Update System
  13" Brake Rotor Upgrade for the 88's (Page 4)
13" Brake Rotor Upgrade for the 88's by fieroguru
Started on: 10-26-2011 08:08 PM
Replies: 231 (9942 views)
Last post by: fieroguru on 09-07-2013 08:17 AM
Greenmeansgo
Report this Post12-19-2011 11:01 PM Click Here to See the Profile for GreenmeansgoSend a Private Message to GreenmeansgoEdit/Delete MessageReply w/QuoteDirect Link to This Post
So , what caliper is this?
Total ratings: 465
Report this Post12-19-2011 11:04 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock 88 calipers.
88 car.
Sourmug
Total ratings: 144
Report this Post12-19-2011 11:32 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the review Raydar.
fieroguru:
The kit looks great. When will this be available?
Thanks
Nolan
[This message has been edited by Sourmug (edited 12-19-2011).]
Report this Post12-20-2011 08:46 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need to revise a couple things in the installation instructions based on Raydar's feedback and then drill the rotors and finish fabricating the parking brake hardware for the first 3 kits. Once this work is done, I will have 3 completed kits ready to ship and will approach the people who have stated they are interested to see who is ready to buy a kit now. The challange is timing... with Christmas here, disposable income will be tight for most, so the first 3 kits will go to the people with cash ready to buy.
Once the first 3 kits are sold, I will start a thread in the mall to sell more kits.
For wave 2, I am probably going to require a $100 to $250 deposit at the time of order, and balance required when the kit is ready to ship. The machine shop lead time is about 1-2 weeks and the rotors are about 1 week as well. I would like this 2nd wave to be as large as possible to fill all current orders and keep the brackets/rings for 5-10 kits in stock for future orders. The rotors are the most expensive part and with there currently being 3 rotor options, I am not planning to keep the rotors in stock (as doing so would just wrap up too much of my limited R&D fund for all my fiero projects).
[This message has been edited by fieroguru (edited 12-20-2011).]
blakeinspace
Total ratings: 120
Report this Post12-20-2011 11:06 AM Click Here to See the Profile for blakeinspaceSend a Private Message to blakeinspaceEdit/Delete MessageReply w/QuoteDirect Link to This Post
awesome Paul... Awesome...!
I have the 12" vette set up on my Formula that I am quite satisfied with, so sadly I will not be your customer... but thank you so much for the effort and innovation you showed to upgrade and modernize our cars.
I know it has been mentioned before... but I will re-cap again why I think this route is better than the 12" vette route:
1) inncreased leverage stopping power
2) removes any LCA interference (is easly corrected with 2 minutes and a grinder on the vette set up, but still...(mine was on the drivers left side)
3) no brake hose routing issues (my front passenger braided hose was too short at full lock on the vette set up)
only 'drawbacks'/quirks? for the 13" setup (for lack of a better term)
1) probably have to use 17" or larger wheels
2) additional step with the e-brake (not required when you go the 12" route)
3) more unsprung weight
It's a no brainer to me... I would go to 13" just for looks!... much less the other advantages mentioned!
<---- did you buy Cliff a beer?
......................................................www.northtexasfieroclub.org
ALJR
Report this Post12-20-2011 11:16 AM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
I am so one the fence at the moment with the set-up...
Two things that I am trying to convince myself that they are no big deal:
1) The thin-ish adapter brackets - Would like someone to really put these larger rotors to the test to make sure the brackets do not bend/tweak. I do understand the direction the force it being applied, but I also know about leverage. The fact that these brackets move the caliper further away from the center only componds that effect. I also understand the brackets are as thick as they are to get proper alighnment...
2) The diamater of the rotor "hat" looks rather large - Quite a bit of it is visable through the wheel, or at least would be visable through the wheels im using (ASA AR1's)...
Ohh man, decisions decisions
[This message has been edited by ALJR (edited 12-20-2011).]
Total ratings: 465
Report this Post12-20-2011 12:44 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can address these.
I, too, was a bit concerned about the brackets, until I had them in my hands. If I was still concerned, I would not have installed them on my car. (Remember, I already had a Corvette setup, with the second design brackets, sitting on my bench.)
They're pretty much as thick as other brackets. (If not, they're very close.) Much thicker than Paul's original mock-ups, pictured early in the thread.
In any event, if there is an issue, I'll share. I plan to drive the car frequently, so I should be on top of it.
That hats are pretty large.
I don't think they look bad, however. I posted some close-ups, above. I'll try to get some more pics of the car from a longer distance.
OTOH, the rotor fills up the space behind the wheels, nicely. Looks perfect with the 17s.
I thought about painting the hats, but I like the way they look. I may clear them to stop them from rusting.
ALJR
Report this Post12-20-2011 01:40 PM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, they do fill nicely
Painting the hats is an option I was/am considering; actually powder coating them if I can find some high enough temp powder...
How thick are the brackets? They only look a 1/4" or so... Are you also using nuts to hold the caliper on, or just the threads in the bracket?
mattwa
Total ratings: 88
Report this Post12-20-2011 01:57 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you tried to bend 1/4" steel plate? Not very easy. Plus, like you said, that is not even the direction of the stresses they are taking, bolts would snap from sheer loading before then.
Report this Post12-20-2011 02:40 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The brackets are 5/16". Currently the brackets are tapped w/o nuts. I have them and can send them if someone wanted to use them on the backs, but the brackets have no issue holding the 74 lb-ft torque for the caliper bolts w/o the nuts.
Alex4mula
Report this Post12-20-2011 04:06 PM Click Here to See the Profile for Alex4mulaSend a Private Message to Alex4mulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
.. actually powder coating them if I can find some high enough temp powder...
Not high temp needed. I powder coated my stock ones with regular powder 6 yrs ago and had no issues at all. I will do the same when I get these.
Total ratings: 465
Report this Post12-20-2011 06:48 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was one who asked about nuts, before I saw the brackets. (I posted earlier in this thread.)
Now that I've seen the brackets, I'm comfortable with them, as is.
ALJR
Report this Post12-21-2011 11:34 AM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, thats good to know...
jscott1
Total ratings: 415
Report this Post12-22-2011 11:32 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Zinc coated rotors should not need paint or powder coating. I have zinc plated on my GT from at least 8 years ago and they are still shiny. One thing I hate is rusty rotors, so I will be going with zinc.
ALJR
Report this Post12-22-2011 12:41 PM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
You Sir, have never seen a New England winter
Granted I do not drive my Fiero in the snow; the salt remains long after the snow is gone. Takes several good rain storms to wash it all away. I have not had very good luck with coated rotors, the constant salt spray combined with numeriour heat cycles kills the coating... Not that PC is "better", it just lasts longer...
jscott1
Total ratings: 415
Report this Post12-22-2011 01:13 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
You Sir, have never seen a New England winter .
Lol, I wish that were true... I grew up in western NY.
However, you are correct that my GT has never seen snow, let alone road salt. But I am impressed that after 8 years, not a sign of rust. I wish I knew what kind I bought, but they were generic ebay coated rotors.
MstangsBware
Total ratings: 459
Report this Post12-22-2011 06:41 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
They will not rust as long as the car is sitting in the garage...It's been 8 years since I seen your GT at a show....J/K....but would be nice to see you at a show this coming year....
ace5514
Report this Post12-23-2011 12:56 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
WOW...you Texans play rough....and right before the holidays....lol
Report this Post12-24-2011 03:07 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been working on the inventory of parking brake hardware. I have 9 cable sleeve extenders completed and 14 longer cable couplers in the fabrication stages. By Monday I should have the first 3 kits 100% complete and ready for new owners, the 4th kit just needs rotors, then I will need to setup a group buy for phase 2 of the bracket/ring orders.
Cable Sleeve Extenders:
Longer Cable Couplers - these are a fair amount of work...
Cut the sleeve from mild steel to the proper length - used the lathe to keep the ends true.
Turn a lip on the nut so it will be centered in the sleeve:
Staging for welding:
Clamp the ends into the tube and tack weld the ends:
Weld the ends solid and let them cool:
I still need to turn down the excess weld on both ends, mill the center slot for the barrel ends, cut the cable slots through the nuts, and then paint... As you can see these cable extenders are quite involved
[This message has been edited by fieroguru (edited 12-24-2011).]
Report this Post12-24-2011 06:50 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Aug 2003
Excess weld turned off the couplers:
In the mill to cut the barrel slot:
Here they have been deburred and are ready for the cable slot:
Double up on the cutoff disc to get the right width for the cable slot:
Here are the first 4 cable connectors:
Now I just need to paint these and the brackets for the first 4 sets...
ALJR
Report this Post12-24-2011 11:57 PM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
Those cable connector sleeves do look labor intensive! But they came out nice...
What is the purpose of welding nuts on either end? Is it to just decrease the i.d. of the tube so the cable does not pull through?
Just a sugestion and this may not even be fesable or easier; but why not use a smaller piece of sleeve with thicker wall (to get a smaller i.d.) and slide it into either end of the cable connector sleeve. weld it in place via two puddle welds on either side; then do your milling and slot...
Report this Post12-25-2011 06:54 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the nuts create the lip to keep the barrel from sliding through the coupler. There are several ways these could be made, but the nuts work well.
ALJR
Report this Post12-25-2011 11:07 PM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, they do look like they are strong... Just tossing a suggestion out there to maybe make them easier/faster. Your 13" upgrade is well thought out and I would have to imagine once all the testing is dune and a few of these are out there, this wil be the defacto upgrade "kit" for the 88's
Total ratings: 465
Report this Post12-25-2011 11:20 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing new to report.
Drove all over town, last week. Used the Fiero for my last minute shopping and grocery grabbing.
The only thing I can say about the brakes is that in normal use, you don't even know they're different from stock. They're unobtrusive. They just work better.
I still haven't gotten them hot enough to try to make them fade, but it's been raining here for several days.
If there's anything in particular that Paul, or anyone else, wants me to pay attention to, I'll be happy to oblige, if I can.
Alex4mula
Report this Post12-26-2011 10:51 AM Click Here to See the Profile for Alex4mulaSend a Private Message to Alex4mulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
.. I would have to imagine once all the testing is dune and a few of these are out there, this wil be the defacto upgrade "kit" for the 88's
You are still on the fence and seems to want more people to test this before you are convinced. If Paul is putting these out it is becasue he is convinced and looking at his work/ethics that is more than enough for me. I'm getting one of these first kits. Will tell you soon how much I like them
FieroMaster88
Total ratings: 168
Report this Post12-26-2011 12:14 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm excited to get my kit. Finally I'll have some nice brakes behind my 18 inch wheels.
88 Coupe: 2.0L Turbo 4 Cylinder
84 Indy #64: Restoration Project!
ALJR
Report this Post12-26-2011 01:55 PM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
Just looking for some extreme performance testing
My stock 88 brakes (actually brand new everything) work well under normal driving. But once hot or pushed to the edge, my confidence in them stopping my Fiero "in time" drops exponentially... If I am going to replace my new stock brakes, I just want to make sure it’s going to do what I want them to do...
Not to mention I have to get my 3800 in and all sorted out first; so I am in no rush
[This message has been edited by ALJR (edited 12-26-2011).]
Alex4mula
Report this Post12-26-2011 03:49 PM Click Here to See the Profile for Alex4mulaSend a Private Message to Alex4mulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hear you. This also came a little late for my GT. I just installed everything new so no plan to upgrade that one. Maybe in 2+ yrs at the rate that I drive these.
Report this Post12-26-2011 09:34 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I said earlier, here are the first 3 completed kits ready for purchase (and the 4th just missing the rotors - and it will be the first kit with the plastic rings):
I have been in the process of approaching the people who were first interested in this kit and giving them an opportunity to purchase one of these first 4 kits. So far I am please to say that Alex4mula and FieroMaster88 have claimed their kits and payment has been received.
This is FieroMaster88's kit right before I boxed it up:
ALJR
Report this Post12-26-2011 09:39 PM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
Damit, STOP posting pics of the Fiero candy! Your gonna make me spend money I don't currently have
BTW, did you get this posted in the mall section yet?
Report this Post12-26-2011 09:57 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
But I like posting pictures!!!
I have not started the mall thread yet. My plan is to get these first 4 kits sold, then I will start a phase 2 purchase thread in the mall.
Report this Post12-26-2011 10:06 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't ever leave well enough alone... This kit adds some additional weight vs. the stock fiero rotors and the drilled/slotting reduced this some... but I want less.
These rotors are from the rear and are originally setup for a drum style parking brake setup. As such, there is a small protruding lip of drum material on the back side that doesn't need to be there for a fiero application.
I was curious how much weight I could reduce by removing this lip, so off it came, and off came 5.2oz.
Granted 5.2oz is only about 1/3 of a lb. so it isn't much weight, but it also opened up the air path to the center of the rotor... Given the machining time involved to perform this modification, if I offer it on the kits, it will be a $50 to $100 option. I am pretty sure I will be doing this modification for my personal sets, just don't know if the weight savings will justify the additional cost for most people.
Total ratings: 465
Report this Post12-26-2011 10:16 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paul...
You mentioned that the drilled/slotted rotors were zinc coated, I think?
Are the solid ones coated as well?
I'm trying to decide if I want to paint the hats.
[This message has been edited by Raydar (edited 12-26-2011).]
Report this Post12-26-2011 10:28 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paul...
The solid rotors are not coated. They should be painted to keep them from rusting.
FieroMaster88
Total ratings: 168
Report this Post12-26-2011 11:24 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can't wait to get my kit! It looks awesome!
Total ratings: 465
Report this Post12-27-2011 12:15 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Paul.
[This message has been edited by Raydar (edited 12-27-2011).]
Report this Post12-27-2011 07:11 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been working out the final details for the last 2 kits.
While that has been going on, also been working on the Mall thread (to be posted shortly), ordering more brackets and rings and getting setup to have everything but the rotors for 25 more kits by the middle of January.
It looks like these kits will officially go on sale January 15th (so start saving your $$$ now), and I am considering selling hardware kits (everything but rotors), but only after I have 15 confirmed buyers for the hardware kits. These kits will make my rotor selection public knowledge and locking in 15 kits will ensure I recover my substantial costs to developing this kit.
The new kits going forward will have the plastic expandable concentric ring vs. aluminum rings. Here are some sample pictures of the kits with the plastic rings:
Here is a pic of the potential hardware kit:
[This message has been edited by fieroguru (edited 12-27-2011).]
85sliverGT
Report this Post12-27-2011 10:51 PM Click Here to See the Profile for 85sliverGTSend a Private Message to 85sliverGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the hardware kit! How much do you anticipate it costing?
Report this Post12-28-2011 06:41 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The hardware kit will be priced at $350 shipped (US and Canada). For this to be offered, I need 15 buyers. The mall thread for purchases is here:
https://www.fiero.nl/forum/Forum4/HTML/060122.html
For those interested in a hardware kit, but concerned about drilling the rotors, I will be posting a DIY write-up this evening on how to drill the rotors using an old wheel bearing and a 1/2" drill bit.
[This message has been edited by fieroguru (edited 12-28-2011).]
mattwa
Total ratings: 88
Report this Post12-28-2011 01:00 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes please, that would be very helpful.
