  A Real Mera in Paradise (Page 154)
This topic is 179 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176   177   178   179
A Real Mera in Paradise by Fiero-in-Paradise
Started on: 08-18-2009 04:06 AM
Replies: 7120 (188855 views)
Last post by: Vernonmera on 01-21-2025 09:34 PM
Rick 88
Report this Post09-17-2014 08:30 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by batousai666:
I thought the same thing plus I love how this looks......
one thing that shy'd me away was stories for tuff to get to spark plugs and such
http://www.gmtuners.com/Cus...4DOHCFiero/index.htm
Well my engine is on it's way. I have purchased another 88 cradle to build the swap on, and have a line on a custom wire harness, and exhaust system. I'm going to drive the 3.4 PR till the DOHC is ready to be swapped in. A Mera should be able to rev easily to 6500 rpm, and sound exotic doing it!!
johnyrottin
Total ratings: 85
Report this Post09-17-2014 09:21 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't wait to here the sound of it purring!!!
Rick 88
Report this Post09-18-2014 01:20 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I hope it turns out to be a BAD KITTY!
batousai666
Report this Post09-18-2014 04:04 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
RIGHT ON!!!
hope you got a bigger brake swap.....not sure but it seems, 240 HP gets fast.......FAST!
glad I stepped up to the vented Grand Am set.....but the 12in Vette set is probably least, for the best
Rick, you are gunna love this swap....the Power is intoxicating!!
*EDIT*
and since you mentioned cats.....curiosity got this cat.
I am wondering which "year" I guess is best way to rate HP are you getting?
the early version 200-210 hp but the '96-'97 states 215 hp. 220 tq
the latter having better flow and all.....is your crate order engine old(er)? like of the era??
It was built from 1991 to 1997. From 1991 to 1993, it used tuned multi-port fuel injection, made 200-210 hp (150-160 kW) at 5200 rpm and 215 lb·ft (292 N·m) of torque at 4000 rpm. From 1994 to 1997, it used sequential port fuel injection, making 210 hp (157 kW) at 5200 rpm and 215 lb·ft (292 N·m) of torque at 4000 rpm. In 1996, the heads were redesigned for better flow as well as now making the engine an interference design and adapting the engine for federally mandated OBDII emissions. Output for the 1996-1997 LQ1 is 215 hp (160 kW) and 220 lb·ft (298 N·m). It had four large valves per cylinder.
[This message has been edited by batousai666 (edited 09-18-2014).]
Rick 88
Report this Post09-18-2014 08:26 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
The crate engine I purchased is a 95 SFI (sequential fuel injection) version. The car will have factory R134 A/C and cruise. The cruise will be the more modern electronic version instead of the vacuum controled unit from the Fiero. All factory gauges and controls will function properly, but the tach will now be able to reach redline easily. The Getrag 5-speed gear ratios are a great match for the DOHC engines power band. Highway mileage should be in the 27 to 30 mpg range if I can keep my foot out of it.
Stock 88 vented disc brakes are much better than the 84 to 87 solid rotor versions if they are properly maintained. I may install more agressive brake pads, and slotted rotors to dissipate more heat. I have not decided on a muffler yet but it will be based on the sound it produces. The more European sounding the better.
I picked this engine because of its broad rpm range and the 60 degree engine sound. Also, it was going to be an option in the still born 89 Fiero.
reholmes
Report this Post09-19-2014 07:44 PM Click Here to See the Profile for reholmesSend a Private Message to reholmesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try this upgrade: https://www.fiero.nl/forum/Forum4/HTML/060500.html
Rick 88
Report this Post09-20-2014 05:42 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
That mod seems to be a big improvement. Not sure about having to take a hammer to the car for clearance though........ Anyone here done this mod?
batousai666
Report this Post09-21-2014 07:48 AM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
if I am not mistaken when OleJoeDad swapped in the 3800 and I mentioned the bigger booster....he said something like "its not needed" I can reconfirm if you want Rick.....but I got the "GrandAm" vented swap on both cars and am very happy
let me know if you want me to check with Joe
Rick 88
Report this Post09-23-2014 08:21 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
While the car is down for the swap, I will freshen up the brakes and install new rotors. I may install slotted rotors this time. I had drilled rotors on my previous 88 GT and you could hear them (made a whirring noise) under hard braking. Since I am keeping the 15 in Cromodoras, there is not really any room for bigger rotors.
Total ratings: 206
Report this Post09-24-2014 07:15 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The GrandAm upgrade doesn't change rotor size. The rotors are upgraded to vented and the calipers and M/C are changed. Braking is much better and fade due to heat is much reduced.
The upgrade will fit behind your wheels.
batousai666
Report this Post09-24-2014 03:46 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Joe
Total ratings: 206
Report this Post09-24-2014 05:35 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Dan!
Run for the Hills was a blast!
[This message has been edited by olejoedad (edited 09-24-2014).]
Rick 88
Report this Post09-24-2014 07:43 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 already has vented rotors front and rear. What is the advantage of the Grand Am calipers over the 88 Fiero calipers? Is the Grand Am master cylinder larger than the Fiero one? I thought this upgrade was only for 84-87 cars with the solid rotors.
Total ratings: 206
Report this Post09-24-2014 07:53 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did not realize your MERA was an 88.
You are correct on all counts.
Total ratings: 206
Report this Post09-24-2014 07:56 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2004
You might be able to squeeze the 12" corvette rotors in there. They fit with the 15 x 7 lace wheels.
Rick 88
Report this Post09-24-2014 08:21 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are those rotors for a C4 or C5? My wife drives a C5 and I have her take off rotors. I put Z51 rotors on her car. Do they make custom brackets to space out the caliper for the addtional diameter of the Vette rotors? Also they would have to be drilled to the 5x100 pattern of the Cromadoras........
Maybe I will dig them out and see how they fit inside the wheel. I do have Rodney's 1 in. lowering ball joints. Would there be a clearance issue using Vette rotors?
Total ratings: 206
Report this Post09-24-2014 08:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The clearance issue on the inside of the wheel would be with the caliper. The rotor may touch the end of the front lower control arm under susp3nsion compression (which can be clearanced).
Fieroguru can supply brackets.
The inner profile of the cromadora wheel may not allow the larger rotors (or it may), the 7" wide lace wheel barely clears, the 6" front (88) will not clear. Again, its entirely dependant on the profile of the inside of the wheel.
batousai666
Report this Post09-24-2014 08:53 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
just out for a cruise......final Night of the season for the Wed. Night Cruise-In at the Gilmore.........
this sky was awesome.......
and soooo was this, Jag!!
and Fiero!!
good time!!
Rick 88
Report this Post09-24-2014 09:04 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Cromadoras are 7 in. wide and I believe 30 offset. I will have to verify the latter. Does that compare to the 88 rear wheel?
Total ratings: 206
Report this Post09-24-2014 09:20 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It depends on the profile of the inside of the wheel....you will have to mock it up to determine if it will fit or not.
johnyrottin
Total ratings: 85
Report this Post09-30-2014 08:57 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally broke down and put a CD player in my MERA. I put in a Pontiac factory player with matching gray buttons. Works fantastic. Now I need to send one off to have the aux plug put in it.
hnthomps
Total ratings: 51
Report this Post10-04-2014 05:46 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
At last a Mera got a bit of respect. My red t-top just took "Best of Class - 1980 to Present" at the Silver Springs All GM Show. There were a lot of very nice cars there and I am quite pleased with the result.
Nelson
Rick 88
Report this Post10-04-2014 06:01 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats Nelson! Is that the one with the Amida Dash in it?
Sage
Total ratings: 71
Report this Post10-04-2014 08:06 PM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
HAGO!
hnthomps
Total ratings: 51
Report this Post10-04-2014 09:54 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it is. Strangely, this is the second time I have attended this show and managed to get the same award a few years ago. Now I have matching crystal beer mugs. I will make use of at least one when I get back home sometime tomorrow evening.
Nelson
I FAR I
Report this Post10-05-2014 08:52 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson
Congratulations Nelson..........I was thinking it would sure be nice to see some pics of the show winner though.....just sayin'.
Cheers
hnthomps
Total ratings: 51
Report this Post10-05-2014 09:04 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cheers
I will see if I can get a picture of the car posted sometime tomorrow after it is cleaned a bit. I just got home and want to take a break after this weekend. My image resizer suddenly stopped functioning and I had to download and learn a new one today. Here are a few pictures of the Red T-Top Mera that got me a crystal beer mug Saturday.
Nelson
[This message has been edited by hnthomps (edited 10-07-2014).]
johnyrottin
Total ratings: 85
Report this Post10-05-2014 09:22 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking to install Homelink in my MERA. I will need to be a very clean install and look factory. I will be trying it on a few spare broken plastic trim pieces I found in the junkyard and then I will do a thread on it.
reholmes
Report this Post10-06-2014 12:17 PM Click Here to See the Profile for reholmesSend a Private Message to reholmesEdit/Delete MessageReply w/QuoteDirect Link to This Post
What model number on the player--pics?
Rick 88
Report this Post10-06-2014 09:36 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am running the 91 to 94 Bonneville CD in mine. This radio has the same style two round knobs on the left, plus the 5 band EQ just the the stock Fiero Cassette EQ. It looks like it came with the car and the red lighting is a dead on match to the stock Fiero illumination. This radio works with the factory sub and sounds great. I think it has a more powerful amp than the original cassette. You will need the GM harness and antenna adapter kit to make it a plug and play 10 min install.
johnyrottin
Total ratings: 85
Report this Post10-06-2014 10:16 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Modified Pontiac Radio
[This message has been edited by johnyrottin (edited 10-13-2014).]
reholmes
Report this Post10-08-2014 03:34 PM Click Here to See the Profile for reholmesSend a Private Message to reholmesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks--X2
batousai666
Report this Post10-08-2014 04:40 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson, that Mera is spotless!!! wow! real nice lookin
hnthomps
Total ratings: 51
Report this Post10-08-2014 06:36 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the positive comment. My gun metal gray car also looks equally nice on the exterior but the interior is almost bone stock.
Nelson
Sage
Total ratings: 71
Report this Post10-08-2014 07:44 PM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson
Gorgeous car!
Nelson, I've seen other pics of your cars, but this one is my favorite.
Congrats on the recognition (well deserved) and award, but not hard to see why it went that way!
Interior leaves me speechless....looks better than an actual f-car, even though I know it isn't meant to replicate one in the first place.
Never get tired of seeing pics of your rides, thanks for posting.
HAGO!
paced84
Report this Post10-08-2014 10:25 PM Click Here to See the Profile for paced84Send a Private Message to paced84Edit/Delete MessageReply w/QuoteDirect Link to This Post
anyone know of a very nice MERA for sale. I have a clinet looking to purchase one
RonT
Fiero Historian
signature by F-I-E-R-O (My Indy on right / #1 IMS)
Pontiac_1986
Report this Post10-09-2014 07:46 AM Click Here to See the Profile for Pontiac_1986Send a Private Message to Pontiac_1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
RonT
Fiero Historian
RonT
Is your client looking for a manual or automatic? Color preference? There was a red automatic for sale at a classic car dealer in the Chicago area...don't know if its still for sale.
Pontiac_1986
1986 Pontiac Mera #6001
I FAR I
Report this Post10-09-2014 08:49 AM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson
Only one word to describe that car -- SWEEEEEET!
johnyrottin
Total ratings: 85
Report this Post10-09-2014 12:04 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
As always Nelson, your cars are beautiful! What color is the gray on your MERA?
reholmes
Report this Post10-09-2014 12:19 PM Click Here to See the Profile for reholmesSend a Private Message to reholmesEdit/Delete MessageReply w/QuoteDirect Link to This Post
RonT
Fiero Historian
What are his requirements: '87/'88, GT, T-top, swap, leather, wheels, shipping? Most important what is his price window? I have several search agents going, will pass along anything that pops up.
Dick
Mera #8046 (Miss January, Mile High Fieros 2014 calendar)
1987 GT T-boned (RIP)
1988 GT T-Top (The Fiero Store Calendar: Miss February 2012)
1987 McBurnie Daytona Spyder
