  My 88 Fiero GT 14k miles (Page 45)
This topic is 49 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49
My 88 Fiero GT 14k miles by BV MotorSports
Started on: 03-16-2012 02:48 PM
Replies: 1937 (68925 views)
Last post by: rbell2915 on 08-15-2025 10:26 AM
BV MotorSports
Total ratings: 189
Report this Post01-15-2014 04:37 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Justinbart:
You replaced a know good HTOB with a bad one?
I replaced the original unknown mileage HTOB with the new one SPEC supplied.
darkhorizon
Total ratings: 451
Report this Post01-16-2014 10:24 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Htobs really last awhile.... I would never replace one without checking everything either as there are 4 different htobs that are commonly used in f23s.
BV MotorSports
Total ratings: 189
Report this Post01-16-2014 02:29 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am hoping its just a defective part. I dont know why it would be anything to the contrary. The previous clutch worked great as you are aware from our tuning session. It did not use a HTOB spacer. I was told I needed the spacer with the SCS pressure plate (extra clamp). Nothing else changed. So either the part is defective or the spacer caused the HTOB to bottom out and it popped a seal is my best guess. Or it could have been damaged when SPEC installed the spacer. I just dont know yet. I am going to bolt the old PP to the flywheel and measure the installed height and compare it to the SCS PP. If they are the same, I will just put the old HTOB back in and call it a day.
I just have rotten luck with this car. it seems anytime I try to do the "right thing", it bites me in the ass. With that said, I will not give up. I know I will prove more stubborn than that inanimate object!
darkhorizon
Total ratings: 451
Report this Post01-16-2014 03:00 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Throw the old pressure plate away (figurtively), it wont tell you anything in regards to how your current one is setup. Just seperate the trans off and measure it.
The pressure plate fingers will be at their most compressed when first installed so it should be nearly the same measurement from fingers to block and bell housing to bearing.
BV MotorSports
Total ratings: 189
Report this Post01-16-2014 04:11 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found a thread on how to measure to get the exact range. I just need to calm down a bit before taking it back apart. Oh well, there are a few more things I wanted to "fix". lol
https://www.fiero.nl/forum/Forum2/HTML/127262.html
joshua riedl
Report this Post01-16-2014 06:49 PM Click Here to See the Profile for joshua riedlSend a Private Message to joshua riedlEdit/Delete MessageReply w/QuoteDirect Link to This Post
For what it's worth, I used the spacer with the same clutch you have. The measurement I found in another thread said to shoot for 2.5" from the clutch fingers to the bell housing surface. The clutch doesn't need a lot of travel to release so I have an over travel issue. I shortened Rodney's adjustable pushrod all the way and it's still not enough. I just don't push the clutch to the floor or it will re-engage. Something to look out for.
BV MotorSports
Total ratings: 189
Report this Post01-21-2014 09:43 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it all back apart. The HTOB did not over extend. I am not sure if it was defective or damaged when SPEC installed the spacer. It wasn't even on straight. :/ Should be back up and running by the weekend.
BV MotorSports
Total ratings: 189
Report this Post01-25-2014 12:39 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine is in, clutch works fine.
KissMySSFiero
Total ratings: 111
Report this Post01-25-2014 07:20 AM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was it just a defective part? Is this the first time you've had it together and running right?
SSFiero@Aol.com
BV MotorSports
Total ratings: 189
Report this Post01-25-2014 12:01 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats all it was. The new HTOB was either defective or it had been damaged by SPEC when they pressed on the HTOB spacer. BTW, I am not using a spacer this time. I can tell you the "super clamp" pressure plate, its definitely got a much harder pedal.
BV MotorSports
Total ratings: 189
Report this Post01-26-2014 09:54 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove the 88 for the first time in nearly 5 months. Went fairly well. 1 small oil leak at the oil pressure sensor. It was finger tight. Ooops! p0134 & P0717 codes. Forgot to plug in the 2nd o2 sensor. Not sure about the 0717 speed sensor code as the speedo works. So thats a new one. Its really rich and stumbles at 3500rpm like it did when I first got it. DH and I are gonna do another tune after I do a nut & bolt check and get it aligned again. Definetly can tell its not right after replacing all the bushings. Clutch... still isnt right. I had to space the MC away from the firewall to keep it from rattling when running with the clutch in. Its a band-aid but I am gonna drive it for a few weeks to try and and enjoy it again before ripping it back apart. OH yeah, and the Tial BOV is staying open at idle. So I got to get a stiffer spring for that as well.
[This message has been edited by BV MotorSports (edited 01-26-2014).]
darkhorizon
Total ratings: 451
Report this Post01-27-2014 08:44 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the tune seems different something mechanically is different. It would be unwise to try to fix (or unfix)a problem by just tuning around it.
BV MotorSports
Total ratings: 189
Report this Post01-27-2014 04:48 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
For sure Scott. I am poking around and checking things out. The o2 prob had a lot to do about it like we spoke about on the phone. I cant think of anything that physically changed that would effect the tune. But then, stranger things have happend. if you remember, this is the same problem I had when I fist got it. The 3,500 rpm stumble.
Justinbart
Total ratings: 119
Report this Post01-27-2014 05:45 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
What gear does the PCM think it's in?
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
BV MotorSports
Total ratings: 189
Report this Post01-31-2014 05:02 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed a few more little stupid problems. I don't want to say what they were, but they were totally on me. Car runs MUCH better. I still have more valvetrain noise than I think it should have. I am gonna check the pushrod length just to be sure. Got a package for a few more little things that need to be sorted today. Mostly ebrake related. I may even make Daytona this year... MAYBE.
darkhorizon
Total ratings: 451
Report this Post02-01-2014 01:24 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try to put a bit more care into checking your vital signs before seeing how well it runs at full boost. The margin for error on big horsepower non factory setups like this is still fairly large, but you do not have nearly the failsafes you would in a 100% factory configuration.
BV MotorSports
Total ratings: 189
Report this Post02-01-2014 08:51 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely. I am not going to even start it again till I can verify the pushrod length.
darkhorizon
Total ratings: 451
Report this Post02-02-2014 12:06 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
what are you expecting? Stock pushrods will be fine for stock rockers...
BV MotorSports
Total ratings: 189
Report this Post02-03-2014 07:47 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I spoke with Steve @ ZZP the other day. We were going over the order Whodumbass made for parts. There was no record of what lifters Dean used with the ST1 (yep, its an ST1 not ST2) cam. He said if I have stock lifters I should be OK. If dean used COMP's there could be a problem with the lash difference. Apparently COMP uses a smaller base circle. The valvetrain is too noisy IMO. So I would rather buy a $15 PR length checker and know for sure. Stock PR, unknown lifters, ST1 cam, milled heads? Stock rockers, ZZP retainers, LS7 "yellow" springs etc. Much mix and match going on.
Hand on heart, I have never had a car so problematic in my life. I'll never farm out work again.
darkhorizon
Total ratings: 451
Report this Post02-04-2014 12:17 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even if you have an OER lifter... You are not going to run into any sigificant problems. The OE non R lifters are ticky and noisy just because thats how it goes... You may also have an exhaust leak tick.
Even if you check lengths on things... You are not going to get any consistant readings across all 12 lifters enough to do any more than suggest a better pushrod length.
thirdly... with everything stock, you are probably looking at a possibly slightly too long pushrod, with a comp lifter you are looking at a possibly slightly too short pushrod... so the variance is going to equal out somewhere in the middle of slightly long or slightly short.... which is a good thing.
BV MotorSports
Total ratings: 189
Report this Post02-04-2014 07:11 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lets hope you are right. There is way too much valvetrain noise though. This one is way louder than any of my previous 3800's. The exhaust leak thing has crossed my mind a few times. I havent found any..yet but I haven't really looked that hard. I have mostly just checked the vbands like we spoke about on the phone.
PR checker arrived today. I'll report my findings tomorrow.
nosrac
Total ratings: 50
Report this Post02-05-2014 02:39 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I googled it 4 U.
http://noisylifters.com/
darkhorizon
Total ratings: 451
Report this Post02-10-2014 06:51 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
paranoia got the best of him.
Justinbart
Total ratings: 119
Report this Post03-06-2014 09:37 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
10.91@133.1
FieroMaster88
Total ratings: 168
Report this Post03-23-2014 09:18 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any updates?
BV MotorSports
Total ratings: 189
Report this Post03-31-2014 06:15 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The engine is back out. Trans/clutch problems continue. So over this car.
rcp builders
Report this Post03-31-2014 10:54 PM Click Here to See the Profile for rcp buildersSend a Private Message to rcp buildersEdit/Delete MessageReply w/QuoteDirect Link to This Post
are you sure you're just not afraid of all that power?
FieroMaster88
Total ratings: 168
Report this Post04-20-2014 07:53 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
BlackThunderGT
Report this Post04-21-2014 12:09 AM Click Here to See the Profile for BlackThunderGTSend a Private Message to BlackThunderGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Send it to the crusher and pick up one of these!
picture share
Formula
Total ratings: 96
Report this Post04-21-2014 09:25 AM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
picture share
I wouldn't send it to the crusher, I would send it to Detroit...
BV MotorSports
Total ratings: 189
Report this Post04-21-2014 03:35 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turbo has been rebuilt and is on its way back. My flywheel is way too thick and thats what is causing all my clutch problems. I have that off and will drop it off to get machined. Once that is done, I need to decide if I am gonna swap the cam or not. Slow but steady.
85sliverGT
Report this Post04-22-2014 08:47 PM Click Here to See the Profile for 85sliverGTSend a Private Message to 85sliverGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What thickness is your flywheel now, and what are you machining it down to?
Justinbart
Total ratings: 119
Report this Post04-22-2014 10:02 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Figured. It looked too think from the pictures in another thread.
10.91@133.1
BV MotorSports
Total ratings: 189
Report this Post04-23-2014 10:14 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh its way off. I took some measurements and pics and emailed them to a very helpful PFF member. He did the calculations and here is what he found:
The top measurement is 1.157" and the bottom one is 1.124", so the crankshaft flange sticks out past the bell housing face by 0.033".
So to end up with the flywheel clutch face at .830" from the bellhousing, the flywheel needs to be .797"
Or take 1.157 - .830 = the amount to remove from the flywheel = 0.327"
Your current flywheel is 1.124" so removing 0.327" = 0.797"
You should be able to target .800 to .810" for the thickness of the flywheel and be fine.
darkhorizon
Total ratings: 451
Report this Post04-23-2014 03:00 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its always better to have too much flywheel height. Justin started running the .840 to allow for later resurfaces and to help the slave cyl / HTOB be happier.
BV MotorSports
Total ratings: 189
Report this Post06-23-2014 01:09 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine is on the engine stand, car is in a million pieces. I have a new trans ordered that Scott (DH) located for me. Found a broken valve spring. Odd, since they are brand new LS7 springs. Making some new fuel lines right now. I never liked the old ones.
I am almost done putting Garths LQ1 swapped Fiero. Its got to go to the exhaust shop, alignment shop and I have to install some fuel lines. I'll be hauling it to Virginia on the 9th of July. When I get back, I'll get back to work on my 88. AFTER, I clean and organize my nasty garage.
2009 G8 GT Kook's 1 3/4 LT's, Kooks catted Xpipe, Magnaflow axleback, Vararam CAI, HSRK, HPTuners, Atari gauges
1988 Fiero GT L67, GT4067S, w2a, F23, & more
1987 Fiero GT 3.4TDC Road Racer.
ƒ13r0'$ rµ£3
BV MotorSports
Total ratings: 189
Report this Post06-23-2014 01:12 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
Member since May 2001
Garths LQ1 1985 GT
BV MotorSports
Total ratings: 189
Report this Post09-04-2014 04:23 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
New cam, 130# springs, retainers, locks, seals, double roller, LS7 lifters, gaskets, 60# injectors (all from Intense Racing) and replacement F23 were ordered yesterday. I have to pull the heads and have the spring pockets machined 60 thousands for the new springs. I also got a CC pushrod length checker as well. Pretty much positive I will need custom length PR's. I also have to weld in a 2" flex joint into the crossover pipe.
Goal is to be up and running by Oct 1st. Set back and watch as I roll the dice, one more, one last time.
Justinbart
Total ratings: 119
Report this Post09-04-2014 04:29 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll come and get it if you want to donate it to a good cause.
10.91@133.1
BV MotorSports
Total ratings: 189
Report this Post09-04-2014 04:34 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL what a thoughtful offer! I'll keep ya in mind.
