  Project "Black Widow" (Page 12)
This topic is 14 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14
Project "Black Widow" by Danyel
Started on: 09-24-2009 12:30 PM
Replies: 526 (34685 views)
Last post by: Danyel on 05-26-2018 08:31 PM
Danyel
Total ratings: 171
Report this Post10-07-2012 01:21 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
As all of you know I have been very busy and away from from home in the last past month. The Widow has been sleeping for a long time... and winter is coming !!! I have ALOT planned for this winter and I'm now working on "The Widow Revamped" All my hundreds of pics are presently being sorted and resized for the new coming thread. Should be soon on this forum a two to three year heavy duty project from the ground up... and I wll be thinking OUTSIDE the box ... anyways here are a couple of pics of what I'm working on for the original Widow ....
I ordered a 6 inch Edelbrock air filter that will fit in the below air intake bowl ... I'm fed up of seeing the V8 sucking up hot manifold air into the carb ... so ... I'm doing an RAM AIR intake ... you can see in the below pics the progress
Sawing the stands off the stacks so they can be welded into their holes...
Here is a basic pic of what I'm aiming for ... My spare decklid will be cut out "Shaker Style". The stacks are all the same height and the air intake and stacks will be powder coated RED. I've used only 6 stacks so that the shaker will be centered on the decklid ... you can also see that the LH side is empty but will function as a resonator box amplifying the carbs intake sound. There are holes with tubes to let the water out in case of rain................... more to come ....
I also recieved my F1F headlight buckets but I will NOT be using 60 or 90 Hellas ... I will modify the buckets to use 4 x 6 HIDs 8000K ... you can see one in the left background....
And of course my LED Projectors to be installed soon !!!!
[This message has been edited by Danyel (edited 10-08-2012).]
jelly2m8
Total ratings: 243
Report this Post10-08-2012 04:33 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure this is an LT-1 from the early 70's in your fiero? You do realise nothing about your motor is LT-1. Your engine block is 1978 or newer as that's when GM moved the dipstick to the passanger side, 1972 was the last year for the LT-1. The LT-1 had a transister distributer with an exteranl can coil, you have a regular old GM HEI distributer and an old Rochester carburetor where as the LT-1 had a Holley with an aluminum intake manifold.
You do know that using the now standard net measurements those old LT-1's only make about 225-250 HP right?
What's shocking is that after 12 pages in this tread not one person has stated the obvious.
Danyel
Total ratings: 171
Report this Post10-08-2012 12:21 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seeing your provenance and your reason for this write up I can see why you wrote this comment.... you should get your facts straight Here's a link to help you in your ignorance http://en.wikipedia.org/wiki/GM_LT_engine ....
LT-1 were ALSO produced for:
Y-body:
1992–1996 Chevrolet Corvette C4
F-body:
1993–1997 Chevrolet Camaro Z28, B4C and SS
1993–1997 Pontiac Firebird Formula and Trans Am
B-body:
1994-1996 Buick Roadmaster
1994–1996 Chevrolet Caprice
1994–1996 Chevrolet Caprice Police Package
1994–1996 Chevrolet Impala SS
1994–1996 Chevrolet Caprice Wagon
1994–1996 Buick Roadmaster Wagon
D-body:
1994–1996 Cadillac Fleetwood
This engine is from 95 or 96 and is NOT ORIGINAL ... and totally rebuilt with different fitting parts ... Eldelbrock intake mainfold and a right hand dip stick oil pan (can be ordered from ANY speed shop .... so whats your point GOT ALL HOT AND BOTHERED FROM MY POST ON ANOTHER FORUM !!!! LOLOL Never saw or heard from you before why now? ... I think you should just go back to from where you came from and leave this thread ALONE.... if you have no constructive critizism to make then DONT!!! Also I am NOT a mechanic ... I'm CCNA, MCSE, IT and what matters to me is "does it start and go" ...I couldnt make the difference between a LT-1 block or an LT-4 block (its not my cup of tea) Carl is the one who rebuilt totally the engine and informed me on its origin .... and you are you a mechanic?? If you are please tell me where you work so me and my friends can stay away !!! Have a nice day EH !!!
EDITED : Minor spelling corrections !!!!
jelly2m8
Total ratings: 243
Report this Post10-08-2012 02:29 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
This engine is from 95 or 96 and is NOT ORIGINAL ... ............. if you have no constructive critizism to make then DONT!!! Also I am NOT a mechanic ... ]I couldnt make the difference between a LT-1 block or an LT-4 block (its not my cup of tea)[/COLOR][/b] Carl is the one who rebuilt totally the engine and informed me on its origin .... and you are you a mechanic??
Oh snap! now it's 95- 96 LT1? holy poop an old LT-1 was more believeable. That is most definitely not an LT1 nor an LT4 cylinder block and your heads are no where near that generation of the SBC. You have run of the mill 991 casting number cylinder heads with the small 1.72 /1.50 valves.
If your going by what your man Carl is telling you then you need to go have a talk with him because that dude totally ripped you off and lied to you because what he sold you is just a standard regular SBC.
Danyel
Total ratings: 171
Report this Post10-08-2012 03:15 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ohhh snap you are hot and bothered and getting your panties all in a knot I REALLY dont F'N care about your comment if its a standard run of the mill V8 ...... only you are getting flustered in revenge of what I posted on another thread because you wouldnt of come here slinging comments...... Looks like a V8, sounds like a V8 ...... holy $hit its a V8!!! now get out of my thread and go talk gearhead crap with your friends on the other forum.... YFM
Danyel
Total ratings: 171
Report this Post10-08-2012 07:52 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
Member since Sep 2008
Man I hate that when people come in your thread and try to pic a fight ... I want to make sure people here understand .... I have an SBC V8 when, where , why it was made or how strong it is I DONT GIVE A $HIT... It can have 1000 HP bored 2000 over with lifters and a drag car racing cam I still DONT GIVE A $HIT .. I paid 1000 for it installed with the parts I bought .. it has a racing cam and roller rockers so I could last a long time ....... how fast is it and what is my 1/4, 1/2, 2/3 1mile time I STILL DONT GIVE A $HIT either... I love this car and THATS WHAT IS IMPORTANT .... thats all ... if you come here to talk shop well we can I'm an IT specialist MCSE and CCNA certified that I can sling $hit all day long with you....but this thread is all about revamping my Widow NOT ON HOW FAST AND WHAT NAME BRANDS I HAVE !!!!
OK RANT IS OVER
as you know I received F1F headlight buckets from Synthesis ... these are a work of art !!! High grade quality ... I'm not the Hella type so I will cut the front off these to install 4 x 6 HID 800K Projectors ... I'm also moving slowly but cautiously on my air intake that a USA friend lazer cut for me ... here are pics of the work .. Got to take measurement so I can cut out my spare rear decklid
New face plate for the buckets being sized and drawn ready to cut out a new pattern
[This message has been edited by Danyel (edited 10-10-2012).]
IROCTAFIERO
Report this Post10-08-2012 08:18 PM Click Here to See the Profile for IROCTAFIEROSend a Private Message to IROCTAFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
For what it is worth, an LT-1 is the old carbed 350, while and LT1 is the newer, reverse-flow, opti-spark EFI engine.
Danyel
Total ratings: 171
Report this Post10-08-2012 08:49 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the information ... I will get the proper info on my V8 this week .... casting numbers dont lie ... as for what my mechanic Carl stated ... I will get to the bottom of it. Thanks for the info.. in the meantime I'm gonna do some hilarious reading ...The 3 stooges just wrote new stuff ...
thanks for the info
regards
Danyel
infinitewill
Total ratings: 85
Report this Post10-08-2012 08:53 PM Click Here to See the Profile for infinitewillSend a Private Message to infinitewillEdit/Delete MessageReply w/QuoteDirect Link to This Post
D,
The new air cleaner stacks are FREAKIN' Sweet well done!
Dr.W.
Is your Fastback GT's trunk seal shot? My Gen III replacement GT trunk seals with solid molded corners are now in production. $95 + $15 flat rate shipping to the US (contact me for international shipping rates) or buy two and pay only a single shipping rate! More info can be found here GT Trunk Seal Project
falcon_ca
Report this Post10-08-2012 09:46 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
See Danyel, like at the bank, a little "-" can makes a big difference
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 |Work done 11-12 |Work done 12-13 |4.9 Swap |Parts for sale
Danyel
Total ratings: 171
Report this Post10-09-2012 12:40 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
YEP you can say that again some people make it a mission to pick an argument because they think that you are NOT 100% accurate... ESPECIALLY THOSE FROM THE OTHER FORUM.....pretty soon we'll have to give out our undershort sizes !!!! I'll correct all my posts and say its a F'N V8 .... thats it thats all ... that way the cry-babies wont come here to be pretending to be SPECIALISTS..... I think they are more '' King $hit of turd island'' ...... there is a proper way to correct the info people write ... others think I'll just pull there strings to get them pissed off .......I just think they're hilarious ......personnally when they do that I think they're just bunch of amatures !!!! LOLLL.......... OOHH got to go and read some more 3 stooges stories !!!! LOL
aaronkoch
Report this Post10-09-2012 01:48 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm with you, who cares what block it is.. You wouldn't believe the crap I got for putting in a NA 3800, and I'm totally happy with it. All that matters is we like what we have, and you're doing a great job on your intake. Can't wait to see the finished product.
Danyel
Total ratings: 171
Report this Post10-10-2012 09:21 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still doing some measuring for the buckets head light holes ... I got the template to the right size,,, They are going to fit and I will also be able to adjust them with 3 bolts... ...
more pics tomorrow ....
Danyel
Total ratings: 171
Report this Post10-14-2012 05:34 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're right ..all that matters is "Do I like it" I still havent talked to my mechanic yet ...but my intake is EDELBROCK and I do like that !!!!
[This message has been edited by Danyel (edited 10-14-2012).]
Danyel
Total ratings: 171
Report this Post10-14-2012 07:26 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
After sitting in the garage for over a month took her out and let her run a bit .. she puffed some smoke but after 15 minutes it stopped ... winter is almost upon us and already its very cold .. 5 degrees celcius (35 for my USA friends) Also cleaned up the shop ready for Phase II of the Black Widow .. I have many projects going on right now .. One piece tail light panel, RAM Air intake, 4 x 6 bucket lights, F-40 six speed swap... and of course the most important one ... still not finished yet kmunson signal light covers .. had ALOT of issues but now thinhs are picking up speed ..... more to come SOON on them.
Intake project
Buckets being ready for test fiiting 4 x 6
Template location ...
Garage has been revamped and ready for Phase II
Lots of space after parting out the 87
Bought 4 racks for all my small fiero parts ganna need 2 more I think
Alot of sorting and cleaning
Getting there !!!
Danyel
Total ratings: 171
Report this Post10-14-2012 07:35 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
As you all know I bought an 1987 GT 5 speed for peanuts and parted out the unwanted parts .. I kept the good items for the Black Widow revamping (Phase II)
I took ALOT of pics but I'm gonna spare you looking at all of them ... I've been searching for a unrusted rolling chasis this car WAS CLOSE but NOT up to par for me. I still havent decide on its faith maybe cut out the good parts, we will see. Here are the pics of what is left of the 87 ...
Parts car beside my Panther
I'm still wanting to buy an UNRUSTED rolling chassis must be an 86 GT Manual with Sunroof... frame has to be impeccable... thanks for any help
Danyel
Total ratings: 171
Report this Post10-14-2012 07:38 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
Danyel
Total ratings: 171
Report this Post10-14-2012 07:40 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
Well I forgot to post my F40 project but stay tuned .. will do this week ... but I'm looking for a HOW TO remove the top without breaking it ... I'm 0 for 3 so far
Tony Kania
Total ratings: 305
Report this Post10-14-2012 08:08 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think that we spend so much time organizing to make things go quicker, that it all levels out in the end. I too like to close my eyes, and grab what I need.
Keep the pics coming.
Tony
thismanyfieros
Total ratings: 120
Report this Post10-14-2012 11:02 PM Click Here to See the Profile for thismanyfierosSend a Private Message to thismanyfierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its easy a nice hot day or crank up the heat in the garage.. Or you can use a heat gun or hair dryer..a lot of patience, a few wedges to put into place and a sharp utility knife will get the job done..But go slowly very slowly and I dont see why you cant do it..
Vernon8360
Report this Post10-15-2012 03:07 PM Click Here to See the Profile for Vernon8360Send a Private Message to Vernon8360Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Widow is looking GOOD. Are you still on schedule for the 30th in Indianapolis?
1988 GT
Medium Red Metallic
Manual, Gray Leather
K Beck LEDs & StuWipes
rcp builders
Report this Post10-15-2012 04:17 PM Click Here to See the Profile for rcp buildersSend a Private Message to rcp buildersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ray
Edit to add: the car is looking great!!!!
[This message has been edited by rcp builders (edited 10-15-2012).]
Austrian Import
Report this Post10-15-2012 04:41 PM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could you take a picture of the bottom of your cut decklid?
Danyel
Total ratings: 171
Report this Post10-17-2012 08:43 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
I checked through all my pics but I havent got one .. will be going to the garage tomorrow night I'll take a couple of pics for you.
regards
Danyel
Danyel
Total ratings: 171
Report this Post10-17-2012 08:48 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
YEP will be there ....
Danyel
Total ratings: 171
Report this Post10-20-2012 06:46 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here you go ...
[This message has been edited by Danyel (edited 10-20-2012).]
Danyel
Total ratings: 171
Report this Post10-20-2012 07:09 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
Been very busy lately and not home very often ... Got some pics up on my server of my headlight conversion ... as you know I bought F1F's buckets but I did not like the round look (personal choice) so I did a little mix and mingle .... I used F1F buckets and Tony Kania's 4 x 6 headlight upgrade with a HID twist ...
I measure over 20 times drew out the template and traced it on the buckets ...
Then I cutted on the line with a skill saw with a metal cutting blade .... I finished the whole thing with a dremel and a round sanding stone ...
The fit is PERFECT ... I'm gonna fiberglass the front with the fiero bottom plate so it looks clean (I photoshop the pic to see the end result)
A before and after pic.. I am going to use the 4 holes that are left for the adjustements ... Tony's method for using JB weld with the headlamps will be used .. will post pics once done ....
Here is a pic if the openings with the HID lamps ... so thats where I'm at so far ...
also bought new parts drawers ..
More to come tomorrow ... will be home to install my new Fiero fastback lip spoiler and get it ready to fiberglass it on ....
[This message has been edited by Danyel (edited 10-26-2012).]
Danyel
Total ratings: 171
Report this Post10-21-2012 01:29 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got home late but had a couple of hours to install my new Fiero Warehouse lip spoiler .... but Krap I hit a snag ... the bolts to hold it down are 1/4 inch too short ... they barely show on the other side of the decklid and not enough for the nuts to grab on ... I'll contact Doug to see what may be the issue ... I am going to glass it in and extend the sides and make it a 3 piece lip ... It did stay on though so I can take pics... looks better than when it had a tall wing ... tonights pics ...
Doug tells me that bolt should be around 1 inch ... uhhh
more tomorrow I'm gonna make a template for my new decklid .. it will be cut out for my RAM air intake (shaker style) that you can see in the pics ...
[This message has been edited by Danyel (edited 10-22-2012).]
Danyel
Total ratings: 171
Report this Post10-24-2012 11:11 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doug sent me an email ...I thought that bolt was molded into the spoiler... uuhh wrong " just unscrew it" he said....thats embarrassing well old dogs can learn new tricks
thanks Doug
michhiker28
Report this Post10-24-2012 11:28 PM Click Here to See the Profile for michhiker28Send a Private Message to michhiker28Edit/Delete MessageReply w/QuoteDirect Link to This Post
That chassis still looks pretty good to me...
-MH
Danyel
Total ratings: 171
Report this Post10-24-2012 11:34 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
-MH
Maybe I can get Kathryn up here to do a little cutting and welding ... It would probably come out top shape !!! ... Seeing that the frame will be chopped and stretched I'm really wanting a perfect rustless frame ... must be the picky old fart in me ..
... please send Kathryn my regards and to you sir a firm hand shake ...
regards
Danyel
michhiker28
Report this Post10-24-2012 11:39 PM Click Here to See the Profile for michhiker28Send a Private Message to michhiker28Edit/Delete MessageReply w/QuoteDirect Link to This Post
We'll do. I have to say the Widow is looking very nice.
-MH
Tony Kania
Total ratings: 305
Report this Post10-24-2012 11:42 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be careful mitchhiker28, those Canadians are know to steal your beer!
Tony
Danyel
Total ratings: 171
Report this Post11-04-2012 04:19 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tony
NAHHH USA beer is more like water to us Canadian Beer Hunters ... like take off EH !!
Danyel
Total ratings: 171
Report this Post11-04-2012 04:20 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
Well Fiero season is now over ... The Widow is in for another winter transformation.... I got my 4 x 6 HID (F1F) buckets in and working all that is left to do to those is sand and paint them black .... here are a couple of pics
In her winter resting place she's gonig back up on jacks ...
RH old.......................... LH new
LH Side View of old and new
Both new .... now looks ALOT better no more Froggy eyes
Lights off ... but up ... New light button will install DRLs soon
Got lots to do this winter ... swaping in an F40 six speed and I'm takin out the fastback and modding it to notchie with fastback style tail lights (one piece LEDs).. MORE TO COME !!!
[This message has been edited by Danyel (edited 11-04-2012).]
Danyel
Total ratings: 171
Report this Post11-04-2012 04:52 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
Wooo hooo forgot to post ... finally got my first top off without breaking it
SUCCESS !!!!!!
falcon_ca
Report this Post11-04-2012 07:05 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel
for your intake, did you ever thought to build it like "California Kid" did ?
https://www.fiero.nl/forum/F...1/HTML/025670-9.html
Danyel
Total ratings: 171
Report this Post11-04-2012 07:59 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Falcon_ca ... yes I based my intakes on California Kid's set-up ... I couldn't afford a Hilborne set up so I went to the next best thing RAM air shaker style with velocity stacks. You will see in future post a look a like to California Kids decklid. My intakes will be chrome RED and will be suckin in cool fresh air instead of under the decklid hot manifold air ...... you can also see my intake has an empty area which will act as a resonator as the carb sucks air.....
Danyel
Total ratings: 171
Report this Post12-02-2012 12:06 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been away from home for a little while ... started a couple of hours on the parting out of my latest acquired 87 GT ...took a pic of my garage with the 3 fieros ... each end are the 2 87 GTs in the middle The Black Widow ... wont see that very often ......
[This message has been edited by Danyel (edited 12-02-2012).]
falcon_ca
Report this Post03-24-2013 08:36 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
spring bump
