  What Did You Do To Your Fiero...TODAY ? (Page 93)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6948 (220247 views)
Last post by: richard in nc on 07-01-2025 02:07 PM
proff
Total ratings: 87
Report this Post02-23-2011 05:24 PM Click Here to See the Profile for proffClick Here to visit proff's HomePageSend a Private Message to proffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing
Jonesy
Total ratings: 104
Report this Post02-23-2011 11:13 PM Click Here to See the Profile for JonesySend a Private Message to JonesyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I fixed my battery cable and made the car work again.. YAY!
Old Lar
Total ratings: 214
Report this Post02-24-2011 02:56 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally reinstalled the "B" driver's side interior plastic on the IMSA. I had to borrow a tap and die tool to tap the anchor hole for the upper seat belt bracket. It was cross threaded and a "hard" angle to insert the bolt. Then trying to reinstall the seat, the mounting base got offset and was a PITA to get realigned to stick on the studs. Also had to replace the seatback release cover as I broke the one on the seat. Fortunately I have extras. I just had to spray it black to match the interior. I took it out to get some gas before 93 octane really gets unaffordable. The IMSA runs like a scaled cat.
[This message has been edited by Old Lar (edited 02-24-2011).]
madcurl
Total ratings: 314
Report this Post02-24-2011 05:56 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
The front. 13" Baer rotors. Brake set-up from D1S.
Baer 14" rear rotors.
Wam3
Report this Post02-24-2011 06:34 PM Click Here to See the Profile for Wam3Send a Private Message to Wam3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got 1/2 way through my trunk release project .... too cold outside.
katatak
Total ratings: 82
Report this Post02-24-2011 06:37 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Readjusted the starter on my V8 Coupe and hurt my back in the process!
Navras
Report this Post02-24-2011 07:34 PM Click Here to See the Profile for NavrasSend a Private Message to NavrasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well... I drove it !
dobey
Total ratings: 371
Report this Post02-24-2011 07:39 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started looking around on eBay/etc… for what parts I will need to start my 85 GT project, as I plan to start on it as soon as my LS4 is running in the 87 GT.
JumpStart
Report this Post02-24-2011 07:45 PM Click Here to See the Profile for JumpStartSend a Private Message to JumpStartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went out, looked at it, shook my head and went back inside.
GMplastic
Report this Post02-25-2011 03:27 PM Click Here to See the Profile for GMplasticSend a Private Message to GMplasticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went out, looked at the 86 gt project I bought a couple of weeks ago...complete with added feature of #3 piston rod sticking through the back of the pan. Looked in the garage at the 3400 sitting on the floor that's supposed to go in there. Went back outside where the windchill is around -10 degrees (thanks you guys up in Canada for sending all that fresh air to us!). Thought about trying to get the tractor started to yank the '86 into the garage. Then debated whether or not I should go back inside and put on my long underwear before going back outside. Decided to go inside and wait a month before going outside again.
GMplastic
Report this Post02-25-2011 03:34 PM Click Here to See the Profile for GMplasticSend a Private Message to GMplasticEdit/Delete MessageReply w/QuoteDirect Link to This Post
GMplastic
Member since May 2005
...I'm waiting for the warm months between July 15th and August 1st.
LILnochie84
Report this Post02-25-2011 06:08 PM Click Here to See the Profile for LILnochie84Send a Private Message to LILnochie84Edit/Delete MessageReply w/QuoteDirect Link to This Post
good to see you got right into it. Now the real question. did you drive it home or tow it home? Every Fiero i have ever owned and i mean every Fiero (about 7) have had to be towed back to my house. thought my formula was going to be different.... nope shifter cable popped.
DROVE HER! yesss she is the best! LOL
Fiero88GT
Report this Post02-25-2011 09:15 PM Click Here to See the Profile for Fiero88GTSend a Private Message to Fiero88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
well over the last 3 days ive been fixing my deck lid release switch. i found that the tab was broken off so first i glued it on with model glue to hold it in place and let it dry over night then last night i used some j-b weld on it and let it dry over night and today i put it back together and now i don't have to use my key to open the deck lid anymore and when i have the money ill be getting rodneys deck lid strut for it so when i open it, it doesn't hit the back window anymore. ive got a lot more im planning to do to it when it gets warmer out too, to get it ready for summer cruising and car shows.
86soon3.4
Report this Post02-25-2011 11:20 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
On my 88 I Installed a new TCC solenoid, 3rd gear switch and side cover gasket. Now to go take it for a ride and test it out.
On the 87 I just sold, I replaced one rear inner tie rod end before they pick it up. (just cuz I'm a nice guy).
Steve
katatak
Total ratings: 82
Report this Post02-25-2011 11:34 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove my V8 Coupe around the neighborhood this afternoon - Unbelievable! I'm going to go through a lot of tires! I'm liking the 16" Baretta Wheels!
craigsfiero2007
Total ratings: 71
Report this Post02-25-2011 11:59 PM Click Here to See the Profile for craigsfiero2007Send a Private Message to craigsfiero2007Edit/Delete MessageReply w/QuoteDirect Link to This Post
I took out some more interior parts for reconditioning and repairing. Finished the wiring harness for my Sony CDX-F7710 Headunit, my favorite headunit.
Gokart
Total ratings: 94
Report this Post02-26-2011 09:03 AM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I laid down the color and clear on my hood with my new Jimmy's cowl inducted low profile hood scoop.
I decided that since I was going through with the work to mold it permanently to the hood that I would fill any definition where the cowl meets the hood and make it look like it's part of the hood. I'm extremely pleased with this scoop. It was well crafted and fits perfectly. It was a pleasure to speak with Jimmy for a bit yesterday and I'm looking forward to seeing more products from him!
RACE
Total ratings: 157
Report this Post02-26-2011 09:57 AM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Old Lar:
I went to a cruise in and saw this: an Extra Terrestrial Vehicle.
That thing is incredibly strange. I want one. Are they availabe for sale anywhere?
[This message has been edited by RACE (edited 02-26-2011).]
Jim_Martin29
Report this Post02-26-2011 10:49 AM Click Here to See the Profile for Jim_Martin29Send a Private Message to Jim_Martin29Edit/Delete MessageReply w/QuoteDirect Link to This Post
I imagine that would depend on how much money you have.
falcon_ca
Report this Post02-26-2011 05:35 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed LED strips on the Lambo doors.
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 |
4.9 ongoing project | Parts for sale
Jim_Martin29
Report this Post02-26-2011 05:50 PM Click Here to See the Profile for Jim_Martin29Send a Private Message to Jim_Martin29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced a leaking exhaust flange gasket.
While I was under the car I did a quick inspection and discovered that the air-conditioning compressor drive belt was loose (again), and was cutting into the lower pipe-to-engine coolant hose (again).
This time I took a few minutes to loosen the alternator and took the A-C belt off. I think it keeps coming loose because the previous owner replaced the A-C compressor bolt with an SAE bolt. If I had taken the time to go get the correct length metric bolt I could have used a lock washer instead of trying to make do with just liquid thread locker.
I will still have to do that, but for now this should hold (yeah, still not enough time for that today). By the way, Does anyone know of hand, what size the lower air-conditioning compressor mounting bolt is?
Jim Martin
White '86 GT
California
craigsfiero2007
Total ratings: 71
Report this Post02-26-2011 08:02 PM Click Here to See the Profile for craigsfiero2007Send a Private Message to craigsfiero2007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took the steel brackets out of the center console and aux gauge mount. They were rusty, so I cleaned them up and gave them a paint job.
What I started with:
After I spent about an hour with some Scotch Brite and elbow grease:
After I painted them:
johnyrottin
Total ratings: 85
Report this Post02-26-2011 08:25 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ohhhhhh I like that! Today I filled up with 3.35 gas...then went home and took my steering whel apart and sanded the center areas to get rid of the crude the PO left when he stuck some scrap brushed aluminum on it. They matched the bezel set he had in it. I have since went back to Dot matrix type so the wheel is back to black.
Jonesy
Total ratings: 104
Report this Post02-27-2011 12:37 AM Click Here to See the Profile for JonesySend a Private Message to JonesyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a turbo kit!
dudewithoutfiero
Report this Post02-27-2011 05:37 PM Click Here to See the Profile for dudewithoutfieroSend a Private Message to dudewithoutfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
i replaced my radiator. it was the original one that the car left the factory with still had the vin on it
greenfiero1986
Report this Post02-28-2011 01:30 AM Click Here to See the Profile for greenfiero1986Send a Private Message to greenfiero1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
I drove mine with the windows down for the first time in months, since it was a nice 60 degree day in Ohio for a change. Damn it felt good.
dsnover
Report this Post02-28-2011 12:06 PM Click Here to See the Profile for dsnoverSend a Private Message to dsnoverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not so much TODAY, but yesterday I started rebuilding the front end, and replacing all the radiator hoses. Existing ball-joints are OK, but the control arm bushings are shot. New bushings, new shocks on the front. Hit a major problem, though, in that the long bolt that holds the upper arm in place is rusted into one of the bushings. Ordered a complete set of bolts from the Fiero Store, so the car will be up on blocks for a bit.
Contemplating whether to cut one coil off each spring or not... Hmm....
Next month I'll have to order poly cradle mounts, and see what the back half of the car really needs. Gotta wait for $, though. Committed to only spending what we budget monthly for car maintenance.....
-Darryl
1987 Fiero GT, back on the road after 5 years
RACE
Total ratings: 157
Report this Post02-28-2011 12:14 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was a big day for me. I took the battery out of the basement and put it back in the car then drove for over an hour. I have missed it so much. It had been months.
donnie072003
Report this Post02-28-2011 08:36 PM Click Here to See the Profile for donnie072003Click Here to visit donnie072003's HomePageSend a Private Message to donnie072003Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bought a set of tires and wheels today from fierochaser. Also a set of 1" lower springs for front and rear. Can't wait to get them all! Will post pics on the car first chance I get but here are a couple of shots he sent me.
Going to look sweet on my white car!!
Getting closer every day!
https://www.fiero.nl/forum/Forum1/HTML/080998.html
Donnie
pontiackid86
Total ratings: 344
Report this Post02-28-2011 09:28 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started it up.. and yup to my dismay my BOV isant working.. still making boost though.I have a vac leak somewhere.
kkavmann69
Report this Post02-28-2011 10:00 PM Click Here to See the Profile for kkavmann69Send a Private Message to kkavmann69Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got the oil pan off today. PITA that it was. I guess it could have been worse if I hadn't followed the advise from this forum.
Tomorrow I will be doing the harmonic balancer. Yeah me
Then I get to put it all back together and start on the valve cover gaskets.
Wam3
Report this Post03-01-2011 12:04 AM Click Here to See the Profile for Wam3Send a Private Message to Wam3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finished the truck release, now to figure out what's not working.... In guessing it's the switch.
Scavenged pick and pull for a self dimming mirror, and homelink.
Blacktree
Total ratings: 350
Report this Post03-01-2011 10:14 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I welded a crack (after cracking a weld, heh) in the exhaust pipe.
[This message has been edited by Blacktree (edited 03-01-2011).]
dobey
Total ratings: 371
Report this Post03-01-2011 01:08 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove mine around for about 1.5 hours straight on Sunday, and saw at least 5 Civics full of kids staring at me when they went by the other direction.
RULOOKIN
Report this Post03-01-2011 01:17 PM Click Here to See the Profile for RULOOKINClick Here to visit RULOOKIN's HomePageSend a Private Message to RULOOKINEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took mine to the touchless car wash ..... went for a cruise.
scott0999
Report this Post03-01-2011 01:30 PM Click Here to See the Profile for scott0999Send a Private Message to scott0999Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just work on mine sat and sunday in the winter. its not worth firing up the heater just to work on it for an hour or two...
when summer comes I will start working on it some during the week again
americasfuture2k
Total ratings: 105
Report this Post03-02-2011 11:56 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
got my trans back from being powder coated and reconditioned.
rchofey
Report this Post03-03-2011 11:24 AM Click Here to See the Profile for rchofeySend a Private Message to rchofeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my Mr. Mike seats and installed them over the weekend. They are very well made and the DVD makes it a breeze to install. Total time was about four hours. That was with removing seats, removing seat rails,cleaning, and painting.
They made my interior conversion from grey to black almost complete.
rchofey
Report this Post03-03-2011 11:42 AM Click Here to See the Profile for rchofeySend a Private Message to rchofeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
rchofey
Member since Aug 2010
Now back to my rear brake and bearing hub replacement. Got hub bearings from Fiero Store in one day. Been waiting for new calipers, brakes, and rotors from Autozone.com for five days now and they are still not shipped yet. They say they are processing the order. Web site said they were in stock and would ship in two business days. I learned my lesson on trying to save a few bucks.
Next time i will get all my parts from the Fiero Store if I need them in a resonable time.
donnie072003
Report this Post03-04-2011 09:36 PM Click Here to See the Profile for donnie072003Click Here to visit donnie072003's HomePageSend a Private Message to donnie072003Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put my new to me wheels on today. I love them. Perfect look on my white car.
Donnie
