Update System
  Another Northstar/F40 Swap. (Page 2)
by 1986 Fiero GT
Started on: 09-13-2010 02:13 AM
Replies: 86 (5340 views)
Last post by: TheseusRises on 03-28-2022 10:56 AM
dratts
Total ratings: 118
Report this Post Click Here to See the Profile for drattsClick Here to Email drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK! Now THATS a story!
dratts
Total ratings: 118
Ok, Now that's a story. I can feel your pain. Almost. Sorry for the double post. Tried to delete it. Only forum leaders can.
[This message has been edited by dratts (edited 01-27-2011).]
1986 Fiero GT
Total ratings: 54
Report this Post Click Here to See the Profile for 1986 Fiero GTClick Here to Email 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Eh, not my first suture. I heal pretty quickly, too...I've already started being able to use that hand, haha.
1986 Fiero GT
Total ratings: 54
Nevermind. Project's for sale. $2,500 for everything I own Fiero-related.
List includes:
1 - 1986 Fiero GT. Clean title, decent shape, mild rust which I began addressing before project had to go.
1 - Getrag 5-speed. Mileage unknown, condition unknown. This one's sort of a mystery, but it's here.
1 - M17 4-speed. ~76,000 miles, never had a problem with it. It's never been behind anything but a tired 2.8L.
1 - 1995/6 Aurora 4.0L. Somewhat disassembled, but that's only because it's part of a project.
1 - F40 6-speed. Brand new, zero miles. Already notched for the Aurora/Northstar starter.
1 - Complete Fiero1Fan Hella 90MM headlight setup
1- Extra '84-'87 cradle. Mild rust, but nothing excessive.
2 - Mr. Mike's leather seats with Audiobahn 3.5" speakers inside of them.
Lots of other parts, too...like a bunch of Rodney Dickman Getrag parts. Aluminum slave, master shift kit, select arm rebuild kit, and a fully-rebuilt Getrag 5-speed shifter. The only things missing from an essentially brand-new Getrag swap are the shift cables. You'll get a complete M17 setup, too. Pretty much, you're getting 2.5 drivetrain setups. The car still needs a decent amount of work, but almost everything is there.
You'll need:
1. Flywheel/Spacer. I can provide a solidworks drawing for the spacer.
2. Clutch disc. The one I have is for a Getrag 5-speed. Won't fit the F40.
3. Clutch hydraulic system. I have nothing for this yet.
4. Some sort of drivetrain. I was going to try my luck with the MU3 Cobalt stuff...
5. Engine harness. Wire it up and reassemble it.
6. Running lights. Most of the car hasn't been wired yet, but some has. Most lights are not wired.
7. Audio, if desired...I've provided nothing in this regard. I hadn't really planned on much.
It pains me greatly to try and move this, but I was fired on Monday, and as such my shop space disappeared. I've no longer got a place to put it and I can't afford a storage garage if I've got no job. It's got to go.
Best offer, of course. Let me know of any interest and if better/more specific pictures are required. Car is located in several places, but the chassis is in Williamsville, NY.
GADJet
Report this Post Click Here to See the Profile for GADJetSend a Private Message to GADJetEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a steal! Wish it were closer and/or driveable now. TTT!
1986 Fiero GT
Total ratings: 54
Just trying to keep this out of the archives, I guess...
1986 Fiero GT
Total ratings: 54
Trying to keep this alive, I guess. Hopefully there's actual progress, here, soon....
L67
Total ratings: 219
Report this Post Click Here to See the Profile for L67Click Here to Email L67Send a Private Message to L67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ouch. A good friend of mine danced with his grinder also the other day. I think he said an article of clothing snagged, but the blade made a perfect five inch incision straight down the underside of his wrist. He's lucky he didn't hit an artery and bleed to death. The scar looks like a suicide cut. Be careful.
If you haven't already, fill this in. It's an enormous stress riser which will lead to a large stress concentration as it axially loads. It can develop into a lateral stress fracture. Same for the other side.
1986 Fiero GT
Total ratings: 54
Have not done this yet. Appreciate the tip. Gives me an excuse to dust her off a bit later today and make a list.
1986 Fiero GT
Total ratings: 54
1986 Fiero GT
Total ratings: 54
Not archived. Sick.
Making some pretty righteous progress.
Couple weeks. Then fire-in-the-hole.
1986 Fiero GT
Total ratings: 54
Replaced my brake/clutch lines. Look for the sweet little weld-on zip-tie tabs I found. Love 'em.
1986 Fiero GT
Total ratings: 54
Put the ICM and coil packs on today
Report this Post Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like you switched transmissions... no more F40?
1986 Fiero GT
Total ratings: 54
Sadly. Gave up on the F40 in favor of something a little more "bolt-in". The F23. I've still got the brand new F40 lying around...
1986 Fiero GT
Total ratings: 54
Put my coil covers together.
Then I welded on my "crossover junction" and test fitted tubes.
Yes...I'm planning on wrapping the rest of the exhaust.
Here's where I'm putting the water-to-oil cooler. Perfect place. I'll work on mounts for that next week.
1986 Fiero GT
Total ratings: 54
Finished plumbing my oil and coolant lines at the motor.
Bloozberry
Total ratings: 311
Report this Post Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's an interesting idea for an oil cooler, and certainly very clean looking. Does the manufacturer list any cooling specs or show any graphs on cooling performance that you could share?
1986 Fiero GT
Total ratings: 54
Hey, thanks Blooz. Means a lot coming from you. Sadly, no...they don't. From everything I've read, though, I should expect oil temps to stay within 15-20 degrees of water temp and for the water to reach operating temp sooner. Pretty scientific I know, but it's better than no cooler at all for sure.
Bloozberry
Total ratings: 311
OK thanks for looking. Could you post the manufacturer and model of the oil cooler so that I can do a little hunting myself?
Fierfly
Report this Post Click Here to See the Profile for FierflyClick Here to Email FierflySend a Private Message to FierflyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fieroguy123:
You can't post a picture of the glove and leave us without the carnage! Post the pics! (Probably no women in this thread anyway)
No women huh?
Pffft. seven stiches? i have an 8 inch incision healing in my gut and havent touched the percoset.
A good man is hard to find...but a good Fiero mechanic is "rare".
1986 Fiero GT
Total ratings: 54
Not really. I think it's a unit made by Seakamp. It's entirely made of copper, has a 6" long body and 1-1/4" hose barbs. It's designed as a drop-in replacement for OEM marine coolers, so it's not really a "performance part" per se. I searched for a few hours to find a list of cooling/efficiency specs, but the only ones I could find are the physical dimensions of the damn thing. I didn't call or e-mail the manufacturer...I suppose that would be a good place to start?
1986 Fiero GT
Total ratings: 54
Got my joesfiero aluminum tank and Bosch 044 pump in and plumbed. Those are -8AN braided nylon hoses.
1986 Fiero GT
Total ratings: 54
Mounted my horn(s) today. Delco Remy A, C, D and F trumpets. Now that's a luxurious tone.
jb1
Report this Post Click Here to See the Profile for jb1Click Here to Email jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
nice build.. I like the idea of the heim joints replacing the inner tie rods on the rear..
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
1986 Fiero GT
Total ratings: 54
That was jstricker solving the bump steer issue his own way. I bought the cradle from him like 5 years ago already built like that. Should be able to comment on the handling improvement in a few weeks...
jb1
Let me know how it does, The p.o. of my car mentioned it 10 years ago about using heim joints but never gave it much thought.... I am redoing all my suspension now and if worth the effort would not be much to do at this point.. hum just thought about it, the same p.o owned all of my cars at one point.....
87 GT
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 08-04-2013).]
1986 Fiero GT
Total ratings: 54
Oh...will do.
Found an engine harness; should be here on Thursday. Then the motor goes back in, fluids get filled, computers get programmed and keys get turned. Stay tuned.
1986 Fiero GT
Total ratings: 54
Should have gone with a carburetor.
1986 Fiero GT
Total ratings: 54
Made you look. Just a bump to keep out of the archives. More work soon. I promise. Hah.
jb1
where the updates?
86GT 3800 n/a---sold
Northstar Rebuild
1986 Fiero GT
Total ratings: 54
Finished the exhaust. Could be loud. Really loud. Won't know for a few weeks.
[This message has been edited by 1986 Fiero GT (edited 10-22-2014).]
1986 Fiero GT
Total ratings: 54
Got my SpeedHuts and threw them in the gnarly replacement cluster panels I had.
Going to head over tomorrow to get all of the senders installed and mount the gauges. They look pretty good turned on. I dropped the extra coin on the dimmer inverter for the glow and an opening ceremony for gauge power-on. It's pretty cool to watch. The gauges themselves are a bit noisy being a mechanical stepper motor design, but they'll be inaudible against the motor behind me.
[This message has been edited by 1986 Fiero GT (edited 10-24-2014).]
1986 Fiero GT
Total ratings: 54
Got sick of trying to find some ridiculous unobtainable throttle cable from a later 4-cyl car or whatever supposedly fits. Ordered up some parts to just make one. My purchase consists of .064mm wire and the appropriate teflon-lined nylon conduit with .250" diameter conduit ends. I found appropriately sized ball ends for the Fiero throttle pedal and the Northstar TB to solder onto the wire. I also picked up an in-line adjuster for the conduit to take out up to 1" of slack from cable stretch and other wear. Found the stuff here. Paid $33 for everything. To my door in three days. Gonna go put a throttle cable together this weekend.
1986 Fiero GT
Total ratings: 54
Mounted and wired the SpeedHuts. Hoping to finish plumbing the coolant system, finish up any wiring gremlins and solder together the throttle cable tomorrow. We'll see.
fieroboy_gt
Report this Post Click Here to See the Profile for fieroboy_gtClick Here to Email fieroboy_gtSend a Private Message to fieroboy_gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice i like the gauges , Ive been trying too figure out what too do for gauges in my swap
1986 Fiero GT
Total ratings: 54
Sounds like a VATS issue, no? Thinking I'll finally buy HPTuners and just delete all of the nonsense. I'm probably going to have to anyhow.
1986 Fiero GT
Total ratings: 54
Did spring cleaning in the shop last week. Motivating myself to finish this thing up in the next few weeks.
Here's a picture I took last week. Really showcases the exhaust. Looks good here.
Fairly short list left, considering:
-Fill Coolant
-Purchase HPTuners and delete VATS
-Fab shifter cable bracket at transmission and install shifter cables
-Install rotors and calipers, terminate hoses at calipers
-Bleed brakes and clutch
-Purchase/install headlights
-Purchase/install outer dew wipes
-Reinstall bodywork
-Install turn signal and high beam indicators in gauge bezel
-Set up all gauges
-Align all four corners
-Break in clutch and tune
-Profit
RCR
Total ratings: 102
Report this Post Click Here to See the Profile for RCRClick Here to Email RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice build. Slow but consistent (like mine). Curious as to the ECU you're running. Someday I hope to get mine on the road, and I suspect I will have ECU issues.
Bob
https://www.fiero.nl/forum/F...1/HTML/076365-5.html
1986 Fiero GT
Total ratings: 54
Hah, thanks. It's only been 7 or 8 years. I went with the LS1 computer running the Shelby Series One program. Haven't gotten it running, but it's close. Hopefully find out how well in the next week or two. I have enough money to order HPTuners.
