  The Getrag F23 Tutorial - By Emc209i (Page 7)
The Getrag F23 Tutorial - By Emc209i by L67
Started on: 10-19-2011 04:38 AM
Replies: 272 (53027 views)
Last post by: pmbrunelle on 11-13-2025 08:02 PM
ericjon262
Report this Post10-12-2024 02:20 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
The cap is also a vent, but be warned, it's very slow going filling the transmission through it.
Was the pressure plate to flywheel interface (number of bolts, thread size, bolt circle diameter, dowel pins if applicable) standardized among FWD GM cars?
In other words, will a Cavalier pressure plate bolt to a Fiero flywheel, or is that likely to require machining?
My Fiero has a Bully stage 5 clutch for a Cavalier, my Gran Damn had a Spec stage 4 for a Berretta. both worked fine with my setups, one using a iron flywheel, one using a fidanza aluminum flywheel, neither had a HTOB spacer of any kind.
[This message has been edited by ericjon262 (edited 10-13-2024).]
pmbrunelle
Total ratings: 63
Report this Post10-13-2024 09:30 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess with the Beretta (Getrag 282) clutch, you needed an HTOB spacer, and with the Cavalier clutch, you didn’t need a spacer?
ericjon262
Report this Post10-13-2024 08:22 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did not use a spacer on either clutch.
pmbrunelle
Total ratings: 63
Report this Post10-15-2024 06:14 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
How is the reverse light switch meant to be installed on the Getrag F23?
I see no sealant on the threads, no washer, no specific method to ensure sealing of the oil.
The body of the switch is aluminium. Is the aluminium meant to act as a cheap crush washer that squeezes against the face of the transmission?
I was able to answer my own question using the Service video on youtube:
https://youtu.be/fB0BpZ6Go3...HEqKWzpfdFWru&t=2142
The reverse light switch is sealed with liquid Teflon thread sealant on the threads.
[This message has been edited by pmbrunelle (edited 10-15-2024).]
pmbrunelle
Total ratings: 63
Report this Post10-21-2024 11:58 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
From here, Jncomutt has identified a potential problem:
https://www.fiero.nl/forum/...1-083654-4.html#p132
For information, Energy Suspension makes the 3.1158 transmission mount which is a shorter version of the 3.1108.
https://www.energysuspensionparts.com/3.1158
While Energy Suspension states that their mount must be used with their "preload plate", which is essentially a steel shim. Normally, the transmission mount is meant to be bolted to a cast transmission case, which is not flat; in this case, I think the requirement for the preload plate makes sense. However, when bolted to a sturdy flat bracket, I think that the preload plate is not necessary, which will save some more space.
hunter29
Report this Post10-22-2024 08:48 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
So how does the f23 take twice the torque it's rated for ? Or can it...
[This message has been edited by hunter29 (edited 10-22-2024).]
ericjon262
Report this Post10-22-2024 10:34 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
well, I can't tell if this is a real question, or another person trying to say the F23 is junk. Mine has gone 12.749 at 109MPH in the 1/4 mile with no issues. Just because something is rated for XXX doesn't mean it won't take XXXX+
Trinten
Report this Post10-22-2024 11:54 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Because GM doesn't rate their transmissions at their actual failure levels. The guy doing all the hard work on my car was an engineer for GM/Saturn, IIRC, he said that the design engineers get the spec sheets on what the engine is likely going to produce. They then try to make a transmission that will handle that power reliably as affordably as they can, plus a power safety margin. There is of course a margin of failure expected (it's baked into the cost of the car which pays for your warranty).
When the test beds are built, they beat the hell out of them - engine and transmission. Some bench testing is done, though (at least when he was there) they had warehouses where they would put pre-production cars on setups to beat the heck out of the entire car - this was to make sure projections for warranty and such would hold up, which includes the engine and transmission.
So how do they come up with the max supported power? By looking up the most powerful engine they plan to put it on, add on a portion of their safety margin, and stamp it. They do not test the transmissions to failure, because they don't need to. They only need to make sure they're going to hold up to what they're throwing at it.
This means that now and then the designers crank out an affordable design that can also take way more of a beating than they are ever going to throw at it.
The Ford 4R70W is another great example of this. Jerry Wroblewski was one of the engineers who designed it. He was told it was going in a Thunderbird, behind a V8, in a 2+2 configuration. So he was thinking "oh, competition for Pontiac", so he designed an affordable, sporty transmission that could take some licks. Ford saw the specs and were like "Ohhh. Um, no. Sporty-like grocery getter, man. Detune this thing." so the valve body was detuned, springs changed, and I *think* some materials downgraded. After it came out, he wrote up a paper (called the J-mod) which was step by step instructions on how to return the transmission to what he designed, for the T-Bird guys that were throwing on superchargers and such on their cars. He knew it could handle a lot more than they were throwing at it. Last I heard, one of the guys in that community was pushing around 700HP through it, only parts changed were the input shaft, a "sundial" (wtf that is), and of course the guided changes to the valve body.
Then you have the other side of the spectrum, where there are transmissions that can hold more HP, as long as you aren't torque loading the hell out of it; the classic 'grenade' concept when you start adding any kind of power.
Total ratings: 236
Report this Post10-23-2024 07:55 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM doesn't really "rate" things like that because they don't care what we do with it once it's out of warranty. They have analyses of what the transmission can handle, both in terms of torque and vehicle weight and stay within those limits.
However, those limits are based on GM's tolerance for warranty claims from component failure. GM has the institutional experience and production volume to come up with quite robust statistics on potential warranty failures.
We are willing to tolerate more risk of failure of these parts than GM is, so we can use them with much higher limits.
Also, as technology advances and cars become better, engineering standards go up. Stiffness in cases and housings is no longer driven by the loads they'll see in operation, but by the need to reduce NVH to keep the product competitive in the marketplace. Compare an F23 to a 282 and you'll see that the F23 has FAR more extensive ribbing and bracing on the right side of the diff housing. Coincidentally, one of the 282's most common failure modes is breaking the right diff bearing out of the case.
This stiffness driven design results in much stronger assemblies than strength driven design. The F23 is clearly a stronger transmission than the 282, yet was used in vehicles of similar size and power to those the 282 was used in.
pmbrunelle
Total ratings: 63
Report this Post10-23-2024 11:08 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is hard to select a “rating” as such, it depends on the life desired in each gear. Typically, tests will not only be conducted at maximum torque; some failures might be uncovered more with high cycles of lower torque.
Here is an interesting article about the smoothness of engine torque:
http://www.epi-eng.com/pist...m_piston_engines.htm
I was wondering how I could have broken my Muncie with my V6 while the Muncie seems to have a good reputation on this forum. V8s are popular and seem to hold up with Fiero transmissions, but the torque delivery is smoother with more cylinders.
So apparently a “torque rating” would depend on the number of cylinders.
Also, the evening before my Muncie broke, I was having a bunch of misfires. I don’t know if misfires actually disrupts the rhythm and increases the peak torque at some point in the rotation.
I may need to superimpose the single-cylinder torque curves and see what happens with a V6 with a misfire, like how they did on the website.
What does it mean when we say “stiffness-driven” design for NVH? Does this mean that misaligned gears are more noisy than gears which remain correctly positioned with respect to one another? So the case and shafts are designed with a max misalignment target?
Load capacity of gears that are well-aligned is better than for crooked gears. So this is perhaps a happy side-effect for the hot-rodder?
Total ratings: 236
Report this Post10-24-2024 07:34 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
No try it with a Harley!
Yes, that's why V12's are renowned for their smoothness. Also, torque from firing a cylinder falls off quickly as the crank continues to turn. The closer the firing interval in degrees, the less torque from the prior cylinder falls off before the next cylinder fires and the smoother the engine is.
Assemblies are designed for high enough stiffness to keep resonant frequencies away from excitation frequencies to result in quieter operation. Yes, a happy side effect is that the extremely stiff assemblies are also extremely strong. That's why so many modern engines can handle >30psi of boost... at least for a while.
[This message has been edited by Will (edited 10-24-2024).]
hunter29
Report this Post10-25-2024 09:18 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, yes a serious question as i'm planning a swap..
Much appreciated...
Trinten
Report this Post10-25-2024 11:04 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Hunter,
I can tell you that I, and others, have definitely put some pressure on the F23. Jncomutt has done repeated clutch dumps, I've pushed mine on the quarter mile track. It's a solid transmission.
Best advice? If you rebuilt it, or have a shop do it, definitely make sure they 'shim' the shafts correctly. There was a few TSBs on this transmissions, and I understand one of them was around shims to deal with noise, and if you "over-shim" it, it stresses the bearing and the bearing goes boom. Outside of that, I think the only F23s that have died are in cases where the axle snapped and swung around, cracking the case apart.
In a race situation, 1st gear is useless. In daily driving, 1st gear is only marginally useful... but still a great transmission. If I could tolerate having a manual again, it would be in my current build.
Total ratings: 236
Report this Post10-26-2024 08:17 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't one of the turbo 3800 users break the left bearing boss off his diff carrier?
Also, it uses the stock Fiero manual transmission inner CV joints. I've broken one of those with a 282.
pmbrunelle
Total ratings: 63
Report this Post10-26-2024 10:05 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I work on smaller parts (not entire engine or trans); usually the OEM gives a vibration spectrum (intensity, frequency), and then our component is expected to remain intact/functional after being exposed to said vibration. So this is more typically about durability/breakage.
For the smaller parts, there are no vibration-related requirements about the parts resonating and becoming noise radiators.
I expect more pickiness about noise as (quiet) electric takes over. In the powersports world, the engine is loud enough to mask a lot of unwanted noises.
[This message has been edited by pmbrunelle (edited 10-26-2024).]
pmbrunelle
Total ratings: 63
Report this Post10-26-2024 10:09 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
pmbrunelle
Member since Sep 2008
I saw a stripped something in a facebook group recently in a Getrag F23, not sure if it was a final drive pinion.
Report this Post10-26-2024 10:18 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Justin had a couple of failures:
Justin had an output shaft bearing failure:
Originally posted by Justinbart:
He also had a differential carrier housing failure:
Broke the Differential.
Took a video of how loose the diff was before I pulled it off and seen how broken it was
A testament to the case strength of the F23 is neither of these broke the case.
hunter29
Report this Post10-26-2024 10:43 AM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Hunter,
Thanks.....
pmbrunelle
Total ratings: 63
Report this Post11-14-2024 10:15 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
For information, Roger Thelin now sells a front transaxle bracket that is meant for the GM Metric transaxle.
https://thelinsells.limited...bracket-number-three
Here it is on my 2000 Sunfire 2.2 OHV transmission:
Some tweaking may be needed to fit it in place.
Report this Post11-16-2024 10:24 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't want to hijack this thread, but would any viewers happen to have a good clutch release fork for an 86 or 87 Getrag? PM or email me if you do.
Total ratings: 236
Report this Post11-16-2024 12:00 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you help him design it?
Looks like it needs some work... unless you haven't snugged the far bolt.
[This message has been edited by Will (edited 11-16-2024).]
pmbrunelle
Total ratings: 63
Report this Post11-17-2024 11:04 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, Roger already had this bracket ready to ship on his shelf when I contacted him.
Some tweaking (cutting/welding/bending) will be needed to get everything to line up I think.
Also, some welds (with poor penetration) should be cut and re-done.
That said, I think that the bracket is still a time-saving starting point.
Kameirocco
Report this Post11-26-2024 04:42 PM Click Here to See the Profile for KameiroccoSend a Private Message to KameiroccoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all - i'm trying to locate a copy of the PDF that was listed - does anyone have that handy? seems to have disappeared
was hoping to get 2 things answered.
1) does anyone have photos or a diagram of the shifter cable adapter? i've seen a few different variants
2) I had heard that some 75" push/pull cables would work just fine instead of the brackets. is this true?
pmbrunelle
Total ratings: 63
Report this Post12-09-2024 08:34 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed a new Centric 13862019 HTOB in my F23 (bleeder assembly installed, and bleed screw cracked open), and I measured the following bellhousing-to-HTOB distances:
Retracted: 2.634"
Extended: 1.814"
Is this normal? With my pressure plate fingers at 2.548" from the bellhousing (Spec 3+ for the Muncie), I don't have much room for wear before the HTOB bottoms out and begins pressing on the clutch.
Are the aftermarket HTOBs all over the place in terms of measurements?
Should I try with another brand of HTOB? From Rockauto photos, it appears that a number of brands are repackaged "FTE" HTOBs, including Centric.
pmbrunelle
Total ratings: 63
Report this Post12-22-2024 01:59 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
For information, here are the distances for a Perfection Clutch 900067 HTOB, in my F23:
Retracted: 2.564"
Extended: 1.859"
It is of a slightly different construction; the aluminium is coloured black. The range is less on both ends, so I do not reccomend this HTOB.
pmbrunelle
Total ratings: 63
Report this Post04-07-2025 08:40 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just ordered some F23 shifter centering springs from Century Spring.
I thought the stock F23 centering action (to bring the shifter into the 3-4 plane) was a bit too weak, especially with my non-ideal shifter linkage that I have planned for the F23 installation in my Fiero.
Stock 2.2 OHV Sunfire F23 shifter shaft axial force:
When pushing towards 1-2: 5 lb
When pushing towards 5-R: 8 lb
Here are some alternatives to the stock springs I suggest (these are Century Spring part numbers):
1-2: 11643CS 17.3 lb
5-R: 1867CS 19.3 lb
5-R (stiffer alternative): 10751CS 28.6 lb
On some cars with the same 5-speed pattern, I noticed that the centering spring force isn't symmetric; the spring force is higher on the 5-R side. I am not sure why this is the case; perhaps because 5 and R are less frequently used than 1 2 3 4, so this forces a more deliberate action to go to the more rarely used side of the shift pattern. Anyway, I included a stiffer alternative for 5-R to emulate that behaviour if desired.
pmbrunelle
Total ratings: 63
Report this Post04-09-2025 10:57 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
***WARNING***
Century Spring recommends a "Suggested Max Deflection" for each spring they sell:
When used in an F23, two of the spring alternatives I suggested will be used beyond their rated deflection.
11643CS 113.9%
1867CS 94.6%
10751CS 106.7%
Of course, Century Spring likely adds some margin to the ratings, and these springs won't be cycling from zero to full deflection (which is less bad for fatigue)...
I am not experienced enough with springs to say exactly what could happen. Maybe the springs could lose force after some number of cycles, or possibly break. I think it's worth a try; I'm doing this on my Fiero.
The F23 was designed with soft centering springs, so when fitting stiffer springs in the same physical space, it is only natural that the springs will end up with high working stresses.
To install the springs, first remove the shifter assembly from the transmission.
Then, push out the roll pin and pull the shift lever.
Then, remove the cast aluminium piece.
From here, compress the spring cup in a vise to make the snap ring accessible:
Remove the snap ring from the shaft, and then the springs will come off.
Installation of new springs is the reverse of removal...
The 1-2 spring bears on a plastic seat. Initially, I was concerned that the plastic part might break from the increased load of the stiffer than stock spring. However, the plastic part was marked "PA66-GF30". By my evaluation, the plastic spring seat should be OK with a stiffer spring.
[This message has been edited by pmbrunelle (edited 04-09-2025).]
pmbrunelle
Total ratings: 63
Report this Post05-05-2025 10:57 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
What connector series do the VSS and back-up light switch connectors belong to?
I would prefer to buy separate housings, terminals, cable seals, etc, rather than automotive aftermarket ready-made pigtails.
Trinten
Report this Post05-06-2025 09:33 AM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a great question. Sometimes I get lucky with doing some Googling about a sensor connector type, but not always about pigtails. You may want to send Will or FieroGuru a PM. They are an amazing wealth of information, including with electrical connectors - probably because they put so much time and thought into their wiring setups. If they do know, please post the answer up here, it'd be good information to have!
Total ratings: 236
Report this Post05-07-2025 07:58 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should be GM Metri-pack 150's... I can check on my F23's this weekend.
You can download the Delphi/Aptiv global catalog here: https://www.tti.com/content...systems-catalog.html
And then look up all the connectors and contacts you'll need.
[This message has been edited by Will (edited 05-07-2025).]
ignorant prodigy
Report this Post06-09-2025 06:00 PM Click Here to See the Profile for ignorant prodigySend a Private Message to ignorant prodigyEdit/Delete MessageReply w/QuoteDirect Link to This Post
hey fella's,
been trying to find that service video online and it seems some things dont live forever on the internet.
few years back I bought a junkyard transmission. mistakes were made and I took their word that it worked good.
when I did install it, I had a hell of a time getting the shifter mechanism back into the housing. I stuck my finger down there and moved a bunch of stuff around, and eventually got it to sit inside.
my ignorant question is: do you think it would it be possible to potentially install that shifter mechanism in such a way where I don't have 1st or 2nd gear (intermediate shaft I presume?)
I have reverse, I have 3rd.. didnt try 4th or 5th.
not really looking forward to swapping in a new transmission, I'm in denial but hoping you guys will cheer me up and say it is possible.
pmbrunelle
Total ratings: 63
Report this Post11-13-2025 07:57 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I did this recently. I wasn't able to engage 1st or 2nd. I could reach all other gears.
This is with a correct, very thin layer of Loctite 518 anaerobic sealant to seal the shifter cover to the case:
Previously, I applied too much Loctite. When I tightened down the cover, the Loctite was forced into the 1st/2nd shaft area, and then the shaft was locked up.
To make it work again, I had to take off the shifter cover, scrape off whatever Loctite I could, and then use heat (in the shaft area), which smacking on the end of the 1st/2nd shaft with a drift punch. Eventually the shaft wobbled loose, and the bushing popped out from the recoil. Then, I was able to clean the parts and reassemble correctly...
For information, the 1st/2nd shaft comes out through the shifter hole; case disassembly is not required to remove it.
pmbrunelle
Total ratings: 63
Report this Post11-13-2025 08:02 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
pmbrunelle
VSS: Metri-Pack 150.2 series, pull-to-seat
Connector: 12162193
Crimp terminal: 12124075-L
Reverse: Metri-Pack 150 series
Connector: 12052641
TPA: 12052634
Cable seal: 15324973
Crimp terminal: 12048074-L
