  RCR's body mods... (Page 13)
This topic is 17 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17
RCR's body mods... by RCR
Started on: 06-15-2009 07:28 PM
Replies: 662 (38878 views)
Last post by: RCR on 09-25-2024 07:33 AM
solotwo
Total ratings: 62
Report this Post07-22-2018 09:28 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like what you are doing and how this car has progressed. I do like the front it looks great.
[This message has been edited by solotwo (edited 07-22-2018).]
RCR
Total ratings: 102
Report this Post08-12-2018 08:00 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Steve. Thanx for the support. Been too long for an update, and although it really doesn't look too different, there's been a lot of hard work behind the curtain. And, I have to admit, I've had to drag my butt out there more than once. Seems I'm past the fun part. Now it's work. But, it's always good to see progress.
So, we left off with the rocker panel. Next on the list was door panel. It needed a lot of cleanup: mounts needed to be finalized, the bottom flanges needed repairs, etc. I started with the bottom.
Here are the bottom mounts before the rework
And after
Then I reworked the front edge and the top most panel mount.
Then I tried to make a blockoff plate between the top of the panel and the Fiero door. It didn't work well, but here's a pic.
Turns out the angle was off, so it's not really blocking much. Maybe next time around.
Also, had to find a way to fix this.
Turns out the top portion/edge of the door is more gel coat than fiber glass. When I glue the blockoff panel in, I filled this hole with SMC adhesive. So far, it looks good.
With the door panel in better shape, I moved back to the front clip.
The previous owner had worn off the bottom edges of the fenders. The front portions were missing part of the fender flare and wheel well support. The backs were missing the wheel well support. So, I had to create all new pieces.
This picture show the area ground down and ready for the facelift. The flare had to be added first.
Then the wheel well area.
There were areas between the fender and the light pods that needed to be filled. Cleans it up and adds some strength.
Then, moving back, the wheel well arches needed to be repaired and the fender flanges needed to be repaired. Here, I took a little more care with the pictures to give a better idea on what I did.
Here's the offending area with the red paint ground off,
Then I grind the area back, tapering the edge so that the glass is very thin. I stuck the notes all over as a reminder of all that needed to be done.
Once satisfied with the cleanup, I made a pattern out of heavy stock cardboard. Once the fit was good, I cover it in packing tape.
Then I added the flange template I made a while back to create the flange between the panels. It too is covered in packing tape.
Once the templates are supported (clamps, wedges, tape), 4-5 layers of glass added.
That was enough work last night, so this is what it looked like this morning with the templates removed.
Then, everything is trimmed and rough sanded.
Rinse and repeat (x3).
to be continued...
RCR
Total ratings: 102
Report this Post08-12-2018 08:13 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
RCR
Member since Sep 2002
The post was getting long, so I broke it up...Didn't want to lose it. Anyway...
Front fenders placed back on the car. The wheel wells do look better.
Money shot.
Now, the next bit of fun time. The nose. Time to get to that and clean it up.
Front back off. Working on the lights for the "I lost count"'th time.
I had an epiphany a couple days ago, then while looking at it again today, it became clear. But, that's a story for next time...
Thanx for checking in.
Bob
[This message has been edited by RCR (edited 08-13-2018).]
Sage
Total ratings: 71
Report this Post08-13-2018 10:17 AM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Beautiful work!
Coming along very nicely.....the time you've spent actually making improvements/moving forward...I've managed to think about what I'd like to get done......next time I HAVE time..LOL.
Wish we were closer to each other...I think we might work well together....we seem to use similar methods.....the shot of doing the well opening where you have the squeegee, the scrap of glass, the vice clamp and the prop rod.....priceless!....and something I'd do and have done in the past! Got a good chuckle out me!
Door looks great...whole thing is really starting to come together....though you pegged it...it's become "work"....but when you look back after you're driving it...it will ALL have been fun! Bottom line is...you're DOING IT!
Keep up the great progress.......and the updates!
HAGO!
355Fiero
Report this Post08-13-2018 03:20 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking really good Bob;
Brings back bad old memories of looking at the underside of the front clip and wondering where the heck to start.....
A quick question. How does the door open interference issue look now with the closer front fender gap? I ended up with a slightly larger gap to accommodate the door skin thickness over stock on my 308 replica due to the hinge location versus outer door skin when the door is fully open. I like your fit and finish way better but wonder if you might end up with a bind at full open?
Looks great and keep digging at it. before you know it, you will be way down to only a couple hundred more items to check off the to-do list..... hahaha
Take care
Don
RCR
Total ratings: 102
Report this Post08-13-2018 09:05 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanx Ted. Working with someone on occasion would be great for motivation. Since were all so far apart, reading old posts helps. Re-reading Boz's thread helped stoke the fires a bit. Neal's is a good read, too. And then there's Don's. Reread that many times.
As for the fender, that wasn't the way it was supposed to go, but the edges were pulling away from each other and I needed something quick and non-sticky to hold it together. Sometimes the quick first thought works out the best.
Hi Don, Thanx for coming by. I had the very same thought, but there is no binding or clearance issues so far. (finger's crossed)
Appreciate the comments, guys.
Bob
355Fiero
Report this Post08-19-2018 02:09 AM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob;
Good to hear there is no door interference. Makes me wonder if I could have done some work to make my door gaps better......
I checked my tire sizes again and mine are 265/50/15 and 225/50/15. I think your mods and updates will fit the 18's perfectly.
Keep up the great work and looking forward to updates. Everything in life and work keeping mine from getting that last 10% to completion..... Killing me.
Enjoy and keep the updates coming
Don
RCR
Total ratings: 102
Report this Post08-27-2018 06:52 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
It was a rough weekend, but the progress looks good. Pics are still on my phone, but I'll get them off and do a proper post.
Bob
PS. Thanx Don for the info.
Total ratings: 328
Report this Post08-27-2018 02:44 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Work looks very nice and unique.. Reminds of Ferrari 355 styling.
RCR
Total ratings: 102
Report this Post08-27-2018 07:28 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanx Dennis, and thanx for dropping in.
Bob
motoracer838
Total ratings: 83
Report this Post08-30-2018 11:09 PM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
Joe
RCR
Total ratings: 102
Report this Post09-03-2018 06:45 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Joe, thanx for dropping by. I hope the move goes well so you can back at it.
As for me, not a whole lot going on between work, and vacation. But, I am still making small amounts of progress.
The last post mentioned working on the fascia. That's what I've been doing. I worked out a new mounting method for the fog lamps, and I cleaned up the front of the fascia where it interfaces with the lights.
Here's some pics.
Here i cut out the back support for the fog lamp, and fabricated a small tab that allows me to fasten the light to the side support.
With the new mounts roughed in, I started working on the gaps around the lights.
I had to add thickness to the fascia and close the gaps. I did this by first filling the gaps with chopped mat, then covering the whole thing with a layer of 1 1/2 oz mat. Then I realized my issue...
Having reconfigured the fog lamps to come out the back, I figure to fill the gaps and cover everything, pop the lights out, and trim to fit. great idea until I realized the turn signals still come out the front. Oops. Going to require some delicate trimming to get out.
Got it..
Cleaned up
Once I was happy with that, I made the final mounting. I used #10 body speed nuts and screws to fasten it all togeter.
Today I disassembled the lights and painted the brackets.
Next on the list is the front spoiler, but again, that will be a tale for later.
Bob
RCR
Total ratings: 102
Report this Post09-16-2018 08:11 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the front clip back on to see how it looks. Not too bad.
I'm a bit tired of fiberglass, so I went back to looking at the lights. Still no idea how to mount them. This is what I started with.
Tried a couple things yesterday. Ended up pretty frustrated, so I watched Deadpool 2 instead.
This morning, it hit me within 30 seconds of being in the garage. Off to Home Depot for supplies.. This is what I came up with.
I started with the original pop up frames I made, and cut them up to reuse the front plate with the holes already set. Then I added a cover ring for added support.
Welding kind of sucks, but it will work.
Then I added some studs (10-32 screws), welded to the plate. The studs will allow me to mount the lights. Springs will go over the studs and provide the spring tension to adjust the lights. Locknuts will finish it off.
Second one done. Both held in with spring clamps.
Now, I'll clean up the back of the lights, and glue/glass the mounts in.
Bob
shemdogg
Report this Post09-16-2018 11:50 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats a great idea for mounting the lights and keeping them adjustable, cars looking good!
shem
RCR
Total ratings: 102
Report this Post09-18-2018 07:56 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
shem
Thanx, Shem...
Bob
exoticse
Total ratings: 108
Report this Post10-28-2018 06:59 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely love this build ! Thanks for sharing and keeping others motivated to also do something creative.
solotwo
Total ratings: 62
Report this Post10-28-2018 04:15 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good.
RCR
Total ratings: 102
Report this Post10-29-2018 07:10 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanx for the compliments and the bumps, guys. I'm looking to get back at some fab work soon.
Bob
RCR
Total ratings: 102
Report this Post12-26-2018 07:29 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing Fiero going on. Life caught up to me as usual. Lot's of plans for next year, though (starting to sound like the Detroit Lions )
Merry Christmas to my Fiero family and have a great new year.
Bob
Neils88
Total ratings: 56
Report this Post12-26-2018 01:35 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Merry Christmas, Bob! Glad to see the build is still progressing...even if only in your thoughts... The good thing about not being in a rush with your build is that you don't need to worry when life catches up and has you doing a few other things. I look forward to seeing progress in the new year!
Neil
mr_corean
Report this Post12-29-2018 10:20 PM Click Here to See the Profile for mr_coreanSend a Private Message to mr_coreanEdit/Delete MessageReply w/QuoteDirect Link to This Post
To adjust your headlights you will need the hood to be open, obviously. Will the part of the hood that is over the headlight bucket be low enough to be in the path of the lights and affect the aiming process? I guess even if it is it won't be much to remove the hood for the aiming since that will rarely change. Good idea and implementation for the mounts though. The one thing I can think of that you need to be sure of is that the fiberglass the housings are suspended from needs to be heavy or reinforced. Because there are 2 lights per side with all there weight hanging behind the mount they are working as a lever to bend it back. If they are bending it at all the lights will bounce when you go over bumps and possibly crack the paint on the buckets from the flexing and possibly the fiberglass itself eventually. The easiest way to check that would be to just push down on the rear of the bulb housing lightly and see if it moves at all. If not I'd consider it good enough for government work.
RCR
Total ratings: 102
Report this Post01-01-2019 07:41 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Mr Corean...Thanx for the feedback. My thoughts exactly. I was thinking of building a support for the back of the lights that would connect at the original headlight mounts. I was waiting to get it all together to determine how much support is needed.
Bob
RCR
Total ratings: 102
Report this Post02-26-2019 07:03 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Mid winter update...
Garage is cleaned up and ready. I need to swap a motor on my son's Dart. He trashed the motor by driving it low on oil Modern VVT's really want oil. Now I'm stuck fixing it.
Itching to get back at it (pun not intended). I picked up the steel I needed to fab a front bumper. I hope I never need it, but you never know... Then back to the body work.
This year's plan (and goal) is to finish body mods and make it driveable. We'll see how that works out.
Thanks for checking in. Comments and suggestions always welcome.
Bob
Neils88
Total ratings: 56
Report this Post02-26-2019 10:23 AM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to see you back at it, Bob! Hopefully the Dart repairs go fast so you can get back to the important stuff.
RCR
Total ratings: 102
Report this Post03-17-2019 04:57 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing yet to relay, but I wanted to post up some info for a fellow 308 builder, and one of the items to finalize this build season is the door handles/latches.
My style kit uses hidden latches built into the body line on the door. It uses the Fiero door handles mounted to a plate that gets glued/bonded to the door. There is a hole in the body line to allow one to grab the handle with one's fingers. I thought it was cheesy and I preferred something more like the 308 door pulls, or maybe something off the 355 or newer.
(edit): After thinking about it and seeing the pics again, I don't think the plates are actually mounted to the door skins, but screwed to the door itself. That makes much more sense, but must be a bit#@ to line up with the door skin.
Here are the handles that came with my body panels.
More soon...
Bob
[This message has been edited by RCR (edited 03-18-2019).]
freedom0226
Report this Post03-18-2019 03:57 PM Click Here to See the Profile for freedom0226Send a Private Message to freedom0226Edit/Delete MessageReply w/QuoteDirect Link to This Post
thank you soo much for posting this info ..... pm sent
RCR
Total ratings: 102
Report this Post05-04-2019 03:47 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been slow getting back at it. But, today I got something worth posting done. I made a front bumper. I'll let the pics speak for themselves.
In a nutshell, I used some 2" x 3/16 round stock for the bumper. The ends were hitting the fascia, so I cut some slots about a foot in on each side to fold the bumper ends back a bit.
I welded some 1.5" 1/8' square tubing to the bumper to make the mounts. Then made nut plates to sit within the frame rail to bolt it all together. Grade 8 hardware holds it all together.
Now, I have less worry that in the event something goes wrong, the first major stopping point won't be the firewall. Plus, now I have someplace to mount a tow ring.
Bob
dobie1
Report this Post05-04-2019 04:48 PM Click Here to See the Profile for dobie1Send a Private Message to dobie1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bob are you using the OEM bumper attachment points to secure to? And are you using the original kit fibreglass bumper cover over the steel ?
Always nice to be moving forward. 😎
I’m busy prepping the dash pod mold to produce the the piece I need to complete the dash , sure is time consuming!
Wayne
RCR
Total ratings: 102
Report this Post05-04-2019 06:20 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Wayne
Ain't that the truth, Wayne.
No, the new nose design doesn't use the original bumper cover. It's much lower and pulled back 3', so the bumper is slung underneath the frame rails. Not optimal, but I didn't want to move the rails back, nor block the big air intake opening.
The bumper fits behind the fascia, under the lights, air intake opening, and godzilla's feet.
Bob
[This message has been edited by RCR (edited 05-04-2019).]
dobie1
Report this Post05-04-2019 08:21 PM Click Here to See the Profile for dobie1Send a Private Message to dobie1Edit/Delete MessageReply w/QuoteDirect Link to This Post
So now that I look at the picture I can see what your doing.
So are you going to mold the lower facia so that if you do crunch the front you can repair or replace it?
Wayne
RCR
Total ratings: 102
Report this Post05-05-2019 08:48 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Wayne
At this point, no. It's all one piece. Plan is not to hit anything. <fingers crossed>
At some future date, I can see how I can split it apart to make three pieces, but there's still too much to do to get it mobile first.
Bob
Neils88
Total ratings: 56
Report this Post05-07-2019 04:57 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great to see you back at it Bob!
RCR
Total ratings: 102
Report this Post05-07-2019 07:10 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Right back at you, Neil. And enjoy Cancun.
Bob
Australian
Report this Post05-08-2019 07:12 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
RCR Bob your truly one of the purist fiero enthusiasts
RCR
Total ratings: 102
Report this Post05-08-2019 07:33 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanx...
Bob
pavo_roddy
Total ratings: 71
Report this Post05-08-2019 03:12 PM Click Here to See the Profile for pavo_roddySend a Private Message to pavo_roddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
HI all
Is that Godzilla in that pic of the front bumper??? He yur muscle? Can't imagine the cost to have a celebrity to work on the car with u....
Thanx,
Ear-eek
Enzo Ferrari....
Aerodynamics are for people who can't build engines....
Enzo Ferrari...
Today they are called garage's, yesterday, they were stable's! Eric Jacobsen.... An advancement, of other
voices I came across.
Do not walk infront of me, I may not follow. Do not walk behind me, I may not lead. Walk beside me and be my friend forever.
-unknown- found here: http://crystal-cure.com/love-quote.html
RCR
Total ratings: 102
Report this Post05-09-2019 06:48 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by pavo_roddy:
HI all
Thanx,
Ear-eek
Hey Pavo,
It's been a while since I've seen you around. Thanx for popping in.
Yes, my mascot, Big G. . He's a picture hog and ends up photo bombing a lot of the pictures. You're the first to mention him
Bob
RCR
Total ratings: 102
Report this Post05-14-2019 08:04 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
No pic update. The weather is good, but the going is slow. Laid some glass down for the first time this year. I'm filling some low areas on the nose, getting it flat.
Having nothing but trouble trying to get the hood to line up with the fenders. I knew it was going to be an issue, but I didn't think it was this big a deal. Damned those 3 dimensions
I think I have it close, but it will require grinding and filling.
Pics to come.
Bob
[This message has been edited by RCR (edited 05-19-2019).]
RCR
Total ratings: 102
Report this Post05-19-2019 03:31 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, today was cut short by a thunderstorm and tornado warning, but I got some good work done.
I also came to the realization that I spend more time trying to think of ways to do what I want than doing what actually needs to be done. I've found there is a slight difference between what I want and what I need to do. I don't know if that will make things go quicker or not, but it's an interesting.
As mentioned above, I'm working on setting the hood position and fixing the gaps.
Here's where I started, filling some low spots and starting to fix the height differences.
After screwing with the hood some more, I finally got a good gap and z-height along the passenger side.
But that left the fascia low, so I had to rebuild that back up.
It also helped line up the driver's side, but half was low and half was high. I ground down the high spot and filled the low spot. Also taking the opportunity to fix up the head light pod.
Where it's at when the storm rushed in.
Bob
shemdogg
Report this Post05-19-2019 05:46 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
That hoods looking really good man! I spent lotsa time thinking about how to do all the things I wanted to do to my car, and what I needed to do. Then tried to find a middle ground. Kit cars are a lotta work, both on and off the car. Ive spent waaaay too much time online looking for parts too. Keep it up man youre getting close!
shem
