  My 88 Fiero GT 14k miles (Page 46)
This topic is 49 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49
My 88 Fiero GT 14k miles by BV MotorSports
Started on: 03-16-2012 02:48 PM
Replies: 1936 (68536 views)
Last post by: BV MotorSports on 01-13-2017 07:45 PM
BV MotorSports
Total ratings: 189
Report this Post09-26-2014 10:02 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plugging along. Making good progress. I should be able to pick up my heads today. Turns out one of the guides was a bit egg shaped. Its also the same valve where the new LS6 spring broke. I also had the guides machined for the lower height seals. All is well....
HOWEVER!! You knew this was coming.
WTF moment. My F23 has the shifter rod clocked 45 degress. Somehow ol' smoke and mirrors clocked it. Luckily I noticed this as I was transferring everything over to my replacement F23 (damaged due to improper FW thickness). So either I need to find the correct shifter brackets for an f23 swap or figure out how to rotate this and use what I have. Personally, I would rather go the correct route.
Have a look:
"new"
old
both
johnyrottin
Total ratings: 85
Report this Post09-26-2014 12:29 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good to hear you are still working the issues Steve. keep with it. Your workmanship is far superior to he who shall not be named.
Justinbart
Total ratings: 119
Report this Post09-26-2014 06:52 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably just drilled a new hole for the roll pin to go in.
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
BV MotorSports
Total ratings: 189
Report this Post09-26-2014 10:14 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorted!
BV MotorSports
Total ratings: 189
Report this Post09-27-2014 02:10 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
Total ratings: 168
Report this Post09-27-2014 10:12 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good to see you are still working on it.
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo.
84 Indy #64: Restoration Project, Super Duty 4 swap
BV MotorSports
Total ratings: 189
Report this Post09-28-2014 03:12 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
Total ratings: 189
Report this Post10-01-2014 01:09 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the car and the 1st job was to bleed the clutch. No leaky HTOB. Time to get busy.
Oh yeah.. notice the orientation of the bolt for the dog bone... LOL
[This message has been edited by BV MotorSports (edited 10-01-2014).]
Total ratings: 259
Report this Post10-01-2014 04:57 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is good news! Did you spin the crankshaft by hand to make sure the pressure place clears the transmission?
BV MotorSports
Total ratings: 189
Report this Post10-01-2014 05:44 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn sure did. I really didn't want to go down this road again. I really appreciate your help with the measurement process. Going together really well. Longest part is finding all the bolts and nuts. Its been apart for a while now. :/
BV MotorSports
Total ratings: 189
Report this Post10-01-2014 11:35 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
Member since May 2001
My gf and I have been working away as we find time. Guys, this is love:
johnyrottin
Total ratings: 85
Report this Post10-02-2014 12:10 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Especially if she is willing to turn wrenches with you...that's awesome!
infinitewill
Total ratings: 85
Report this Post10-02-2014 12:15 PM Click Here to See the Profile for infinitewillSend a Private Message to infinitewillEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by infinitewill (edited 01-01-2016).]
BV MotorSports
Total ratings: 189
Report this Post10-02-2014 06:09 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Almost there, should start tonight.
BV MotorSports
Total ratings: 189
Report this Post10-04-2014 08:20 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update:
Will not crank. Stater was seized. Replaced with new unit. Cranks better than ever. FIXED
Crank, no start. No 12v signal at coil packs. Replaced CPS. FIXED
Crank, no start. Spark plugs soaked. Spoke with DH and he told me how to rescale the tune for 60# injectors w/ pictures! lol AWESOME.
Just need to burp the coolant, nut & bolt check and clean her up. I plan on driving it around for 2 weeks then trailer it to MASE to get it dyno tuned. Vids to come!
BV MotorSports
Total ratings: 189
Report this Post10-04-2014 12:15 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
FieroMaster88
Total ratings: 168
Report this Post10-04-2014 12:50 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cool! How does it run?
BV MotorSports
Total ratings: 189
Report this Post10-04-2014 07:30 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Needs tuned... its a mess.
Justinbart
Total ratings: 119
Report this Post10-04-2014 08:21 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
in for video of curb jumping.
10.91@133.1
darkhorizon
Total ratings: 451
Report this Post10-06-2014 10:05 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is currently no maf sensor connected. So technically it needs a maf and not a "tune"
It was tuned well when it was parked and the changes the new injectors made are very simple to do in one flash. Dyno tuning would be a waste of money without a doubt.
[This message has been edited by darkhorizon (edited 10-06-2014).]
BV MotorSports
Total ratings: 189
Report this Post10-06-2014 10:32 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what you are saying is.. "Hey Steve, I'd love to come visit sunny Florida next week"!
FieroMaster88
Total ratings: 168
Report this Post11-29-2014 09:31 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Updates?
BV MotorSports
Total ratings: 189
Report this Post01-27-2015 02:43 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spun 2 bearings. Looking for a new engine.
BV MotorSports
Total ratings: 189
Report this Post01-27-2015 03:30 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BV MotorSports
[This message has been edited by BV MotorSports (edited 01-27-2015).]
nosrac
Total ratings: 51
Report this Post01-27-2015 03:52 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess you were having fun driving it jumping curbs...NO?
davylong86
Report this Post01-27-2015 03:56 PM Click Here to See the Profile for davylong86Send a Private Message to davylong86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Damn! Thank goodness you have another racing Pontiac you don't have to tear down on a monthly basis. Sorry to hear about more issues with what should be a really nice car when done.
[This message has been edited by davylong86 (edited 01-27-2015).]
BV MotorSports
Total ratings: 189
Report this Post01-27-2015 03:59 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its a beast... then it breaks. LOL I dont like to drive it.
BV MotorSports
Total ratings: 189
Report this Post02-05-2015 04:25 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine found and ordered!
[This message has been edited by BV MotorSports (edited 03-14-2015).]
BV MotorSports
Total ratings: 189
Report this Post03-14-2015 05:24 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up a 32k mile 2005 Monte SS engine. Plans are to swap in my ST3 cam, LS7 lifters, MLS HG, ported heads, valve train, Manley SS vavles, ARP HS & double roller. Hopefully I will be driving it this month. Not touching the bottom end.
Justinbart
Total ratings: 119
Report this Post03-14-2015 09:43 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't reuse the lifters since they probably have contaminated oil in them. Clean the heads really really good and don't forget to flush out your turbo and feed/drain lines, oil pan, etc.
10.91@133.1
BV MotorSports
Total ratings: 189
Report this Post03-18-2015 03:48 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Intake fixed:
I just need to verify my pushrod length once I reassemble the engine and fingers crossed, all should be good to go. Granted, I need to learn how to do it properly.
[This message has been edited by BV MotorSports (edited 03-18-2015).]
bigformula
Report this Post03-18-2015 05:24 PM Click Here to See the Profile for bigformulaSend a Private Message to bigformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
awesome thread. hopefully this has a good ending
BV MotorSports
Total ratings: 189
Report this Post03-26-2015 12:08 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine is back in!
BV MotorSports
Total ratings: 189
Report this Post03-31-2015 09:23 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Up and RUNNING! So good so far.
johnyrottin
Total ratings: 85
Report this Post04-01-2015 06:51 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get that thing done so I can come down for a ride!!!
bigformula
Report this Post04-01-2015 02:14 PM Click Here to See the Profile for bigformulaSend a Private Message to bigformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rea through every page. Took 2 days. Amazing the trials and tribulations this project has gone through. I hope this new engine has a happier conclusion and things work out as they should. All I can say is way to stick to it and great job overall. Many kudos
BV MotorSports
Total ratings: 189
Report this Post04-02-2015 08:51 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats a lot of reading. I try to look back to reference things but it gets me angry when I read some of the garbage in this thread. It really needs cleaned or I need to start a new one.
Anyway, for your viewing pleasure.
uploading a vid to youtube
Formula
Total ratings: 96
Report this Post04-02-2015 09:27 AM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! Hopefully this is the fix that sticks.
BV MotorSports
Total ratings: 189
Report this Post04-10-2015 04:43 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Meh! Leaking HTOB. So I have to build an engine brace to support the engine. No way I am pulling it all back apart.
Justinbart
Total ratings: 119
Report this Post04-10-2015 10:42 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put the car on 4 jack stands. Lower the cradle, about 6" on the pass side and rest the cradle on blocks. Remove trans mounts. Put jack under engine. Tip cradle down on drivers side and the trans will pop right off.
10.91@133.1
