  New Project: Indy Fiero #64 Restoration (Page 4)
New Project: Indy Fiero #64 Restoration by FieroMaster88
Started on: 10-09-2011 03:31 PM
Replies: 188 (8172 views)
Last post by: FieroMaster88 on 12-14-2020 08:16 PM
FieroMaster88
Total ratings: 168
Report this Post02-27-2013 01:04 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm waiting to get the block and parts from Toddster. He said he found some ignition parts and sent them with the other parts.
Forgot to mention the Weber carbs came with a ton of extra parts and the seller threw in a copy of the super duty build directions. Ill post more pictures later when I get home from work.
[This message has been edited by FieroMaster88 (edited 02-27-2013).]
FieroMaster88
Total ratings: 168
Report this Post03-01-2013 03:19 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
Total ratings: 168
Report this Post03-05-2013 07:03 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got some nice used arm rests and another set of floor mats for the Indy today. Still waiting for the lower engine parts and block so I can get started on the engine build.
FieroMaster88
Total ratings: 168
Report this Post04-11-2013 10:38 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Went and started the car for the first time in a couple months. Kinda got me in the mood to start working on it again.
FieroMaster88
Total ratings: 168
Report this Post04-20-2013 12:23 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, what shocks/struts would be the best for this car? I want a stock ride quality for now. Are Monroe sensatrack struts any good?
FieroMaster88
Total ratings: 168
Report this Post04-21-2013 09:01 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I ordered a set of Monroe shocks/struts from RockAuto since they were on rebate. Now to get the weather to cooperate so I can work on the car.
FieroMaster88
Total ratings: 168
Report this Post04-28-2013 10:14 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
They arrived the other day. Added them to my pile of parts. I need some time so I can work on this car! I have gaskets for the engine, ball joints, shocks, struts, door arm rests, ignition parts, wheel bearings and brake parts to install. It will be nice to have a good ride when driving it. Right now it bounces all over the place due to worn struts.
FieroMaster88
Total ratings: 168
Report this Post05-20-2013 01:48 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still waiting on the SD block. I need to get the car out of storage and install some of these parts I have stacking up in the garage.
FieroMaster88
Total ratings: 168
Report this Post06-20-2013 10:58 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing new. Car is still in storage. I have no time to work on it at the moment.
FieroMaster88
Total ratings: 168
Report this Post07-26-2013 04:57 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got a set of drop spindles and springs for the car. Should look good once the suspension is done!
FieroMaster88
Total ratings: 168
Report this Post07-31-2013 08:15 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started it and backed it into the driveway.
FieroMaster88
Total ratings: 168
Report this Post07-31-2013 09:04 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
Member since Nov 2000
The iron duke is noisy.
FieroMaster88
Total ratings: 168
Report this Post08-25-2013 10:56 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nearing 2 years of ownership. I hope to get time to work on the car still this year. Sounds like I might get the rest of the super duty parts here soon too.
redraif
Report this Post08-26-2013 03:27 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been having the same knid of year with mine. Pile o parts and no time to really get busy. At least the rewiring I did means the little guy starts each and everytime I ask.
1984 Indy Fiero SE Pace Car Replica #770
"SE" Stormtrooper Edition
Rescued, resuscitated and reversibly modified! (I'm so not done yet!)
Poly all round & Black Drag DR-34s
Frt: 225/45 on 18x8 (47 offset w/ 8-9mm spacer) 1.5 coils cut off 1984 WS6 springs
Rear: 265/35 on 18x8.5 (45 offset) Coil-overs w/ 10 inch 300lb springs & 7 inch sleeve
Everything is the previous owners fault!
RWDPLZ
Total ratings: 306
Report this Post08-26-2013 06:08 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool, I was just wondering about this build.
This year I went from having lots of time and no money, to lots of money and no time. It's not fair!
FieroMaster88
Total ratings: 168
Report this Post09-01-2013 09:51 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
This year I went from money and no time to no money and no time, lol. Kids are expensive!
I need to find a crankshaft for the Super Duty engine, figure out what to use for an ignition system and find a carb for it. I sold the webers because they would not fit in the stock chassis without some serious modifications. I have 2 of the 2 barrel Holley intake manifolds so thats what I plan on using.
[This message has been edited by FieroMaster88 (edited 09-01-2013).]
FieroMaster88
Total ratings: 168
Report this Post09-15-2013 08:53 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was surfing RockAuto.com over the weekend and found front calipers for $12 each, hoses for $12 each and a bunch of tune up parts for $1 or less each. So now I have more parts on the way for the car. I need to find a good deal on E-brake cables and rear calipers. My pile of parts is getting bigger.
FieroMaster88
Total ratings: 168
Report this Post09-25-2013 10:43 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got a right rear caliper new in box for $50. Now to find the left side. Is love to find a set of intrax lowering springs for the car too. I had them on a SE I had years ago and loved them.
FieroMaster88
Total ratings: 168
Report this Post10-23-2013 07:34 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
nealreno
Report this Post10-23-2013 08:06 PM Click Here to See the Profile for nealrenoSend a Private Message to nealrenoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Question, who do you find the # of your pace car. I purchased on here in KC and was told it was #3. I have been very excited to to this car togewther but struggle because I was to 3800 swap it.
Is the number in the vin? PHS the only way to find it?
FieroMaster88
Total ratings: 168
Report this Post10-23-2013 09:11 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pm superchargedv6. He has all the Indy info.
redraif
Report this Post10-24-2013 11:34 AM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
Super duty.... ugh.... so jealous! I would love to do that swap and build! The little duke is still alive and strong so I can't justify it... maybe one day when I have money to burn. Lol...
The spare arm rests you got... did you happen to have any spare screw hole cover plugs. I keep striking out finding ones for the indy. Are you keeping your old arm rests?
[This message has been edited by redraif (edited 10-24-2013).]
FieroMaster88
Total ratings: 168
Report this Post11-09-2013 10:50 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have any screw hole plugs, sorry. I'm going to try and get my factory arm rests recovered at some point. Doesn't look like i will get time to work on the car this year. It's getting cold outside. It will have to wait until spring.
RWDPLZ
Total ratings: 306
Report this Post11-09-2013 11:40 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't wait!
FieroMaster88
Total ratings: 168
Report this Post01-06-2014 11:23 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing new. Once the snow/winter is over I plan on bringing the car home to work on it. Might make it my daily driver this summer.
FieroMaster88
Total ratings: 168
Report this Post02-16-2014 12:33 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Getting ready for spring. Got my pile of new parts ready to go on the Indy. Hope it warms up soon!
FieroMaster88
Total ratings: 168
Report this Post03-08-2014 06:33 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just checked, it's still way too cold out.
BrittB
Report this Post03-08-2014 09:23 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Love those Indy Fieros, I have since 1984!
FieroMaster88
Total ratings: 168
Report this Post03-29-2014 03:32 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have been unable to find a crankshaft for the super duty engine. I'm considering selling the super duty stuff and going turbo 3800. Thinking I'll just fix up the iron duke for now and consider my options.
What about Bob
Report this Post03-29-2014 05:45 PM Click Here to See the Profile for What about BobSend a Private Message to What about BobEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why not go with another 4 banger, a turbo Ecotec?
FieroMaster88
Total ratings: 168
Report this Post03-29-2014 07:56 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
The turbo 3800 would be cheaper/easier.
Report this Post03-30-2014 03:14 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
heh.....
Crankshaft - $1,375
KRP fully machined, drilled, balanced and heat treated:
3.100" stroke x 4" bore = 155.80 cid
3.125" stroke x 4" bore = 157.08 cid
3.250" stroke x 4" bore = 163.80 cid
3.500" stroke x 4" bore = 175.90 cid
3.500" stroke x 4.125" bore = 187.00 cid
FieroMaster88
Total ratings: 168
Report this Post03-30-2014 03:58 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, don't have that kind of cash sitting around right now. Just gonna fix up the duke for now. Maybe I'll find a good used crankshaft sometime. I could trade a cylinder head for it since I have two.
FieroMaster88
Total ratings: 168
Report this Post04-10-2014 05:37 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got a deal on a left rear brake caliper. Loaded reman ac delco brake caliper for $39 on clearance at rock auto! Was the last one. Got it today now I have everything I need for the car!
FieroMaster88
Total ratings: 168
Report this Post04-17-2014 04:54 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaned and painted drop spindles for the Indy. Machined the rotors and repacked the bearings with grease. All assembled and ready to go:
What about Bob
Report this Post04-19-2014 04:19 PM Click Here to See the Profile for What about BobSend a Private Message to What about BobEdit/Delete MessageReply w/QuoteDirect Link to This Post
James,
What do you use for a spring compressor on the front suspension?
FieroMaster88
Total ratings: 168
Report this Post04-19-2014 05:03 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I use a jack under the lower control arm and slowly lower it down after taking the ball joint loose.
FieroMaster88
Total ratings: 168
Report this Post05-18-2014 03:18 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
What a beautiful day. If only I had the car at home so I could work on it.
Csjag
Report this Post05-18-2014 07:17 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
You mentioned that the duke was noisy. I have one too, I am going to change it to adjustable rocker arms by installing 66 Chevy 153 4 cylinder rocker arms and GM LS rocker studs, with those you can eliminate the slop in the pushrods that cause most of the noise. Ventura did this to his and he is the one that told me about it, he said it made the engine much quieter.
FieroMaster88
Total ratings: 168
Report this Post05-18-2014 09:09 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, it can be noisy. I have a super duty 4 to build for it so the duke won't be in there forever.
