  3800 Turbo Build (Page 10)
This topic is 20 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20
3800 Turbo Build by nosrac
Started on: 05-09-2012 10:45 PM
Replies: 787 (27287 views)
Last post by: MstangsBware on 08-27-2014 03:08 AM
Jncomutt
Total ratings: 221
Report this Post07-13-2012 05:50 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is that frozenboost advertisement on a billet valve cover?? :O
nosrac
Total ratings: 50
Report this Post07-13-2012 06:12 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by darkhorizon:
Why didnt you have your wideband hooked up during this? Why didnt you have the narrowband disabled? I am becoming a bit worried already, you could have severely damaged something like that.
I didn't think max of 6lbs of boost and 2 sec of WOT in boost was going to do anything tragic as I was monitoring knock. I was testing if switching the PCM fixed the 0 power issue and if I could get into boost.
The car is still at the shop and is NOT done yet. I will properly tune it when it gets Home. I plan on running both a Narrowband and Wideband simultaneously.
nosrac
Total ratings: 50
Report this Post07-13-2012 06:13 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
Member since Jan 2005
LOL.... I didn't do that.... It will be removed
nosrac
Total ratings: 50
Report this Post07-13-2012 06:40 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
antilag is easy. Just toss a switch inline with the air temp sensor so that it unplugs when you press a switch (the safer way is to have it "plug in" when you hit the switch, but you cant watch IATs). When it plugs or unplugs, command -49 degrees of timing in the air temp spark table... Just dont press the button without your foot on the pedal at least 30%. The switch has to be manhandled at all times so I mounted mine on my shifter.. press to lag, release to go, so I could use it in any gear, any speed... You could wire it to your brake switch as well if you wanted to make launching it a bit less reliant on your skill to pop your finger off the button when you lift the brakes.
Cool, make sense but where in the Air temp spark table do I put the retarded timing? (High End 80*C or Low end -40*C)
Also, Since I currently don't have an Air Temp Sensor I assume the PCM used the High End 80*c witch retards timing and that would explain the low power output on my test drive!
I'm really amped now....I think you just helped me run a 10
I said it before and I will say it again, I don't care what no one says about you... you are all right with me....
as you helped me out tremendously with my build issues as well as I copied your basic design, I just tried to make it mo' prettier
But you could use some internet sensitivity training....O wait, I almost forgot you have a Troll Avatar....LOL
[This message has been edited by nosrac (edited 07-13-2012).]
Pete Matos
Report this Post07-13-2012 06:42 PM Click Here to See the Profile for Pete MatosSend a Private Message to Pete MatosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also, Since I currently don't have an Air Temp Sensor I assume the PCM used the High End 80*c with retards timing and that would explain the low power output on my test drive!
Agreed...... you guys crack me up. Just sitting here grinning and anticipating that high nine hehehe peace
Pete
Justinbart
Total ratings: 119
Report this Post07-13-2012 06:56 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
No air temp is -40c
Turbo 3800 E85 F23 5spd spec5
11.54@132.7
nosrac
Total ratings: 50
Report this Post07-13-2012 07:27 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Justinbart:
No air temp is -40c
There is Table for it in DHP and ZZP race pellet is -40 I think...
I guess you don't have any Dry ICE around as that is -78*C......
darkhorizon
Total ratings: 451
Report this Post07-13-2012 08:46 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Temp unplugged is -40 not Max.
nosrac
Total ratings: 50
Report this Post07-15-2012 07:00 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my IAT adapter so the car should be ready early next week.
Big thanks to DH and LFiero67 for some tuning Tips and help.
I had the wrong MAF table loaded for the LT1 so I'm pretty sure my AFR's and spool time will be 100% better now.
Justinbart
Total ratings: 119
Report this Post07-15-2012 07:06 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for not keeping your build Top Secret.
11.54@132.7
nosrac
Total ratings: 50
Report this Post07-15-2012 08:19 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
NP, thanks you, If you guys didn't share first I wouldn't have a 3800 Turbo to COPY...LOL
Info sharing is what makes PFF great. Plus, I need to ask 100 questions so keeping it in the closet wouldn't do me or future DIY Turbo installers any good.
Pete Matos
Report this Post07-15-2012 08:20 PM Click Here to See the Profile for Pete MatosSend a Private Message to Pete MatosEdit/Delete MessageReply w/QuoteDirect Link to This Post
EXACTLY!!!
Pete
darkhorizon
Total ratings: 451
Report this Post07-15-2012 08:38 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Uh, I hope thats not holding anything up... Its a cosmetic fix at best.
nosrac
Total ratings: 50
Report this Post07-15-2012 09:55 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
How will your anti lag solution work without it?
Also, I like the ZZP race pellet idea much better than flashing a new tune on the track.
darkhorizon
Total ratings: 451
Report this Post07-15-2012 11:47 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would just put a random resistor in that registers like 30c, then "unplug" it for antilag. You can use a iat sensor just sitting in the engine bay instead of finding the right resistor. (google the ohms for the resistor if you want to do that)
nosrac
Total ratings: 50
Report this Post07-15-2012 11:58 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the 3800 IAT, and Adapter and planned on using a Normally closed switch that I would mount by the Cig lighter. Press tje switch to anti lag and spool her like a red headed stepchild.
nosrac
Total ratings: 50
Report this Post07-16-2012 12:05 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Random Dumb Question to those who know...
Are the LS1 and LT1 MAF the same thing? I keep seeing that some people refer them as being different.
I have the MAF for a 94 Camao Z28 and want to verify I have the correct MAF table loaded.
I'm going for the for the cleanest and Fastest trapping turbo 3800 Fiero..
Justinbart
Total ratings: 119
Report this Post07-16-2012 12:42 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure i'll be in the 136-138 area next time I go.
11.54@132.7
darkhorizon
Total ratings: 451
Report this Post07-16-2012 12:45 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You will need to be able to activate it and deactivate it all 100% manually. I would highly suggest the shifter, or steering wheel, or something with easy access... its not like a "mode" you will enable its very organic.
IwannaIRM
Total ratings: 58
Report this Post07-16-2012 04:10 PM Click Here to See the Profile for IwannaIRMSend a Private Message to IwannaIRMEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE] I'm going for the for the cleanest and Fastest trapping turbo 3800 Fiero..
[/QUOTE]
93-97 Camaro (f-bodies) would be an LT1 MAF. F-bodies didn't have an LS1 until 1998-2002 model years.
nosrac
Total ratings: 50
Report this Post07-16-2012 04:34 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
But did they use the same MAF sensors?
Dementia
Report this Post07-16-2012 04:57 PM Click Here to See the Profile for DementiaSend a Private Message to DementiaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think not cuz they look different. Also 98 was a changer over year, remember GM PCM in 96 n 97 were also different in the 98 year.
darkhorizon
Total ratings: 451
Report this Post07-16-2012 05:11 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty sure they were the same.
There seem to be 2 maf tables out there... the one that appears to flow alot more is the one I use.
LFiero67
Report this Post07-16-2012 08:06 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
LT1 and LS1 aluminum ended MAF sensors are the same up till 2002. Same part number is used on camaro from 1993 until 2002, and corvette until 2000. Also used in a variety of trucks, and vans. The corvette got the 85mm plastic MAF in 2000-2001, and camaro followed after.
11.425 @115.60
Best 60' 1.543 seconds
3800 S/C 4T65E
New combo : Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 130lb springs, comp pushrods, HV3, ARP Rod bolts, otherwise stock L36.
10.263 @ 134.44MPH
nosrac
Total ratings: 50
Report this Post07-17-2012 03:28 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
IT's HOME but far from finished....
BV MotorSports
Total ratings: 189
Report this Post07-17-2012 04:01 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Atleast you got it home! Good for you. What is next?
Justinbart
Total ratings: 119
Report this Post07-17-2012 04:10 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is that a 2.5" pipe?
11.54@132.7
nosrac
Total ratings: 50
Report this Post07-17-2012 04:27 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
NOPE! 3" baby..
nosrac
Total ratings: 50
Report this Post07-17-2012 04:34 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
I NEED an alignment and the Trunk brace Welded back.
I also need to and move the IC back and lower it like on Justin build as I want it low enough to build a trunk.
Then I will fix the little cosmetic stuff that broke during the install and get that emergency brake piece that was lost.
And ultimately Paint and Finish off the interior.
darkhorizon
Total ratings: 451
Report this Post07-17-2012 05:34 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
That ST3 always made for a good chop on a little cam.
Why are we making videos of a turbo car idling in a garage again?
nosrac
Total ratings: 50
Report this Post07-17-2012 06:21 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fierofreak00:
I'd like to "hear"a comparison test.. Or what it actually sounds like. -Jason
Originally posted by Pete Matos:
So does this mean it is running right now? Oh and HOW DARE YOU not post a running video....hhehehe peace
Pete
Simple, someone asked and I obliged..
[This message has been edited by nosrac (edited 07-17-2012).]
FieroMaster88
Total ratings: 168
Report this Post07-17-2012 10:20 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds good.
mattwa
Total ratings: 88
Report this Post07-17-2012 10:59 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That sounds great, very nice idle. Now for some "action" videos.
Pete Matos
Report this Post07-17-2012 11:05 PM Click Here to See the Profile for Pete MatosSend a Private Message to Pete MatosEdit/Delete MessageReply w/QuoteDirect Link to This Post
+1 LOL
Pete
Justinbart
Total ratings: 119
Report this Post07-18-2012 12:58 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
NOPE! 3" baby..
Looks small from here.
11.54@132.7
skuzzbomer
Total ratings: 92
Report this Post07-18-2012 02:11 AM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not going there...
Does that funny little venturi muffler actually make a difference in the real world?
nosrac
Total ratings: 50
Report this Post07-19-2012 11:54 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worked on the tune some and turned up the boost from 6psi to 9psi. I am still trying to get used to the turbo as it is a very different animal.
I keep expecting to hear some whine or whistle or something but only thing I hear is the mellow exhaust note.
Spool is much better but I can't burn any rubber...yet. Maybe I need to start out in a lower gear?
darkhorizon
Total ratings: 451
Report this Post07-19-2012 12:32 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
How does the antilag work? That turbo probably wont make decent power untill your pressure ratio gets up around 14psi anyway... power per PSI is EXTREMELY exponetial in turbo setups as compressor efficency goes up the more pressure ratio you make (to a point anyway).
Its was not that easy to for me to spin tires in first gear on 15psi with my old T3 setup... even my all seasons... antilag and 15+psi really increased my tire melting ability.
Justinbart
Total ratings: 119
Report this Post07-19-2012 02:04 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
The magic starts over 20 psi.
11.54@132.7
nosrac
Total ratings: 50
Report this Post07-19-2012 02:29 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't hooked up antilag yet and might not need it. I turned up the boost a little more and I increased the low RPM timing and changed some PE settings as suggested by LFiero67.
Now I only read -2.5 vacuum instead of -8.5 and can get into a little boost from foot brake. Now I have some real power when I stomp on it and the acceleration is worlds better than before.
[This message has been edited by nosrac (edited 07-19-2012).]
