  My 88 Fiero GT 14k miles (Page 15)
This topic is 49 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49
My 88 Fiero GT 14k miles by BV MotorSports
Started on: 03-16-2012 02:48 PM
Replies: 1936 (68536 views)
Last post by: BV MotorSports on 01-13-2017 07:45 PM
BV MotorSports
Total ratings: 189
Report this Post10-05-2012 11:46 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by BV MotorSports (edited 10-14-2012).]
darkhorizon
Total ratings: 451
Report this Post10-05-2012 04:40 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by nosrac:
Plugging as in driving or fixing? I have the same pump (Brand Spanking New) that I would have sold you for next to nothing but you were too fast on the draw.
I didn't need it as I ended up copying how D H routed his setup.
I am looking for a turbowerx for my trailblazer!!! PM me!
mptighe
Total ratings: 122
Report this Post10-05-2012 04:59 PM Click Here to See the Profile for mptigheSend a Private Message to mptigheEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by BV MotorSports:
Just fixing things. Hopefully I will be driving it today. Just depends on when that stupid pump arrives. 5 days from TX seems awful long for shipping......
Texas via Hong Kong! lol
BV MotorSports
Total ratings: 189
Report this Post10-06-2012 02:10 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pump is in. I went into town and had some outrageously over-spec lines made for the oil return. I pulled the crap Pep Boys filter that Dean installed and put on a big K&N filter. Now I'd like to say I was surprised, sadly I am not, there were all kinds of trash & metal shavings INSIDE the filter.
BV MotorSports
Total ratings: 189
Report this Post10-06-2012 02:35 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
Member since May 2001
P0300
P0134
P1673
Got those on my way to get the car aligned. its running like dog doo-doo. Spits, sputter, hesitates and the CEL is flashing.
oh yeah.. still smokes too.
DavePatron
Report this Post10-06-2012 02:43 PM Click Here to See the Profile for DavePatronClick Here to visit DavePatron's HomePageSend a Private Message to DavePatronEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow i love those black wheels, really makes it look aggresive
Tattoo Training
BV MotorSports
Total ratings: 189
Report this Post10-06-2012 02:54 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Dave. I forgot how small these are on the road. Even a Prius towers over it.
Justinbart
Total ratings: 119
Report this Post10-06-2012 04:40 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
What do you men running like poo? Idle, part throttle, boost? I would start with checking plug wires. What spark plugs are in there? Check for cracks etc.
I spy something missing in this pic, lol.
Turbo 3800 E85 F23 5spd spec5
11.54@132.7
nosrac
Total ratings: 51
Report this Post10-06-2012 06:21 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
P0300 Caused by the Big Cam and Needs to be removed from the tune.
P0134 Probably need to disable the second O2 bank.
P1673 Not sure what the hell that one is.
Spits, sputter, hesitates MAYBE because of low IAC setting should be set @ 900 for ST2 cam or Maybe because O2 sensor is NOT working
CEL is flashing because of misfire P0300.
oh yeah.. still smokes too .probably need a oil feed restrictor for the smoke problem
[This message has been edited by nosrac (edited 10-06-2012).]
BV MotorSports
Total ratings: 189
Report this Post10-06-2012 06:31 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder what?
Idle, tip in, part throttle, you name it. Only time it runs decent is when its cold or above part throttle. I am going to move the coil pack and wires to more of an original set up. I dont like the wires routed the way they are.
BV MotorSports
Total ratings: 189
Report this Post10-06-2012 06:34 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
nosrac
Total ratings: 51
Report this Post10-06-2012 06:41 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I may have to try one. When I called Precision Turbo they said not to use one and just use a -4 oil feed.
I have a Precision too and used this restrictor. No smoke and works well so far.
http://www.ebay.com/itm/Gar...&hash=item3a7a31dcde
nosrac
Total ratings: 51
Report this Post10-06-2012 06:47 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
Member since Jan 2005
P0134 - What does the scanner read for the O2 sensor? It should constanly change, about 4 times a second, and be all over the map, IIRC.
Spits, sputter, hesitates ....LOL you gotta break dat horse in....in other words tune it properly.
BV MotorSports
Total ratings: 189
Report this Post10-06-2012 08:25 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am getting fed up with this car.
nosrac
Total ratings: 51
Report this Post10-06-2012 08:56 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I spoke with Charlie.. he makes his own restrictors using NOS jets. He makes them per application. He is coming tomorrow to DL the tune to get a head start for Tuesday. *fingers crossed* it goes well with the tune. I am getting fed up with this car.
I assume he has HP Tuners and I'm not sure if you have a DHP tune in yout PCM. You may not be able to DL it.
The tune is not hard if you know what to do or start from a good base.
Be sure to get a mini or Fixed freq AFC from ZZP or you will run out of MAF and blow it up.
BV MotorSports
Total ratings: 189
Report this Post10-06-2012 10:05 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
darkhorizon
Total ratings: 451
Report this Post10-07-2012 11:42 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC the car has a base map in it with HP tuners. 1st I have heard about the AFC bit. I'll look into it. Is there a big MAF conversion for our application?
No maf conversion is worth it... Get the afc. more info below.
It will smoke from build up stuck all over in the turbo... just wait for it to go away after 20-30 miles. Dont use a restrictor.
Bad spark of some sort... wires/plugs/coils.... Or its just WAY too rich. This will cause a flashing cel.
Dont try to "tune" this car or put it on a dyno before you have it driving around... or you will just be in for a giant shop bill trying to get it running right on the dyno, only to make some useless "tuning" runs as you will need to change out the maf setup soon anyway.
BV MotorSports
Total ratings: 189
Report this Post10-07-2012 01:05 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drove the car into town (20min each way) and there was no noticeable reduction in the amount of smoke coming out of the exhaust. Either its so rich that its washing the cylinders and preventing the rings from seating, or there is a issue in the valves or turbo seals. That's my best guess.
I just need to see whats going on with the tune before getting too crazy with it. I will look into the MAF/AFC as well.
Thanks guys...
[This message has been edited by BV MotorSports (edited 10-07-2012).]
Justinbart
Total ratings: 119
Report this Post10-07-2012 02:23 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
You NEED to get the AFC, all mechanical issues need to be fixed and boost leak checked before it sees the turner.
11.54@132.7
BV MotorSports
Total ratings: 189
Report this Post10-07-2012 05:55 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worth stepping up to the Northstar kit by ZZP or S2 L67 TB?? Or should I just try the mini AFC or fixed mini AFC?
BTW Charlie Stump is a one stop shop kind of builder. He is well known for his late model turbo car builds.
darkhorizon
Total ratings: 451
Report this Post10-07-2012 05:57 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Justinbart
Total ratings: 119
Report this Post10-07-2012 06:55 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
AFC, ...bro.
Although I don't use the afc, just epoxy and scrap metal.
11.54@132.7
nosrac
Total ratings: 51
Report this Post10-07-2012 07:24 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Problem is the stock PCM can only read 11500 Hz so you HAVE to scale that back so the Turbo airflow wont exceed that value.
BV MotorSports
Total ratings: 189
Report this Post10-07-2012 08:13 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I read about that. I do not doubt you guys about the MAF issue. I am just curious if its worth getting the N* kit from ZZP.
nosrac
Total ratings: 51
Report this Post10-07-2012 08:50 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMO, Not worth it in a Turbo application unless you have a GenIII NA intake and the TB will better match the port.
Justinbart
Total ratings: 119
Report this Post10-07-2012 08:56 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no point in a larger throttle body when you have a huge restriction after it.
11.54@132.7
darkhorizon
Total ratings: 451
Report this Post10-07-2012 09:02 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could swap a 2.8 throttle body on if you wanted and not lose power.. Look at the outlet of your turbo....
BV MotorSports
Total ratings: 189
Report this Post10-07-2012 10:12 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL Fair enough.
IwannaIRM
Total ratings: 58
Report this Post10-08-2012 02:44 AM Click Here to See the Profile for IwannaIRMSend a Private Message to IwannaIRMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not to get too far off track of your tuning issues but why do you still have the old vaccum cruise control? If you are still using cruise control wouldn't it be electronic now? If you aren't using cruise control why is it still there?
Just curious.
BV MotorSports
Total ratings: 189
Report this Post10-08-2012 09:11 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't see anything wrong with the stock CC as long as it works. I have no idea if it does..... lol
BV MotorSports
Total ratings: 189
Report this Post10-09-2012 07:28 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dropped the car off with Charlie today. Here goes nothing...............................................
Update when I hear anything.
Justinbart
Total ratings: 119
Report this Post10-09-2012 07:40 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
good luck........ .......
11.54@132.7
BV MotorSports
Total ratings: 189
Report this Post10-09-2012 07:58 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks... I appreciate it! I just need to catch a break on this damn car.
Justinbart
Total ratings: 119
Report this Post10-09-2012 08:07 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worst case, you'll need a new short block and turbo. That's really no big deal.
11.54@132.7
BV MotorSports
Total ratings: 189
Report this Post10-09-2012 08:08 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it comes down to that, I will pull it all out and install a stock L67.
nosrac
Total ratings: 51
Report this Post10-09-2012 10:03 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put in a L36 and you would absolutely love it with the cam, IC, headers, and F23.
Anyhoo, hope the tuner can "dial" it in.
[This message has been edited by nosrac (edited 10-09-2012).]
BV MotorSports
Total ratings: 189
Report this Post10-10-2012 08:25 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dean is so f'ing full of **** . I swear that guy is a damn liar and I hate his worthless guts. Hey dumbass, the car was never going to run with a STOCK L67 tune with the 68# injectors, ST2 cam, turbo etc.
Worthless piece of dog sh*t!!!!!!!!!!!!!
All those that neg'd me over telling the truth about Dean... keep ignoring the facts, you'll be sorry if you let him touch your car.
1988holleyformula
Total ratings: 68
Report this Post10-10-2012 08:34 PM Click Here to See the Profile for 1988holleyformulaSend a Private Message to 1988holleyformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anything constructive for an update?
edit: VVV thanks Did he re-tune it for your turbo application then?
[This message has been edited by 1988holleyformula (edited 10-10-2012).]
BV MotorSports
Total ratings: 189
Report this Post10-10-2012 08:38 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Charile re-wired the oil & charge-cooling pumps to run off the fuel pump circuit or something like that. Now they wont run unless the engine is running. Thats a step in the right direction....
darkhorizon
Total ratings: 451
Report this Post10-10-2012 11:47 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
in fact it would never start, and it most likely wouldnt move very well.
