  A Real Mera in Paradise (Page 176)
This topic is 179 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174   175   176   177   178   179
A Real Mera in Paradise by Fiero-in-Paradise
Started on: 08-18-2009 04:06 AM
Replies: 7120 (188855 views)
Last post by: Vernonmera on 01-21-2025 09:34 PM
Rexgirl
Report this Post03-05-2021 01:53 AM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
The sills on my 1987 MERA were painted a GM black (similar to what was applied to the inner door frame) although the donor Fiero color was a metallic red. The picture below is the best I have.
swing69
Report this Post03-05-2021 09:15 AM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Rexgirl.
I still learning about my MERA and what should be there, and what has been added or modified.
1) I have polished SS plates on my door sills. Now I know they were added by the orig. owner.
2) The exhaust muffler on my car...seem to be original. But they hand lower, so the tail pipes have been modified. I THINK that was done when IRM installed the MIller-Woods Turbo kit. I'm assuming the exhaust was lowered to clear the turbocharger, requiring the mod. SO...If I bought rodney's pipes, I'd have to modify them as well!
3) Still wondering, what the rear lower valance finish was: smooth or texture? semi gloss? flat? black?
Thanks all for your patience!
Larryinkc
Report this Post03-05-2021 10:49 AM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the parts diagram for the V6 exhaust.
hnthomps
Total ratings: 51
Report this Post03-05-2021 01:36 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by swing69:
Thanks Rexgirl.
What Rodney sells are the Mera equivalent of parts 1 and 10 on the exhaust system diagram. They need to be specially shaped to fit through the Mera bumper. I am not very familiar with the Miller Woods turbo setup, but do know that my 3.4 push rod turbo Mera (1987) did not have any exhaust system mods around the muffler area. This is what the engine side of my turbo setup looks.
Nelson
[This message has been edited by hnthomps (edited 03-05-2021).]
Rexgirl
Report this Post03-05-2021 06:23 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Everything below the MERA's rear bumper was painted flat black by Corporate Concepts.
swing69
Report this Post03-05-2021 07:01 PM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
Texture? Or smooth. I have areas that have a rough surface, and some smooth areas....
Also: I don’t think my exhaust is stock. It doesn’t look like the schematic, unless 88s were different
[This message has been edited by swing69 (edited 03-05-2021).]
swing69
Report this Post03-05-2021 07:03 PM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
swing69
Member since Nov 2020
Rexgirl
Report this Post03-05-2021 07:22 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are correct, most/all of your exhaust is not a stock Fiero assembly, and does not have the MERA tailpipes as illustrated in Larry's earlier post.
swing69
Report this Post03-06-2021 05:51 PM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
[img]https://images.fiero.nl/userimages/swing69/060 2C67B-7CCC-432B-8DCC-978635B7905B.jpeg[/img]I bought some black plastic centers to make some custom centers for the Chromadoras. The ID is right, OD slightly smaller.
Also swapped out chrome lugs for black Mcgards. If you do this, seap out the lug wrench as mcgards are smaller than the stock lug nuts!
Also: under the MERA stickers of the stock ones were MERA and Fiero transfers. I guess 87-88 centers of stock Fiero and MERA wheels are the same
[This message has been edited by swing69 (edited 03-06-2021).]
hnthomps
Total ratings: 51
Report this Post03-08-2021 06:23 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are speaking of the stock wheels on a Mera you are correct. The Chromadoras were an option in 1988 and the small center cap is slightly different than the stock diamond pattern wheel. If you are in a hurry, silicone will keep the small stock centers locked in place for quite a while.
Nelson
swing69
Report this Post03-27-2021 08:43 AM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
I still in the process of getting 8118 road ready. All new calipers and hoses are installed finally.
Now; on to the issue of fixing the little chips with touch up paint. I'm using the Dr. Colorchip system. seems to work very nicely. much better than the standard touch up bottles. Its a little tedious, but the results are much better.
Anyway: due to the fender shape and the wide tires up front; both sides have a lot of nicks / chips. I want to add splash guards of some time. maybe black plastic, small as possible? Anyone have splash guards on a MERA?
Rexgirl
Report this Post03-27-2021 02:49 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Splash guards were never an Mera option and I don't remember ever seeing any owner-created versions fitted. Of course, you certainly could do that.
If you have a source for new GM aluminum calipers, that are unique and typically only available used or rebuilt for the 1988 Fiero, you might want to post that information over in "Technical Discussion and Questions" .
swing69
Report this Post03-28-2021 11:48 AM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
Roger that : no option. But the sandblasting of the side yielding a white dot at point of impact isn’t the most attractive! Once I correct the paint, I want to prevent further chips. I guess I’ll fab some up.
No new calipers, rebuilt ones. Fiero store had front readily available and a right rear. I had to buy a core for the LR and have it rebuilt. So: all 4 are rebuilt. Hoses new. Steel outer halves were all powder coated silver. Should hold up better than grey paint.
swing69
Report this Post03-28-2021 11:51 AM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
swing69
Picked up some cheap repop centers and Ukrainian made silicone center sticker. This is my back up set. I have my originals with Rodney repop stickers. Rodney ones are a 10/10. My backups? 8/10. Just another option out there
hnthomps
Total ratings: 51
Report this Post03-28-2021 12:44 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a set of original Mera center caps designed for the standard lace type wheel. They apparently were clear with black circle and MERA. The one on the right is an original and Rodney's reproduction center (silver/black) is on the left.
Nelson
swing69
Report this Post03-28-2021 01:46 PM Click Here to See the Profile for swing69Send a Private Message to swing69Edit/Delete MessageReply w/QuoteDirect Link to This Post
When I peeled off the degraded “MERA” silicone stickers from my 88 Chromadora centers; there were a couple “Fiero” logo and MERA logo. Both black vinyl on brushed aluminum. So I’d say the stock Fiero wheel and Chromadora used the same cap.
I bought the Dickman center stickers which I put in the original center caps. My Spare set is the plastic centers with “foreign” sourced stickers.
hnthomps
Total ratings: 51
Report this Post03-30-2021 11:06 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My stock center caps would not stay on the Chromadora wheels until I used some silicone as glue. If they were the same size, I would not have had this issue. There is a slight difference in size or my three sets of Chromadoras are manufactured incorrectly or have been modified.
Nelson
freedom0226
Report this Post03-30-2021 06:01 PM Click Here to See the Profile for freedom0226Send a Private Message to freedom0226Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Larryinkc:
On a stock Mera Rodneys tailpipes connect to the factory muffler pipes which are higher than the muffler pipes on your Mera.
A friend bought a low mile 88 Mera and the door sills were painted body color, they look kinda plain that way. Mine were body color also when I got it. I put a set of brushed stainless I got from Vince at Snapperheads when he was still making Fiero parts. I put MERA vinyl letters on them and I think it gives a more finished look.
Larry your interior is absolutely stunning.
Larryinkc
Report this Post03-30-2021 07:29 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, the seats are MrMikes, he does amazing work, I did the install The dash and door panels are the Pisa Euro kits, they were covered by Vintage Fabrication. They are a local shop in the Kansas City area, they build really awesome cars. They did my exhaust also.
http://www.vintagefabrication.com/
batousai666
Report this Post06-05-2021 04:24 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
BUUUUUUUMMMMMMP!!! damn...... way back to March, even??
all you tri-state Fiero Owners.....
Saturday August 28th, 2021 bring your Fiero to the Metro 28 Cruise in Grand Rapids Michigan!!
TIME TO DOMINATE!!
[This message has been edited by batousai666 (edited 06-05-2021).]
batousai666
Report this Post07-30-2021 12:56 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
check this out. i would love to have a 3800 SC Quicksilver too
https://youtu.be/H3l5gkU_88s
[This message has been edited by batousai666 (edited 07-30-2021).]
Julian
Report this Post08-17-2021 01:02 PM Click Here to See the Profile for JulianSend a Private Message to JulianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just spent over an hour looking back at posts that I missed in the last 3 years. Quick update for those who remember me. Everything is going great. Well it took 3 years to get divorced but now all is good. I posted a while back for information as to what my Mera would be worth. No I wasn't selling, I just had to get a real world value for my separation agreement. And yes I kept Mera8071.
Recently met a wonderful young lady with a 4 car garage. (Had to throw in that caveat).
Since we been dealing with this pandemic, we have not taken the Mera out much. Next week I will be installing the original split exhaust tips.... finally. I still need to replace the pins and bushings in my doors and probably service the A/C since it's just not as cold as it use to be.
Someone asked for me to post a pic of my raised white letter tires so I will post that next. I hear another yellow Mera resides here in Canada. I'm sure there's room for the two of us...LOL
I see many new faces and I just love the pictures I keep seeing in here.
Julian
Report this Post08-17-2021 01:39 PM Click Here to See the Profile for JulianSend a Private Message to JulianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Julian
Member since Nov 2000
Here are two pictures....before the raised white letters and after. I also removed my center caps.
I had the car on a dyno that morning of the second pic and I see all the dirt on the rear tire sidewall..... weird how I just noticed. grrrr
Also note that the original Mera came with Good Year Gatorback tires 265-50VR-15 rear and 245-50VR-15 front. I went with 255-60-15 BF Goodrich raised white letters all around so it not only fills the wheel wells much better with the 60 series but it makes life easy when it comes to rotating tires.
[This message has been edited by Julian (edited 08-17-2021).]
Rexgirl
Report this Post08-17-2021 01:52 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great looking Mera, Julian ! So, we know there are four yellow Mera's around at least. Two in Canada, one in Wisconsin and one in Europe.
Julian
Report this Post08-17-2021 02:15 PM Click Here to See the Profile for JulianSend a Private Message to JulianEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was going to comment on the good looking 87 at the top of this page....
IMSA GT
Total ratings: 253
Report this Post08-17-2021 02:21 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just removing the center caps made a world of difference in the appearance. Beautiful.
hnthomps
Total ratings: 51
Report this Post08-19-2021 12:25 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I concur!. The large plastic center cap does not look good (IMO) on any of the 88 Meras and I have removed them from all of my 88 cars. The tabs on these center caps are also brittle and I have previously lost caps while on the road.
Nelson
riverbug86
Report this Post11-30-2021 01:56 PM Click Here to See the Profile for riverbug86Send a Private Message to riverbug86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am restoring an 88 MERA, and am looking for a set of door toppers to complete my beechwood interior swap. Hoping some other MERA owners might have an idea or two!
THX-Dave S.
freedom0226
Report this Post11-30-2021 07:16 PM Click Here to See the Profile for freedom0226Send a Private Message to freedom0226Edit/Delete MessageReply w/QuoteDirect Link to This Post
i had the same issue and asked this same question on several different forums / sites. at the end NO LUCK. i had to custom make my own using the my MERA originals as the test piece. luckily i already had a set. i needed to make a new one for my kit car. Sorry i know this isnt much help. you can also ask on the facebook mera group
THX-Dave S.
IMSA GT
Total ratings: 253
Report this Post11-30-2021 07:23 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which was my question. How difficult are they to reproduce if I could borrow originals? I wouldn't mind taking on the challenge if these are highly sought after parts.
riverbug86
Report this Post12-05-2021 07:04 PM Click Here to See the Profile for riverbug86Send a Private Message to riverbug86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking about making my own as well, I had a set I let go on my 308 rebody, should have kept them for when I got the MERA.
IMSA GT
Total ratings: 253
Report this Post12-05-2021 07:12 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I could borrow a set I would make a few but I don't even know what the originals were made from.
Rexgirl
Report this Post12-05-2021 07:16 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, the door card caps on my Mera were made of thin-ish fiberglass.
solotwo
Total ratings: 62
Report this Post12-07-2021 09:43 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all. I have a question for you all. Kinda been thinking about getting a Mera. What is the overall length of the Mera? Front bumper to rear bumper? I am wondering if a Mera will fit in the new dinky garages. LOL Yes a 88 coupe and an 87 GT have been parked in the garage with out a problem, but isn't a Mera just a little longer? Thanks!
I live in Grand Rapids, MI, and some of the houses they were building 20 years ago have small 2 stall garages. LOL
Larryinkc
Report this Post12-07-2021 11:33 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Mera sales brochure lists the dimensions as
Width - 73"
Height - 46.9"
Length - 172"
solotwo
Total ratings: 62
Report this Post12-08-2021 06:21 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. That will work
riverbug86
Report this Post12-09-2021 10:32 AM Click Here to See the Profile for riverbug86Send a Private Message to riverbug86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Im probably going to make my own. I have to get the car painted first, and that wont be until spring. Does anyone have a copy of the Corporate Concept sheet from 1987 and 1988 that listed what was included in each conversion that you could PM to me so I can make a paper copy instead of trying to zoom in on the ones posted?
Larryinkc
Report this Post12-09-2021 11:15 AM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney has the Corporate Concepts sales brochures on his site.
http://rodneydickman.com/pr....php?products_id=368
riverbug86
Report this Post12-19-2021 07:08 PM Click Here to See the Profile for riverbug86Send a Private Message to riverbug86Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I have been on and off the forum since around 2008 when I bought my first and I'm not really big on posting much, however, I wanted to introduce my self on this thread since Nelson actually sold me a MERA from his collection. I am the proud new owner of #8095 and it now resides in my barn in Marion NY. Currently the car is awaiting paint and I have to reinstall the interior, but I extremely excited since I have wanted MERA forever!!!!!
Dave S.
Rexgirl
Report this Post12-19-2021 07:55 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congratulations Dave :-) Will you be keeping the Green paint?
You might also want to update your owners information on JR's Mera list:
https://www.fiero.nl/forum/Forum1/HTML/099427.html
Mera's are amazing and I miss mine a lot!
