  The New and Improved Quarter Mile List (Page 18)
The New and Improved Quarter Mile List by Blacktree
Started on: 05-02-2008 01:12 AM
Replies: 758 (41267 views)
Last post by: ls3mach on 04-27-2022 01:54 AM
Formula
Total ratings: 96
Report this Post08-11-2015 05:02 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by darkhorizon:
Solid 9s from the dh car this weekend. No major changes except a little different turbo.
I unfortunately scrambled to get my phone to video tape the pass (because my friend said, hey is that scott running?), but his car took off like a bat out of hell.
[This message has been edited by Formula (edited 08-11-2015).]
dratts
Total ratings: 118
Report this Post08-12-2015 09:19 AM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good one! I'll bet that pass surprised a few people. Thanks for the video!
LFiero67
Report this Post08-12-2015 11:19 AM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any nitrous on that pass, or all turbo?
I believe you changed cams since last listing too? Can we get a updated mod list?
10.132 @ 131.69MPH - 1.42 60'
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 140lb springs, comp pushrods, HV3, stock L32 bottom end and heads.
Best MPH 136.12
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
[This message has been edited by LFiero67 (edited 08-12-2015).]
darkhorizon
Total ratings: 451
Report this Post08-14-2015 08:12 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Small bit of nitrous till it makes 10psi. 50shot.
St5 cam yes. Didnt even remeber my st5 was new because i really didnt like the changes the st5 did for me.
Blacktree
Total ratings: 350
Report this Post08-20-2015 07:30 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, nice! Using the nitrous to offset turbo lag is pretty ingenious.
It's interesting that 2 of the top 3 cars have Buick V6 engines in them.
2nasti
Report this Post08-20-2015 09:30 PM Click Here to See the Profile for 2nastiSend a Private Message to 2nastiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went to the track Tue to try the turbo out. hope the image works...left lane #3598.
HX-35 7 blade 17-18 psi @ 16* timing. NO intercooler yet, E85. N*, LQ4 maf, 80# injectors. plain Kumho tires. Need to sell the supercharger stuff and 60's to help offset dr's and a intercooler. Hope the trans stays together.
[This message has been edited by 2nasti (edited 08-20-2015).]
darkhorizon
Total ratings: 451
Report this Post08-21-2015 01:11 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Id almost suggest against the intercooler at this point... looks like you may have pedaled through it a bit? Time seems a little low when i trapped 119 with my hx35 i was running 1.80 60 with 11.4 times.
2nasti
Report this Post08-21-2015 06:29 PM Click Here to See the Profile for 2nastiSend a Private Message to 2nastiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love E85, but its a hassle to get locally. I want to switch back to pump-hence the intercooler need. I have one source for E85 17 miles west of me, most of it stop lights. The other is 65 miles east of me, but only 10 from the track still I am limited to where I can drive.
I am not sure what you mean by pedaled through it?
I agree, I think the time is a little slow for the mph. I felt even my s/c times were a little slow for the mph. I thought maybe weight is an issue. I am about 100# overweight, and I run with nearly a full tank , gauge is broke so I need to keep it as full as possible. I get some tire spin, so dr's may help but I am concerned about braking the stock trans with too hard of a launch. I did not adjust much in the trans shifting or timing pull during shifts, may be some e/t to be had there. The tune is still Iaggy on initial wot, I will be working on that. I can't think of much more for the e/t vs mph. Add all that up though and it may be close to expected e/t though.
I still need to tune the a/f and timing for mph. Need dr's. Maybe add anti-lag. I have had the turbo on for about a week. I used the 2.8" tune I was playing with as my base for the turbo, and only made a couple of adjustments to it before running it. If you have an idea on the missing couple of 10ths, I am all ears.
Thanks
Al
darkhorizon
Total ratings: 451
Report this Post08-22-2015 01:49 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any spinning will cause the trap to inflate over the times. Sounds to me that it spins when you come into good boost and it slows you down in the 330ft range. I ran 17psi on 93 and a big ebay water to air intercooler for awhile on my hx35 and ran those wame trap speeds with times around 11.4.
2nasti
Report this Post08-23-2015 09:56 AM Click Here to See the Profile for 2nastiSend a Private Message to 2nastiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can confirm some traction loss with the plain Jane Kumho tires I have on there, even with good track prep. Thinking back, I forgot to lower the pressure in them, surely did not help. Log shows a bubble surge in the rpm graph starting about 1.0-1.2 seconds after wot and lasts until about 2.4 second mark. I can feel it get a little loose midway through 1st, which looking at the logs matches pretty good. I guess the cheap tires don't like the boost increase from 8-17 psi . I am hoping to get some DR's soon, that may net me a couple of 10th's.
[This message has been edited by 2nasti (edited 08-23-2015).]
NightMare Cruiser
Report this Post08-29-2015 10:55 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took my car the Raceway park on 8/28/15. Did two passes. 1st: 14.006 100.61mph 2nd 13.432 at 101.21mph. I got the slips but not sure how to post pictures.
3800 S/C 3.4 pulley 3inch down pipe y'ed off to two moroso freeflow mufflers then resonator tips. Got video also.
It's a CAR, now drive it!!
http://s1277.beta.photobuck...50016365924013387734
After all the work, It's time to drive it!!
Blacktree
Total ratings: 350
Report this Post08-30-2015 06:44 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can upload the photos to a free picture hosting site like Flickr or Photobucket, then post the links.
2nasti
Report this Post08-30-2015 09:49 PM Click Here to See the Profile for 2nastiSend a Private Message to 2nastiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went back to the track Friday night. It was packed. I wanted to get one more outing before adding the intercooler.
My nephew got the run on his cell, and my son uploaded to YouTube.
https://youtu.be/M2pFvUm8p_Q
My first two runs the car was down 2 mph but et's were the same as last outing, but I wasn't sure why it was down on mph. Last run I upped the boost 1 lb. (18-19'ish) and built 2-3 psi at the line. It was a good run considering the tires are 205/50R17 Kumhos. The next day I found the bolts holding the turbo on had come loose, I could rock the turbo up and down. I guess I figured out was down on mph, lol.
[This message has been edited by 2nasti (edited 08-31-2015).]
NightMare Cruiser
Report this Post08-30-2015 11:25 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
NightMare Cruiser
Report this Post09-02-2015 10:12 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!!
Blacktree
Total ratings: 350
Report this Post09-06-2015 11:16 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
updated
djlamp14
Report this Post09-13-2015 11:29 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
11.190 at 119.16 is my best time so far this year. Trying to get 11.0
video
https://www.youtube.com/watch?v=pBYwDorZF5c
mods are l36 topswap, ic, e85, genv 2.6 pulley, xp cam, built 4t65e trans
11.8@115mph 1/4 mile 1999 Regal GSX being demodded for swap into a 87 Fiero GT.
11 sec pass>>http://www.youtube.com/watch?v=SQT4X2eBlR8
2nasti
Report this Post09-14-2015 06:07 PM Click Here to See the Profile for 2nastiSend a Private Message to 2nastiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice. Great 60'!
LFiero67
Report this Post09-17-2015 01:27 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats on the new quickest m90 fiero!
video
Best MPH 136.12
11.425 @115.60
1.543 60'
LFiero67
Report this Post09-18-2015 01:29 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
3 passes from last Friday. Messed up my 2-step release on the first run. Second run was new best 10.007 @135.54, backed up with 10.009 @131.08. Was getting heat soaked by last run and got some KR in 3rd gear so dropped off on back half. Guess I should have taken out the passenger seat to get the in the 9s. Likely parting the car out in the next few months, so watch the mall for GM racing 1" chain, aremet input shaft, billet precision converter, and a bolt on 3800 turbo setup. If interested in parts please PM me, if there is interest I may start taking it apart sooner.
Vid of 10.007 : https://www.youtube.com/watch?v=OEuMPUxtWY8
In car of 10.007 : https://www.youtube.com/watch?v=XYClFlS7Twk
In car of 10.009, Car wheelied on launch can kind of tell in video : https://www.youtube.com/watch?v=ZGJw0Tjk5Do
In car of 10.6 pass, can see me reach back and turn off two step after launch, go pro camera flips back from g force when power comes in. Had to tighten mount after this run : https://www.youtube.com/watch?v=gMUSvfVJxik
10.007 @ 135.54MPH
Best 60' 1.42
Best mph 137.66
11.425 @115.60
1.543 60'
[This message has been edited by LFiero67 (edited 09-18-2015).]
2nasti
Report this Post09-19-2015 01:46 PM Click Here to See the Profile for 2nastiSend a Private Message to 2nastiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats on a new best. Pull that seat, and go back on a day with some better air, then claim your 9. Sent a pm regarding trans parts.
[This message has been edited by 2nasti (edited 09-19-2015).]
Justinbart
Total ratings: 119
Report this Post09-20-2015 08:30 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn so close. You gotta try again!
Turbo 3800 E85 F23 twin disk
10.91@133.1
lildevil
Total ratings: 56
Report this Post09-20-2015 09:54 PM Click Here to See the Profile for lildevilClick Here to visit lildevil's HomePageSend a Private Message to lildevilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why are you getting rid of the car?
Formula
Total ratings: 96
Report this Post09-21-2015 03:21 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
if only your headlights were down, you probably could have picked up .008
LFiero67
Report this Post09-21-2015 04:21 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't made up my mind yet. Really struggling with the decision. Going to maybe look for something the whole family can enjoy together. Wife, 2 kids and only two seats doesn't make for good family cruising. Thinking maybe a 4 door Chevy 2 or a turbo Buick/Grand National.
Fiero has been beaten on pretty relentlessly for 13 years by me. Over 300 hp for most of that and near/over 600 for the last 3. It's starting to show its unhappy. Creaks and groans have become clunks and squeaks. I've had a blast with the car, but hopefully if I take it apart, the drivetrain parts I've aquired over the last couple of years can go to someone else who can build something and get their share of excitement. I've had this car almost as long as I've known my wife. Even she was surprised and a little sad when I mentioned the possibility. We have had some great memories together with it. Building, racing, cruising, even camping together with the car. It's almost a part of the family.
10.007 @ 135.54MPH
Best 60' 1.42
Best mph 137.66
11.425 @115.60
1.543 60'
lildevil
Total ratings: 56
Report this Post09-22-2015 10:05 PM Click Here to See the Profile for lildevilClick Here to visit lildevil's HomePageSend a Private Message to lildevilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I FULLY understand. Going through the same here with wife and two kids. Been looking at 80''s F bodies to do an LS swap in. But I just can't get rid of the Fiero. It was my first car over 20 years ago. LOL
Fiero4Seven
Report this Post09-27-2015 12:05 AM Click Here to See the Profile for Fiero4SevenSend a Private Message to Fiero4SevenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interested in your drivetrain - sent you a PM
edmjay
Report this Post10-09-2015 08:34 PM Click Here to See the Profile for edmjaySend a Private Message to edmjayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was hoping to break into the 12's but this is probably going to be it for this year. I did have one run slightly quicker at 13.18 but I can't find the slip :/
Old run:
edmjay: 13.792 @ 101.39mph ('86 GT / NorthStar / 5spd Getrag)
New run:
edmjay: 13.196 @ 106.23mph ('86 GT / Northstar / 5spd Getrag, ITB Intake (Russ544) CHRFAB 280 Cams, Aluminum Flywheel, DOT slicks)
[This message has been edited by edmjay (edited 10-09-2015).]
djlamp14
Report this Post10-11-2015 07:32 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped another tenth and gained some mph with the taller hoosiers.
Right lane. 137 car. 11.044@122.12mph.
3800sc intercooled, E85, 2.6 pulley.
https://youtu.be/FsboH9Ba7ZY
nosrac
Total ratings: 51
Report this Post10-12-2015 03:22 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
very nice,
What is your MAX timing? What size injectors?
djlamp14
Report this Post10-12-2015 10:51 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
23-24* depends on the temp. I run 65lb injectors.
11.044@122mph 1/4 mile 87 Fiero GT
11.8 sec pass>>http://www.youtube.com/watch?v=SQT4X2eBlR8
11.044 pass>>https://youtu.be/FsboH9Ba7ZY
djlamp14
Report this Post10-18-2015 10:23 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does the first post in this thread ever get updated?
LFiero67
Report this Post10-19-2015 05:40 AM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Whenever blacktree gets around to it.
10.007 @ 135.54MPH
Best 60' 1.42
Best mph 137.66
11.425 @115.60
1.543 60'
Fierobsessed
Total ratings: 147
Report this Post12-05-2015 09:39 PM Click Here to See the Profile for FierobsessedSend a Private Message to FierobsessedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car number 364
3.4 DOHC GT3582R turbo, 88 Fiero GT F40 transmission 15.5 PSI
LFiero67
Report this Post12-05-2015 09:57 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anybody heard from blacktree or know him locally? He hasn't posted on pennocks at all since his last post in this thread. Hopefully all is OK!
10.007 @ 135.54MPH
Best 60' 1.42
Best mph 137.66
11.425 @115.60
1.543 60'
LFiero67
Report this Post12-19-2015 04:55 AM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for a possible update?
10.007 @ 135.54MPH
Best 60' 1.42
Best mph 137.66
11.425 @115.60
1.543 60'
dratts
Total ratings: 118
Report this Post12-19-2015 04:18 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Old run:
New run:
Sure is pretty!
DimeMachine
Report this Post12-26-2015 07:41 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blacktree posted today.
[This message has been edited by DimeMachine (edited 12-26-2015).]
djlamp14
Report this Post01-10-2016 07:56 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump
LFiero67
Report this Post01-10-2016 08:11 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
I sent him a PM asking if he was still going to do the list, no response yet. Someone else may end up having to start a new list as black tree did when the last guy stopped.
10.007 @ 135.54MPH
Best 60' 1.42
Best mph 137.66
11.425 @115.60
1.543 60'
