Happy T Day!
do you have any dimensions or specs on that cradle dolly?
RaptorSP
Report this Post11-29-2010 08:32 PM Click Here to See the Profile for RaptorSPSend a Private Message to RaptorSPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today was day two of A looooong project. Started with the rear of the car, removed taillights and began disconnection of the engine so maybe by Christmas I will have at least a halfway decent 87gt. Planning on panel off resto. Man, its amazing that I bought a fiero to use as a rebody, but it had enough heart to keep me from ripping her apart they are too nice of a car as they are
[This message has been edited by RaptorSP (edited 11-29-2010).]
Danyel
Total ratings: 171
Report this Post11-29-2010 09:28 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
americasfuture2k ---- here you are one craddle stand schematics just unzip, print buy the parts and do some assembly ...
http://www.blackwidowfiero....ges/cradle_dolly.zip
Blacktree
Total ratings: 350
Report this Post11-29-2010 09:28 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
My engine went from this:
...to this:
I actually did the swap yesterday. But by the time I finished, it was too dark to take photos.
thedrue
Report this Post11-29-2010 09:55 PM Click Here to See the Profile for thedrueSend a Private Message to thedrueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rebuilt my 5 speed shifter, Cant try it out though too much snow!
Tinker
Report this Post11-29-2010 10:45 PM Click Here to See the Profile for TinkerClick Here to visit Tinker's HomePageSend a Private Message to TinkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I wrapped mine up and put it away for the winter. See ya next season Fiero. Kevin
High speed, low drag
1987 Fiero GT auto
2005 Crown Victoria Police Interceptor
