Photo Chop Shop is open lets give it a shot! by 85SEnochie
Started on | : 12-19-2007 01:00 PM |
Replies | : 2550 (102994 views) |
Last post by | : engine man on 11-04-2018 06:32 PM |
Sep 23rd, 2011
johnyrottin Member Posts: 5496 From: Northwest Florida Registered: Oct 2007
The second pic I took today....I was trying to get the picture alignment a bit better....  Yummy!
05:15 PM
NEVERDONE Member Posts: 1088 From: ft worth, tx Registered: Sep 2011
Sep 24th, 2011
FieroGT-Lithuania Member Posts: 21 From: Vilnius, Lithaunia Registered: Nov 2006
Sep 26th, 2011
CowsPatoot Member Posts: 2792 From: Skidway Lake, MI Registered: May 2007
Oct 12th, 2011
85SEnochie Member Posts: 2081 From: Tri-cities, WA Registered: Oct 2007
don't look close I could not find a wing at that angle that was high rez what do you think?  Lowered it a little   ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 10-12-2011).]
01:50 PM
BoxerFanatic Member Posts: 20 From: Central Iowa, United States Registered: Nov 2010
I thought I would put some of my highly-amateur photo-chop efforts up, and see what you guys think.   I am trying to homage the Maserati Bora/Merak, DMC12 Delorean, (all by Giugiaro/ItalDesign) and the M-B C111 concept, with a generalized mash-up of traits from all of them. I have yet to try a photo-chopped slight chassis stretch, to fit my preferred drivetrain... a Subaru EG33 flat 6 (or an EZ30/36), with a longitudinal 2WD converted Subaru manual gearbox. Possibly twin-turbocharged and inter-cooled, and arranged much like a Ferrari 288 GTO's longitudinal driveline, which was converted from the transverse 308 GTB.
05:04 PM
Oct 13th, 2011
03:36 AM
| quote | Originally posted by CowsPatoot:
Thanx. I like the wing, I think we will be doing that shortly. Not sure I like it lowered though. That would be about a two inch drop, right? Maybe if we cut it back to about an inch...I think a set of Eibach lowering springs would be perfect on it. If it were as simple as switching springs, no problem...but if I am going that far in, I am going to do Poly bushings...and then I might as well put new joints in it...and then I might as well powdercoat all the suspension parts while I have it torn down...and it would be a shame to have everything else perfect without reconditioning the frame around it. Yeah, its sitting real good the way it is for now.
Cool glad you liked the wing!  Nice work on the roadster buy the way!  lol yah I hear you on that as for the lowering part. It's one thing to lower a new car buy a set of springs and call it done but with these beautiful old cars there is allot more to consider  Terry ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 10-13-2011).]
12:26 PM
| quote | Originally posted by BoxerFanatic:
I have yet to try a photo-chopped slight chassis stretch, to fit my preferred drivetrain... a Subaru EG33 flat 6 (or an EZ30/36), with a longitudinal 2WD converted Subaru manual gearbox. Possibly twin-turbocharged and inter-cooled, and arranged much like a Ferrari 288 GTO's longitudinal driveline, which was converted from the transverse 308 GTB. |
I like your photo shops they are clean! How much of a streach do you want to see I would like to give it ago if you don't mind? OOOO yah can we see what you started with on the photo? I like to see all the details in what you changed. Terry ------------------
12:32 PM
Thanks, I am not sure how much the stretch would be... I would have to measure from the hub-center axle line to the firewall clearance on the car, and the axle-center to crank pulley on a Subaru drivetrain to be swapped in. It would be less than what is necessary for a longitudinal V8 re-fit, as a flat 6 is shorter in both length and height. A shorter turbo flat 4 might not even need a stretch, but I love H6 engines with 60 degree firing order. The rear trunk might have to give up some depth, or be cut out altogether. The "donor" car for my photo-editing, was the V8 Archie-built Stinger, it is a fantastic, CLEAN example. I wouldn't replicate Stinger directly obviously, probably not even the color, but with a similar clean execution, with a lack of extra add-ons to dilute the form. The front and rear fascias, window sill, side mirror, and obviously the fastback shape are the areas I focused on. original:  changed: (without permission, not for profit or redistribution, and for demonstration purposes only.)  [This message has been edited by BoxerFanatic (edited 10-13-2011).]
01:15 PM
Thanks,
original:
Yah the stinger is a nice platform to play with! I could not help myself and worked on it allready probable a 2 or 3 inch in this chop. I liked the black on the roof in the first one you did so tried to put it in this one and thought a GT marker light with trim would look good on the front fascia?  ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 10-13-2011).]
01:39 PM
Looks good. The stretch doesn't distort the lines much at all. It might also favor a slight and very gradual rear fender flare across the whole panel, as well. A Subaru Turbo 4 or an NA flat 6 with some tuning is capable of 300+ horsepower to the rear wheels... one might want to fit some substantial width tires back there. The GT truncated front indicators look nice, and I can see why to smooth the nose. I also considered a unitized front end, with the top half of the fenders, and the top of the nose panel unified with the hood, all opening forward, sort of like a Ferrari Berlinetta Boxer. I would use the belt-line to hide the panel seam. (and I'd probably recess the belt line, rather than having it protrude, and it would also be black. And maybe this color, or something similar.
01:58 PM
Looks good.
How is this?   I know the color does not match but just having some fun with it what do you think?  ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 10-13-2011).]
02:53 PM
Oct 20th, 2011
pavo_roddy Member Posts: 4351 From: State with a city named Gotham Registered: Apr 2004
Hi all  Hopefully the pics work rite away..... Looking for a chop of the munson style front-end with a pisa ZR-2 front end....... The very top of the Munson front-end, those scoops that are molded into the bumper to allow air to the radiator, could you put those in the ZR-2 front bumper, the same spot, PWEASE?????? Munson bumper:  Zr-2 bumper:  ------------------ Me, I sell engines, the cars are for free, I need something to crate the engines in.... Enzo Ferrari....
Aerodynamics are for people who can't build engines.... Enzo Ferrari...
Today they are called garage's, yesterday, they were stable's! Eric Jacobsen.... An advancement, of other voices I came across.
S.F??, hint, it's a car manufacturer....
Do not walk infront of me, I may not follow. Do not walk behind me, I may not lead. Walk beside me and be my friend forever. -unknown- found here: http://crystal-cure.com/love-quote.html
06:41 PM
Oct 21st, 2011
gtxbullet Member Posts: 4180 From: Pewaukee, Wisconsin, USA Registered: Apr 2008
I'M IN LOVE!!!! the yellow one looks like a Fiero and Delorean hooked up. I'd say it could be mistaken for a Fiero prototype. looks like a good one!
12:00 PM
02:44 PM
HI all  Thanx bro!!
04:22 PM
Oct 22nd, 2011
HI all  Knew it would look good, but not that great!! Awesome job!!!
02:09 PM
Oct 23rd, 2011
| quote | Originally posted by gtxbullet:
I'M IN LOVE!!!! the yellow one looks like a Fiero and Delorean hooked up. I'd say it could be mistaken for a Fiero prototype. looks like a good one! |
Yah I think Boxerfanatic did a great job both with his vision and the photo shop  ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 10-23-2011).]
09:52 AM
Oct 26th, 2011
OOOOOOOO Goody! Another lizardo to play with it looks good in yellow I think  what to do? what to do?  Ok I know the pillar angle is not wright but had to chop it anyway   ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 10-26-2011).]
03:36 PM
Oct 27th, 2011
Nov 4th, 2011
01:00 PM
redraif Member Posts: 1460 From: GA Registered: May 2005
lol!  Edit... stupid link in sig... GRRRR ------------------ 1984 Indy Fiero Pace Car[This message has been edited by redraif (edited 11-04-2011).]
01:08 PM
Nov 16th, 2011
Now I'm just messing with differant thoughts. Let me know if you like any of them john?  ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 11-16-2011).]
04:43 PM
Finally_Mine_86_GT Member Posts: 4809 From: Hyde Park, New York Registered: Sep 2006
how about  With this front bumper?  Never a big fan of the huge holes in the front of a car.
08:57 PM
Nov 17th, 2011
01:34 PM
Hockaday Member Posts: 2165 From: Clifton Park, New York, The States. Registered: Sep 2009
| quote | Originally posted by 85SEnochie:
Some ideas for RBS in Limbo
I like this one.
01:41 PM
close enough... thank you!
02:53 PM
Nov 18th, 2011
Nov 19th, 2011
Trying an RX7 rear window for a notchie hatch back ?  and the notch unmodified with same window  and the RX7 that I got the window from.  ------------------  Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html[This message has been edited by 85SEnochie (edited 11-19-2011).]
07:25 PM
hnthomps Member Posts: 5749 From: Columbia, SC Registered: Jul 2003
Can someone show a Mera with Chromadora wheels in British racing green? That is beyond my skill level and I would like to get an idea as to what the car looks like before selecting this color.
Nelson
09:21 PM
Nov 21st, 2011
| quote | Originally posted by hnthomps:
Nelson |
Forget the photoshop...just look at this nice one I saw at Daytona 2010...even had the T-Tops
04:34 AM
OK, OK...for those who didn't get the joke, that picture was photoshopped from Nelson's blue Mera...
05:09 AM
Or was it his lavender one? I lost track. How many Meras DO you own, Nelson?  [This message has been edited by CowsPatoot (edited 11-21-2011).]
05:14 AM
